Page 14 of 19
Re: [REQUEST] Plugin for Tuya
Posted: Thursday 29 August 2019 12:00
by merlot
For your referencie, activating the DEBUG (uncommenting the line and commentig de loggin ERROR level one in the ___init__.py) this is what I get from get_dps.py for a dual socket with version 3.3 of plug protocol:
- Spoiler: show
INFO:pytuya:pytuya version 7.0.4
INFO:pytuya:Python 3.5.3 (default, Sep 27 2018, 17:25:39)
[GCC 6.3.0 20170516] on linux
INFO:pytuya:Using PyCrypto (2, 6, 1, 'final', 0)
INFO:pytuya:Using PyCrypto from '/home/pi/.local/lib/python3.5/site-packages/Crypto/__init__.py'
DEBUG:pytuya:status() entry
DEBUG:pytuya:json_payload=b'{"devId":"836742153c71bf3xxxxx","gwId":"836742153c71bf3xxxxx"}'
DEBUG:pytuya:socket.error=<class 'OSError'>
DEBUG:pytuya:address='192.168.1.66'
DEBUG:pytuya:payload_sent=b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00H\x8d\xeb\x00\x98\x07X~\xe8H\xb9\rx\xfeu\xa9\'\xdb\xa1\x89\xde\x01\xcb9\x89\x1c"\xa9\x82N\xf3}\x81,+z\xf3\xec\xca\xffj\x1a\x96Z\xeeu\xc2\xf9f=\xf2V\x86#\xc5m\xd3-\x98MU\x84\x90{\x8e\xc7M\x19)\x00\x00\xaaU'
DEBUG:pytuya:data_rcv:b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\xac\x00\x00\x00\x00\x8d\xeb\x00\x98\x07X~\xe8H\xb9\rx\xfeu\xa9\'\xdb\xa1\x89\xde\x01\xcb9\x89\x1c"\xa9\x82N\xf3}\x81O\x1f\x9c\'\x97P\x16\xf4\xc6\x8cH\x9a4\x9d\xd0hW\x1d\x8f\x1c\xc4\xc7\xd6\xfe\xc0\x9a\xaa)\xf0\xf0l\xa2N\xd2\xe4\xf0\x0c\xc7\xe9\xc2\xd1\x87\x93\xf9\x9d\x02\x19\xd9}\xdf\x9eX\xbb\x9f:~\xe5\xd8\x08 \'\x0bq\xb8\x17R\x1b\xfa\x83`\xed`\x05\x80\xa2\xa8C\xf7kzT\xd9\xf7\xc6Z~\xe3%\xac\x0e\n\xeaU\xc7+\xb9q\xd9\xf1#\x0b\xb2\x01.\xa6\xb4\x83\xe6\x0f\xe0\x1e\x93\xe0\x04\xabcG\x01\xc2\t\r\xac\xb1&\xe6\xc8\xb8fakr\x16\x00\x00\xaaU'
DEBUG:pytuya:close
DEBUG:pytuya:status received data=b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\xac\x00\x00\x00\x00\x8d\xeb\x00\x98\x07X~\xe8H\xb9\rx\xfeu\xa9\'\xdb\xa1\x89\xde\x01\xcb9\x89\x1c"\xa9\x82N\xf3}\x81O\x1f\x9c\'\x97P\x16\xf4\xc6\x8cH\x9a4\x9d\xd0hW\x1d\x8f\x1c\xc4\xc7\xd6\xfe\xc0\x9a\xaa)\xf0\xf0l\xa2N\xd2\xe4\xf0\x0c\xc7\xe9\xc2\xd1\x87\x93\xf9\x9d\x02\x19\xd9}\xdf\x9eX\xbb\x9f:~\xe5\xd8\x08 \'\x0bq\xb8\x17R\x1b\xfa\x83`\xed`\x05\x80\xa2\xa8C\xf7kzT\xd9\xf7\xc6Z~\xe3%\xac\x0e\n\xeaU\xc7+\xb9q\xd9\xf1#\x0b\xb2\x01.\xa6\xb4\x83\xe6\x0f\xe0\x1e\x93\xe0\x04\xabcG\x01\xc2\t\r\xac\xb1&\xe6\xc8\xb8fakr\x16\x00\x00\xaaU'
DEBUG:pytuya:result=b'\x8d\xeb\x00\x98\x07X~\xe8H\xb9\rx\xfeu\xa9\'\xdb\xa1\x89\xde\x01\xcb9\x89\x1c"\xa9\x82N\xf3}\x81O\x1f\x9c\'\x97P\x16\xf4\xc6\x8cH\x9a4\x9d\xd0hW\x1d\x8f\x1c\xc4\xc7\xd6\xfe\xc0\x9a\xaa)\xf0\xf0l\xa2N\xd2\xe4\xf0\x0c\xc7\xe9\xc2\xd1\x87\x93\xf9\x9d\x02\x19\xd9}\xdf\x9eX\xbb\x9f:~\xe5\xd8\x08 \'\x0bq\xb8\x17R\x1b\xfa\x83`\xed`\x05\x80\xa2\xa8C\xf7kzT\xd9\xf7\xc6Z~\xe3%\xac\x0e\n\xeaU\xc7+\xb9q\xd9\xf1#\x0b\xb2\x01.\xa6\xb4\x83\xe6\x0f\xe0\x1e\x93\xe0\x04\xabcG\x01\xc2\t\r\xac\xb1&\xe6\xc8\xb8f'
DEBUG:pytuya:decrypted result='{"devId":"836742153c71bf3xxxxx","dps":{"1":false,"2":false,"9":0,"10":0,"18":0,"19":0,"20":2335,"21":1,"22":602,"23":28250,"24":16000,"25":1300}}'
Plug State Information:
{'devId': '836742153c71bf3xxxxx', 'dps': {'22': 602, '18': 0, '10': 0, '20': 2335, '23': 28250, '19': 0, '24': 16000, '2': False, '9': 0, '25': 1300, '1': False, '21': 1}}
Plug DPS List:
2;1
Posted: Thursday 29 August 2019 12:14
by Loky31
Many thanks for the reply!!
Just a detail, to activate protocol V3.3 do I only need to edit the tuyapi/index.js file (by replacing 3.1 by 3.3) ?
is that enough?
Posted: Friday 30 August 2019 10:46
by Loky31
I've tried to update the index.js with 3.3 instead of 3.1 but din't change anything...
I still have an OSError when launching the get_dps.py
I don't know where I'm wrong then....
Posted: Friday 30 August 2019 12:20
by merlot
Loky31 wrote:Many thanks for the reply!!
is that enough?
As I've mentioned before
"Then you can add device.set_version(3.3) in the get_dps.py after creating the device and the get_dps.py should work"
But you need pytuya 7.0.4
Enviado desde mi Redmi Note 4 mediante Tapatalk
Posted: Saturday 31 August 2019 12:24
by Loky31
Thanks for the help!
So here is the situation :
I have modified the __init__.py in the pytuya directory to change 3.1 to 3.3 in the " class XenonDevice(object): " which results in "self.version = 3.3".
The get_dps.py was still crashing as follow:
File "./get_dps.py", line 46, in <module>
data = device.status()
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/pytuya/__init__.py", line 279, in status
payload = self.generate_payload('status')
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/pytuya/__init__.py", line 219, in generate_payload
json_payload = self.cipher.encrypt(json_payload, False)
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/pytuya/__init__.py", line 64, in encrypt
cipher = AES.new(self.key, mode=AES.MODE_ECB)
File "/usr/lib/python3/dist-packages/Crypto/Cipher/AES.py", line 94, in new
return AESCipher(key, *args, **kwargs)
File "/usr/lib/python3/dist-packages/Crypto/Cipher/AES.py", line 59, in __init__
blockalgo.BlockAlgo.__init__(self, _AES, key, *args, **kwargs)
File "/usr/lib/python3/dist-packages/Crypto/Cipher/blockalgo.py", line 141, in __init__
self._cipher = factory.new(key, *args, **kwargs)
ValueError: Key cannot be the null string
So I hard coded the local key in :
class Device(XenonDevice):
def __init__(self, dev_id, address, local_key=None, dev_type=None):
super(Device, self).__init__(dev_id, address, 'xxxxxxxxxxxxx', dev_type)
Which succed to give me the DPS of both my plugs and the one of the curtain switch.
Socket : 'dps': {'1': False, '2': 0}
Curtain switch : 'dps': {'1': '3'}
I put it back again to "super(Device, self).__init__(dev_id, address, local_key, dev_type)" and my socket are more or les working on domoticz :
The switches created by the pluggin does not update to reflect socket state, so I created a dummy switch to pilot it.
All mesures are out of order (but I don't really care about that).
So I'm pretty happy to be able to pilot the plug even in degraded situation...
Still not able to deal with the curtain switch as I don't knoàw how to handle the " 'dps': {'1': '3'} " through the pluggin ( if it works) or if some modifications are needed...
Any further idea on all this epic tuya story?
Posted: Tuesday 03 September 2019 12:10
by Loky31
I finally handled the switch to work
But still the pluggin does not handle well status (the domoticz switch is stuck on OFF state)...
Anyway, it works with a dummy that activate the switch created by the pluggin. Fair enough to be functionnal
Posted: Friday 20 September 2019 16:42
by xavierlp
Hello to all and thanks again tixi for the plugin
I could setup the plggin with the guide to catch device id and key
I've got some error in the log and when i run get_dps.py the message "A problem occur please retry..."
In the plugin setting I changes the value of debug to 1 and can read this :
2019-09-20 16:40:24.186 Error: (Tuya) 'onMessage' failed 'KeyError'.
2019-09-20 16:40:24.186 Error: (Tuya) ----> Line 534 in '/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/plugin.py', function onMessage
2019-09-20 16:40:24.186 Error: (Tuya) ----> Line 442 in '/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/plugin.py', function onMessage
Is it an issue with python, script ?
Thanks for your help
More details
2019-09-20 16:40:24.031 (Tuya) Debug logging mask set to: PYTHON PLUGIN QUEUE IMAGE DEVICE CONNECTION MESSAGE ALL
2019-09-20 16:40:24.031 (Tuya) onStart called
2019-09-20 16:40:24.031 (Tuya) Pushing 'ConnectDirective' on to queue
2019-09-20 16:40:24.031 (Tuya) Processing 'ConnectDirective' message
2019-09-20 16:40:24.031 (Tuya) Protocol for 'Tuya' not specified, 'None' assumed.
2019-09-20 16:40:24.031 (Tuya) Transport set to: 'TCP/IP', 192.168.1.23:6668.
2019-09-20 16:40:24.032 (Tuya) Connect directive received, action initiated successfully.
2019-09-20 16:40:24.116 (Tuya) Pushing 'onConnectCallback' on to queue
2019-09-20 16:40:24.132 (Tuya) Processing 'onConnectCallback' message
2019-09-20 16:40:24.132 (Tuya) Calling message handler 'onConnect'.
2019-09-20 16:40:24.132 (Tuya) Connected successfully to: 192.168.1.23:6668
2019-09-20 16:40:24.133 (Tuya) Pushing 'WriteDirective' on to queue
2019-09-20 16:40:24.134 (Tuya) Processing 'WriteDirective' message
2019-09-20 16:40:24.134 (Tuya) Sending 86 bytes of data
2019-09-20 16:40:24.134 (Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 46 7b 22 64 65 ..U�...........F{"de
2019-09-20 16:40:24.134 (Tuya) 76 49 64 22 3a 22 35 35 31 34 32 37 30 37 62 63 64 64 63 32 vId":"55142707bcddc2
2019-09-20 16:40:24.134 (Tuya) 39 35 66 39 36 61 22 2c 22 67 77 49 64 22 3a 22 35 35 31 34 95f96a","gwId":"5514
2019-09-20 16:40:24.134 (Tuya) 32 37 30 37 62 63 64 64 63 32 39 35 66 39 36 61 22 7d 49 51 2707bcddc295f96a"}IQ
2019-09-20 16:40:24.134 (Tuya) d9 16 00 00 aa 55 .. .. .. .. .. .. .. .. .. .. .. .. .. .. �...�U
2019-09-20 16:40:24.145 (Tuya) Pushing 'ReadEvent' on to queue
2019-09-20 16:40:24.184 (Tuya) Processing 'ReadEvent' message
2019-09-20 16:40:24.184 (Tuya) Received 173 bytes of data
2019-09-20 16:40:24.184 (Tuya) 00 00 55 aa 00 00 00 00 00 00 00 0a 00 00 00 9d 00 00 00 00 ..U�...........�....
2019-09-20 16:40:24.184 (Tuya) 7b 22 64 65 76 49 64 22 3a 22 35 35 31 34 32 37 30 37 62 63 {"devId":"55142707bc
2019-09-20 16:40:24.185 (Tuya) 64 64 63 32 39 35 66 39 36 61 22 2c 22 64 70 73 22 3a 7b 22 ddc295f96a","dps":{"
2019-09-20 16:40:24.185 (Tuya) 31 22 3a 66 61 6c 73 65 2c 22 32 22 3a 66 61 6c 73 65 2c 22 1":false,"2":false,"
2019-09-20 16:40:24.185 (Tuya) 39 22 3a 30 2c 22 31 30 22 3a 30 2c 22 31 38 22 3a 30 2c 22 9":0,"10":0,"18":0,"
2019-09-20 16:40:24.185 (Tuya) 31 39 22 3a 30 2c 22 32 30 22 3a 32 32 38 32 2c 22 32 31 22 19":0,"20":2282,"21"
2019-09-20 16:40:24.185 (Tuya) 3a 31 2c 22 32 32 22 3a 36 30 39 2c 22 32 33 22 3a 32 37 32 :1,"22":609,"23":272
2019-09-20 16:40:24.185 (Tuya) 39 37 2c 22 32 34 22 3a 31 35 35 31 39 2c 22 32 35 22 3a 31 97,"24":15519,"25":1
2019-09-20 16:40:24.185 (Tuya) 33 34 30 7d 7d 53 83 91 98 00 00 aa 55 .. .. .. .. .. .. .. 340}}S���..�U
2019-09-20 16:40:24.185 (Tuya) Pushing 'onMessageCallback' on to queue
2019-09-20 16:40:24.185 (Tuya) Processing 'onMessageCallback' message
2019-09-20 16:40:24.185 (Tuya) Calling message handler 'onMessage'.
2019-09-20 16:40:24.185 (Tuya) onMessage called: 192.168.1.23:6668 b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\x9d\x00\x00\x00\x00{"devId":"55142707bcddc295f96a","dps":{"1":false,"2":false,"9":0,"10":0,"18":0,"19":0,"20":2282,"21":1,"22":609,"23":27297,"24":15519,"25":1340}}S\x83\x91\x98\x00\x00\xaaU'
2019-09-20 16:40:24.024 Status: (Tuya) Entering work loop.
2019-09-20 16:40:24.025 Status: (Tuya) Initialized version 1.0.0, author 'tixi_sincze'
Posted: Friday 20 September 2019 17:23
by xavierlp
More information with DEBUG and get_dps
pi@raspberrypi:~/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin $ sudo python3.5 get_dps.py '192.168.1.23' '55142707bcddc295f96a'
INFO:pytuya:Python 3.5.7 (default, Aug 17 2019, 22:31:31)
[GCC 4.9.2] on linux
INFO:pytuya:Using PyCrypto from '/usr/local/lib/python3.5/site-packages/Crypto/__init__.py'
DEBUG:pytuya:json_payload=b'{"gwId":"55142707bcddc295f96a","devId":"55142707bcddc295f96a"}'
Posted: Friday 20 September 2019 21:09
by deennoo
@xavierlp
Which kind of device did you use ? Action One ?
I get a Smart-Plug and a Led Strip from Action and they use v3.3 tuya version (MCUFW 1.1.5 for the Plug and 1.1.6 for the Led Strip)
@merlot
Did you think that it can e possible to choose which version to use on the plugin ? (3.1, 3.2, 3.3)
Can you be more explicit about how to choose version 3.3 using Pytuya 7.0.4 ?
Posted: Saturday 21 September 2019 13:43
by xavierlp
Hello @deennoo
I am using OxaOxe
https://www.amazon.fr/gp/product/B07G2J ... le_o02_s00
I could red your post on github. For my side I don't know how to check the version of tuya.
thanks
Posted: Sunday 22 September 2019 22:27
by FearNaBoinne
Adding Set_Version(3.3) to the get_dps, turnOn and turnOFF scripts made it work*
*) Also had to modify the device generator to contain the key, and add a 3rd argument (key) to get_dps...
My get_dps.py is now:
#!/usr/bin/python3
# Domoticz Tuya Smart Plug Python Plugin #
# MIT License #
# Copyright (c) 2018 tixi #
# Permission is hereby granted, free of charge, to any person obtaining a copy #
# of this software and associated documentation files (the "Software"), to deal #
# in the Software without restriction, including without limitation the rights #
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell #
# copies of the Software, and to permit persons to whom the Software is #
# furnished to do so, subject to the following conditions: #
# The above copyright notice and this permission notice shall be included in all #
# copies or substantial portions of the Software. #
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR #
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, #
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE #
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER #
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, #
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE #
# SOFTWARE. #
import sys
import pytuya
import socket #needed for socket.timeout exception
if(len(sys.argv)!=4):
print("usage: " + sys.argv[0] + " <IP> <DevID> <DevKey>")
exit(1)
ip = sys.argv[1]
devid = sys.argv[2]
devkey = sys.argv[3]
device = pytuya.OutletDevice(devid,ip,devkey)
data = 0 #stub for the try except
try:
except (ConnectionResetError, socket.timeout, OSError) as e:
print("A problem occur please retry...")
exit(1)
print("\nPlug State Information:")
print(data)
print("\nPlug DPS List:")
dps_list = ""
first=True
for key in data['dps'].keys():
if(type (data['dps'][key]) is bool):
if(not first):
dps_list += ";"
dps_list += str(int(key))
first=False
print(dps_list)
My other 2 scripts:
turnON.py
#!/usr/bin/python3
# MIT License #
# SOFTWARE. #
import sys
import pytuya
if(len(sys.argv)!=5):
print("usage: " + sys.argv[0] + " <IP> <DevID> <Local key> <DPS value>")
exit(1)
ip = sys.argv[1]
devid = sys.argv[2]
localkey = sys.argv[3]
dps_value = sys.argv[4]
device = pytuya.OutletDevice(devid,ip,localkey)
try:
payload = device.generate_payload('set', {str(dps_value):True})
device._send_receive(payload)
exit(1)
turnOFF.py
#!/usr/bin/python3
# MIT License #
# SOFTWARE. #
import sys
import pytuya
exit(1)
ip = sys.argv[1]
devid = sys.argv[2]
try:
payload = device.generate_payload('set', {str(dps_value):False})
exit(1)
Now to get the plugin working...
Posted: Monday 23 September 2019 8:00
by FearNaBoinne
xavierlp wrote: Friday 20 September 2019 16:42
It's hard to say without having the actual code as you're running it in your environment, but 'KeyError' often refers to missing dictionary items. For instance, the Parameters dictionary only has 6 entries (Mode1 - Mode6), trying to use Mode7 will not work, because it doesn't exist and referring to it (ie Parameters["Mode7"]) would generate a key error.
You'd have to go in to plugin.py and look at line 534 to see what is happening there...
Posted: Monday 23 September 2019 13:58
by xavierlp
Hello FearNaBoine
The line 534 is
_plugin.onMessage(Connection, Data)
from the
def onMessage(Connection, Data):
global _plugin
So nothning very clear.
so I read your previous message and I updated the get_dps.py
I've got now this message ValueError: Input strings must be a multiple of 16 in length
sudo python3.5 get_dps.py 192.168.1.23 55142707bcddc295f96a c6e4fd6a1f14fe20
DEBUG:pytuya:json_payload=b'{"devId":"55142707bcddc295f96a","gwId":"55142707bcddc295f96a"}'
DEBUG:pytuya:status received data=b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00\x1d\x00\x00\x00\x01data format errorM\xdf\x82\xac\x00\x00\xaaU'
DEBUG:pytuya:result=b'data format error'
File "get_dps.py", line 48, in <module>
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/pytuya/__init__.py", line 308, in status
result = cipher.decrypt(result, False)
File "/home/pi/domoticz/plugins/Domoticz-Tuya-SmartPlug-Plugin/pytuya/__init__.py", line 87, in decrypt
raw = cipher.decrypt(enc)
File "/usr/local/lib/python3.5/site-packages/Crypto/Cipher/blockalgo.py", line 295, in decrypt
return self._cipher.decrypt(ciphertext)
SO I removed the plugin from smartdevice app on my android and rerun the process but I have the same key and same error message.
Any ideas ?
thanks a lot
Xavier
Posted: Monday 23 September 2019 14:13
by FearNaBoinne
What about line 442?
When I run the script I do not get debug output, so I may be doing something wrong there, but I *do* get useful response data:"
{'devId': '70116356840d8e5c3382', 'dps': {'1': False, '9': 0}}
Plug DPS List:
1
(Of course, your dual plug may just be incompatible with the default plugin)
Posted: Monday 23 September 2019 14:20
by xavierlp
On the line 442
I can read Devices[key+1].Update(0,str(state[str(self.__ampere)]/1000)) # TypeName="Current (Single)
for key in self.__plugs:
error = error or self.__plugs[key].update_state(state[str(key)])
442-->>>>> Devices[key+1].Update(0,str(state[str(self.__ampere)]/1000)) # TypeName="Current (Single)
Devices[key+2].Update(0,str(state[str(self.__watt)]/10) + ";0") # kWh / Calculated
Devices[key+3].Update(0,str(state[str(self.__voltage)]/10)) # TypeName="Voltage"
Devices[key+4].Update(0,str(state[str(self.__watt)]/10)) # TypeName="Usage"
Posted: Monday 23 September 2019 14:22
by xavierlp
For debugging I uncomment theses lines in __ini__.py
log = logging.getLogger(__name__)
logging.basicConfig() # TODO include function name/line numbers in log
log.setLevel(level=logging.DEBUG) # Debug hack!
Posted: Monday 23 September 2019 15:04
by FearNaBoinne
My output shows the devID and gwID in reversed order compared to yours:
INFO:pytuya:Python 3.7.3 (default, Apr 3 2019, 05:39:12)
[GCC 8.2.0] on linux
INFO:pytuya:Using PyCrypto from '/usr/lib/python3/dist-packages/Crypto/__init__.py'
DEBUG:pytuya:json_payload=b'{"gwId":"70116356840d8e5c3382","devId":"70116356840d8e5c3382"}'
DEBUG:pytuya:status received data=b'\x00\x00U\xaa\x00\x00\x00\x00\x00\x00\x00\n\x00\x00\x00L\x00\x00\x00\x00#H7\x00\x03\xe9\xb5p\x18\xdf`?\xa5+\x9f \x7f#\xf4\xe14)\x0f_5\xa1\x93\xb92f\xf1\xecp(\xff\xda\x9dT\xbeZ\xc4\xca\xbaSi@\x892\x14\xc3\x89\xbb2\xe6\x82\x02\xabI\xe0\x9c\xf9\x18\x7fQ`\x02\xba-\x00\x00\xaaU'
DEBUG:pytuya:result=b'#H7\x00\x03\xe9\xb5p\x18\xdf`?\xa5+\x9f \x7f#\xf4\xe14)\x0f_5\xa1\x93\xb92f\xf1\xecp(\xff\xda\x9dT\xbeZ\xc4\xca\xbaSi@\x892\x14\xc3\x89\xbb2\xe6\x82\x02\xabI\xe0\x9c\xf9\x18\x7fQ'
DEBUG:pytuya:decrypted result='{"devId":"70116356840d8e5c3382","dps":{"1":false,"9":0}}'
Plug DPS List:
1
Not sure whether that is the 'data format error' referenced in your output...
Posted: Monday 23 September 2019 15:12
by tete
FearNaBoinne wrote: Sunday 22 September 2019 22:27
# MIT License #
I've made these changes and now I can get the plugin working.
{'devId': '60417563840d8e68fe98', 'dps': {'22': 626, '19': 1334, '23': 34433, '9': 0, '20': 2358, '18': 634, '1': True, '24': 19774, '21': 1, '25': 1045}}
Plug DPS List:
1
However, when I add the device to domoticz, the values are 0 and neither does work the on / off function.
But it works the on / off by command line (turnON.py, turnOFF.py).
What could be wrong?
Posted: Monday 23 September 2019 15:56
by xavierlp
FearNaBoinne wrote: Monday 23 September 2019 15:04
Plug DPS List:
1
What is strange for my side is that key and device id are the same !!!!
Posted: Monday 23 September 2019 16:00
by FearNaBoinne
It's not key and devID, it's devID and gwID... They key is different, but not shown in the debug info...
