Page 15 of 16
Re: Python Plugin: GoodWe solar inverter via SEMS API
Posted: Saturday 26 September 2026 12:06
by RNEE
@jan-jaap : update runs now ! Thank you !
Posted: Saturday 26 September 2026 13:41
by Jeweettoch13
Awesome Work Jan-jaap!
It seems though that the data is coming trough is not what Domoticz expect it to be:
- Error.jpg (88.18 KiB) Viewed 346 times
I've reset the value but am not sure if im missing 3 days of generated power. Ill investigate further.
Posted: Saturday 26 September 2026 14:23
by Jeweettoch13
Also:
1 of 2 MPP-trackers is going to zero occasionally but they are working both as well in domoticz. Current output value is also none.
- Error.jpg (231.36 KiB) Viewed 338 times
Posted: Saturday 26 September 2026 16:39
by RNEE
I have the same problem in my dzVents script.
i think Goodwe now delivers sometimes nil- values, so domoticz calculaties te difference.
i think we need an otter variable witch always holds the cummelative total values.
Regarding time-out errors : the token has a live of 60 minuten, so it does not have to be renewed every time. Goodwe says renew every 50 minuts.
Posted: Saturday 26 September 2026 21:03
by Jeweettoch13
Fair enough
In the fixed script no output current comes with the data. Could this be addressed?
Posted: Sunday 27 September 2026 10:02
by Jeweettoch13
Jeweettoch13 wrote: Saturday 26 September 2026 13:41
*update:
The total generated values as of 2020 comes with the total generated daily output (even after resetting the graphs from yesterday. Could this be a bug?
- Error.jpg (31.14 KiB) Viewed 268 times
Posted: Sunday 27 September 2026 12:45
by RNEE
Very strange; one moment it shows the correct daily value, and the next, the total quantity produced appears as a negative figure.
Posted: Sunday 27 September 2026 12:52
by RNEE
Jeweettoch13 wrote: Saturday 26 September 2026 21:03
Fair enough
My dzVents script (seen here) only is capable of retrieving total and temperature, i can't find detail info on the api.
Anybody more info about the new Goodwe API?
Posted: Sunday 27 September 2026 13:07
by waltervl
It works now again but it has some strange results.
It seems it sometimes sends values with factor 1000 (Wh -KWh) too much.
The totals for the day are correct so not sure what is going on here. The red bar is because of the few days of errors and not counting.
- Screenshot_20260927-130102_Chrome.jpg (164.28 KiB) Viewed 243 times
Posted: Sunday 27 September 2026 15:26
by RNEE
@waltervl :
Nice earrnings
Posted: Monday 28 September 2026 13:54
by RNEE
For those interested : i completed a dzVents script with fills all data i had before for 2 strings.
This is not an easy to use tool like the python plug-in from Jan-jaap. You have to set up some things manually.
It is still a work in progress but now it suits my needs.
You can find my script here :
https://github.com/RneeJ/Domoticz-Goodwe-SEMSPLUS
Posted: Monday 28 September 2026 19:36
by waltervl
waltervl wrote: Sunday 27 September 2026 13:07
I made a github issue for this as the plugin resets the counter due to receiving partial values from the portal.
https://github.com/JanJaapKo/domoticz-G ... /issues/38
Posted: Monday 28 September 2026 20:10
by JanJaap
Plugin also support reading individual strings? What do you miss in the plugin that you prefer the DzVents script?
Posted: Monday 28 September 2026 20:11
by Jeweettoch13
waltervl wrote: Monday 28 September 2026 19:36
Cant wait to try it out, unfortunately the sun is letting us down lol.
Is this fix so that the total generated output will no longer comes trough on the daily value?
- error1.jpg (97.84 KiB) Viewed 121 times
Is this fix also to get the PV AC output back? Cant get this one to work since..
- error2.jpg (269.65 KiB) Viewed 121 times
Posted: Monday 28 September 2026 20:59
by RNEE
JanJaap wrote: Monday 28 September 2026 20:10
Your plugin is great, please keep up the good work. I miss nothing in it and i will use it again if the data come in nicely.
And yes the script scans for different strings within the inverter and gets its individual data !
This dzVents script was a learning process for me. I had an life error and testing situation on hand and some time available.
I want to be able to make more scripts in dzVents but lack knowledge and experience.
I used several AI but ended up with Claude witch worked very very well.
Posted: Monday 28 September 2026 22:06
by JanJaap
Jeweettoch13 wrote: Monday 28 September 2026 20:11
Yes it fixes the spikes in the generated energy
I did not check all the devices. Which one is now missing? The output current?
Posted: Monday 28 September 2026 22:13
by JanJaap
So the spikes in daily energy generation should be gone. You'd need to clean up the data manually though. The UI should allow you by <shift> click on th egraph to remove the bvalue, but for me it doesn't clean up the data so I'll go for the more 'you need to know what you're doing' route of manually altering the database.....
Posted: Tuesday 29 September 2026 10:58
by RNEE
JanJaap wrote: Monday 28 September 2026 22:13
I cleaned up some data and updated the plugin, disabled my dzVent-script , restarted Domoticz.
But i still have new large data spikes in history, any body else same problems ?
Posted: Tuesday 29 September 2026 11:45
by JanJaap
For me energy data for today looks as expected, no spikes:
- Screenshot 2026-09-29 114336.png (72.75 KiB) Viewed 42 times
Whereas earlier it was spikes all over (did not clean up yet):
- Screenshot 2026-09-29 114525.png (62.4 KiB) Viewed 42 times
Posted: Tuesday 29 September 2026 13:15
by RNEE
i manually cleaned up domoticz.db , it seems that the rolling total according tot the SEMS website is lower than the older total value in domoticz.db.
This gives negative values.
Very strange.
Today's value look good now and i will investigate further, maybe enter history data manualy.
