Thank you but still nor work ..
- htilburgs
What kind of ipcam you use (name & type)?
Hardware:
- htilburgs
Hardware:
woody4165
Does the url in dashticz work in a browser?
niwreg
Hey,
I'm new with Dashticz, and after a day of fiddling i found out that i should use config['auto_positioning'] = 0; to get mij groups and other sensors to work.
However is it possible to control kodi with dashticz? I've got an overview of what is is playing, but i would like to pause/play kodi from dashitcz, is this possible? (i now i can add a dummy switch with some logic but it would be nice to have it integrated)
the URL work in chrome browser . It's very strange because when i use this 'http://192.168.0.22/web/tmpfs/snap.jpg' , it works without (admin:xxxx@ ) !
My cam, it's advisen visio 7.
woody4165
Try without the user:pass
yes , i tried and it works
woody4165
Same as me.
The only things is that from time to time you have to access that page directly from browser with credentials if the browser looses it...
Not a good thing, but this is the way actually...
DAVIZINHO
Hello.
Im new user of Dashticz v2. I see your dashboardas and its amazing!!!!
I install today it on default folder, and make little changes (title in CONFIG.js) but this little change not make nothing in the web.
And if I change something in the web it says that the changes are only for browser.
I change the CONFIG.js in /domoticz/www/dashticz_v2/custom/
what im doing wrong?
thanks a lot
thanks a lot
CaesarPL
What is in your config file? Have you changed auto positioning and uncommented lines?
DAVIZINHO
wow. IM stupid!, all the config.js is comented!CaesarPL wrote: Friday 13 October 2017 22:26 What is in your config file? Have you changed auto positioning and uncommented lines?
thanks!!!
DAVIZINHO
Hello again.
Im very happy with dashticz!, is amazing!!
Since yesterday im trying to configure a dashboard for my house and i make some progress but i have a little problem. This 2 items mi CONFIG.js
The 2 items are the idx 47 and 27
47 = "Purificador"
27 = "Sa_Boton"
In domoticz both items are config as "select button".
I need this items are select button because I need to be more small than actual and follow the style of the rest blocks in "4 width.
Any idea?
thanks a lot and sorry for my poor english
columns[4] = {} //SALON
columns[4]['blocks'] = ['salon',95,17,7,7,'18_2',4,33,47,27,'mauri',66,64,63,65,62,'bebeto']
columns[4]['width'] = 4; 47 = "Purificador"
27 = "Sa_Boton"
Any idea?
- htilburgs
Maybe you can try to put the next line in your config.JSDAVIZINHO wrote: Sunday 15 October 2017 17:57 Hello again.
This 2 items mi CONFIG.jsThe 2 items are the idx 47 and 27Code: Select all
columns[4] = {} //SALON columns[4]['blocks'] = ['salon',95,17,7,7,'18_2',4,33,47,27,'mauri',66,64,63,65,62,'bebeto'] columns[4]['width'] = 4;
47 = "Purificador"
27 = "Sa_Boton"
Any idea?
thanks a lot and sorry for my poor english![]()
config['selector_instead_of_buttons'] = 1;Hardware:
DAVIZINHO
htilburgs wrote: Monday 16 October 2017 8:55Maybe you can try to put the next line in your config.JSDAVIZINHO wrote: Sunday 15 October 2017 17:57 Hello again.
47 = "Purificador"
27 = "Sa_Boton"
Any idea?
Then you get a dropdown menu for the selector.Code: Select all
Great!! i will try afterwork. thanks!!!
It's possible to change the scale for graphs ?
DAVIZINHO
hi again.htilburgs wrote: Monday 16 October 2017 8:55 Maybe you can try to put the next line in your config.JS
The problem now is the next: It show a selector and this is perfect! but the block is to long :-O
any idea?
thanks again!!!
- htilburgs
What is the width of the block in your config.JS?
Orherwise please post your config.JS wirhout the personal keys and other private stuff.
EDIT: see also the Wiki - http://www.domoticz.com/wiki/Dashticz_V2_-_Positioning
Hardware:
DAVIZINHO
im a completly noob, im trying to learn fast
this is mi config.js
is too large becasue im trying to configure a lot of thins, jejejeje.
The problem i have is with blocks 8 in page 3 (the example of the image i share in the last post.
thanks a lot
var _EDIT_MODE = false;
var config = {}
config['domoticz_ip'] = 'http://192.168.1.4:8084';
config['app_title'] = 'Dashticz davizinho';
config['default_news_url'] = 'http://estaticos.elmundo.es/elmundo/rss/portada.xml';
config['news_scroll_after'] = '7';
config['standby_after'] = 0;
config['auto_swipe_back_to'] = 1;
config['auto_swipe_back_after'] = '30';
config['auto_slide_pages'] = 0;
config['slide_effect'] = 'slide';
config['standard_graph'] = 'month';
config['language'] = 'es_ES';
config['timeformat'] = 'DD-MM-YY HH:mm';
config['calendarformat'] = 'dd DD.MM HH:mm';
config['calendarlanguage'] = 'es_ES';
config['calendarurl'] = 'https://cors-anywhere.herokuapp.com/https://calendar.google.com/calendar/';
config['boss_stationclock'] = 'RedBoss';
config['gm_api'] = 'api';
config['gm_zoomlevel'] = 4;
config['gm_latitude'] = '40.4989948';
config['gm_longitude'] = '-3.6610076';
config['wu_api'] = 'api';
config['wu_city'] = 'pws:IMLASTAB2';
config['wu_name'] = 'Las Tablas';
config['wu_country'] = 'ES';
config['idx_moonpicture'] = 0;
config['switch_horizon'] = 0;
config['host_nzbget'] = 'http://192.168.1.4:8084';
config['spot_clientid'] = 'api';
config['use_favorites'] = 1;
config['last_update'] = 1;
config['hide_topbar'] = 0;
config['hide_seconds'] = 0;
config['hide_seconds_stationclock'] = 0;
config['use_fahrenheit'] = 0;
config['use_beaufort'] = 0;
config['translate_windspeed'] = 1;
config['static_weathericons'] = 1;
config['hide_mediaplayer'] = 0;
var maps = {}
maps.location = { height: 800, width:12, latitude: 40.4989948, longitude: -3.6610076, zoom:15 }
var frames = {}
frames.weather = {height:526,frameurl:"https://gadgets.buienradar.nl/gadget/zoommap/?lat=40.4165&lng=-3.70256&overname=2&zoom=11&naam=madrid&size=3&voor=0",width:12}
frames.floorplan = {height:800,frameurl:"http://davizinho.myvnc.com:8084/#/Floorplans",width:36}
var blocks = {}
blocks['router'] = {} //ROUTER
blocks['router']['width'] = 12;
blocks['router']['type'] = 'blocktitle';
blocks['router']['title'] = 'Router ASUS AC88U'
blocks['nas'] = {} //NAS SYNOLOGY
blocks['nas']['width'] = 12;
blocks['nas']['type'] = 'blocktitle';
blocks['nas']['title'] = 'NAS Synology'
blocks['salon'] = {} //SALON
blocks['salon']['width'] = 12;
blocks['salon']['type'] = 'blocktitle';
blocks['salon']['title'] = 'Salon'
blocks['dormitorio'] = {} //DORMITORIO
blocks['dormitorio']['width'] = 12;
blocks['dormitorio']['type'] = 'blocktitle';
blocks['dormitorio']['title'] = 'Dormitorio'
blocks['mauri'] = {} //MAURI
blocks['mauri']['width'] = 4;
blocks['mauri']['type'] = 'blocktitle';
blocks['mauri']['title'] = 'Mauri'
blocks['bebeto'] = {} //Bebeto
blocks['bebeto']['width'] = 4;
blocks['bebeto']['type'] = 'blocktitle';
blocks['bebeto']['title'] = 'Bebeto'
blocks['frikyroom'] = {} //Frikyroom
blocks['frikyroom']['width'] = 4;
blocks['frikyroom']['type'] = 'blocktitle';
blocks['frikyroom']['title'] = 'Frikyroom'
blocks['terraza'] = {} //Terraza
blocks['terraza']['width'] = 4;
blocks['terraza']['type'] = 'blocktitle';
blocks['terraza']['title'] = 'Terraza'
blocks['entrada'] = {} //Entrada
blocks['entrada']['width'] = 4;
blocks['entrada']['type'] = 'blocktitle';
blocks['entrada']['title'] = 'Entrada'
blocks['pasillo'] = {} //Pasillo
blocks['pasillo']['width'] = 4;
blocks['pasillo']['type'] = 'blocktitle';
blocks['pasillo']['title'] = 'Pasillo'
var columns = {}
columns['bar'] = {}
columns[1] = {}
columns[1]['blocks'] = ['currentweather_big','weather',frames.weather]
columns[1]['width'] = 4;
columns[2] = {}
columns[2]['blocks'] = ['spotify']
columns[2]['width'] = 4;
columns[3] = {}
columns[3]['blocks'] = [maps.location]
columns[3]['width'] = 4;
columns[4] = {}
columns[4]['blocks'] = [frames.floorplan]
columns[4]['width'] = 12;
columns[5] = {}
columns[5]['blocks'] = ['spotify']
columns[5]['width'] = 4;
columns[6] = {}
columns[6]['blocks'] = [maps.location]
columns[6]['width'] = 4;
columns[4] = {}
columns[4]['blocks'] = [buttons.buienradar,'sunrise','spotify',buttons.nos,buttons.tweakers,buttons.nunl]
columns[4]['width'] = 2;
columns[5] = {}
columns[5]['blocks'] = [buttons.domoticz,'sunrise']
columns[5]['width'] = 2;
columns[6] = {}
columns[6]['blocks'] = ['traffic','train',maps.sonenbreugel]
columns[6]['width'] = 5;
columns[7] = {} //SALON
columns[7]['blocks'] = ['salon',95,17,7,7,'18_2',4,33,47,27,'mauri',66,64,63,65,62,'bebeto']
columns[7]['width'] = 4;
columns[8] = {} //DORMITORIO y FRIKYROOM
columns[8]['blocks'] = ['dormitorio',96,14,31,40,'15_2',38,6,'frikyroom',97,48,51,49]
columns[8]['width'] = 4;
columns[9] = {} //TERRAZA Y ENTRADA Y PASILLO
columns[9]['blocks'] = ['terraza',1,12,29,'2_2',39,45,29,'entrada',10,35,'pasillo',20,23,21]
columns[9]['width'] = 4;
columns[10] = {} //ROUTER
columns[10]['blocks'] = ['router',89,67,68,71,70,69]
columns[10]['width'] = 4;
columns[11] = {} //NAS
columns[11]['blocks'] = ['nas',72,77,78,73,90,85,74,91,86,75,92,87,76,93,88]
columns[11]['width'] = 4;
columns[13] = {}
columns[13]['blocks'] = ['log','news_1','news_2']
columns[13]['width'] = 5;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
var screens = {}
screens['default'] = {}
screens['default']['maxwidth'] = 1920;
screens['default']['maxheight'] = 1080;
screens['default'][1] = {}
screens['default'][1]['background'] = 'bg9.jpg';
screens['default'][1]['columns'] = [1,2,3]
screens['default'][2] = {}
screens['default'][2]['background'] = 'bg9.jpg';
screens['default'][2]['columns'] = [4]
screens['default'][3] = {}
screens['default'][3]['background'] = 'bg9.jpg';
screens['default'][3]['columns'] = [7,8,9]
screens['default'][4] = {}
screens['default'][4]['background'] = 'bg9.jpg';
screens['default'][4]['columns'] = [10,11,12]
screens['tablet'] = {}
screens['tablet']['maxwidth'] = 1024;
screens['tablet']['maxheight'] = 768;
screens['tablet'][1] = {}
screens['tablet'][1]['background'] = 'bg9.jpg';
screens['tablet'][1]['columns'] = [1]
screens['tablet'][2] = {}
screens['tablet'][2]['background'] = 'bg9.jpg';
screens['tablet'][2]['columns'] = [2]
thanks a lot
