Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
84dasilva
Re: Python Plugin: Domoticz-TinyTUYA-Plugin (Cloud)
Post by 84dasilva »
Xenomes wrote: Thursday 11 September 2025 21:19
waltervl wrote: Thursday 11 September 2025 21:16 @Xenomes: for the dehumify setting perhaps use the new setpoint device (based on thermostat) where you can configure min- ,max value, step size etc
Thanks, I didn't try that, I'll check it out.
Edit: Changed the device to the new thermostat with a water image and a humidity symbol.
Thanks! Its now working, great!
In case you get bored :mrgreen: , perhaps these could also be added.
countdown_set;
filter_reset;
filter_life;
runtime_total_reset;
type_of_equipment; suspect to be the total runtime counter.
Xenomes
Domoticz version: 2025.2
Post by Xenomes »
84dasilva wrote: Friday 12 September 2025 21:12 Thanks! Its now working, great!
countdown_set;
filter_reset;
filter_life;
Good to hear!
Never bored with home automation in place. :lol:
countdown_set; not needed; you can control it with the Domoticz Timer.
filter_reset;
filter_life;
type_of_equipment;
These four are added.
HP T630 (256GB SSD/8GB Mem) - Ubuntu 24.04.3 LTS (64Bit) - Domoticz 2025.2 (Docker) Machinon theme - RFLink - KaKu - Sonoff - Tasmota - Shelly - MQTT2Zigbee - OpenTherm Gateway - Tinytuya - IR Blaster - P1 Smart Meter - NPN Watermeter - Google Assistant
84dasilva
Post by 84dasilva »
Xenomes wrote: Saturday 13 September 2025 11:24 Never bored with home automation in place. :lol:
filter_reset;
filter_life;
type_of_equipment;
Great! Enjoy the coffees! :mrgreen:
ronalddevos
Domoticz version: 2025.1
Post by ronalddevos »
Love this plugin! Has been running flawlesly for a while. Just updated to 2.2.8e with TinyTuyaVersion:1.17.4 and now have a problem.
It runs OK for a while and after about 10 minutes I get the following error:
Error: TinyTuya: onCommand ERROR: HTTPSConnectionPool(host='openapi.tuyaeu.com', port=443): Max retries exceeded with url: /v1.0/iot-03/devices/bf58f96d002fcb03beswmt/commands (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x071A9418>: Failed to establish a new connection: [WinError 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond'))
and
Error: TinyTuya hardware (16) thread seems to have ended unexpectedly
and the plugin is unresponsive. I am at a loss... Any suggestions?
Xenomes
Post by Xenomes »
ronalddevos wrote: Sunday 21 September 2025 10:37 Love this plugin! Has been running flawlesly for a while. Just updated to 2.2.8e with TinyTuyaVersion:1.17.4 and now have a problem.
and
Looks like there is a issue with TinyTuya version:1.17.4 you can try to downgrade the version.
sudo pip install tinytuya==1.17.3
ronalddevos
Xenomes wrote: Sunday 21 September 2025 19:59
and
Thanks! - done, i will monitor the result and report back.
ronalddevos
ronalddevos wrote: Monday 22 September 2025 8:48
and
It has been working flawlesly for hours (i have been flicking switches) then on flicking a switch I get:
Error: TinyTuya: onCommand ERROR: HTTPSConnectionPool(host='openapi.tuyaeu.com', port=443): Max retries exceeded with url: /v1.0/iot-03/devices/bf58f96d002fcb03beswmt/commands (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x040996E8>: Failed to establish a new connection: [WinError 10060] A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond'))
I restarted the plugin, eberything freezes for some 30 seconds and I get:
2025-09-22 16:36:52.310 Error: TinyTuya: Devices dictionary null or not valid in 'FindDevice'.
2025-09-22 16:36:52.311 Error: TinyTuya: Devices dictionary null or not valid in 'FindDevice'.
2025-09-22 16:36:52.311 Error: TinyTuya: Call to function 'onCommand' failed, exception details:
2025-09-22 16:36:52.317 Error: TinyTuya: Traceback (most recent call last):
2025-09-22 16:36:52.318 Error: TinyTuya: File "C:\Program Files (x86)\Domoticz\plugins\Domoticz-TinyTUYA-Plugin\plugin.py", line 967, in onCommand
2025-09-22 16:36:52.318 Error: TinyTuya: _plugin.onCommand(DeviceID, Unit, Command, Level, Color)
2025-09-22 16:36:52.319 Error: TinyTuya: File "C:\Program Files (x86)\Domoticz\plugins\Domoticz-TinyTUYA-Plugin\plugin.py", line 130, in onCommand
2025-09-22 16:36:52.320 Error: TinyTuya: dev = Devices[DeviceID].Units[Unit]
2025-09-22 16:36:52.320 Error: TinyTuya: NameError: name 'Devices' is not defined
After that things work fine again.
Any information I can collect for you?
Xenomes
Post by Xenomes »
ronalddevos wrote: Monday 22 September 2025 17:09 It has been working flawlesly for hours (i have been flicking switches) then on flicking a switch I get:
What is you 'API Polling interval' and how much devices do you have?
ronalddevos
Xenomes wrote: Tuesday 23 September 2025 21:52
API Polling interval is set to 15 minutes.
I have 31 physical Tuya devices in the network , obviously logicals (Sensor gives T, H and T&H, plug gets W, V, mA, etc) about 90
Xenomes
Post by Xenomes »
ronalddevos wrote: Wednesday 24 September 2025 7:54 API Polling interval is set to 15 minutes.
Okay that are a lot devices! on 15min don't think you are hitting the limit. Do you have a test system?
ronalddevos
Xenomes wrote: Wednesday 24 September 2025 21:25
No test system. There are a number of devices though that I use for testing - I can remove those, about 5 I think. Would that help?
I do have a few Pi's floating about and can set up a test system if that helps.
ronalddevos
ronalddevos wrote: Thursday 25 September 2025 9:24
Removed 7 (test) devices = wait and see...
Xenomes
Post by Xenomes »
ronalddevos wrote: Thursday 25 September 2025 9:24 No test system. There are a number of devices though that I use for testing - I can remove those, about 5 I think. Would that help?
Okay, I have another version of the plugin that uses Pulsar a different type of communication.
ronalddevos wrote: Thursday 25 September 2025 9:46 Removed 7 (test) devices = wait and see...
I am curious about the result.
ronalddevos
Xenomes wrote: Thursday 25 September 2025 21:32
It is still happening every now and then (twice in the last 24 hours) . It seems to have to do when I flick a switch under certain conditions and I don't know what these conditions are - can't reproduce it at will.
Where do I find the other plugin? Tried 'git pull' but 'already up to date'
Oh, and thanks for your help, btw!
Xenomes
Post by Xenomes »
ronalddevos wrote: Friday 26 September 2025 8:44 It is still happening every now and then (twice in the last 24 hours) . It seems to have to do when I flick a switch under certain conditions and I don't know what these conditions are - can't reproduce it at will.
I hope you can reproduce it, i have only one device. 😅
ronalddevos wrote: Where do I find the other plugin? Tried 'git pull' but 'already up to date'
For the readme... change to pulsar.
Schermafdruk van 2025-09-26 19-22-31.png (22.69 KiB) Viewed 167 times
In the plugin folder
git checkout pulsar
Restart Domoticz
To revert
git checkout Master
ronalddevos wrote: Oh, and thanks for your help, btw!
No, problem there is the community for.
ronalddevos
Xenomes wrote: Friday 26 September 2025 19:30
git checkout pulsar
Restart Domoticz
To revert
git checkout Master
Done! I'll monitor...
Xenomes
Post by Xenomes »
ronalddevos wrote: Saturday 27 September 2025 8:25 Done! I'll monitor...
Nice, hopefully all device are controlled correctly, Internal the code is simplified. Don´t forget to change the setting in the plugin to pulsar.
ronalddevos
Xenomes wrote: Saturday 27 September 2025 9:15
It is working fine, I just the occasional:
2025-09-27 15:33:53.215 Error: TinyTuya: handleThread: Credentials are incorrect or tuya subscription has expired! line 1217
2025-09-27 15:35:21.511 Error: TinyTuya: handleThread: Credentials are incorrect or tuya subscription has expired! line 1217
2025-09-27 15:36:22.974 Error: TinyTuya hardware (16) thread seems to have ended unexpectedly
2025-09-27 15:36:24.639 Error: TinyTuya: handleThread: Credentials are incorrect or tuya subscription has expired! line 1217
2025-09-27 15:37:27.770 Error: TinyTuya: handleThread: Credentials are incorrect or tuya subscription has expired! line 1217
2025-09-27 15:38:29.223 Error: TinyTuya hardware (16) thread seems to have ended unexpectedly
2025-09-27 15:38:30.899 Error: TinyTuya: handleThread: Credentials are incorrect or tuya subscription has expired! line 1217
but is still seems to work
Response time seems slower though (not an issue)
Xenomes
Post by Xenomes »
ronalddevos wrote: Saturday 27 September 2025 16:16 but is still seems to work
Can you set de debug to python, and report the data in the error lines.
ronalddevos wrote: Saturday 27 September 2025 16:16 Response time seems slower though (not an issue)
Should be faster, no 15 min wait until status change.
ronalddevos
Xenomes wrote: Saturday 27 September 2025 16:31
Is that the debug in the plugin config page?
