Dashticz - Feature Requests
Vomera
Re: Dashticz - Feature Requests
Post by Vomera »
Hi!
I wanted to use an icon on awesome font, but i see it's an icon made in version 5.5. Somewhere I saw 5.0.13 is supported in dashticz. Any idea awesome font will be updated to the latest version ? :) or can i update it by my self ?
tileiran
Post by tileiran »
support of RTSP would be awesome, I have big problems with the image-based webcam possibilities at the moment.
Minglarn
Domoticz version: v3.8153
Post by Minglarn »
Flash the sensor when it receives update.
Same as the built in Domoticz.
Edit: Strange... The Attachments does not work ... :(
Minglarn
Post by Minglarn »
Minglarn wrote: Tuesday 25 December 2018 16:30 Flash the sensor when it receives update.
Did some adjustments in "main.js" ...
At line: 668 I added:
$('div.block_'+idx).animate({'background-color': 'rgba(255, 255, 255, 1)'},550).animate({'background-color': 'rgba(90, 90, 90, 1)'},550);
Hard to show the result... but it's better than nothing. :)
So the new function adds an "flash" effect to the idx when it updates...
Now I have to figure out how to use a setting when I don't want it to flash... Any help someone?
EDIT:
Nailed it...
In main.js i've added:
function triggerChange(idx, value, device) {
    if (typeof(oldstates[idx]) !== 'undefined' && value !== oldstates[idx]) {
        //disableStandby();
        try {
            eval('getChange_' + idx + '(idx,value,device)');
        catch (err) {
        if (typeof(blocks[idx]) !== 'undefined' && blocks[idx]['flash'] === false) {
		} else {
		}[code]
Where
		} else {
is the added code.
This makes my block flash...
If I dont want any flash I add:
blocks[69]	 	= {title:'PIR', flash:false};
Hope this will get implemented.. :)
Lokonli
Post by Lokonli »
Minglarn wrote: Saturday 29 December 2018 10:00
EDIT:
Nailed it...
        //disableStandby();
        try {
        catch (err) {
		} else {
		}[code]
Where
		} else {
is the added code.
I've created the PR and it will be part of beta 2.5.3.
Small change: the flash parameter determines the duration of the animation (msec). By default flash is off.
HansieNL
Post by HansieNL »
@Lokonli : Is it maybe an option to set your own blink color. For example: config['blink_color'] = '255, 0, 0, 0.7';
Then we can also add the option to the config menu.
I'm trying to use the setting in main.js, but I think I'm missing something:
var flash_color = settings['blink_color'];
$('div.block_'+idx).animate({'background-color': 'rgba( flash_color )'}, flash_value).animate({'background-color': cur_bc},flash_value);
Maybe someone can tell me how to get this setting working.
Blah blah blah
Lokonli
Post by Lokonli »
HansieNL wrote: Saturday 26 January 2019 2:09 @Lokonli : Is it maybe an option to set your own blink color. For example: config['blink_color'] = '255, 0, 0, 0.7';
That should work. Some code has to be added in settings.js to make the config setting available in the config menu, and to copy config['blink_color'] to settings['blink_color']
Something for the next beta.
HansieNL
Post by HansieNL »
Lokonli wrote: Sunday 27 January 2019 20:51 Some code has to be added in settings.js to make the config setting available in the config menu, and to copy config['blink_color'] to settings['blink_color']
@Lokonli: Thanks for your help. Files to set your flash color in screen settings menu uploaded to GitHub.
Blah blah blah
silver323
Post by silver323 »
Maybe someone can help with the following.
I want a popup screen when the doorbell is pushing.
But what have I need do display text in a popup instead of a URL?
blocks[IDX]['openpopupOn'] = {}
blocks[IDX]['openpopupOn']['????'] = 'Someone at the door!';
blocks[IDX]['openpopupOn']['auto_close'] = 5; //seconds
Lokonli
Post by Lokonli »
silver323 wrote: Tuesday 26 February 2019 13:24 Maybe someone can help with the following.
Workaround:
Save a file named door.html with the following content in your Dashticz folder:
<center><font size="5" color="red">'Someone at the door!'</font>
Then define the openpopupOn as follows:
blocks[IDX]['openpopupOn'] = { url: './door.html', auto_close : 500, frameheight:200};
silver323
Post by silver323 »
Lokonli wrote: Tuesday 26 February 2019 19:45
Workaround:
Thanks for the workaround. Will test it!
EDIT: Had to change for working
blocks[IDX]['openpopupOn'] to [code]blocks[IDX]['openpopup'] without the on and it works!
Lokonli
Post by Lokonli »
Vomera wrote: Monday 17 December 2018 16:53 Hi!
I've created the PR. The new beta will use FontAwesome 5.7.2.
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Added the following requested feature:
Confirmation for switches, no more accidental presses.
I had this for myself too, often with some switches so decided to add this.
Available in beta 2.5.10
blocks[IDX]['confirmation']=1
EdwinK
Post by EdwinK »
Since this last update, not all my blocks are shown.
Previous screen
Present screen
At first glance, it looks like the RFXcom devices are missing, but they are still active in Domoticz.
robgeerts
Post by robgeerts »
Could you check latest beta?
(Just uploaded)
EdwinK
Post by EdwinK »
Working again ;)
Vomera
Post by Vomera »
Lokonli wrote: Friday 01 March 2019 23:22
Awesome !! will update now!
stlaha2007
Post by stlaha2007 »
Searched several ways but couldn't find an answer.
Instead of adding block[idx][width] = 6; to all my blocks.
Is there a setting for the default block size. Or is it possible to add this in the config, so it keeps the config.js a lot cleaner?
Regards Stephan
EdwinK
Post by EdwinK »
stlaha2007 wrote: Monday 18 March 2019 10:15 Hi all,
Regards Stephan
I second that. Maybe something like [blocks] 1,2,4,6,[width] = 6'; or something like this.
stlaha2007
Hi devs...
Recently replaced my bmp280 with an bmp180. Unfortunately discovered the new device wasn't diplaying correctly (Turned Up as a Switch :lol: ).
However looked into the code of the master and beta branch and dicovered only devices are displayed correctly when they are temp / hum / baro(pressure) or temp + hum or temp + hum + baro.
So the device temp + baro is missing.
I updated my running Beta-branch here
In js/main.js:
Just below function getAutoAppendSelector(device) {
around line 1314:
         case 'Temp + Baro':
And below switch (device['Type']) {
around line 1407:
        case 'Temp + Baro':
I updated my running master-branch here
In js/main.js:
around line 1248:
         case 'Temp + Baro':
around line 1340:
        case 'Temp + Baro':
And now working as expected for me...
Can this be integrated in the near future ??
Locked
