Dashticz - Bug report
Locked
gijsje
Domoticz version: Stable
Re: Dashticz - Bug report
Post by gijsje »
This is in devices
43 RFXCOM 16E2000 2 Radiator Radiator 1 Smartwares 15.0
And this is in the log file when you change it
2017-11-17 22:46:10.474 (RFXCOM) Radiator 1 (Radiator)
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Open: http://DOMOTICZ_ADDRESS:PORT/json.htm?type=devices
Search for Radiator. I want to check the piece of code between 'AddjMulti' and 'idx'
Have to go now but will fix this asap.
gijsje
Post by gijsje »
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "15.0",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 2,
"HardwareName" : "RFXCOM",
"HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
"HardwareTypeVal" : 1,
"HaveTimeout" : false,
"ID" : "16E2000",
"LastUpdate" : "2017-11-17 22:46:10",
"Name" : "Radiator",
"Notifications" : "false",
"PlanID" : "10",
"PlanIDs" : [ 10 ],
"Protected" : false,
"SetPoint" : "15.0",
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "Smartwares",
"Timers" : "false",
"Type" : "Radiator 1",
"TypeImg" : "override_mini",
"Unit" : 2,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "43"
gijsje
Post by gijsje »
Thanks no hurry
robgeerts
Post by robgeerts »
@Gijsje
In latest version you can view this device as a temperature-device.
Controlling is not yet possible. Do you now wich url is called when controlling the temperature of this device in Domoticz?
You can see this in console (F12) when pressing/sliding.
gijsje
Post by gijsje »
It shows now as a temp device thats ok but it should show up as a thermostat or something i guess
The ouput is json.htm?type=command&param=setsetpoint&idx=43&setpoint=15.5
robgeerts
Post by robgeerts »
Well thats not possible at the moment I guess, you can add a Selector Switch to domoticz, wich has several buttons for setting default temperatures (for example 15.5, 17.5 20,21) Behind every button you can add an action-url (in Domoticz)
EdwinK
Post by EdwinK »
With new update (Nov. 22/22:15) I get a blueish empty screen
This is in the log:
jquery.min.js:4 [Deprecation] Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
send @ jquery.min.js:4
VM56:235 Uncaught ReferenceError: c is not defined
at handleStringBlock (eval at globalEval (jquery.min.js:2), <anonymous>:235:13)
at getBlock (eval at globalEval (jquery.min.js:2), <anonymous>:108:21)
at buildScreens (main.js?v=1511385345348:284)
at onLoad (main.js?v=1511385345348:137)
at Object.<anonymous> (main.js?v=1511385345348:109)
at i (jquery.min.js:2)
at Object.fireWith [as resolveWith] (jquery.min.js:2)
at z (jquery.min.js:4)
at HTMLScriptElement.c (jquery.min.js:4)
at HTMLScriptElement.dispatch (jquery.min.js:3)
csi.gstatic.com/csi?v=2&s=mapsapi3&v3v=31.0&action=apiboot2&e=10_1_0,10_2_0&rt=main.18 Failed to load resource: net::ERR_CONNECTION_REFUSED
aiolos
Domoticz version: stable
Post by aiolos »
Ah, that's something I broke I think. (Quite a big refactor of the code was merged today)
I'll look into it.
If others experience problems with the latest beta let me know. In the end it should get better, but there can be some rough edges right now.
Contributor to Dashticz
More on my Github profile
EdwinK
Post by EdwinK »
Thanks. I know that running beta this could happen, so no worries
raymond
Domoticz version: V4.10232
Post by raymond »
Checked, did a fresh git pull this morning. Screens come up but the garbage and Sonarr modules don't seem to load.
Don't know if this helps.
robgeerts
Post by robgeerts »
Garbage works here....
Whats your garbage-config?
EdwinK
Post by EdwinK »
Strangely, I created another index file with some other settings, and that one is working
raymond
Post by raymond »
robgeerts wrote: Thursday 23 November 2017 10:24 Garbage works here....
mijnafvalwijzer
aiolos
Post by aiolos »
EdwinK wrote: Wednesday 22 November 2017 22:19 With new update (Nov. 22/22:15) I get a blueish empty screen
This is in the log:
I created a pull request for this issue. hope it solves the issue.
EdwinK
Post by EdwinK »
:) Thanks. Will wait till the merge :)
robgeerts
Post by robgeerts »
It's merged :)
EdwinK
Post by EdwinK »
Latest update fixed it. Thanks Rob and aiolos
aiolos
Post by aiolos »
Cool, good the hear.
EdwinK
Post by EdwinK »
Screen Shot 2017-11-23 at 12.15.02.png (309.49 KiB) Viewed 3176 times
Now I've got this little problem. Not to serious, just need to resize them myself ;)
Locked
