Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
blacksn0w
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by blacksn0w »
There seems to be a new command to synchronise the devices.
A German news site wrote about it, so I will give it a try in German when im at Home.
Madgeni
Post by Madgeni »
Great! Nice of them to let developers know ;-)
I'll try it now, and see what happens :)
Madgeni
Post by Madgeni »
For those with connectivity issues, have updated your Profile page in Controlicz with functionality to test connections :)
Madgeni
Post by Madgeni »
bldewit wrote: Thursday 14 December 2017 11:19 Hi Madgeni...
I used it for several days and I must say, it worked like a charm. Kudos for that! I noticed however that some of the names of my devices were not so practical (dutch names in an English Google Home) so I added some names in description fields.
Queriïng devices did not trigger the names to be added to my Google Home, so I went into the GH app and unlinked the Controlicz service.
so I owe you a massive apology. Something has changed on Google's side, and now it's no longer reading changes to the names (using the Controlicz: tag). They are being set, but Google is no longer refreshing them. I'll raise another issue with them and let you know
Noka
Post by Noka »
It work ! You rock. Thanks donation on the way
Madgeni
Post by Madgeni »
ok, sync working again, and also 'Sync my devices' works :D
bldewit
Domoticz version: Stable
Post by bldewit »
Madgeni wrote: Thursday 14 December 2017 14:48
Big thx from me! I have just been able to add the service again to GH! Test it later because I am not home right now. As for our google friends, wel, .... no need for you to apologize for them! :mrgreen:
Running on rPi 3b (main) and rPi 2b (somfy), both RFLink
IthoRemote, Xiaomi Gateway, KAKU
HarryHase
Domoticz version: stable
Post by HarryHase »
@Madgeni: can you please send me instructions for google home, i'm registred tka*******@gmail.com
ticranou
Post by ticranou »
Hi Madgeni,
I just registered to Controlicz.
Could you please add me in your beta program.
My email is ****@gmail.com
Thanks in advance,
Last edited by ticranou on Thursday 14 December 2017 17:05, edited 1 time in total.
Madgeni
Post by Madgeni »
done & done
ticranou
Post by ticranou »
Thanks ;-)
Lyrex
Post by Lyrex »
Madgeni wrote: Thursday 14 December 2017 13:32 pretty much what i put -
https://developers.google.com/actions/s ... aits/modes
the documentation has been cheekily changed since I raised this with them - initially they had "custom names need to be submitted to Google" - now they've put:
"Currently, you must use the names in the example JSON; custom names are not yet supported."
https://github.com/actions-on-google/ac ... /issues/75
Allright, hopefully this issue will be solved in the near future
Madgeni
Post by Madgeni »
yep, and they still don't work, even when I hardcode in their silly example :/
HarryHase
Post by HarryHase »
Okay, that works fine; Also with german language. But how i can add additional devices?
I added them in the floorplan, but in the google home i can't find an update button. Where is my fault?
Madgeni
Post by Madgeni »
have you tried "Sync my devices" ? also, devices need to be in room plans, not floor plans :)
querying a device will resync all devices also
blacksn0w
Post by blacksn0w »
"OK Google, synchronisiere meine Smart Home Geräte"
They should show up within a few minutes.
gijsje
Post by gijsje »
Sync my devices that a great function
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
HarryHase
Post by HarryHase »
thx Mageni & blacksn0w : my fault; It works
quirk
Post by quirk »
Thanks Madgeni for the test button, I've been able to spot error in my Nginx reverse proxy config that prevents Controlicx to access Domoticz!
toutazimuth
Post by toutazimuth »
Hi Madgeni
With Controlicz, everything works perfectly for me.
Thank you very much for the work done and the follow up :)
