Page 15 of 16
Re: Python plugin: Xiaomi Mi Robot Vacuum
Posted: Thursday 18 June 2020 19:36
by JanvdW
hoeby wrote: Thursday 11 June 2020 21:31
JanvdW wrote: Monday 08 June 2020 23:58
Does no one has an idea how to fix this issue?
Could you check if msgpack is correctly installed?
The error looks to have some connection with that.
Go to the .env environment to check.
When I install the msgpack again I get messages that requirements are already satisfied. I used the following commands:
source .env/bin/activate
pip3 install gevent msgpack-python python-miio==0.3.1
This gives the follwing output
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: gevent in ./.env/lib/python3.7/site-packages (20.5.0)
Requirement already satisfied: msgpack-python in ./.env/lib/python3.7/site-packages (0.5.6)
Requirement already satisfied: python-miio==0.3.1 in ./.env/lib/python3.7/site-packages (0.3.1)
Requirement already satisfied: greenlet>=0.4.14; platform_python_implementation == "CPython" in ./.env/lib/python3.7/site-packages (from gevent) (0.4.15)
Requirement already satisfied: android-backup in ./.env/lib/python3.7/site-packages (from python-miio==0.3.1) (0.1.0)
Requirement already satisfied: attrs in ./.env/lib/python3.7/site-packages (from python-miio==0.3.1) (17.2.0)
Requirement already satisfied: zeroconf in ./.env/lib/python3.7/site-packages (from python-miio==0.3.1) (0.26.2)
Requirement already satisfied: cryptography in ./.env/lib/python3.7/site-packages (from python-miio==0.3.1) (2.1.3)
Requirement already satisfied: typing in ./.env/lib/python3.7/site-packages (from python-miio==0.3.1) (3.7.4.1)
Requirement already satisfied: pytz in ./.env/lib/python3.7/site-packages (from python-miio==0.3.1) (2020.1)
Requirement already satisfied: click in ./.env/lib/python3.7/site-packages (from python-miio==0.3.1) (6.7)
Requirement already satisfied: pretty-cron in ./.env/lib/python3.7/site-packages (from python-miio==0.3.1) (1.2.0)
Requirement already satisfied: construct in ./.env/lib/python3.7/site-packages (from python-miio==0.3.1) (2.8.16)
Requirement already satisfied: pycrypto in ./.env/lib/python3.7/site-packages (from python-miio==0.3.1) (2.6.1)
Requirement already satisfied: ifaddr in ./.env/lib/python3.7/site-packages (from zeroconf->python-miio==0.3.1) (0.1.6)
Requirement already satisfied: six>=1.4.1 in ./.env/lib/python3.7/site-packages (from cryptography->python-miio==0.3.1) (1.11.0)
Requirement already satisfied: cffi>=1.7; platform_python_implementation != "PyPy" in ./.env/lib/python3.7/site-packages (from cryptography->python-miio==0.3.1) (1.11.2)
Requirement already satisfied: asn1crypto>=0.21.0 in ./.env/lib/python3.7/site-packages (from cryptography->python-miio==0.3.1) (0.23.0)
Requirement already satisfied: idna>=2.1 in ./.env/lib/python3.7/site-packages (from cryptography->python-miio==0.3.1) (2.6)
Requirement already satisfied: pycparser in ./.env/lib/python3.7/site-packages (from cffi>=1.7; platform_python_implementation != "PyPy"->cryptography->python-miio==0.3.1) (2.18)
Posted: Thursday 18 June 2020 21:13
by hoeby
Did you use this command line to install the plugin?
If so, i have bad experiance with it. It doesn't install all packages which are needed.
This command line will install much more, but look on page 14, that the pip_req.txt file is changed.
Without changing i kept having issues on OS Buster.
Posted: Thursday 18 June 2020 23:05
by JanvdW
I am not sure if I understood you comment well, but if I run 'pip3 install -r pip_req.txt' in the .env environment I get a long list of error messages (can't even see all messages when I scroll back).
Posted: Friday 19 June 2020 8:11
by hoeby
JanvdW wrote: Thursday 18 June 2020 23:05
If you run the original pip_req.txt file, then you have a lot of errors.
The first time i runned that command with the original pip_req.txt file i also got a lot of red errors messages.
This is the original pip_req.txt, which needs to be changed
android-backup==0.1.0
asn1crypto==0.23.0
attrs==17.2.0
cffi==1.11.2
click==6.7
construct==2.8.16
cryptography==2.1.3
enum-compat==0.0.2
gevent==1.2.2
greenlet==0.4.12
idna==2.6
msgpack-python==0.4.8
netifaces==0.10.6
pretty-cron==1.0.2
pycparser==2.18
pycrypto==2.6.1
python-miio==0.3.1
pytz==2017.3
six==1.11.0
typing==3.6.2
zeroconf==0.19.1
Change it to this and then run the command 'pip3 install -r pip_req.txt' in the .env environment
asn1crypto==0.23.0
attrs==17.2.0
cffi==1.11.2
click==6.7
construct==2.9.31
cryptography==2.1.3
enum-compat==0.0.2
gevent==1.4.0
greenlet==0.4.15
idna==2.6
netifaces==0.10.6
pretty-cron==1.0.2
pycparser==2.18
pycrypto==2.6.1
python-miio==0.4.4
pytz==2017.3
six==1.11.0
typing==3.6.2
zeroconf==0.19.1
Posted: Friday 19 June 2020 13:40
by JanvdW
Thanks; I succeeded to run the command without errors now. Unfortunately the robot still doesn't react when I address him from Domoticz. Then I started the miio server from the console:
sudo ./miio_server.py <ip address> <token id> --host 127.0.0.1 --port 22222
This results in the following output:
server: Starting server on 127.0.0.1 22222
server: connected ('127.0.0.1', 34080)
./miio_server.py:67: DeprecationWarning: encoding is deprecated, Use raw=False instead.
unpacker = Unpacker(encoding='utf-8')
server: got socket msg: ['status']
Got error when receiving: timed out
server: vac result {'exception': 'python-miio: No response from the device', 'cmd': 'status'}
server: send reply ('127.0.0.1', 34080)
The ping result on the robot's ip is positive. I don't understand why the robot gives no response.
Posted: Friday 19 June 2020 17:28
by hoeby
Just to be sure.
Is that first line the exact code you send?
This line
You need to replaced the ip address with the ip address from the vacuum. And token by its token.
An example
sudo ./miio_server.py 192.168.1.12 476e6b70343055483230644c53707a12 --host 127.0.0.1 --port 22222
Posted: Friday 19 June 2020 17:38
by JanvdW
Yes, of course. I used the proper parameters
Posted: Friday 19 June 2020 22:49
by hoeby
Did it worked in the past?
Or is it the first time?
Reason why, is to check if the token is right.
Don't un-install the vacuum in the app and add it again. Then the token will change.
I had some kind of error you had. But don't know if it was exactly the same.
This i had when i first installed with the wrong install line: pip3 install gevent msgpack-python python-miio==0.3.1
After that i cleared the SD and started with a fresh install and now used the modified pip_req.txt file. That went without errors.
Don't know if there is old stuff installed, because you first used to other install line. which gives the error.
further i don't know how to help you.
I am not that great with the codes. Hopefully someone else jumps in.
Posted: Saturday 20 June 2020 23:03
by JanvdW
It worked before, but not in my new Domoticz installation. I am not 100% sure if I reinstalled the app. I didn't thought that the token will change. When I have time I will check the token; I remember that takes some time (with an old version of the app, right?)
Posted: Sunday 21 June 2020 15:12
by hoeby
JanvdW wrote: Saturday 20 June 2020 23:03
When i removed and add the vacuum in the app. Then i get a new token.
There a multi options to get the token.
The old version app is one of them
Posted: Tuesday 14 July 2020 13:25
by Romel
Hi all is this caused by wrong token ?
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ miiocli device --ip 192.168.88.155 --token 5735396c756d554d79614e70496f6577 info
ERROR:miio.device:Got error when receiving: timed out
Error: No response from the device
Iam encountering to this problem:
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ sudo ./miio_server.py 192.168.88.155 5735396C756D554D79614E70496F6577 --host 127.0.0.1 --port 22222
server: connected ('127.0.0.1', 54120)
Retrying with incremented id, retries left: 3
Retrying with incremented id, retries left: 2
Retrying with incremented id, retries left: 1
server: vac result {'exception': 'python-miio: ', 'cmd': 'status'}
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ ping 192.168.88.155
PING 192.168.88.155 (192.168.88.155) 56(84) bytes of data.
64 bytes from 192.168.88.155: icmp_seq=1 ttl=64 time=5.39 ms
64 bytes from 192.168.88.155: icmp_seq=2 ttl=64 time=2.71 ms
64 bytes from 192.168.88.155: icmp_seq=3 ttl=64 time=1.66 ms
no LAN firewall rules
two times I reseted vacuum for new token.
thanks in advance
SOLVED - bad TOKEN from wireshark. after used from Mi Home v 5.4.54 it is working
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ python3 ./test.py
test: python modules path: ././.env/lib/python3.7/site-packages
test: trying connect to 127.0.0.1:22222
test: sent request to server [status]
test: reading response...
test: got server reply {'error': None, 'state_code': 8, 'battery': 100, 'fan_level': 102, 'clean_seconds': 1691, 'clean_area': 31.785, 'cmd': 'status'}
Posted: Tuesday 14 July 2020 20:53
by tjabas
is it possible to get roomcleaning with this plugin?
is it possible to speak to google home and say" clean the livingroom"?
it would be awsome if it was possible.
Posted: Thursday 30 July 2020 10:58
by Hybris03
i just tested the plug-in with my xiaomi mi robot V1.
Everything appears fine in domoticz, but no action works and the levels remain at 0 (battery for example).
I am using the latest stable version of Domoticz.
When I run the following test command, it hangs on: Test: reading response
sudo service miio_server start
sudo chmod +x test.py
sudo ./test.py
Can you give me a hand ?
In the logs I have the following:
2020-07-30 11:57:18.460 (Aspirateur Xiaomi) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2020-07-30 11:57:18.460 (Aspirateur Xiaomi) 'HardwareID':'15'
2020-07-30 11:57:18.460 (Aspirateur Xiaomi) 'HomeFolder':'/home/pi/domoticz/plugins/xiaomi-mirobot/'
2020-07-30 11:57:18.460 (Aspirateur Xiaomi) 'StartupFolder':'/home/pi/domoticz/'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'UserDataFolder':'/home/pi/domoticz/'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'Database':'/home/pi/domoticz/domoticz.db'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'Language':'fr'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'Version':'0.1.3'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'Author':'mrin'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'Name':'Aspirateur Xiaomi'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'Port':'0'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'Key':'xiaomi-mi-robot-vacuum'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'Mode2':'15'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'Mode4':'Debug'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'Mode5':'selector'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'Mode6':'127.0.0.1:22222'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'DomoticzVersion':'2020.2 (build 12221)'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'DomoticzHash':'74c0c9fcc-modified'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) 'DomoticzBuildTime':'2020-07-12 10:47:23'
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) Device count: 9
2020-07-30 11:57:18.461 (Aspirateur Xiaomi) Device: 1 - ID: 80, Name: 'Aspirateur Xiaomi - Status', nValue: 0, sValue: ''
2020-07-30 11:57:18.462 (Aspirateur Xiaomi) Device ID: '80'
2020-07-30 11:57:18.462 (Aspirateur Xiaomi) Device Name: 'Aspirateur Xiaomi - Status'
2020-07-30 11:57:18.462 (Aspirateur Xiaomi) Device nValue: 0
2020-07-30 11:57:18.462 (Aspirateur Xiaomi) Device sValue: ''
2020-07-30 11:57:18.462 (Aspirateur Xiaomi) Device LastLevel: 0
2020-07-30 11:57:18.462 (Aspirateur Xiaomi) Device: 2 - ID: 81, Name: 'Aspirateur Xiaomi - Control', nValue: 0, sValue: ''
2020-07-30 11:57:18.462 (Aspirateur Xiaomi) Device ID: '81'
2020-07-30 11:57:18.462 (Aspirateur Xiaomi) Device Name: 'Aspirateur Xiaomi - Control'
2020-07-30 11:57:18.462 (Aspirateur Xiaomi) Device: 4 - ID: 82, Name: 'Aspirateur Xiaomi - Fan Level', nValue: 0, sValue: ''
2020-07-30 11:57:18.462 (Aspirateur Xiaomi) Device ID: '82'
2020-07-30 11:57:18.462 (Aspirateur Xiaomi) Device Name: 'Aspirateur Xiaomi - Fan Level'
2020-07-30 11:57:18.463 (Aspirateur Xiaomi) Device: 5 - ID: 83, Name: 'Aspirateur Xiaomi - Battery', nValue: 0, sValue: ''
2020-07-30 11:57:18.463 (Aspirateur Xiaomi) Device ID: '83'
2020-07-30 11:57:18.463 (Aspirateur Xiaomi) Device Name: 'Aspirateur Xiaomi - Battery'
2020-07-30 11:57:18.463 (Aspirateur Xiaomi) Device nValue: 0
2020-07-30 11:57:18.463 (Aspirateur Xiaomi) Device sValue: ''
2020-07-30 11:57:18.463 (Aspirateur Xiaomi) Device LastLevel: 0
2020-07-30 11:57:18.463 (Aspirateur Xiaomi) Device: 6 - ID: 84, Name: 'Aspirateur Xiaomi - Care Main Brush', nValue: 0, sValue: ''
2020-07-30 11:57:18.463 (Aspirateur Xiaomi) Device ID: '84'
2020-07-30 11:57:18.463 (Aspirateur Xiaomi) Device Name: 'Aspirateur Xiaomi - Care Main Brush'
2020-07-30 11:57:18.463 (Aspirateur Xiaomi) Device: 7 - ID: 85, Name: 'Aspirateur Xiaomi - Care Side Brush', nValue: 0, sValue: ''
2020-07-30 11:57:18.463 (Aspirateur Xiaomi) Device ID: '85'
2020-07-30 11:57:18.463 (Aspirateur Xiaomi) Device Name: 'Aspirateur Xiaomi - Care Side Brush'
2020-07-30 11:57:18.464 (Aspirateur Xiaomi) Device: 8 - ID: 86, Name: 'Aspirateur Xiaomi - Care Sensors', nValue: 0, sValue: ''
2020-07-30 11:57:18.464 (Aspirateur Xiaomi) Device ID: '86'
2020-07-30 11:57:18.464 (Aspirateur Xiaomi) Device Name: 'Aspirateur Xiaomi - Care Sensors'
2020-07-30 11:57:18.464 (Aspirateur Xiaomi) Device nValue: 0
2020-07-30 11:57:18.464 (Aspirateur Xiaomi) Device sValue: ''
2020-07-30 11:57:18.464 (Aspirateur Xiaomi) Device LastLevel: 0
2020-07-30 11:57:18.464 (Aspirateur Xiaomi) Device: 9 - ID: 87, Name: 'Aspirateur Xiaomi - Care Filter', nValue: 0, sValue: ''
2020-07-30 11:57:18.464 (Aspirateur Xiaomi) Device ID: '87'
2020-07-30 11:57:18.464 (Aspirateur Xiaomi) Device Name: 'Aspirateur Xiaomi - Care Filter'
2020-07-30 11:57:18.464 (Aspirateur Xiaomi) Device: 10 - ID: 88, Name: 'Aspirateur Xiaomi - Care Reset Control', nValue: 0, sValue: ''
2020-07-30 11:57:18.464 (Aspirateur Xiaomi) Device ID: '88'
2020-07-30 11:57:18.464 (Aspirateur Xiaomi) Device Name: 'Aspirateur Xiaomi - Care Reset Control'
2020-07-30 11:57:18.465 (Aspirateur Xiaomi) Pushing 'ProtocolDirective' on to queue
2020-07-30 11:57:18.465 (Aspirateur Xiaomi) Pushing 'PollIntervalDirective' on to queue
2020-07-30 11:57:18.465 (Aspirateur Xiaomi) Processing 'ProtocolDirective' message
2020-07-30 11:57:18.465 (Aspirateur Xiaomi) Protocol set to: 'None'.
2020-07-30 11:57:18.465 (Aspirateur Xiaomi) Processing 'PollIntervalDirective' message
2020-07-30 11:57:18.465 (Aspirateur Xiaomi) Heartbeat interval set to: 15.
2020-07-30 11:57:27.966 (Aspirateur Xiaomi) Pushing 'onHeartbeatCallback' on to queue
2020-07-30 11:57:27.980 (Aspirateur Xiaomi) Processing 'onHeartbeatCallback' message
2020-07-30 11:57:27.981 (Aspirateur Xiaomi) Calling message handler 'onHeartbeat'.
2020-07-30 11:57:27.981 (Aspirateur Xiaomi) Pushing 'ConnectDirective' on to queue
2020-07-30 11:57:27.981 (Aspirateur Xiaomi) Trying connect to MIIOServer 127.0.0.1:22222
2020-07-30 11:57:27.981 (Aspirateur Xiaomi) Processing 'ConnectDirective' message
2020-07-30 11:57:27.981 (Aspirateur Xiaomi) Transport set to: 'TCP/IP', 127.0.0.1:22222.
2020-07-30 11:57:27.982 (Aspirateur Xiaomi) Connect directive received, action initiated successfully.
2020-07-30 11:57:27.982 (Aspirateur Xiaomi) Pushing 'onConnectCallback' on to queue
2020-07-30 11:57:28.032 (Aspirateur Xiaomi) Processing 'onConnectCallback' message
2020-07-30 11:57:28.032 (Aspirateur Xiaomi) Calling message handler 'onConnect'.
2020-07-30 11:57:28.032 (Aspirateur Xiaomi) MIIOServer connection status is [0] [Success]
2020-07-30 11:57:42.969 (Aspirateur Xiaomi) Pushing 'onHeartbeatCallback' on to queue
2020-07-30 11:57:43.009 (Aspirateur Xiaomi) Processing 'onHeartbeatCallback' message
2020-07-30 11:57:43.009 (Aspirateur Xiaomi) Calling message handler 'onHeartbeat'.
2020-07-30 11:57:43.010 (Aspirateur Xiaomi) Pushing 'WriteDirective' on to queue
2020-07-30 11:57:43.010 (Aspirateur Xiaomi) Processing 'WriteDirective' message
2020-07-30 11:57:43.010 (Aspirateur Xiaomi) Sending 19 bytes of data
2020-07-30 11:57:43.010 (Aspirateur Xiaomi) 91 b1 63 6f 6e 73 75 6d 61 62 6c 65 5f 73 74 61 74 75 73 .. ѱconsumable_status
2020-07-30 11:57:43.010 (Aspirateur Xiaomi) Sending 8 bytes of data
2020-07-30 11:57:43.010 (Aspirateur Xiaomi) 91 a6 73 74 61 74 75 73 .. .. .. .. .. .. .. .. .. .. .. .. Ѧstatus
2020-07-30 11:57:57.972 (Aspirateur Xiaomi) Pushing 'onHeartbeatCallback' on to queue
2020-07-30 11:57:57.989 (Aspirateur Xiaomi) Processing 'onHeartbeatCallback' message
2020-07-30 11:57:57.989 (Aspirateur Xiaomi) Calling message handler 'onHeartbeat'.
2020-07-30 11:57:57.989 (Aspirateur Xiaomi) Pushing 'WriteDirective' on to queue
2020-07-30 11:57:57.989 (Aspirateur Xiaomi) Processing 'WriteDirective' message
2020-07-30 11:57:57.989 (Aspirateur Xiaomi) Sending 8 bytes of data
2020-07-30 11:57:57.989 (Aspirateur Xiaomi) 91 a6 73 74 61 74 75 73 .. .. .. .. .. .. .. .. .. .. .. .. Ѧstatus
2020-07-30 11:58:17.099 (Aspirateur Xiaomi) Pushing 'onHeartbeatCallback' on to queue
2020-07-30 11:58:17.105 (Aspirateur Xiaomi) Processing 'onHeartbeatCallback' message
2020-07-30 11:58:17.105 (Aspirateur Xiaomi) Calling message handler 'onHeartbeat'.
2020-07-30 11:58:17.106 (Aspirateur Xiaomi) Pushing 'WriteDirective' on to queue
2020-07-30 11:58:17.106 (Aspirateur Xiaomi) Processing 'WriteDirective' message
2020-07-30 11:58:17.106 (Aspirateur Xiaomi) Sending 8 bytes of data
2020-07-30 11:58:17.106 (Aspirateur Xiaomi) 91 a6 73 74 61 74 75 73 .. .. .. .. .. .. .. .. .. .. .. .. Ѧstatus
Posted: Thursday 30 July 2020 15:36
by Hybris03
Hello everyone again,
I found a little thing on the french domoticz forum to test the ip and the token.
Apparently I have a return, which confirms that the information entered is correct.
The problem therefore comes from elsewhere.
If you have any ideas ... I'm interested!
thank you in advance
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ sudo service domoticz.sh restart
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ export MIROBO_IP=192.168.1.XX
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ export MIROBO_TOKEN=4e75566b30XX54536331XXXXXXXXXXXX
(.env) pi@raspberrypi:~/domoticz/plugins/xiaomi-mirobot $ mirobo
State: Charging
Battery: 100 %
Fanspeed: 60 %
Cleaning since: 0:38:04
Cleaned area: 35.755 m²
Posted: Thursday 30 July 2020 18:51
by Hybris03
End of story,
after removing everything, I re-installed plugin but updating all the dependencies.
I used python-miio == 0.5.3
If that helps, there is a clear tutorial at the following address:
https://ehoco.nl/roborock-vacuum-cleane ... -domoticz/
Posted: Monday 03 August 2020 14:57
by Destyny
Has anyone installed mi-robot plugin on synology NAS (no-docker, no VM) ?
Posted: Wednesday 09 December 2020 10:14
by DarkAllMan
My Domoticz Device status is not updated.
When I send tasks the cleaner starts...
When I run test.py, I get following output:
got server reply {'error': None, 'state_code': 5, 'battery': 82, 'fan_level': 106, 'clean_seconds': 180, 'clean_area': 2.3325, 'cmd': 'status'}
But the selector switch stays set to "OFF"
After checking github, it seems I'm missing the status device for my vaccuum cleaner:
Forgot to enable this device.... got it now....
Posted: Sunday 20 December 2020 18:08
by Argden
I have tried to add my Mi Robot to Domoticz exactly like in the instruction, but something is wrong.
Please see attached files.
What can be wrong?
Posted: Monday 21 December 2020 16:20
by HFman
Did you check the Domoticz LOG ?
Can you connect mannually to to the robot ?
Posted: Tuesday 19 January 2021 15:55
by vodor
Kinda related question: Anybody in this forum considered looking at communicating with their Xiaomi vaccum via Valentudo and MQTT from Domoticz?
This seem to be doable by using NodeRed however I would much rather prefer a MQTT plugin in domoticz.
Example
https://blog.keroi.net/valetudo-libere-aspire-2/
NOTE: You might have to use google translate
Would love to year your thoughts
