Blockly examples
Jawi
Re: Blockly examples
Post by Jawi »
micbou wrote:
Thomasdc wrote:
micbou wrote:Also I want to make my light turns off after 20 minuten of no activity, but this doesnt seem to work. Instead it just shuts off the lights 20 minutes after it's in turned 'off' state.
i think The problem you have is:
1) motionsensors turnes off
2) command to turn lights off after 1200 seconds (timer starts running)
3) motionsenser turns on again because of some motion
but even after event '3' the timer of event '2' is still running (timer is still running) so when timer is done.. it will still set your lights off..
so '2' is actualie setting a timer for 1200 seconds.. once the time is up turn the lights off. but once the timer is started.. it cant be stopped anymore so it will always turn your lights independent of other events..
Correct, so how do you suggest I'd set it up. So I want my light to turn on when the light in the room is under an x-amount of Lux (MotionSensor6), but only when motion is detected in the living room. If there hasnt been any motion for >15 minutes the lights need to be turned off.
If you have a multisensor you can set the time in the settings menu of the sensor.
emme
Domoticz version: latest
Post by emme »
OT:
sorry guys... but... you have a specific block for logic operator (AND)
I cannot find it in my blocky editor not under "control", nor under "Logic"....
do I have to upgrade my blocky interface? (domo SD image, v3.5582b)
"We always done this way"
MarcelMAH
Domoticz version: v3.8025
Post by MarcelMAH »
emme wrote:OT:
Rightmouseclick on the and operator block and click 'external outputs' will make it look like that.
Running Domoticz on Ubuntu 16.04 on VMware with RFXCOM - RFXtrx433 and Aeotec Z-Stick Gen5
emme
Post by emme »
thanks! :P
cobra045
Domoticz version: 3.4834
Post by cobra045 »
Thanks, I have now found it.
cobra045
RMU
Post by RMU »
I'm trying to make a blocky, and it works but not the way i wanted.
I have made two, which should do the same;
The one that works:
Here are all switches seperate as you can see.
But what i want is working with groups:
This should do the same as the first picture, but when i set "Iemand thuis" to "off" then only the first group gets done, so in this case: "Lampen woonkamer" is set to off. But the second "Apparaten woonkamer" is not set to off.
Can someone tell me why this does not work and how i can fix it? Thanks!
cobra045
Post by cobra045 »
Hallo RMU,
I also had the problem with switching off
Try it with a delay in the group
see the picture
cobra045
thecosmicgate
Domoticz version: newest
Post by thecosmicgate »
I've build a blackly when using a pir to power on a lamp. But when using this blockly it's to slow.
Because when we enter the room with this pir the light must be powered on instantly. Is lua faster ?
It's nice to be important, but it's more important to be nice
Scooter ;)
Bart77
Domoticz version: Latest
Post by Bart77 »
I've just installed my Domoticz server and was pretty impressed, so next step was to start implementing use cases.
I downloaded the Pilot app to enable geofencing on my phone which is linked to 2 dummy switches, one @Work and one for @Home.
For this I made some basic Blockly scipts where I experienced some strange behavior.
1. User variables do not seem to be updated inside the script itself
2. Nested if and else if statement do not deliver expected results
This script works:
This one did not:
When updated this always returns ERROR, which is stange, looking at the log all nested if actions are executed.
Result in the log:
Does anyone have any tips/suggestions?
Should I switch to LUA scripting or does this have the same restrictions?
Many thanks for your input
rickybee
Post by rickybee »
This is a simple script to turn off a light when my wife leaves and back on when she returns. This works fine except at the end of the day when we want to turn it off manually it comes right back on. I had thought that the script would only be triggered upon the cell phones' change of state but apparently not. Any advice would be appreciated.
StanHD
Post by StanHD »
If it helps, I would add a dummy Auto/Manual switch which is controlled with the built in timers. Then simply check the state of the switch in the blockly before carrying out the action.
Python:- Broadlink RM2, Sonos
rickybee
Post by rickybee »
Thanks StanHD, as you suggested I created a 'Manual On' switch which is on between 9pm and 7am and added it to the script. Testing it now but I think it should work for what I need.
deejc
Domoticz version: 3.5641
Post by deejc »
hello
i have an RFXCom doorbell that has multiple chimes, i captured each chime in domoticz nd created a bell for each and now i am trying to get a camera snapshot to send if any one of the bells is triggered (it seems to rotate each sound) so it could be one of the seven that chimes, this blockly does not seem to fire at all???
the end of the first line of the blockly is or bell7 = on
Domoticz 3.5641 on RPI (Raspbian GNU/Linux 8)
four2six
Post by four2six »
deejc wrote:this blockly does not seem to fire at all???
not sure i understood your 'capturing' correctly, but it lacks the 'logic'-part. It should be something like "if bell1='on' " or "if bell2='on' "... etc.
deejc
Post by deejc »
Ok thanks I'll change it
deejc
Post by deejc »
another one i cant get to work, this one does nothing, nothing in the logs, the 1 minute timer doesn't fire.. i know the 3in1 motion is triggered…
twig 1 and twig 2 are leds on their own plugs, so just off and on, 3 in 1 motion is fibaro eye motion sensor which is working correctly, 1 min timer is taken from a previous post in this thread.
any ideas ?
Domosapiens
Domoticz version: V3.5981
Post by Domosapiens »
AFAIK,
Set can not be combined with an AND statement.
Use 2x Set:
Set Twig1 =On
Set Twig2 =On
deejc
Post by deejc »
Ah ha, thanks I'll try that
bacinatorz
Post by bacinatorz »
Is there a possibility to make sure this event does not turn on again after I turned letstrips off by hand (in domoticz web) because now it tries every few minutes.
thecosmicgate
Re: RE: Re: Blockly examples
bacinatorz wrote:Hi all,
Sure, when you use variables
Scooter ;)
