Page 14 of 17
Re: Alexicz - FREE Domoticz to Alexa Integration
Posted: Thursday 06 August 2020 19:59
by ldeutsch
I wanted to express my gratitude to the author of that skill. I have been using domoticz for nearly three years and was struggling with habridge and its limitations.
I was on the verge to develop such a skill myself out of sheer frustration with my previous solution.
By luck I found that topic - seriously: not having native Alexa integration is one of the most serious drawbacks of Domoticz - until now.
Here are my gotchas I encountered along the way to set up that skill:
- you might share a link how to use domoticz ssl port from the outside. In fact I was wondering why the skill does not use MyDomoticz.
- the walk thru to set up the skill is not quite up to date - I had to improvise at some points...
- choosing Ireland for the lambda location is essential _ otherwise the account linking throws weird errors
- the name of the lambda function in the git repository needs to be adapted to the current version
- the final hurdle: make sure to create a floor plan, assign the devices you want to be discovered by Alexa and set the plan ID in the config Jason to your Alexa devices plan I was struggling quite a bit with that last one..
I recommend to link to that topic from the starting page of the forum... It's a huge benefit. I can now set the colors of my MySensors and z-wave rgb strips... Hurray
Cheers,
Lars
Posted: Thursday 06 August 2020 20:25
by tarmacalastair
@Lars,
I wonder, can you remember what your improvisations were? I tried to set up this skill following the instructions here earlier this year and failed miserably because the steps required have changed so much.
Thanks.
Posted: Thursday 20 August 2020 16:33
by fireport
Dear all, I added 3 aqara door sensors to domoticz using zigbee2mqtt. Alexa sees them but is unable to update the state.
If I change the switch type from door sensor to "on/off" the status is updated. Do you have a solution to solve this problem?
This is the json config of one of my aqara sensors.
"ActTime" : 1597933860,
"AstrTwilightEnd" : "21:46",
"AstrTwilightStart" : "04:41",
"CivTwilightEnd" : "20:33",
"CivTwilightStart" : "05:55",
"DayLength" : "13:39",
"NautTwilightEnd" : "21:08",
"NautTwilightStart" : "05:19",
"ServerTime" : "2020-08-20 16:31:00",
"SunAtSouth" : "13:14",
"Sunrise" : "06:25",
"Sunset" : "20:03",
"app_version" : "2020.2",
"result" :
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 100,
"CustomImage" : 0,
"Data" : "Open",
"Description" : "",
"DimmerType" : "none",
"Favorite" : 0,
"HardwareID" : 24,
"HardwareName" : "Zigbee2MQTT",
"HardwareType" : "Zigbee2MQTT",
"HardwareTypeVal" : 94,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "0x00158d00047dd1c3_sensor",
"Image" : "Door",
"InternalState" : "Open",
"IsSubDevice" : false,
"LastUpdate" : "2020-08-20 15:55:04",
"Level" : 1,
"LevelInt" : 1,
"MaxDimLevel" : 100,
"Name" : "Z porta cucina",
"Notifications" : "false",
"PlanID" : "2",
"PlanIDs" :
2
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : 1,
"Status" : "Open",
"StrParam1" : "",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "Door Contact",
"SwitchTypeVal" : 11,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "door",
"Unit" : 29,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "222"
"status" : "OK",
"title" : "Devices"
Posted: Thursday 20 August 2020 19:40
by philchillbill
fireport wrote: Thursday 20 August 2020 16:33
Well, Domoticz itself does not update the skill's Lambda with changed state. You have to run a python script locally whenever anything changes in Domoticz to push the change(s). See my posts from
and before (no idea how to link to a specific post).
Posted: Saturday 22 August 2020 10:29
by fireport
I modified python scripts following your instructions and now the door sensors are shown as a contact but Alexa doesn't understand the query to know door status (open ad close). Any helps?
Posted: Saturday 22 August 2020 10:30
by philchillbill
fireport wrote:I modified python scripts following your instructions and now the door sensors are shown as a contact but Alexa doesn't understand the query to know door status (open ad close). Any helps?
Did you include EndpointHealth ? I mentioned that in some posts around the same time.
Posted: Saturday 22 August 2020 15:08
by fireport
I added all the three pieces of code into the python scripts.
This is the output of a discovery of one of the three sensors
"endpointId": "Contact-222",
"friendlyName": "porta cucina",
"description": "Light/Switch",
"manufacturerName": "Zigbee2MQTT",
"displayCategories": [
"CONTACT_SENSOR"
"additionalApplianceDetails": {},
"capabilities": [
"type": "AlexaInterface",
"interface": "Alexa.EndpointHealth",
"version": "3",
"properties": {
"supported": [
"name": "connectivity"
"proactivelyReported": true,
"retrievable": true
"interface": "Alexa.ContactSensor",
"version": "3",
"properties": {
"supported": [
"name": "detectionState"
"retrievable": true
Posted: Thursday 10 September 2020 17:54
by phil12
hello all
i just installed alexicz and followed the how to pdf , i hope all was made correctly
just on point on chapter 5.11
5.11. Click on « alexicz » to configure the function (1) Change the handler information to
« lambda.event_handler » (2) Select the « Upload a ZIP file » option (3) Click to upload your
function (4) and select the package you created previously (§4)
first : i never founded where to change the handler information to "lambda.event_handler"
second : when i upload the zip file the system request to have a "lambda_function.py" file
so i had renamed lambda.py to lambda_function.py and system was quiet !!
But now in chapter 9 ( Tests) i have problems
whan i test i got this message
"errorMessage": "Handler 'lambda_handler' missing on module 'lambda_function'"
is somebody can help me
thanks in advance
Posted: Monday 02 November 2020 12:09
by Harryb17
Is anyone using this successfully with an IPv6 only server?
I've used Alexicz in the past with a domain name which pointed to a static IPv4 address.
Now my ISP are charging for static IPs and because of the particular setup in our apartment building, using something like DuckDNS doesn't work.
With this change my ISP started giving us IPv6 addresses which don't change so I assumed everything would continue working.
I can still connect to my Domoticz sever successfully using my domain name but the Alexicz function has stopped working.
I now get the following error when running a test inside of the Lambda function.
urllib.error.URLError: <urlopen error [Errno 97] Address family not supported by protocol>
I've read a few things about using the urllib2 library but I'm not familiar with python.
Any advice would be appreciated!
Posted: Monday 02 November 2020 17:44
by philchillbill
I'm nearly sure Amazon does not support IPv6 endpoints. For the hell of it, you could setup a quick ngrok tunnel and see if that resolves.
Posted: Tuesday 17 November 2020 15:04
by alexjcgdf
Hey sir;
I am stuck on step 5.4 5.5 5.6 5.7 since the AWS platform has changed and it does not reflect with the actual option anymore. I got stuck exactly on creating the new IAM Role. Can you help me on that one? I am not a developer so I really dont know what to do if it is not explicitly on the HOWTO.
ldeutsch wrote: Thursday 06 August 2020 19:59
Cheers,
Lars
Posted: Tuesday 08 December 2020 1:10
by wolfguru
Hello, thank you for the great effort and documentation.
I managed to follow all the steps, and worked around the ones that are changed due to changes in AWS. Now my lambda function is working, but the discovery is returning HTTP Error 401: Unauthorized
I have the port open on my router, and I created the user in domoticz with the password and added them to the json file. I'm using HTTPS. I think it is not liking my username/passowrd.
When I try to execute https://<my dns namel>:<my port>/json.htm?type=devices on mobile connected in my wifi (inside my lan) it works fine, but when if I trun off wifi and use 4G and try the same then I get unauthorized ... but that is also because my domoticz does not need username/password within ny LAN.
Anyone have the same issue? Any suggestions?
Posted: Tuesday 08 December 2020 1:26
by wolfguru
wolfguru wrote: Tuesday 08 December 2020 1:10
The issue is fixed if I use the username and password for "Website Protection" ... I was trying to use another Domoticz user.
Can I not use another domoticz user created specifically for this skill? I can create other users in Setup->More Options -> Edit Users
Thanks for help.
Posted: Saturday 12 December 2020 9:51
by DrMacabre
Everything was working fine until may be a month from now, alexa keeps saying device not responding almost every time then eventually the device turns on, sometimes it works fine but 80% of the time, there this not responding message then a few seconds later, the device turns on like if domoticz was stalled and then able again to process the incoming command. I can’t think of anything explaining this issue.
Any idea ?
Posted: Saturday 12 December 2020 9:53
by philchillbill
DrMacabre wrote:Hello,
Any idea ?
Have you checked the Cloudwatch logs ?
Posted: Sunday 13 December 2020 23:12
by DrMacabre
philchillbill wrote: Saturday 12 December 2020 9:53
Any idea ?
Nope, actually it’s also doing the same with your LMS light skill so I think it’s more related to alexa rather than any of the skills. Anyone is using pi-hole and alexa ?
Posted: Monday 22 February 2021 10:30
by kitopopo
philchillbill wrote: Tuesday 23 July 2019 9:51
@grasuoare The skill code needs to be able to reach Domoticz via HTTPS - that's simply an Amazon requirement. The url for your instance is hard-coded in the configdz.json file and is e.g.
https://myhouse.ddns.net:443. I've never used a VPN but if it gives you a url to allow external traffic to talk to your server at will, you can use it. If not, it won't work. What *will* work is a reverse proxy that sits between Alexa and Domoticz and adds more security, albeit still requiring a port to be opened. I personally think people get too hung up on open ports. If properly done with a reverse proxy behind them only accepting TLS and with X509 authentication (or basic auth with a huge password), they are not a security issue.
@poudenes What exactly do you mean by Security Profile? Forgive me, but I cannot match that term to Amazon terminology.
Dear friend, i test all the process and alexa works correctly.
I had to modify one of the files to make it work for me. Change https to http, because I connect to domoticz by http. Could you talk about the security issues? I don't really like to introduce my public ip, my external port, my username and my domoticz password in that file. Could this be a security problem? Could you explain how to increase security with the reverse proxy or some other way? thanks in advance
Posted: Monday 22 February 2021 10:57
by philchillbill
What/where did you change https to http? Alexa can only work with an external https URL with a domain name. Your internal IP address like
http://192.168.1.10:8080 cannot be reached from the cloud.
Posted: Monday 22 February 2021 11:08
by kitopopo
philchillbill wrote: Monday 22 February 2021 10:57
I changed https by http in configdz-template.json or configdz.json in "url"
https://myexternalip was replaced by "url"
http://myexternalip.
making this change alexa works with my domoticz perfectly but I am afraid of security problems, either because I use http or because I give my username, password, public ip and port in that configuration file. I am giving all my data.
Do you think it is safer if I use https? Besides this, is it not dangerous to put all my data in that file? thanks in advance
Posted: Monday 22 February 2021 12:11
by philchillbill
kitopopo wrote: Monday 22 February 2021 11:08
Aha, that's allowed because you are not publishing the skill and it's for personal use only in your dev-account. It's a very bad idea though, as your Domoticz is fully exposed with no protection. It's not 'if' you will be hacked, but 'when'...
You already have an external IP address, right? Have you tried getting an SSL cert for it from LetsEncrypt?
