Page 143 of 184
Posted: Thursday 12 October 2017 19:00
by AWP2000
Thank you but still nor work ..
Posted: Thursday 12 October 2017 20:38
by AWP2000
not
Posted: Thursday 12 October 2017 20:57
by htilburgs
What kind of ipcam you use (name & type)?
by htilburgs
Posted: Thursday 12 October 2017 22:45
by woody4165
Does the url in dashticz work in a browser?
Posted: Thursday 12 October 2017 22:56
by niwreg
Hey,
I'm new with Dashticz, and after a day of fiddling i found out that i should use config['auto_positioning'] = 0; to get mij groups and other sensors to work.
However is it possible to control kodi with dashticz? I've got an overview of what is is playing, but i would like to pause/play kodi from dashitcz, is this possible? (i now i can add a dummy switch with some logic but it would be nice to have it integrated)
Posted: Friday 13 October 2017 18:59
by AWP2000
the URL work in chrome browser . It's very strange because when i use this 'http://192.168.0.22/web/tmpfs/snap.jpg' , it works without (admin:xxxx@ ) !
My cam, it's advisen visio 7.
Posted: Friday 13 October 2017 19:04
by woody4165
Try without the user:pass
Posted: Friday 13 October 2017 19:10
by AWP2000
yes , i tried and it works
Posted: Friday 13 October 2017 19:15
by woody4165
Same as me.
The only things is that from time to time you have to access that page directly from browser with credentials if the browser looses it...
Not a good thing, but this is the way actually...
Posted: Friday 13 October 2017 22:17
by DAVIZINHO
Hello.
Im new user of Dashticz v2. I see your dashboardas and its amazing!!!!
I install today it on default folder, and make little changes (title in CONFIG.js) but this little change not make nothing in the web.
And if I change something in the web it says that the changes are only for browser.
I change the CONFIG.js in /domoticz/www/dashticz_v2/custom/
what im doing wrong? :-(
thanks a lot
Posted: Friday 13 October 2017 22:26
by CaesarPL
What is in your config file? Have you changed auto positioning and uncommented lines?
Posted: Friday 13 October 2017 22:42
by DAVIZINHO
CaesarPL wrote: Friday 13 October 2017 22:26 What is in your config file? Have you changed auto positioning and uncommented lines?
wow. IM stupid!, all the config.js is comented! :-(
thanks!!!
Posted: Sunday 15 October 2017 17:57
by DAVIZINHO
Hello again.
Im very happy with dashticz!, is amazing!!
Since yesterday im trying to configure a dashboard for my house and i make some progress but i have a little problem.
This 2 items mi CONFIG.js
columns[4] = {} //SALON
columns[4]['blocks'] = ['salon',95,17,7,7,'18_2',4,33,47,27,'mauri',66,64,63,65,62,'bebeto']
columns[4]['width'] = 4;
The 2 items are the idx 47 and 27
47 = "Purificador"
27 = "Sa_Boton"
In domoticz both items are config as "select button".
I need this items are select button because I need to be more small than actual and follow the style of the rest blocks in "4 width.
Any idea?
thanks a lot and sorry for my poor english :-(
Posted: Monday 16 October 2017 8:55
by htilburgs
DAVIZINHO wrote: Sunday 15 October 2017 17:57 Hello again.
47 = "Purificador"
27 = "Sa_Boton"
Any idea?
Maybe you can try to put the next line in your config.JS
config['selector_instead_of_buttons'] = 1;
Then you get a dropdown menu for the selector.
Posted: Monday 16 October 2017 10:15
by DAVIZINHO
htilburgs wrote: Monday 16 October 2017 8:55
47 = "Purificador"
27 = "Sa_Boton"
Any idea?
Great!! i will try afterwork. thanks!!!
Posted: Monday 16 October 2017 19:15
by AWP2000
It's possible to change the scale for graphs ?
Posted: Monday 16 October 2017 21:41
by DAVIZINHO
htilburgs wrote: Monday 16 October 2017 8:55 Maybe you can try to put the next line in your config.JS
hi again.
The problem now is the next:
It show a selector and this is perfect! but the block is to long :-O
any idea?
thanks again!!!
Posted: Monday 16 October 2017 21:54
by htilburgs
What is the width of the block in your config.JS?
Orherwise please post your config.JS wirhout the personal keys and other private stuff.
EDIT: see also the Wiki - http://www.domoticz.com/wiki/Dashticz_V2_-_Positioning
Posted: Monday 16 October 2017 22:15
by DAVIZINHO
im a completly noob, im trying to learn fast :-(
this is mi config.js
var _EDIT_MODE = false;
var config = {}
config['domoticz_ip'] = 'http://192.168.1.4:8084';
config['app_title'] = 'Dashticz davizinho';
config['default_news_url'] = 'http://estaticos.elmundo.es/elmundo/rss/portada.xml';
config['news_scroll_after'] = '7';
config['standby_after'] = 0;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '30';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'month';
config['language'] = 'es_ES';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'es_ES';
config['calendarurl'] = 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar/';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 'api';
config['gm_zoomlevel'] = 4;
config['gm_latitude'] = '40.4989948';
config['gm_longitude'] = '-3.6610076';
config['wu_api'] = 'api';
config['wu_city'] = 'pws:IMLASTAB2';
config['wu_name'] = 'Las Tablas';
config['wu_country'] = 'ES';
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 'http://192.168.1.4:8084';
config['spot_clientid'] = 'api';
config['use_favorites'] = 1;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 1;
config['hide_mediaplayer'] = 0;
var maps = {}
maps.location = { height: 800, width:12, latitude: 40.4989948, longitude: -3.6610076, zoom:15 }
var frames = {}
frames.weather = {height:526,frameurl:"https://gadgets.buienradar.nl/gadget/zoommap/?lat=40.4165&lng=-3.70256&overname=2&zoom=11&naam=madrid&size=3&voor=0",width:12}
frames.floorplan = {height:800,frameurl:"http://davizinho.myvnc.com:8084/#/Floorplans",width:36}
var blocks = {}
blocks['router'] = {} //ROUTER
blocks['router']['width'] = 12;
blocks['router']['type'] = 'blocktitle';
blocks['router']['title'] = 'Router ASUS AC88U'
blocks['nas'] = {} //NAS SYNOLOGY
blocks['nas']['width'] = 12;
blocks['nas']['type'] = 'blocktitle';
blocks['nas']['title'] = 'NAS Synology'
blocks['salon'] = {} //SALON
blocks['salon']['width'] = 12;
blocks['salon']['type'] = 'blocktitle';
blocks['salon']['title'] = 'Salon'
blocks['dormitorio'] = {} //DORMITORIO
blocks['dormitorio']['width'] = 12;
blocks['dormitorio']['type'] = 'blocktitle';
blocks['dormitorio']['title'] = 'Dormitorio'
blocks['mauri'] = {} //MAURI
blocks['mauri']['width'] = 4;
blocks['mauri']['type'] = 'blocktitle';
blocks['mauri']['title'] = 'Mauri'
blocks['bebeto'] = {} //Bebeto
blocks['bebeto']['width'] = 4;
blocks['bebeto']['type'] = 'blocktitle';
blocks['bebeto']['title'] = 'Bebeto'
blocks['frikyroom'] = {} //Frikyroom
blocks['frikyroom']['width'] = 4;
blocks['frikyroom']['type'] = 'blocktitle';
blocks['frikyroom']['title'] = 'Frikyroom'
blocks['terraza'] = {} //Terraza
blocks['terraza']['width'] = 4;
blocks['terraza']['type'] = 'blocktitle';
blocks['terraza']['title'] = 'Terraza'
blocks['entrada'] = {} //Entrada
blocks['entrada']['width'] = 4;
blocks['entrada']['type'] = 'blocktitle';
blocks['entrada']['title'] = 'Entrada'
blocks['pasillo'] = {} //Pasillo
blocks['pasillo']['width'] = 4;
blocks['pasillo']['type'] = 'blocktitle';
blocks['pasillo']['title'] = 'Pasillo'
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['currentweather_big','weather',frames.weather]
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = ['spotify']
columns[2]['width'] = 4;
columns[3] = {}
columns[3]['blocks'] = [maps.location]
columns[3]['width'] = 4;
columns[4] = {}
columns[4]['blocks'] = [frames.floorplan]
columns[4]['width'] = 12;
columns[5] = {}
columns[5]['blocks'] = ['spotify']
columns[5]['width'] = 4;
columns[6] = {}
columns[6]['blocks'] = [maps.location]
columns[6]['width'] = 4;
columns[4] = {}
columns[4]['blocks'] = [buttons.buienradar,'sunrise','spotify',buttons.nos,buttons.tweakers,buttons.nunl]
columns[4]['width'] = 2;
columns[5] = {}
columns[5]['blocks'] = [buttons.domoticz,'sunrise']
columns[5]['width'] = 2;
columns[6] = {}
columns[6]['blocks'] = ['traffic','train',maps.sonenbreugel]
columns[6]['width'] = 5;
columns[7] = {} //SALON
columns[7]['blocks'] = ['salon',95,17,7,7,'18_2',4,33,47,27,'mauri',66,64,63,65,62,'bebeto']
columns[7]['width'] = 4;
columns[8] = {} //DORMITORIO y FRIKYROOM
columns[8]['blocks'] = ['dormitorio',96,14,31,40,'15_2',38,6,'frikyroom',97,48,51,49]
columns[8]['width'] = 4;
columns[9] = {} //TERRAZA Y ENTRADA Y PASILLO
columns[9]['blocks'] = ['terraza',1,12,29,'2_2',39,45,29,'entrada',10,35,'pasillo',20,23,21]
columns[9]['width'] = 4;
columns[10] = {} //ROUTER
columns[10]['blocks'] = ['router',89,67,68,71,70,69]
columns[10]['width'] = 4;
columns[11] = {} //NAS
columns[11]['blocks'] = ['nas',72,77,78,73,90,85,74,91,86,75,92,87,76,93,88]
columns[11]['width'] = 4;
columns[13] = {}
columns[13]['blocks'] = ['log','news_1','news_2']
columns[13]['width'] = 5;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
var screens = {}
screens['default'] = {}
screens['default']['maxwidth'] = 1920;
screens['default']['maxheight'] = 1080;
screens['default'][1] = {}
screens['default'][1]['background'] = 'bg9.jpg';
screens['default'][1]['columns'] = [1,2,3]
screens['default'][2] = {}
screens['default'][2]['background'] = 'bg9.jpg';
screens['default'][2]['columns'] = [4]
screens['default'][3] = {}
screens['default'][3]['background'] = 'bg9.jpg';
screens['default'][3]['columns'] = [7,8,9]
screens['default'][4] = {}
screens['default'][4]['background'] = 'bg9.jpg';
screens['default'][4]['columns'] = [10,11,12]
screens['tablet'] = {}
screens['tablet']['maxwidth'] = 1024;
screens['tablet']['maxheight'] = 768;
screens['tablet'][1] = {}
screens['tablet'][1]['background'] = 'bg9.jpg';
screens['tablet'][1]['columns'] = [1]
screens['tablet'][2] = {}
screens['tablet'][2]['background'] = 'bg9.jpg';
screens['tablet'][2]['columns'] = [2]
is too large becasue im trying to configure a lot of thins, jejejeje.
The problem i have is with blocks 8 in page 3 (the example of the image i share in the last post.
thanks a lot
