Page 15 of 114
Posted: Tuesday 12 December 2017 22:29
by stefanjongerius
Dear Madgeni,
I face a challenge adding test Home Controlicz in GH...I allow the full-access but then Google says, after trying to link, it couldn't update the service and I need to check my connection. Any ideas?
Posted: Tuesday 12 December 2017 22:54
by Madgeni
stefanjongerius wrote: Tuesday 12 December 2017 22:29
Dear Madgeni,
sure - you just need to use https - i think the port you've given Controlicz is your http port
Posted: Wednesday 13 December 2017 10:06
by sly14
Hello Madgeni, i will be happy to test and use controlicz,
[email protected]
Posted: Wednesday 13 December 2017 16:38
by stress1ner
Hey Madgeni I cant find the controlicz app in google home/smarthome, is there anything else i have to do to make it show up.
acole****
[email protected]
Posted: Wednesday 13 December 2017 18:07
by Madgeni
if you've enabled it in the simulator, then it should show up?
Posted: Wednesday 13 December 2017 22:30
by stefanjongerius
Hi Madgeni,
I now have changed the port in controlicz, this is the https port for Synology (
https://MYID.synology.me and then credentials then you reach DSM), I have been able to install Let's Encrypt certificate. However I do not know how to reach domoticz in https, which is still available in http. Is there any way to fwd in DSM to Domoticz? E.g. the tutorials available did not solved the issue yet.
It might be out of your ballpark but who knows...
Posted: Thursday 14 December 2017 3:39
by stress1ner
Hey Madgeni can you ad king**
[email protected] to the beta please.
Posted: Thursday 14 December 2017 8:19
by Pwiiikkk
Hi, I registered controlicz as gaec****@gmail.com could you add me. Thanks.
Posted: Thursday 14 December 2017 8:45
by Noka
First a big thanks for your work Madgeni !
I subscribe to Controlicz and I work "hard" for make it work but nothing appear on my home app.
Do you have maybe just a simple tutorial how to make it work?
Thanks in advance for your work
Posted: Thursday 14 December 2017 11:19
by bldewit
Hi Madgeni,
I am running into some funky stuff here.
Initially I had problems getting connected to the service in GH. Finally, after adding a fresh new user in Domoticz, I had it up and running.
I used it for several days and I must say, it worked like a charm. Kudos for that! I noticed however that some of the names of my devices were not so practical (dutch names in an English Google Home) so I added some names in description fields.
Queriïng devices did not trigger the names to be added to my Google Home, so I went into the GH app and unlinked the Controlicz service. I then tried to link it agein, with the same credentials, and I got an error saying that my settings cannot be updated, please check your connection.
So, learning from my first experience, I added a new, fresh user and changed the settings on the Controlicz webpage. Same result!
Now, no matter what I do, I always get the same errormessage, using the newest credentials or the credentials that worked before!
Any suggestions?
Unm is blde.....com
Posted: Thursday 14 December 2017 11:45
by quirk
I also have problems with Controlicz settings and my Domoticz setup, so it would be nice to have a button on the Controlicz profile page to test and check connection between Controlicz and Domoticz
Posted: Thursday 14 December 2017 12:12
by Madgeni
urgh - I can look to add it, but honestly, this isn't the issue with bldewit - i can see the sync requests being made, and the responses back are fine. The Google apps are just, well, shit. They really don't respond well to change. When I first wrote this integration, it NEVER came back with a success at account linking, it just told me there was an error, you had to leave, and go back in.
And respectfully, if you want to change a device name, this just works, and the sync does work in Google (if Google itself is working).
If you change a user on the Domoticz side, as long as it has access to the devices - and those devices are in A room plan (or more than 1), and you're using https, and you can access it externally yourself, you're good to go.
Posted: Thursday 14 December 2017 12:14
by Madgeni
Noka wrote: Thursday 14 December 2017 8:45
The app is *still* in beta (thanks Google) - so you need to let me know who you are
give me a few characters of your email address, and i'll find you
Posted: Thursday 14 December 2017 12:18
by Madgeni
by Madgeni
Pwiiikkk wrote: Thursday 14 December 2017 8:19
done
Posted: Thursday 14 December 2017 13:09
by stress1ner
Hey thanks donation sent 74N23146AL0297534 and for dashbutton help.
Posted: Thursday 14 December 2017 13:12
by Lyrex
Madgeni wrote: Friday 08 December 2017 19:08
Lyrex wrote: Friday 08 December 2017 17:38
Hey Madgeni,
can you leave a message if your selector switch impelentation is finished? Im happy to try it out!
sure thing. as far as I can tell, it's ready, BUT it's with Google, it seems you have to tell them (Seriously) if you want them to include a particular Mode name. I can imagine this not being a quick process..
What do you mean exactly?
Posted: Thursday 14 December 2017 13:32
by Madgeni
pretty much what i put -
https://developers.google.com/actions/s ... aits/modes
the documentation has been cheekily changed since I raised this with them - initially they had "custom names need to be submitted to Google" - now they've put:
"Currently, you must use the names in the example JSON; custom names are not yet supported."
https://github.com/actions-on-google/ac ... /issues/75
Posted: Thursday 14 December 2017 14:18
by Noka
Madgeni wrote: Thursday 14 December 2017 12:14
Ah yes of course
There it is : jmi****.****@gmail.com
Hope it will work !
Thanks again
Posted: Thursday 14 December 2017 14:20
by Madgeni
done! any problems, post in here
