Page 14 of 28
Re: Dashticz - Bug report
Posted: Friday 17 November 2017 9:45
by DewGew
htilburgs wrote: Friday 17 November 2017 9:23
@robgeerts, in the latest beta the language 'nl_NL' is not committed anymore. Bar is in english.
Going to setup, the language is empty and I'm not able to set it either through Setup of in config.JS.
I had same problem, i had to clear localstorage in my webbrowser. try that first.
Posted: Friday 17 November 2017 10:02
by htilburgs
I've cleared my browser already. It's the first thing I do after an update
Problem did still exists. I've removed the dashticz (beta) installation and did a new git pull --branche beta, restored custom folder and now it's working again. Strange behaviour.
Posted: Friday 17 November 2017 10:06
by aiolos
There was a small bug in the code from the speak_lang setting. It did overwrite the language, causing weird behaviour. I saw Rob just merged the PR's, so the problem should be gone.
Posted: Friday 17 November 2017 10:08
by DewGew
htilburgs wrote: Friday 17 November 2017 10:02
If you are using chrome. try this:
Hit F12 the find the Application tab. find "storage" click at "local storage" then right click on your domoticz url and click clear.
Posted: Friday 17 November 2017 10:13
by htilburgs
DewGew wrote: Friday 17 November 2017 10:08
Thanx, that's new for me. Never to old to learn....
1 down, 1 to go....
Using Dashticz in IE11 gives error in beta since 16-11:
getBlock is niet gedefinieerd
main.js (276,8)
line 276: getBlock(columns['bar'],'bar','div.screen'+s+' .row .colbar',false);
I'm using a Microsoft Surface RT and only have IE11 available.
On my Microsoft Surface Pro 3 I have the same issue in IE11. In Google Chrome it still works...
Posted: Friday 17 November 2017 10:32
by aiolos
htilburgs wrote: Friday 17 November 2017 10:13
main.js (276,8)
I fixed it in a new PR Rob can merge. It looks like IE11 uses an older version of javascript. In the blocks-code some functionality from a newer version was used since it looks cleaner in code, but unfortunately it didn't work.
Posted: Friday 17 November 2017 10:43
by DewGew
It seems that custom.js is not loading in lataste beta?? or is it just my setup??
Posted: Friday 17 November 2017 10:49
by aiolos
I don't use it myself, but if I test it with some simple logging to the console, I see that logging.
Posted: Friday 17 November 2017 10:53
by DewGew
This dont work anymore:
// Change block background color
function getStatus_245(idx,value,device){
if(device['Data']=='On'){
$('div.block_245').addClass('warning');
else {
$('div.block_245').removeClass('warning');
Posted: Friday 17 November 2017 11:01
by aiolos
If I paste that in my custom.js it is executed.
with this css:
.warning {
background-color: red !important;
it is getting a red background if the device is on.
Posted: Friday 17 November 2017 11:04
by htilburgs
DewGew wrote: Friday 17 November 2017 10:43
I can confirm.
In latest Stable version custom.js still works
in latest Beta versieon custom.js is broken
Posted: Friday 17 November 2017 13:52
by aiolos
Can it be something that has to do with
this change?
It looks like the execution of getStatus_* is now depending on more settings, which might initially not be set at all:
if(typeof(onOffstates[idx])!=='undefined' && value!==onOffstates[idx]){
Posted: Friday 17 November 2017 14:05
by DewGew
aiolos wrote: Friday 17 November 2017 13:52
this change?
Yes it does. I commented that part out and now its working. How can we get around this issue?
Posted: Friday 17 November 2017 14:14
by aiolos
Move the try-catch outside the if statement for the onOffStates. It was not in there before the change, so it is not necessary for the getStatus_* function.
Edit: I think it is even better to move the code for the sound or speak to the triggerChange function. That function already handles the case where a status has changed. Now there is quite some duplication between triggerStatus() and triggerChange()
Posted: Friday 17 November 2017 14:26
by DewGew
this change?
I made a PR to fix this ..
Posted: Friday 17 November 2017 14:43
by htilburgs
Posted: Friday 17 November 2017 22:23
by DewGew
htilburgs wrote:
Bugfix is now merged on latest beta
Posted: Friday 17 November 2017 22:31
by gijsje
I have a radiator valve from smartwares with type "Radiator 1" in domoticz and this shows up as light switch in dasticz.
I also have the thermostat with type "Thermostat" that shows as thermostat in Dashticz what is correct.
Could you change it somehow that the "Radiator 1" also shows that you can change the temperature?
Posted: Friday 17 November 2017 22:43
by robgeerts
Could you send me the device output from Domoticz of that device?
Posted: Friday 17 November 2017 22:45
by gijsje
How can i get this?
