Moderators: leecollings , htilburgs , robgeerts
tontze
Posts: 317 Joined: Thursday 12 January 2017 15:30
Domoticz version: Beta Ch
Post
by tontze » Monday 18 December 2017 18:35
That didnt make any difference :/ and im in master
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
robgeerts
Posts: 1273 Joined: Saturday 24 January 2015 22:12
Domoticz version: 3.7067
Post
by robgeerts » Monday 18 December 2017 20:15
Do you get any console errors?
madrian
Posts: 231 Joined: Saturday 27 August 2016 1:18
Post
by madrian » Monday 18 December 2017 20:35
Hello @Rob,
Two questions.
1, In the sidebar it is possible to make temperature box bigger? It looks ugly:
Screen Shot 2017-12-18 at 20.32.11.png (385.74 KiB) Viewed 2698 times
2, when I click on this box, in the popup I see a very straight line:
Screen Shot 2017-12-18 at 20.34.05.png (252.8 KiB) Viewed 2698 times
aiolos
Posts: 127 Joined: Sunday 13 September 2015 18:58
Domoticz version: stable
Post
by aiolos » Monday 18 December 2017 23:54
madrian wrote: Monday 18 December 2017 20:35
Unfortunately the current library for the graphs doesn't support multiple Y-scales. And since the barometer is around 1000, the temperature and humidity get very small.
JacEngels
Posts: 18 Joined: Sunday 03 December 2017 10:17
Post
by JacEngels » Wednesday 20 December 2017 0:45
After the initial setup it seems that the CONFIG.js file is not loading correctly and not used.
I've changed the language in the CONFIG.js to nl_NL but the page is displayed in English.
I can change the settings in the GUI and save them but they are not stored in the CONFIG.js
Furthermore I only see my basic domoticz stuff but not the stuff I expected to see in the default dashboard.
What can I do to check if the dashticz environment is working correctly?
tontze
Post
by tontze » Wednesday 20 December 2017 6:37
robgeerts wrote: Monday 18 December 2017 20:15
Only this is visible :
jquery.min.js:4 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check
https://xhr.spec.whatwg.org/ .
If i remove everything else but these below, it gives me my favorites. so it must be my added config, i just dont figure what is wrong ..
var config = {}
config['language'] = 'en_US'; //or: en_US, de_DE, fr_FR, hu_HU, it_IT, pt_PT, sv_SE
config['domoticz_ip'] = 'http://xxxxxxxxxxxx:8080';
var trashnames = {}
trashnames['Gft'] = 'GFT';
trashnames['Pmd'] = 'Plastic';
trashnames['Rest'] = ''; //LEAVE EMPTY IF YOU WANT TO HIDE IT
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
CaesarPL
Posts: 104 Joined: Tuesday 08 November 2016 14:03
Post
by CaesarPL » Wednesday 20 December 2017 8:54
Write your own CONFIG.js in an editor, turn off auto-positioning and favorites.
Configure your stuff as you wish.
EdwinK
Posts: 1820 Joined: Sunday 22 January 2017 21:46
Post
by EdwinK » Wednesday 20 December 2017 10:30
Could it be this:
columns[10] = {}
columns[10]['blocks'] = ['clock',calendars.hobbydeed,119,120,121,2,185,144,1]
columns[10]['width'] = 5;
Earlier you do this:
//var calendars = {}
//calendars.hobbydeed = { url: 'https://www.hobbydeed.com/api/v2/public/calendar-share/fi/user/***', icalurl:'https://www.hobbydeed.com/api/v2/public/calendar-share/fi/user/-***/fi\
e/all.ics' }
So it might be that the script is trying to load 'calendars.hobbydeed' when defined? Just my 2 cents
tontze
Post
by tontze » Wednesday 20 December 2017 19:05
EdwinK wrote: Wednesday 20 December 2017 10:30
Could it be this:
columns[10] = {}
e/all.ics' }
Nope, doesnt work :/ i also verified that all IDX are available
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
tontze
Post
by tontze » Wednesday 20 December 2017 19:13
Ok, i started removing block by block, problem was this :
Not sure why it doesnt work ?
columns[30] = {}
columns[30]['blocks'] = ['sunrise',buttons.moon]
//columns[30]['blocks'] = ['sunrise',buttons.moon,'streamplayer']
columns[30]['width'] = 2;
EDIT: ok, propably because i didnt have streamplayer block defined ..
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
PeJeWe
Posts: 65 Joined: Monday 28 November 2016 20:52
Domoticz version: Latest
Post
by PeJeWe » Wednesday 20 December 2017 20:19
maybe you forgotten to remove the " // " at the beginning of the config file ?
JacEngels
Post
by JacEngels » Wednesday 20 December 2017 21:35
PeJeWe wrote: Wednesday 20 December 2017 20:19
That's it. On the first and last line of the config file there is a "/* ". Once removed the config file is loaded correctly!
Thanks.
sailmich
Posts: 245 Joined: Wednesday 17 February 2016 22:55
Post
by sailmich » Saturday 23 December 2017 7:42
robgeerts wrote: Sunday 10 December 2017 21:21
sailmich wrote: Sunday 10 December 2017 13:55
robgeerts wrote: Sunday 10 December 2017 10:05
Will check the arrows for blinds.
It only uses your own config.js ... (in custom-folder).
But if you see strangs things, this could happen because of browser-caching..
Thanks for your quick response. I can't see anything different from my older CONFIG.js but maybe you can have a look into my CONFIG.js. I cleared the cache and have this issue on my Laptop, Tablet and Phone.
CONFIG.js
var config = {}
config['calendarlanguage'] = 'de_DE';
config['domoticz_ip'] = 'http://192.xxxxxxxxxx ';
config['wu_api'] = 'my own';
config['wu_city'] = 'pws:';
config['wu_name'] = 'my own';
config['wu_country'] = 'DL';
config['auto_positioning'] = false;
config['use_favorites'] = false;
config['boss_stationclock'] = 'RedBoss';
config['hide_seconds'] = 1;
config['hide_topbar'] = 0;
config['hide_seconds_stationclock'] = 1;
config['idx_moonpicture'] = 2; //index of the uservariabele MoonPicture
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '20';
config['slide_effect'] = 'coverflow';
config['last_update'] = 0;
config['selector_instead_of_buttons'] = 0;
config['static_weathericons'] = 1;
config['standard_graph'] = 'month';
var frames = {}
frames.secpanel = {height:660,frameurl:"http://my own/secpanel/index.html",width:12}
var buttons = {}
buttons.jalousien={width:6, title:'Jalousien', slide:2}
buttons.beleuchtung= {width:6, title: 'Beleuchtung',slide: 3}
buttons.alarm= {width:6, title: 'Alarm',slide: 4}
buttons.wetterstation= {width:6, title: 'Wetter',slide: 5}
buttons.webcam = {width:12, isimage:true, refresh:2000, image: 'http://my own/mjpeg_read.php', url: 'http://my own'}
buttons.moon = {width:12, isimage:true, refreshimage:60000, image: 'moon'}
buttons.radio = {width:12, image: 'img/radio_on.png', title: 'Radio', url: 'http://www.radio21.de/musik/livestream.html '}
var blocks = {}
blocks['blocktitle_1'] = {}
blocks['blocktitle_1']['title'] = 'Erdgeschoss';
blocks['blocktitle_2'] = {}
blocks['blocktitle_2']['title'] = 'Wohnzimmer';
blocks['blocktitle_3'] = {}
blocks['blocktitle_3']['type'] = 'blocktitle';
blocks['blocktitle_3']['title'] = 'Küche';
blocks['blocktitle_4'] = {}
blocks['blocktitle_4']['type'] = 'blocktitle';
blocks['blocktitle_4']['title'] = 'Obergeschoß';
blocks['blocktitle_5'] = {}
blocks['blocktitle_5']['type'] = 'blocktitle';
blocks['blocktitle_5']['title'] = 'Jalousien Terrasse';
blocks['blocktitle_6'] = {}
blocks['blocktitle_6']['type'] = 'blocktitle';
blocks['blocktitle_6']['title'] = 'Jalousien';
blocks['blocktitle_7'] = {}
blocks['blocktitle_7']['type'] = 'blocktitle';
blocks['blocktitle_7']['title'] = 'Beleuchtung';
blocks['blocktitle_8'] = {}
blocks['blocktitle_8']['type'] = 'blocktitle';
blocks['blocktitle_8']['title'] = 'Nachtruhe';
blocks['blocktitle_9'] = {}
blocks['blocktitle_9']['type'] = 'blocktitle';
blocks['blocktitle_9']['title'] = 'Außen';
/*blocks[40] = {}
blocks[40]['width'] = 6; //1 to 12, remove this line if you want to use the default (4)
blocks[40]['image'] = 'blinds_open.png'; //if you want to show an image instead if icon, place image in img/ folder
blocks[40]['switch'] = true; //if you want to switch the title and data
blocks[40]['hide_data'] = true; //if you want to hide the data of this block
blocks[40]['protected'] = false; //protect switching manually in Dashticz
blocks[40]['title'] = 'Links' //change name of switch against Domoticz name*/
blocks[1] = {}
blocks[1]['width'] = 4;
blocks[1]['image'] = 'blinds_open.png';
blocks[1]['switch'] = true;
blocks[1]['hide_data'] = true;
blocks[1]['protected'] = false; // Jalousie Wohnzimmer mitte
blocks[1]['hide_stop'] = false;
blocks[6] = {}
blocks[6]['width'] = 6;
blocks[6]['image'] = 'blinds_open.png';
blocks[6]['switch'] = true;
blocks[6]['hide_data'] = true;
blocks[6]['protected'] = false;
blocks[6]['title'] = 'Rechts'; // Jalousie Küche rechts
blocks[6]['hide_stop'] = true;
blocks[7] = {}
blocks[7]['width'] = 4;
blocks[7]['image'] = 'blinds_open.png';
blocks[7]['switch'] = true;
blocks[7]['hide_data'] = true;
blocks[7]['protected'] = false; // Jalousie Wohnzimmer links
blocks[7]['hide_stop'] = true;
blocks[8] = {}
blocks[8]['width'] = 4;
blocks[8]['image'] = 'blinds_open.png';
blocks[8]['switch'] = true;
blocks[8]['hide_data'] = true;
blocks[8]['protected'] = false; // Jalousie Wohnzimmer rechts
blocks[8]['hide_stop'] = true;
blocks[9] = {}
blocks[9]['width'] = 4;
blocks[9]['image'] = 'blinds_open.png';
blocks[9]['switch'] = true;
blocks[9]['hide_data'] = true;
blocks[9]['protected'] = false; //Markise draußen
blocks[10] = {}
blocks[10]['width'] = 4;
blocks[10]['image'] = 'blinds_open.png';
blocks[10]['switch'] = true;
blocks[10]['hide_data'] = true;
blocks[10]['protected'] = false;
blocks[10]['title'] = 'Seite'; //Jalousie seite draußen
blocks[11] = {}
blocks[11]['width'] = 4;
blocks[11]['image'] = 'blinds_open.png';
blocks[11]['switch'] = true;
blocks[11]['hide_data'] = true;
blocks[11]['protected'] = false;
blocks[11]['title'] = 'Vorne'; //Jalousie vorne draußen
blocks[40] = {}
blocks[40]['title'] = 'Links'; //Jalousie Küche linke Seite
blocks[40]['hide_stop'] = true;
blocks[128] = {}
blocks[128]['width'] = 6;
blocks[128]['hide_data'] = true;
blocks[128]['title'] = 'Innen';// Wetterstation Außen Temperatur
blocks[134] = {}
blocks[134]['width'] = 6;
blocks[134]['image'] = 'white-arrow-down.png';
blocks[134]['switch'] = true;
blocks[134]['hide_data'] = true;
blocks[134]['protected'] = false;
blocks[134]['title'] = 'Ein';// Nachtruhe ein
blocks[135] = {}
blocks[135]['width'] = 6;
blocks[135]['hide_data'] = true;
blocks[135]['title'] = 'Außen';// Wetterstation Innen Temperatur
blocks[139] = {}
blocks[139]['width'] = 6;
blocks[139]['image'] = 'bulb_on.png';
blocks[139]['switch'] = false;
blocks[139]['hide_data'] = true;
blocks[139]['protected'] = false; // Wohnzimmer Licht
blocks[140] = {}
blocks[140]['width'] = 6;
blocks[140]['image'] = 'bulb_on.png';
blocks[140]['switch'] = false;
blocks[140]['hide_data'] = true;
blocks[140]['protected'] = false; //Küche Licht
blocks[142] = {}
blocks[142]['width'] = 6;
/*blocks[142]['icon'] = 'fa-arrow-circle-left';*/
blocks[148] = {}
blocks[148]['width'] = 6;
blocks[148]['icon'] = '';
blocks[148]['title'] = 'Boen'; // Wind_gust
blocks[148]['graph'] = true;
blocks[151] = {}
blocks[151]['width'] = 6;
blocks[151]['image'] = 'white-arrow-up.png';
blocks[151]['switch'] = true;
blocks[151]['hide_data'] = true;
blocks[151]['protected'] = false;
blocks[151]['title'] = 'Aus'// Nachtruhe aus
blocks[152] = {}
blocks[152]['width'] = 6;
blocks[152]['image'] = 'bulb_on.png';
blocks[152]['switch'] = false;
blocks[152]['hide_data'] = true;
blocks[152]['protected'] = false; // Flur oben Licht
blocks[153] = {}
blocks[153]['width'] = 6;
blocks[153]['image'] = 'bulb_on.png';
blocks[153]['switch'] = false;
blocks[153]['hide_data'] = true;
blocks[153]['protected'] = false; // Schlafzimmer Licht
blocks[174] = {}
blocks[174]['width'] = 6;
blocks[174]['icon'] = 'fa-tint';
/*blocks[174]['image'] = '6.svg';*/
blocks[174]['title'] = '24 Stunden'; //Regen
blocks[175] = {}
blocks[175]['width'] = 6;
blocks[175]['icon'] = 'fa-tint';
blocks[175]['title'] = 'Aktuell'; // Rain_rate
blocks[191] = {}
blocks[191]['width'] = 6;
blocks[191]['icon'] = 'fa-moon-o';
blocks[191]['hide_data'] = true;
blocks[191]['protected'] = true;
blocks[191]['title'] = ''; // Mondphase
/*blocks[192] = {}
blocks[192]['width'] = 4;
blocks[192]['image'] = 'Moon-stars.png';
blocks[192]['hide_data'] = true;
blocks[192]['protected'] = true;
blocks[192]['title'] = ''; //Moonage*/
blocks[193] = {}
blocks[193]['width'] = 6;
blocks[193]['icon'] = 'fa-moon-o';
blocks[193]['hide_data'] = true;
blocks[193]['graph'] = false;
blocks[193]['protected'] = true;
blocks[193]['title'] = ''; // Mondprozente
blocks[194] = {}
blocks[194]['width'] = 4;
blocks[194]['image'] = 'blinds_open.png';
blocks[194]['switch'] = true;
blocks[194]['hide_data'] = true;
blocks[194]['protected'] = false;
blocks[194]['hide_stop'] = true;// Jalousie Badezimmer
blocks[209] = {}
blocks[209]['width'] = 6;
blocks[209]['image'] = 'bulb_on.png';
blocks[209]['switch'] = false;
blocks[209]['hide_data'] = true;
blocks[209]['protected'] = false; // Steinel Außenlicht
blocks[203] = {}
blocks[203]['width'] = 6;
blocks[203]['title'] = 'Auge Oben';
blocks[213] = {}
blocks[213]['width'] = 6;
blocks[213]['title'] = 'Steinel'; // Steinel Bewegungsmelder
blocks[215] = {}
blocks[215]['width'] = 6;
blocks[215]['title'] = 'Steinel'; // Steinel Helligkeit
blocks[231] = {}
blocks[231]['width'] = 6;
blocks[231]['hide_data'] = true;
blocks[231]['title'] = 'Bewegung'; // Bewegung um das Haus herum
blocks[232] = {}
blocks[232]['width'] = 6;
blocks[232]['hide_data'] = true;
blocks[232]['title'] = 'Reset'; // Rücksetzen von Bewegung
columns[2] = {}
columns[2]['blocks'] = [buttons.jalousien, buttons.beleuchtung, buttons.alarm, buttons.wetterstation, 'blocktitle_8', 134, 151, 128, 135, 'sunrise' , 231, 232, buttons.radio]
columns[2]['width'] = 4;
columns[3] = {}
columns[3]['blocks'] = [buttons.webcam]
columns[3]['width'] = 6;
columns[4] = {}
columns[4]['blocks'] = ['blocktitle_1', 'blocktitle_2', 7, 1, 8, 'blocktitle_3', 40, 6, 'blocktitle_4', 194]
columns[4]['width'] = 8;
columns[5] = {}
columns[5]['blocks'] = ['blocktitle_7', 'blocktitle_1', 139, 140, 'blocktitle_4', 152, 153, 'blocktitle_9', 209]
columns[5]['width'] = 8;
columns[6] = {}
columns[6]['blocks'] = [frames.secpanel]
columns[6]['width'] = 12;
columns[7] = {}
columns[7]['blocks'] = ['blocktitle_4']
columns[7]['width'] = 8;
columns[10] = {}
columns[10]['blocks'] = ['currentweather_big', 'weather', 174, 175, 148, 142]
columns[10]['width'] = 4;
columns[11] = {}
columns[11]['blocks'] = [buttons.moon, 191, 193]
columns[11]['width'] = 4;
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg3.jpg';
screens[1]['columns'] = [2,3]
screens[2] = {}
screens[2]['background'] = 'bg3.jpg';
screens[2]['columns'] = [2,4]
screens[3] = {}
screens[3]['background'] = 'bg3.jpg';
screens[3]['columns'] = [2,5]
screens[4] = {}
screens[4]['background'] = 'bg3.jpg';
screens[4]['columns'] = [6]
screens[5] = {}
screens[5]['background'] = 'bg3.jpg';
screens[5]['columns'] = [2,10,11]
Your config looks fine... (that sentence about the config in my previous response was for Tontze
Hello Rob, did you have a look about the issue with arrows up/down for blinds? I have an older beta were the arrows working, they working with my CONFIG.js and custom.css, so might be something different in betas. It would be very good to get my blinds back to work. I can't use the older beta because off a bug with sliding pages.
I wish you a merry Christmas and happy new year.
rldn
Posts: 16 Joined: Thursday 16 November 2017 20:02
Post
by rldn » Tuesday 26 December 2017 10:38
Hi, big fan of this project.
But can someone please tell me why i cant get the news feed show up? I already put the proxy address in front of the feed address, tried several feeds but nothing shows up in the dashboard!?
blocks['news_10'] = {} // NU.NL
blocks['news_10']['feed'] = '
https://crossorigin.me/http://www.nu.nl/rss/algemeen ';
welby
Posts: 36 Joined: Monday 20 November 2017 3:24
Post
by welby » Tuesday 26 December 2017 11:17
Have you assigned it to a column?
rldn
Post
by rldn » Tuesday 26 December 2017 13:18
welby wrote: Tuesday 26 December 2017 11:17
Yes of course, but it doesnt show up. Also tried other columns, other block id's, clearing caches
EdwinK
Post
by EdwinK » Tuesday 26 December 2017 17:38
I don't know what happend, but after adding two more blocks, I get the evil white page. Checked, tripple checked and checked again, but as far as I can see, everything is okay on CONFIG.js.
CONFIG.js
Spoiler: show var config = {}
config['domoticz_ip'] = 'http://192.168.0.11:8080 ';
config['app_title'] = 'ControlCenter';
config['room_plan'] = '0';
config['domoticz_refresh'] = '10';
config['dashticz_refresh'] = '30';
config['default_news_url'] = 'http://www.nu.nl/rss/algemeen ';
config['news_scroll_after'] = '7';
config['standby_after'] = 'false';
config['auto_swipe_back_after'] = '0';
config['auto_slide_pages'] = '0';
config['slide_effect'] = 'slide';
config['standard_graph'] = 'day';
config['language'] = 'nl_NL';
config['timeformat'] = 'YY-MM-DD HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'nl_NL';
config['calendarurl'] = '0';
config['gm_api'] = '';
config['gm_zoomlevel'] = '11';
config['gm_latitude'] = '51.860067';
config['gm_longitude'] = '4.412692';
config['speak_lang'] = 'en-US';
config['wu_api'] = '17318c1fc1678195';
config['wu_city'] = 'Rhoon';
config['wu_name'] = '0';
config['wu_country'] = 'NL';
config['idx_moonpicture'] = 1;
config['switch_horizon'] = '0';
config['host_nzbget'] = '0';
config['spot_clientid'] = '';
config['sonarr_url'] = '0';
config['sonarr_apikey'] = '0';
config['sonarr_maxitems'] = '0';
config['garbage_company'] = 'mijnafvalwijzer';
config['garbage_icalurl'] = '0';
config['google_api_key'] = '';
config['garbage_calendar_id'] = '';
config['garbage_zipcode'] = '3161LH';
config['garbage_street'] = 'Jonkerhof';
config['garbage_housenumber'] = '27';
config['garbage_housenumberadd'] = '';
config['garbage_maxitems'] = 1;
config['garbage_width'] = '6';
config['no_rgb'] = 1;
config['auto_positioning'] = '0';
config['use_favorites'] = '0';
config['last_update'] = '0';
config['hide_topbar'] = '0';
config['edit_mode'] = '0';
config['hide_seconds'] = '0';
config['hide_seconds_stationclock'] = '0';
config['use_fahrenheit'] = '0';
config['use_beaufort'] = 1;
config['translate_windspeed'] = '0';
config['static_weathericons'] = '0';
config['hide_mediaplayer'] = '0';
config['garbage_hideicon'] = '0';
config['garbage_icon_use_colors'] = 1;
config['garbage_use_colors'] = 1;
config['garbage_use_names'] = 1;
config['garbage_use_cors_prefix'] = '0';
// Calendar
var calendars = {}
calendars.business = { url: 'PRIVATEbasic.ics' }
calendars.private = { icon: 'fa-calendar', maxitems: 5, color:'green',icon:'fa-calendar', color:'green', icalurl: 'PRIVATEbasic.ics' }
calendars.combined = {}
calendars.combined.maxitems = 15 ;
calendars.combined. calendars = [
{ color:'white', calendar:calendars.business },
{ color:'red', calendar:calendars.private }
calendars.combined.url = 'https://calendar.google.com/calendar/re ... i=1#main_7 ';
//Afval
gft: {kliko: 'green', code: '#375b23', name: 'GFT'},
pmd: {kliko: 'orange', code: '#db5518', name: 'PMD'},
rest: {kliko: 'grey', code: '#5e5d5c', name: 'Restafval'},
papier: {kliko: 'blue', code: '#153477', name: 'Papier'},
kca: {kliko: 'red', code: '#b21807', name: 'Chemisch afval'},
brown: {kliko: 'brown', code: '#7c3607', name: 'Bruin'},
black: {kliko: 'black', code: '#000000', name: 'Zwart'},
var maps = {};
maps.location = { height: 450, width:12, latitude: 51.860067, longitude: 4.412692, zoom:14 }
var buttons = {}
buttons.moon = {key:'moon',width:6, isimage:true, refreshimage:60000, image: 'moon'}
// cam
buttons.webcam = {key:'webcam',width:12, isimage:true, refresh:2000, image: 'http://192.168.0.115:8080/shot.jpg ', url: 'http://192.168.0.115:8080/video '}
// end config
var blocks = {}
blocks['blocktitle_1'] ['type'] = 'blocktitle';
blocks['blocktitle_1'] ['title'] = 'Schakelaars';
blocks['blocktitle_2'] ['type'] = 'blocktitle';
blocks['blocktitle_2'] ['title'] = 'Temperatuur';
blocks['blocktitle_2'] ['width'] = 8;
blocks['blocktitle_2a'] = {}
blocks['blocktitle_2a'] ['type'] = 'blocktitle';
blocks['blocktitle_2a'] ['title'] = 'Gas/Elektra';
blocks['blocktitle_3'] ['type'] = 'blocktitle';
blocks['blocktitle_3'] ['title'] = 'Divers';
blocks['blocktitle_4'] ['type'] = 'blocktitle';
blocks['blocktitle_4'] ['title'] = 'Map';
blocks['blocktitle_5'] ['type'] = 'blocktitle';
blocks['blocktitle_5'] ['title'] = 'Webcam achter';
blocks['blocktitle_6'] ['type'] = 'blocktitle';
blocks['blocktitle_6'] ['title'] = 'Luchtkwaliteit';
blocks['blocktitle_7'] ['type'] = 'blocktitle';
blocks['blocktitle_7'] ['title'] = 'Raspberry';
blocks['blocktitle_7a'] = {}
blocks['blocktitle_7a'] ['type'] = 'blocktitle';
blocks['blocktitle_7a'] ['title'] = 'ALIVE?';
blocks['blocktitle_8'] ['type'] = 'blocktitle';
blocks['blocktitle_8'] ['title'] = 'test1';
blocks['blocktitle_9'] ['type'] = 'blocktitle';
blocks['blocktitle_9'] ['title'] = 'Agenda';
blocks['blocktitle_10'] = {}
blocks['blocktitle_10'] ['type'] = 'blocktitle';
blocks['blocktitle_10'] ['title'] = 'test2';
blocks['blocktitle_11'] = {}
blocks['blocktitle_11'] ['type'] = 'blocktitle';
blocks['blocktitle_11'] ['title'] = 'test3';
blocks[48] = {}
blocks[48]['title'] = 'KODI HSK';
blocks[48]['width'] = 6;
blocks[49] = {}
blocks[49]['title'] = 'KODI SLK';
blocks[49]['width'] = 6;
blocks[53] = {}
blocks[53]['title'] = 'Kerst';
blocks[84] = {}
blocks[84]['width'] = 6;
blocks[120] = {}
blocks[120]['icon'] = 'fa fa-moon-o';
blocks[120]['title'] = 'Maan';
blocks[120]['switch'] = true;
blocks[123] = {}
blocks[123]['icon'] = 'fa fa-moon-o';
blocks[123]['title'] = 'Maan fase';
blocks[123]['width'] = 12;
blocks[123]['switch'] = true;
blocks[130] = {}
blocks[130]['title'] = 'Streaming';
blocks[130]['width'] = 6;
blocks[167] = {}
blocks[167]['width'] = 6;
blocks[167]['icon'] = 'fa-lightbulb-o';
blocks['175_1'] = {}
blocks['175_1']['title'] = 'SLK';
blocks['176_1'] = {}
blocks['176_1']['title'] = 'Buiten';
blocks['177_1'] = {}
blocks['177_1']['title'] = 'Zolder';
blocks[185] = {}
blocks[185]['width'] = 6;
blocks[187] = {}
blocks[187]['title'] = 'Fijnstof';
blocks[187]['switch']= true;
blocks[188] = {}
blocks[188]['title'] = 'Ozon';
blocks[188]['switch']= true;
blocks[189] = {}
blocks[189]['title'] = 'Stikstofm.';
blocks[189]['switch']= true;
blocks[190] = {}
blocks[190]['title'] = 'Koolstof';
blocks[190]['switch']= true;
blocks[191] = {}
blocks[191]['title'] = 'Zwaveld.';
blocks[191]['switch']= true;
blocks[192] = {}
blocks[192]['title'] = 'Ammoniak';
blocks[192]['switch']= true;
blocks[193] = {}
blocks[193]['title'] = 'Stikstofd.';
blocks[193]['switch']= true;
blocks[194] = {}
blocks[194]['title'] = 'Temp. instelling';
blocks[194]['switch']= true;
blocks[195] = {}
blocks[195]['title'] = 'HSK Temp.';
blocks[196] = {}
blocks[196]['title'] = 'Ketel';
blocks['199_1'] = {}
blocks['199_1']['switch'] = true;
blocks['199_1']['width'] = 6;
blocks['199_2'] = {}
blocks['199_2']['switch'] = true;
blocks['199_2']['width'] = 6;
blocks['199_3'] = {}
blocks['199_3']['switch'] = true;
blocks['199_3']['width'] = 6;
blocks['200_1'] = {}
blocks['200_1']['title'] = 'Vandaag';
blocks['200_1']['switch'] = true;
blocks['200_2'] = {}
blocks['200_2']['title'] = 'Totaal';
blocks['200_2']['switch'] = true;
blocks[201] = {}
blocks[201]['icon'] = 'fa-male';
blocks[201]['width'] = 6;
blocks[201]['title'] = 'Edwin';
blocks[201]['protected'] = true;
blocks[239] = {}
blocks[239]['title'] = 'Zone 1 Alarm';
blocks[239]['switch'] = true;
blocks[239]['width'] = 4;
blocks[240] = {}
blocks[240]['title'] = 'Zone 1 Status';
blocks[240]['width'] = 4;
blocks[240]['switch'] = true;
blocks[241] = {}
blocks[241]['title'] = 'Home Aan/Uit';
blocks[241]['width'] = 4;
blocks[242] = {}
blocks[242]['title'] = 'Away Aan/Uit';
blocks[242]['width'] = 4;
blocks[249]= {}
blocks[249]['title']= 'Printer';
blocks[249]['icon'] = 'fa-print';
blocks[250]= {}
blocks[250]['title']= 'Network';
blocks[250]['icon'] = 'fa-network';
blocks[251]= {}
blocks[251]['title']= 'Internet';
blocks[258] = {}
blocks[258]['title'] = 'Max2Play'
blocks[258]['icon'] = 'fa fa-music';
blocks['267_1'] = {}
blocks['267_1']['width'] = 8;
blocks[276] = {}
blocks[276]['title'] = 'CPU'
blocks[276]['switch'] = true;
blocks[276]['image'] = 'rpi.png';
blocks[277] = {}
blocks[277]['title'] = 'Int. Temp'
blocks[277]['switch'] = true;
blocks[277]['image'] = 'rpi.png';
blocks[279] = {}
blocks[279]['title'] = 'Memory'
blocks[279]['switch'] = true;
blocks[279]['image'] = 'rpi.png';
blocks[280] = {}
blocks[280]['switch'] = true;
blocks[280]['image'] = 'rpi.png';
blocks[281]= {}
blocks[281]['image'] = 'rpi.png';
blocks[281]['switch'] = true;
blocks[282] = {}
blocks[282]['switch'] = true;
blocks[282]['image'] = 'rpi.png';
blocks[286] = {}
blocks[286]['title'] = 'TV'
blocks[286]['icon'] = 'fa fa-television';
blocks[287] = {}
blocks[287]['image'] = 'kodi.png';
blocks[288] = {}
blocks[288]['image'] = 'kodi.png';
blocks['300_1'] = {}
blocks['300_1']['title'] = 'Temp';
blocks['300_1']['switch'] = true;
blocks['300_2'] = {}
blocks['300_2']['title'] = 'Luchtv.';
blocks['300_2']['switch'] = true;
blocks['300_3'] = {}
blocks['300_3']['title'] = 'Baro';
blocks['300_3']['switch'] = true;
blocks[301] = {}
blocks[301]['title'] = 'Wind';
blocks[301]['switch'] = true;
blocks[302] = {}
blocks[302]['title'] = 'Uv';
blocks[302]['switch'] = true;
blocks[304] = {}
blocks[304]['title'] = 'Zichtb.';
blocks[304]['switch'] = true;
blocks[305] = {}
blocks[305]['title'] = 'Ozon';
blocks[306] = {}
blocks[306]['title'] = 'Cloud.';
blocks[306]['icon'] = 'fa fa-cloud';
blocks[306]['switch'] = true;
blocks[307] = {}
blocks[307]['title'] = 'Neerslag';
blocks[307]['switch'] = true;
blocks['s2'] = {}
blocks['s2']['width'] = 12;
var columns = {}
columns['bar'] = {}
columns['bar']['blocks'] = ['sunrise','miniclock','settings']
columns[1] = {}
columns[1]['blocks'] = ['weather','300_2','300_3',301,302,304,306,307,308,'blocktitle_2',195,'300_1','175_1','176_1','177_1']
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = ['blocktitle_1',84,167,51,222,291,55,56,57,58,125,53,'s3','s4','s5','s6','s7','s8']
columns[3] = {}
columns[3]['blocks'] = ['blocktitle_2a','200_1','200_2',196,'199_1','199_2','blocktitle_3',185,201,buttons.moon,'garbage']
columns[3]['width'] = 4;
columns[4] = {}
columns[4]['blocks'] = ['blocktitle_4',maps.location]
columns[4]['width'] = 6;
columns[5] = {}
columns[5]['blocks'] = ['blocktitle_5',buttons.webcam]
columns[5]['width'] = 6;
columns[6] = {}
columns[6]['blocks'] = ['blocktitle_6',187,188,189,190,191,192,193]
columns[6]['width'] = 4;
columns[7] = {}
columns[7]['blocks'] = ['blocktitle_7',276,277,279,280,281,'blocktitle_7a',249,250,251,258,286,287,288]
columns[7]['width'] = 4;
columns[8] = {}
columns[8]['blocks'] = ['blocktitle_8',292,293,294]
columns[8]['width'] = 4;
columns[9] = {}
columns[9]['blocks'] = ['blocktitle_9',calendars.combined]
columns[9]['width'] = 4
columns[10] = {}
columns[10]['blocks'] = ['blocktitle_10']
columns[11] = {}
columns[11]['blocks'] = ['blocktitle_11',199]
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg10.jpg';
screens[2] = {}
screens[2]['background'] = 'bg10.jpg';
screens[2]['columns'] = [6,7,8]
screens[3] = {}
screens[3]['background'] = 'bg10.jpg';
screens[3]['columns'] = [4,5] // map and webcam
screens[4] = {}
screens[4]['background'] = 'bg10.jpg';
screens[4]['columns'] = [9,10,11] // map and webcam
[/spoier]
dagger38
Posts: 40 Joined: Wednesday 01 November 2017 17:01
Domoticz version: 3.8153
Post
by dagger38 » Tuesday 26 December 2017 18:59
delete /* at line 242 , 227 , 66
in the blocks section forgotten ; at the end of the line (several times)
Dashtics works with me if i remove the AFVAL section , so the error is in that section to!!
My system:
1 Raspberry Pi 3
1 Rfx-Trx 433 module
1 Milight module
1 aeotec Zwave stick
1 Philips Home Bridge
3 Qubino ZMNHBDx Flush 2 Relays
2 FIBARO System FGS223 Double Relay
1 Niko home system
EdwinK
Post
by EdwinK » Tuesday 26 December 2017 20:06
Thanks. Trying again.
EdwinK
Post
by EdwinK » Tuesday 26 December 2017 20:51
Didn't work. Would also be strange, because it worked before with the same settings.
Edit: It was indeed in de //AFVAL part. There is something missing.
