Page 15 of 17
Re: Alexicz - FREE Domoticz to Alexa Integration
Posted: Monday 22 February 2021 12:33
by kitopopo
philchillbill wrote: Monday 22 February 2021 12:11
kitopopo wrote: Monday 22 February 2021 11:08
I changed https by http in configdz-template.json or configdz.json in "url"
https://myexternalip was replaced by "url"
http://myexternalip.
making this change alexa works with my domoticz perfectly but I am afraid of security problems, either because I use http or because I give my username, password, public ip and port in that configuration file. I am giving all my data.
Do you think it is safer if I use https? Besides this, is it not dangerous to put all my data in that file? thanks in advance
Aha, that's allowed because you are not publishing the skill and it's for personal use only in your dev-account. It's a very bad idea though, as your Domoticz is fully exposed with no protection. It's not 'if' you will be hacked, but 'when'...
You already have an external IP address, right? Have you tried getting an SSL cert for it from LetsEncrypt?
Thanks for your answer,
No, I should start using the LetsEncrypt certificates as soon as possible. But even so, do you think it does not bring any security risk to give the public ip, port, user and password even if the LetsEncrypt certificates are used and it is via https?
this is my doubt, leave alexa running permanently delivering all my data.
thanks in advanced
Posted: Monday 22 February 2021 13:07
by philchillbill
kitopopo wrote:philchillbill wrote: Monday 22 February 2021 12:11
thanks in advanced
When https, everything is safe. The data cannot be intercepted.
Posted: Monday 22 February 2021 13:45
by kitopopo
philchillbill wrote: Monday 22 February 2021 13:07
thanks in advanced
But amazon aws have my data, public ip, password and port.
Posted: Monday 22 February 2021 14:15
by philchillbill
kitopopo wrote:philchillbill wrote: Monday 22 February 2021 13:07
thanks in advanced
I wouldn’t worry about that. It’s encrypted in storage. Same as any cloud storage.
Posted: Wednesday 08 December 2021 20:01
by andromo
I have been using alexicz for a while. It is very nice. I don't like to have a open port at home, so I added port knocking to the api() function in the lambda, so before adressing the domoticz port it knocks 3 different ports in the correct order. I dont't know much about python, but now it's working. My firewall (mikrotik router) has input firewall rules for acepting connections only from IPs that did the correct port knocking combination, and Alexicz is doing it right now (
https://wiki.mikrotik.com/wiki/Port_Knocking)
By the way, I'm trying to control an AC split with an ESP8266 board and IR LEDs. Now I have a thermostat setpoint that can be cofigured with Alexa with no problem. But I want to change de mode also (HEAT, COOL). I have seen in the Alexicz code that if you set an ligth/switch selector with Alexa_extra:{ "OFF": 0, "HEAT": 10, "COOL":20} It should work, but I really don't know what I'm doing, and alexa says there is a problem with the discovered thermostat (from the Selector switch configured with alexa_extra).
Can some one who use or know about this feature help me please?
Andrés
Posted: Thursday 09 December 2021 10:29
by andromo
I have seen that in my domoticz version, "LevelNames" are base64 encoded, I have managed this, but the Thermostat selector is still not working at all... any clues?
andromo wrote: Wednesday 08 December 2021 20:01
Andrés
Posted: Thursday 09 December 2021 10:48
by tarmacalastair
Silly question but I assume you have checked that the setpoints are working via a browser?
Since I upgraded from Domoticz 2020.2 to 2021.1 I have had no end of problems with my thermostat setpoints. Everything was working fine in 2020.2 and no one seems to have a solution. I've been told to clear browser cache, change from ZWave to zwavejs2mqtt. I've done both of these things on completely fresh installs of Domoticz and no progress so far. The swap from Zwave to zwavejs2mqtt causes the setpoints to behave exactly the same.
(See my postings at
viewtopic.php?f=6&t=34838 and
viewtopic.php?f=6&t=37456)
Apologies if you've already checked they are working through the browser interface...
Posted: Thursday 09 December 2021 11:22
by andromo
Thank you for your answer tarmacalastair.
The set point is working rigth for my needs. I am using it from amazon Alexa voice commands. What I can't make work is the thermostat selector device that is defined in the Alexicz skill.
Now I have a virtual switch to switch on/off AC and a virtual thermostat to set the target temperature. Both are working from alexa interface.
I want to set mode of the thermostat to COOL or HEAT, I see that this is managed throught a switch selector in alexicz skill, but is not working for me. Thats why I ask help from someone that use that feature or understand how it works...
Thanks!!!
Posted: Friday 15 April 2022 16:11
by binbo
I have just been told that Python 3.6 is being dropped on AWS.
You’ve got to upgrade to 3.9
Is Alexicz compatible with this version of Python?
Posted: Friday 15 April 2022 17:48
by fibigod
Same here, don’t know if it is compatible, there are always some issues when upgrading.
AWS will support the current version, but doesn’t gives any support and you cannot make new lambda’s with that python version.
So if nothing changes, you don’t have to upgrade the scripts.
Posted: Monday 16 May 2022 16:20
by Jorn
I've set up Alexicz successfully lasty week, the only strange thing than I'm heaving is when using scene's/groups, when I tell Alexa to activate a scene it responds with "I'm having trouble reacing null" but the scene is activated, so it's only the response that is faulty.
Is this a known issue?
Posted: Thursday 19 May 2022 10:47
by vco1
Jorn wrote: Monday 16 May 2022 16:20
Same issue here.
Also the question re. an upgrade of the Python version.
Posted: Thursday 19 May 2022 12:38
by tarmacalastair
Still hoping someone might be able to post some up to date instructions on how to set this up. I tried a year or so back and Amazon had changed so many steps that it didn't make sense to me and I gave up.
It would be lovely if someone (who understands) could spare a few minutes to update the instructions.
Thanks.
Posted: Tuesday 19 July 2022 14:57
by marco92120
Hello Python 3.9 runtime update worked fine for me.
What I've done :
1/ Logon AWS console and go on functions :
https://eu-west-1.console.aws.amazon.co ... /functions
2/ Select Alexicz function by clicking on it
3/ At page bottom in "Runtime Settings" section select Edit on the right
4/ Select Python 3.9 in runtime popup menu
5/ Click save
You're done. On my side I got no errors or side effects for all my switches and thermometer.
If something goes wrong for you, probably selecting python 3.6 in "Other supported" should bring you back to previous state
Posted: Sunday 24 July 2022 19:12
by Jpaul78
First, sorry for my English (I am french, professionally retired and don't practise English anymore).
I am trying to make alexicz skill working.
From the test console, using the test json exemples :
It retrieves my devices.
I can make one of the lights on and off.
But when I am on my android phone I can't discover the devices.
I guess that, as I was confused on the Account Linking step and don't complete it, it could be the reason.
I finish by seeing the "
https://layla.amazon.com/api/skill/link/xxxxxxx" part at the end of the configuration page and now I have an error telling :
Instance at property path "$.accountLinkingRequest.scopes" is expected to be present when instance at property path "$.manifest.apis.smartHome" is present.
I don't understand that message. Can any one help me ? Thanks in advance.
Jean-Paul
Posted: Friday 02 December 2022 17:16
by Jpaul78
Hello all,
I finished to solve my problem selecting the right location in the console page and create again my lambda. So it was working but now I have a new problem...
When I ask :
"Alexa allume la chambre." (for : "Alexa turns on the bedroom.")
I have a reply telling :
"L'appareil chambre ne répond pas." (means : "Room device not responding.")
What is following is a Google translation :
The problem appeared after a previous socket failed and I replaced it with a new one. So I deleted the old socket in domoticz connected the new one. Checked it was OK with domoticz then reloaded the devices on alexa. Device rediscovery told me that it found a new device that I installed but when I ask to turn it on I have the problem telling that the device is not responding.
The other devices were working. I deleted all my devices on Alexa, asked again for device updates, Alexa found them all but none of them worked, I got the message that the device is not responding.
Am I alone to encounter this problem ?
Does anyone have a solution to this problem ?
Thanks in advance,
Jean-Paul
Posted: Sunday 04 December 2022 14:10
by philchillbill
Jpaul78 wrote:Hello all,
When I ask :
Thanks in advance,
Jean-Paul
If you visit the Amazon Cloudwatch log for your Alexicz you will see the error message in the logs. Google how to access Cloudwatch.
Posted: Monday 05 December 2022 15:21
by Jpaul78
Just for information in case someone encounters the same problem : everything went back to normal after a few days without changing anything.
Regards,
Jean-Paul
Posted: Monday 05 December 2022 15:27
by Jpaul78
philchillbill wrote: Sunday 04 December 2022 14:10
I just see your reply now, thanks a lot for it. I will look at that Amazon Cloudwatch if I have some problem again in the future.
Best regards,
Jean-Paul
Posted: Thursday 22 December 2022 17:13
by xavierlp
Hello all,
As you maybe know, Controlicz will be discontinued at the end of 2023.
So I would like to have a look on Alexicz. I could discover that the project is not supported.
I followed to How to , and I can not discover my devices.
If I made a test on AWS console I've got this error
"errorMessage": "'directive'",
"errorType": "KeyError",
"requestId": "b72988b4-04c0-4fe0-bbbd-9464317feebe",
"stackTrace": [
" File \"/var/task/lambda.py\", line 49, in event_handler\n response = AlexaSmartHome.handle_message(dzRemote, request)\n",
" File \"/var/task/AlexaSmartHome.py\", line 320, in handle_message\n message = message[API_DIRECTIVE]\n"
the code is
dzRemote = DomoticzHandler.Domoticz(config.url, config.username, config.password)
dzRemote.configure(config)
The 3 variables are correct - I use the same with contrloicz without issues.
Have you got any ideas on how I can troubleshoot this error.
Thanks a lot
