Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
There seems to be a new command to synchronise the devices.
A German news site wrote about it, so I will give it a try in German when im at Home.
Great! Nice of them to let developers know
I'll try it now, and see what happens
For those with connectivity issues, have updated your Profile page in Controlicz with functionality to test connections
so I owe you a massive apology. Something has changed on Google's side, and now it's no longer reading changes to the names (using the Controlicz: tag). They are being set, but Google is no longer refreshing them. I'll raise another issue with them and let you knowbldewit wrote: ↑Thursday 14 December 2017 11:19 Hi Madgeni...
I used it for several days and I must say, it worked like a charm. Kudos for that! I noticed however that some of the names of my devices were not so practical (dutch names in an English Google Home) so I added some names in description fields.
Queriïng devices did not trigger the names to be added to my Google Home, so I went into the GH app and unlinked the Controlicz service.
It work ! You rock. Thanks donation on the way
ok, sync working again, and also 'Sync my devices' works
- Domoticz version: Stable
Big thx from me! I have just been able to add the service again to GH! Test it later because I am not home right now. As for our google friends, wel, .... no need for you to apologize for them!Madgeni wrote: ↑Thursday 14 December 2017 14:48so I owe you a massive apology. Something has changed on Google's side, and now it's no longer reading changes to the names (using the Controlicz: tag). They are being set, but Google is no longer refreshing them. I'll raise another issue with them and let you knowbldewit wrote: ↑Thursday 14 December 2017 11:19 Hi Madgeni...
Running on rPi 3b (main) and rPi 2b (somfy), both RFLink
IthoRemote, Xiaomi Gateway, KAKU
- Domoticz version: stable
@Madgeni: can you please send me instructions for google home, i'm registred tka*******@gmail.com
Hi Madgeni,
I just registered to Controlicz.
Could you please add me in your beta program.
My email is ****@gmail.com
Thanks in advance,
Thanks in advance,
Last edited by ticranou on Thursday 14 December 2017 17:05, edited 1 time in total.
done & done
Allright, hopefully this issue will be solved in the near futureMadgeni wrote: ↑Thursday 14 December 2017 13:32 pretty much what i put -
https://developers.google.com/actions/s ... aits/modes
the documentation has been cheekily changed since I raised this with them - initially they had "custom names need to be submitted to Google" - now they've put:
"Currently, you must use the names in the example JSON; custom names are not yet supported."
https://github.com/actions-on-google/ac ... /issues/75
yep, and they still don't work, even when I hardcode in their silly example :/
Okay, that works fine; Also with german language. But how i can add additional devices?
I added them in the floorplan, but in the google home i can't find an update button. Where is my fault?
have you tried "Sync my devices" ? also, devices need to be in room plans, not floor plans
querying a device will resync all devices also
"OK Google, synchronisiere meine Smart Home Geräte"
They should show up within a few minutes.
- gijsje
Sync my devices that a great function
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
thx Mageni & blacksn0w : my fault; It works
Thanks Madgeni for the test button, I've been able to spot error in my Nginx reverse proxy config that prevents Controlicx to access Domoticz!
Hi Madgeni
With Controlicz, everything works perfectly for me.
Thank you very much for the work done and the follow up
