Page 15 of 24
Re: Aurora theme
Posted: Thursday 22 February 2018 22:06
by olinek2
Do you have any idea why Utility sections and Switches looks like this?
Re: Aurora theme
Posted: Friday 23 February 2018 13:20
by blauwebuis
@Xztraz: thanks!
@Olinek2: I have no idea. Have you cleared your application cache? tried different browsers? What device are you on?
UPDATE
BUGFIX
I've added a fix for the RGBW popup, which was recently changed in Domoticz.
NEW FEATURE
If the value of a text item is a URL, then the theme will automatically turn it into an iframe. This allows you to incorporate external sources into your dashboard, like weather and news feeds.
To try it:
- Create a dummy text item.
- On the Utilities page, click on the text and input a URL.
- Go to the dashboard and enjoy your iFrame.
Re: Aurora theme
Posted: Friday 23 February 2018 20:55
by Xztraz
iframe. where do you enter the url? as the name of the device, description or as the data?
Re: Aurora theme
Posted: Saturday 24 February 2018 8:24
by remb0
blauwebuis great work! I gonna test the iframes!
Re: Aurora theme
Posted: Saturday 24 February 2018 9:03
by blauwebuis
@Xztraz: click on the text. Just try it, you'll find it.
Aurora theme
Posted: Saturday 24 February 2018 9:55
by bdormael
Just a suggestion:
Would it be possible to have the highlighted items to be independent from the columns?
For example I want my cameras to show in the most right columns, now this is not possible because it is only showing utilities.
Verzonden vanaf mijn iPad met Tapatalk
Re: Aurora theme
Posted: Saturday 24 February 2018 11:04
by Xztraz
blauwebuis wrote: Saturday 24 February 2018 9:03
i guess its the hello world text? do you have an example of some site that should work in iframe? tried all different fields but only get an icon
Re: Aurora theme
Posted: Saturday 24 February 2018 11:09
by bdormael
Xztraz wrote: Saturday 24 February 2018 11:04
https://w.bookcdn.com/weather/picture/1 ... c_id=14924
Re: Aurora theme
Posted: Saturday 24 February 2018 11:11
by Xztraz
This works: (adress in data field)
- iframe.PNG (5.78 KiB) Viewed 4207 times
- veckaiframe.PNG (12.31 KiB) Viewed 4207 times
Awesome!
Re: Aurora theme
Posted: Saturday 24 February 2018 11:33
by blauwebuis
@bdormael: the items position and and order is linked to their containers/type. Technically it would be possible to 'fish out' some items and store their ID in a user variable. And then always load these items into the special "highlighted" container when the page is built. Not a bad idea. But in a way you're then creating a system where you can make favourites inside your favourites
Re: Aurora theme
Posted: Saturday 24 February 2018 13:17
by hsvt
First, thank for the beautiful project.
After some time domoticz picked up again and then his change.
My IP webcam (old phone) also works in the Iframe way.
Now only find out how I can adjust the resolution of this with the url.
Re: Aurora theme
Posted: Sunday 25 February 2018 11:43
by rhendriks
@ blauwe buis compliments for this theme.
Is it possible to make an update button in the menu for an update from the aurora-theme ,
instead of the git pull rule in putty.
Re: Aurora theme
Posted: Sunday 25 February 2018 13:49
by Xztraz
workaround for update if you are that lazy
make a shell script under scripts/update_aurora.sh
fill it with(this is for rpi):
#!/bin/sh
cd /home/pi/domoticz/www/styles/aurora
git pull
chmod +x
call script from dummy button.
script://update_aurora.sh
Re: Aurora theme
Posted: Sunday 25 February 2018 15:10
by Eoreh
Domoticz Version: 3.8946
I update today to this version beta domoticz, and we lost button "Theme" in settings.
I also check in new version Aurora the same problem.
Of course i clear all cache.
EDIT: becouse jquery in domoticz upgrade to ->jquery-3.3.1.min.js
and from version jquery 3.0 .andSelf() removed, and we have to use .addBack() in line 1951 in custom.js
- eg23.png (58.83 KiB) Viewed 4089 times
Re: Aurora theme
Posted: Sunday 25 February 2018 15:58
by Xztraz
tested replacing what you said. seem to work. and made a pull request
Re: Aurora theme
Posted: Sunday 25 February 2018 20:48
by Xztraz
Should be fixed now. please test
Also added more viz for more sensors(even more coming)
Re: Aurora theme
Posted: Sunday 25 February 2018 21:25
by Xztraz
fixed viz for negative temps (on pull request now)
Re: Aurora theme
Posted: Sunday 25 February 2018 22:14
by blauwebuis
Merged. Thanks for the great contribution!
UPDATE
- Theme settings button is back.
- More devices and sensor types now support data visualization on the dashboard.
- Negative temperatures are now also shown in these visualizations.
Re: Aurora theme
Posted: Sunday 25 February 2018 22:26
by Xztraz
I do what i can
thanks for a great theme!
Added the last of viz sensors. phu. takes 6 datapoints before any viz shows. can be good to know
Re: Aurora theme
Posted: Monday 26 February 2018 12:59
by olinek2
Update of Domoticz and plugin has solved issue
