Read British Gas Hive Heating temperature
sach
Re: Read British Gas Hive Heating temperature
Post by sach »
Thanks for updating the plugin, it works great.
One issue I have is this message in the logs appearing every hour:
"Error: (Hive) Error Getting Devices - Recreating Session"
Any ideas or is there a way to suppress this message so it stops sending me emails :-)
imcfarla
Post by imcfarla »
I have reduced this to just a log message - it was never meant to happen that often but it seems to be a session now only lasts an hour.
sach
Post by sach »
Thanks for the quick reply.
I updated the py file but it’s still showing up as errors in the logs.
imcfarla
Post by imcfarla »
Are you using the urllib version? I haven't updated that one
sach
Post by sach »
No the normal one.
Is this the section you updated?
# Bad session?
Domoticz.Error("Error Getting Devices - Recreating Session")
self.sessionId = ''
mark.sellwood
Post by mark.sellwood »
This may be a silly question, what's the difference between the normal & urllib versions?
How do I know what one I'm using & how do I switch to the other?
3 x Pi, 1 Master, 2 Slaves, 1x Aeotec Z-Stick S2, 4xSP103 PIR, 5xPowerNode 1, 1xSmart Energy Switch Gen5, 4xFGSS101 Smoke Sensor, 2xFGD212, 9xFGS212 , 7xFGS221/2, 1xAD142 , 1xTKB TZ68E , 2xAeotec Multi Sensor, 3 x NodOn CRC-3-1-00.
imcfarla
Post by imcfarla »
oops - I missed one.... updated now
There are 2 files called plugin* in the repository. One is normal plugin.py which uses the domoticz connection objects for all the conections and the second one uses urllib to connect directly ignore domoticz until it is time to update devices.
The urllib one was developed before domoticz had connections and is more directly related to the original script. However there was a time a while back that there were problems with the version of python in domoticz versus the version in various distributions that crasheddomoticz whenever a plugin loaded urllib. I suspect that whatever the problem is has mostly gone away but I do not know if it was ever fixed. Hence I rewrote the plugin to use the connection objects.
To switch between the two versions you need to rename plugin.py to plugin.py.orig (or similar) and rename plugin.urllib.py to plugin.py
I use the newer one rather than the urllib one but I try to keep them feature equivalent.
sach
Post by sach »
Thanks mate. Update again on my end. Will let you know if it comes back but that should do it :-)
mark.sellwood
Thanks for the explanation on the versions.
sach
Post by sach »
sach wrote: Tuesday 06 October 2020 23:13 Thanks mate. Update again on my end. Will let you know if it comes back but that should do it :-)
No error in the logs now :-)
But i do have some stability issues with my Domoticz VM becoming totally unresponsive. Cannot honestly say its the Hive plugin doing it, but i'm going to switch it off for a day or 2 and see if it still crashes.
I use Hive as a boiler switch when one of my 5 zones requests heat. Previously i was using a virtual switch linked to IFTTT Webhook for this and using the original script to ensure the boiler state was as it should be.
Seriously considering purchasing a Secure Z-Wave boiler switch so i can get rid of hive altogether and make everything local.
mark.sellwood
I'm looking at getting rid of Hive too, my Hive Hub stops working randomly and needs to be power cycled, Hive know all about it, its a design issue but wont be fixing it.
They have said I have 2 options:-
Replace my Hub at a cost of £80
Put a time switch in to power cycle the Hub daily
I'm looking at Nest
MikeF
Domoticz version: V2022.2
Post by MikeF »
Although I switched away from Hive about 15 months ago ( https://www.domoticz.com/forum/viewtop ... 20#p218657), as the OP of this thread I’m still interested to watch developments from time to time.
I must say that I am disappointed to see that people are having problems with BG changing the API, so that plugins, etc., need to be modified - my main reason for moving away is that the system is not under my control, and that I have to rely on minute-by-minute calls to an external server to operate my domestic central heating: view temperature, change thermostat setting, turn boiler on / off, etc. I changed to the Drayton Wiser system (see above link), and whilst this does have a far simpler thermostat than Hive’s, and uses an iPhone / Android app for most settings, the server resides in the controller with no need for a hub, so that the system can be controlled entirely locally.
Some third-party Python APIs have been produced, and I have developed a number of dzVents scripts based on these, so that I can control my system from within Domoticz, both locally and remotely. I rarely use the Drayton app, and I could (but I haven’t) block the app through my router, and I would still have complete control.
sach
Post by sach »
Thanks Mike.
Is this the same system?
https://www.amazon.co.uk/Drayton-Wiser- ... th=1&psc=1
How reliable are the plugins for Domoticz? I already have zwave trv’s and room sensors in all the bedrooms so have a blocky setup to set Hive to either on (25°) or off (7°) depending on whether a room is calling for heat. I’m guessing this is already possible from the existing plugin for Wiser?
Also how easy is it to replace Hive. Does it just clip into the existing plate? I don’t have a combi so require heating too, but I leave that on a schedule on Hive currently.
Cheers
Sach
MikeF
Post by MikeF »
Yes, it’s that system, and yes, it fits on the same backplate.
I have to admit to no experience of the Wiser plugin - I only have a combi system (heating only, hot water on demand), no TRVs, and no smart plugs. So I find the plugin overkill for my needs - also, I’ve had bad experience with plugins in the past, with repeated ‘onMessage’ failure errors. I prefer to write my own code for my own needs, so I know what’s going on!
sach
Post by sach »
Heads up. Amazon UK is selling the 2 channel Wiser system that I linked above for £56.99. I just purchased it myself and when in the basket it dropped to £46.99 for some reason (not that i'm complaining). Thanks for the heads up on this system Mike. I will now be pestering you to help me with the scripts! :lol:
dgilbert2
Domoticz version: 2024.7
Post by dgilbert2 »
Here we go again?!
I can no longer login to the Hive API, so no updates since 14:20 today.
Anyone else having this issue and if so, any clues what the problem is?
mark.sellwood
Same with me
roadsnail
Domoticz version: 13314
Post by roadsnail »
Yep, same here. Noticed the house was cooling down! :shock:
(Hive) HTTP Error 401: Unauthorized
Errors started around the same time.
Haven't started looking yet, but I think I will bail on the Hive system. Once I get rid, then I will not be relying on third parties any longer
for automation.
_______________________________________________________________________________________________
Pi4, Z-Wave: Danfoss TRVs, aeotec hem, d-link siren, heiman door contacts. Hive heating ctrl, esp8266 based sensors, zigbee2mqtt, Zigbee bulbs etc
mark.sellwood
I'm looking to bail on Hive too, I have to reboot my hub daily to keep it working, that know about the issue & want me to pay for a new hub.
roadsnail
Post by roadsnail »
mark.sellwood wrote: Wednesday 02 December 2020 18:45 I'm looking to bail on Hive too, I have to reboot my hub daily to keep it working, that know about the issue & want me to pay for a new hub.
Just wish I'd started homebrewing my own solution the last time BG changed stuff! I would have had a working replacement by now. Anyhow...
My plan is to rip the guts out of a cheap (probably ebay) s/h 2 channel controller. Replace said guts with esp32 based wifi solution. (My existing esp8266 work for months on end without any issues).
