Dashticz - Show your dashboard and how-to's!
Very pleased with the results of an evening playing with Dashticz - a very nice framework. I did have some problems using the GUI interface, but not once modifying the config files with a text editor. Thanks for making it - very nice!
- EdwinK
- Domoticz version: BETA
Looks nice
welby
Here's my pretty simple setup, it's running on a lenovo 10inch tablet on my wall. This is a pic from chrome.
- Screenshot (1).jpg (123.9 KiB) Viewed 6529 times
robgeerts
- Domoticz version: 3.7067
Very nice Guys!!
- EdwinK
digdilem wrote: Saturday 20 January 2018 17:31 Very pleased with the results of an evening playing with Dashticz - a very nice framework. I did have some problems using the GUI interface, but not once modifying the config files with a text editor. Thanks for making it - very nice!
CONFIG.js
CUSTOM.css.txt
Instead of uploading your config files, you could paste them within the [ code ] an [/ code ] tags.
Mads
Hi.
How do i know, the block number, that matches the diffent switches? is it the IDX nr there also is the block nr?
- EdwinK
You use the idx number in Domoticz as blocknumber.
- htilburgs
In Short:
Domoticz: IDX --> Dashticz: block[idx]
Dashticz block[idx] --> custom.css: .block_idx
Hardware:
How can I make a switch show two buttons, for example both on and off? I would like this for scenes, since sometimes you want to turn on a scene but in Dashticz it is marked as on even if it's just partially on. In domoticz you can have both ON and OFF buttons also for scenes. Is this possible in dashticz?
TheRedOne09
- Domoticz version: 3.5877
Hi jurjan, I like your style. Can you please share CONFIG.js and custom.css?jurjan wrote: Monday 13 November 2017 20:31 I got a css question, how can I set the background color of the entire block?
I placed an inline red color on the 'Fontijn' block as an example, but I cannot find how to do this by using custom.css
All -selected- blocks should become green (rgba(0,255,0,0.3)
Any help would be appreciated.
clubeddie
Kewl tweak. I want to use it, but i did not get it to work for medutchdevil83 wrote: Monday 28 August 2017 20:16 I have made a spinning font awesome icon when my solar panels are generating power. Ofcourse you can also use this for spinning other icons.
Add this to CUSTOM.JS for defining the action:
Add this to CUSTOM.CSS to define a slower spinning speed for the font awesome spinning function (i liked this better):Code: Select all
function getStatus_29(idx,value,device){ if(parseFloat(device['Usage'])>0){ blocks['29_1']['icon'] = 'fa fa-sun-o slow-spin'; //if you use "fa-spin" instead of "slow-spin" then it is not necessary to add code to custom.css } else { blocks['29_1']['icon'] = 'fa fa-sun-o'; } }
Have fun with spinning your icons !Code: Select all
.slow-spin { -webkit-animation: fa-spin 4s infinite linear; animation: fa-spin 4s infinite linear; }
First of all i use Youless for the read of my solar panels, for some reason the default icon for this is fa-fire (the same as gas), it is configured in main.js, rule 1657.
If i add your script, nothing is happened with the flame icon.
I can confirm that your script is working, when i use it on a undefined block it is spinning.
How do you read your solar panel ?
- gjaa
My dasboard is under contruction and I have a problem
How can I change the height of Buienradar As you can see Buienradar has an other height, so the the blocks do not align properly
Gerard
Gerard
jeroenkl
same issue here, who can assist/help?clubeddie wrote: Wednesday 07 February 2018 21:14Kewl tweak. I want to use it, but i did not get it to work for medutchdevil83 wrote: Monday 28 August 2017 20:16 I have made a spinning font awesome icon when my solar panels are generating power. Ofcourse you can also use this for spinning other icons.
- felix63
- Domoticz version: 2020.1
A Raspberry Pi 7-Inch Touch Screen with a HC-SR501 PIR motion sensor on top in a 3d printed case. Tricky part was the script to wake the system from sleep.
# HC-SR501 motion sensor
# https://raspberrytips.nl/hc-sr501-bewegingssensor-pir-raspberry-pi/
import RPi.GPIO as GPIO
import time
import requests
import os, subprocess, time
subprocess.call("DISPLAY=:0 xscreensaver-command -activate", shell=True)
displayison = False
maxidle = 1*60 # seconds
lastsignaled = 0
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD)
PIN = 8
GPIO.setup(PIN, GPIO.IN)
time.sleep(20)
print "Start sensor..."
time.sleep(2)
print "Sensor activated..."
while True:
now = time.time()
if GPIO.input(PIN):
print "Movement detected! " + (time.strftime("%H:%M:%S"))
if not displayison:
subprocess.call("DISPLAY=:0 xscreensaver-command -deactivate", shell=True)
displayison = True
r = requests.get("http://viola.local/json.htm?type=command¶m=switchlight&idx=599&switchcmd=On")
lastsignaled = now
time.sleep(7) # wait 4 seconds for PIR to reset.
else:
if now-lastsignaled > maxidle:
if displayison:
displayison = False
time.sleep(1)
- IMG_0206.jpg (105.11 KiB) Viewed 5828 times
- gjaa
gjaa wrote: Thursday 08 February 2018 19:31 My dasboard is under contruction and I have a problem
Gerard
Fixed it my self, changed the buienradar settings (the height by RadarMapNL?w=256&h=180')
buttons.buienradar = {width:6, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/Rada ... =256&h=180', url:'http://www.buienalarm.nl/widget/graphic ... lor=4395c7'}
The blocks do align now properly
Gerard
dens1975
Re: Show your Dashticz v2.0 and how-to's!
Hi, I also use this script but how do I get a block with the name and status? How does this look in your config.js?lukev wrote: Friday 05 May 2017 19:59This is my working LUA-script. You have to make 3 dummy devices, 2 text and 1 percentage: "iPhone Battery PERSON1", "Postion PERSON1" and "PowerState PERSON1".mvveelen wrote:
I see you have the charging / % charged in your dashboard. How exactly did you get this (I know the topic, but there are a lot of pages to read....), AND doesn't it drain your iPhone when you repeatedly poll the status or whereabouts of the iPhone?
I poll every 10 minutes, it seems to drain the battery a little faster, but nothing spectacular.
I have disabled the notification, don't need it:Code: Select all
-- Script to check the location of multiple iPhones every X minutes, -- test if they are "home" and represent this using virtual switches commandArray = {} -- polling interval in minutes (1-59), setting this too low may drain the phones' batteries interval = 10 local m = os.date('%M') if (m % interval == 0) then json = (loadfile "/volume1/@appstore/domoticz/var/scripts/lua/JSON.lua")() -- Array of users to be checked users = { PERSON1 = {username = "itunes username" ; password = "itunes password" ; devicename = "itunes devicename"}; PERSON2 = {username = "itunes username" ; password = "itunes password" ; devicename = "itunes devicename"} } -- The latitude and longitude of your house (use Google Maps or similar to find this) homelongitude = xxxxx homelatitude = xxxxxxx -- Radius (in km) which will be used to determine if a device is at home radius = 0.3 function address(longitude, latitude) command = "curl -s https://maps.googleapis.com/maps/api/geocode/json?latlng=" .. latitude .. "," .. longitude .. "&sensor=false" local handle = io.popen(command) local result = handle:read("*a") handle:close() output = json:decode(result) return output.results[1].formatted_address end for user,credentials in pairs(users) do getlocation = "curl -s -X POST -L -u '" .. credentials.username .. ":" .. credentials.password .. "' -H 'Content-Type: application/json; charset=utf-8' -H 'X-Apple-Find-Api-Ver: 2.0' -H 'X-Apple-Authscheme: UserIdGuest' -H 'X-Apple-Realm-Support: 1.0' -H 'User-agent: Find iPhone/1.3 MeKit (iPad: iPhone OS/4.2.1)' -H 'X-Client-Name: iPad' -H 'X-Client-UUID: d98c8ae0db3311e687b92890643032df' -H 'Accept-Language: en-us' -H 'Connection: keep-alive' https://fmipmobile.icloud.com/fmipservice/device/" .. credentials.username .."/initClient" local handle = io.popen(getlocation) local result = handle:read("*a") handle:close() output = json:decode(result) for key,value in pairs(output.content) do if value.name == credentials.devicename then lon = value.location.longitude lat = value.location.latitude bat = value.batteryLevel * 100 / 1 powerstateval = value.batteryStatus table.insert(commandArray,{['UpdateDevice'] = otherdevices_idx['iPhone Battery ' .. user] .. '|0|' .. bat}) table.insert(commandArray,{['UpdateDevice'] = otherdevices_idx['PowerState ' .. user] .. '|0|' .. powerstateval}) distance = math.sqrt(((lon - homelongitude) * 111.320 * math.cos(math.rad(lat)))^2 + ((lat - homelatitude) * 110.547)^2) -- approximation position = address(lon,lat) position_text = string.gsub(position, ', Netherlands', '') .. ' (' .. (math.floor(distance*10+0.5)/10) .. ' km)' print(position) prev_distance_str = string.match(otherdevices['Position ' .. user], '%(.*%)') or '(1000 km)' prev_distance = tonumber(string.sub(prev_distance_str, 2,-5)) -- update text device, but only if postion has changed more than defined in "radius" to reduce log size if math.abs(prev_distance - distance) > radius then table.insert(commandArray,{['UpdateDevice'] = otherdevices_idx['Position ' .. user] .. '|0|' .. position_text}) end print('iPhone ' .. user .. ': ' .. math.floor(distance*100+0.5)/100 .. ' km from home, ' .. bat .. '% battery remaining. PowerState: '.. powerstateval ..' ') if distance < radius then if otherdevices['iPhone ' .. user] == 'Off' then commandArray['iPhone ' .. user] = 'On' -- table.insert(commandArray, {['SendNotification'] = 'Presence update#' .. user .. ' came home'}) end else if otherdevices['iPhone ' .. user] == 'On' then commandArray['iPhone ' .. user] = 'Off' -- table.insert(commandArray, {['SendNotification'] = 'Presence update#' .. user .. ' left home'}) end end end end end end return commandArray
Don't forget to point out the correct location of json.lua! I use a synology, so this url isn't working on a rpi!Code: Select all
-- table.insert(commandArray, {['SendNotification'] = 'Presence update#' .. user .. ' came home'}) -- table.insert(commandArray, {['SendNotification'] = 'Presence update#' .. user .. ' left home'})
Justin2501
- Domoticz version: V3.8922
I just watched all these great Dashticz interfaces that i decided to install it for myself.
Sadly enough i can't get it to work.
Domoticz V3.8922 (BETA) is running and fully functional
Ran "git clone https://github.com/robgeerts/dashticz_v2 --branch beta" in the domoticz/www/ folder
Config:
When i go to http://192.168.0.5:8080/dashticz_v2 is says "Domoticz Offline" even though it's online
When i go to http://192.168.0.5:8080/dashticz_v2/index.html is says "Timeout. Check your CONFIG.js"
Any idea what i might be missing?
Config:
var config = {}
config['domoticz_ip'] = 'http://192.168.0.5:8080';
config['dashticz_refresh'] = '60';When i go to http://192.168.0.5:8080/dashticz_v2/index.html is says "Timeout. Check your CONFIG.js"
Hardware:
Raspberry Pi 3 | Raspbian Stretch | Domiticz Beta | Dashticz V2 Beta | Pi-hole | Nest Thermostat | RFxcom |
- DewGew
- Domoticz version: V4.10618
It should be working with those settings. Do you use user and password to domoticz even in your local network? Then you have to set that in config also. Make sure you have renamed CONFIG_DEFAULT.js to CONFIG.js and that the file contains only:Justin2501 wrote: Thursday 15 February 2018 23:39 I just watched all these great Dashticz interfaces that i decided to install it for myself.
Config:When i go to http://192.168.0.5:8080/dashticz_v2 is says "Domoticz Offline" even though it's onlineCode: Select all
var config = {} config['domoticz_ip'] = 'http://192.168.0.5:8080'; config['app_title'] = 'Dashticz'; config['domoticz_refresh'] = '5'; config['dashticz_refresh'] = '60';
var config = {}
config['user_name'] = 'domoticz username';
config['pass_word'] = 'domoticz password';
config['dashticz_refresh'] = '60';Raspberry Pi 3 | domoticz | Aeon Labs Z-Stick GEN5 | RFlink gateway
Justin2501
CONFIG_DEFAULT.js is indeed renamed to CONFIG.jsDewGew wrote: Friday 16 February 2018 8:36 It should be working with those settings. Do you use user and password to domoticz even in your local network? Then you have to set that in config also. Make sure you have renamed CONFIG_DEFAULT.js to CONFIG.js and that the file contains only:Delete all other text for testing you connection.Code: Select all
var config = {} config['domoticz_ip'] = 'http://192.168.0.5:8080'; config['user_name'] = 'domoticz username'; config['pass_word'] = 'domoticz password'; config['app_title'] = 'Dashticz'; config['domoticz_refresh'] = '5'; config['dashticz_refresh'] = '60';
I do have a username and password, but my local network is credentials-free in this care. (127.0.0.*;192.168.0.*)
I tried the format "config['domoticz_ip'] = 'http://user:[email protected]:8080';" which was shown in the internet but will try your config setup this evening to see if it's working.
Hardware:
Justin2501
Clearing the CONFIG.js and adding the info above seems to do the trick!DewGew wrote: Friday 16 February 2018 8:36 It should be working with those settings. Do you use user and password to domoticz even in your local network? Then you have to set that in config also. Make sure you have renamed CONFIG_DEFAULT.js to CONFIG.js and that the file contains only:Delete all other text for testing you connection.Code: Select all
Thank you
Hardware:
