Domoticz App
Jem101
Re: Domoticz App
Post by Jem101 »
For what it's worth, I'm not seeing any errors with the logs, variables or events. Pressing the Buttons displays the relevant info just fine on my iPhone. I'll try it on the iPad when I get a chance.
I firmly believe in having an open mind - although not so open that your brain falls out!
- sometimes attributed to Carl Sagan, but the original quote is much older than that
G3rard
Domoticz version: No
Re: Domoticz App
Post by G3rard »
I have a beta version on my iPad (think 0.030?) and there logs, user variables, events and rooms are working fine (except the barometer).
So it's strange it doesn't work on my iPhone with 1.01 and the same Domoticz environment.
Not using Domoticz anymore
johansson
Re: Domoticz App
Post by johansson »
Bought the full version (mainly to support the development, no real need for the add ons); looks ok, maybe a bit slower than Pilot. Some remarks:
- Adding the possibility to bring user variables to the Dashboard would be great; my car heating is controlled by a script, in which the required time is set as a user variable. Currently it's too may clicks away :)
- Location of + and - buttons of thermostat is a bit irrational, should be other way around:
koowee
Re: Domoticz App
Post by koowee »
Thanks for a great app! Are you going to add support for more than one Domoticz servers?
galadril
Domoticz version: latest
Re: Domoticz App
Post by galadril »
koowee wrote: Wednesday 06 September 2017 7:43 Thanks for a great app! Are you going to add support for more than one Domoticz servers?
Thanks on my list yes
galadril
Re: Domoticz App
Post by galadril »
johansson wrote: Tuesday 05 September 2017 14:32 - Adding the possibility to bring user variables to the Dashboard would be great; my car heating is controlled by a script, in which the required time is set as a user variable. Currently it's too may clicks away :)
Thanks also not possible in Domoticz itself right?
I try to stick to the Domoticz basics..
johansson wrote: Tuesday 05 September 2017 14:32 - Location of + and - buttons of thermostat is a bit irrational, should be other way around:
Valid point :)
galadril
Re: Domoticz App
Post by galadril »
G3rard wrote: Monday 04 September 2017 23:54 I have a beta version on my iPad (think 0.030?) and there logs, user variables, events and rooms are working fine (except the barometer).
The latest beta is 0.0.33 as of yesterday. do you have that one?
galadril
Re: Domoticz App
Post by galadril »
galadril wrote: Wednesday 06 September 2017 7:53
maybe the numbering looks a bit weird.. but 0.0.33 is a buildnumber, and 1.01 is a releasenumber in Apple..
At this moment 0.0.33 beta is a new beta after the 1.0.1 release :)
Need to see how we can make that more clear..
galadril
Re: Domoticz App
Post by galadril »
if somebody still has startup issues.. please send me a view-account on your system so i can debug why....
G3rard
Re: Domoticz App
Post by G3rard »
Just installed 0.0.33 on my iPhone. But I still have the same errors (also after deleting and re-installing the app), see below.
On the iPad with an older beta version (0.030?) everything (except barometer) works fine.
JSON Call: http://192.168.1.157:8084/json.htm?type=plans
The CancellationTokenSource has been disposed.
Object reference not set to an instance of an object
JSON Call: http://192.168.1.157:8084/json.htm?type=devices&filter=all&used=true&favorite=1
Fout: geen verbinding met netwerk
JSON Call: http://192.168.1.157:8084/json.htm?type=scenes
galadril
Re: Domoticz App
Post by galadril »
G3rard wrote: Wednesday 06 September 2017 8:48 Fout: geen verbinding met netwerk
I do know that there was an issue with a crash on wrong connection settings...
so maybe that is the issue. I just fixed that in the upcoming beta (0.0.34)
G3rard
Domoticz App
Post by G3rard »
The app logo is looking a bit strange in v0.033.
Edit: will try v0.034 to see if that solves the issues with the connection.
Last edited by G3rard on Wednesday 06 September 2017 8:56, edited 2 times in total.
galadril
Re: Domoticz App
Post by galadril »
G3rard wrote: Wednesday 06 September 2017 8:56 The app logo is looking a bit strange in v0.033.
the previous icon was a bit to purple
G3rard
Re: Domoticz App
Post by G3rard »
Okay, but I meant the black border. It seems the logo hasn't the right size and therefore the black border is shown.
Vomera
Re: Domoticz App
Post by Vomera »
Tnx for the app i'm very happy you lauched this.
I have only a small problem, i think ;)
When i setup the connection i get the message unautorized.
On my domoticz i installed the latest stable version Domoticz V3.8153
I used the login data from the setup->settings->system tab->Website Protection (pulldown menu says login page)
That doesnt work.
Also made a new user account on the setup->more options->edit users
also that doesnt work.
I'm sure i used the right username and password.
Anyone other tips?
EDIT: Solved by setting the pulldownmenu to login basic Auth
Last edited by Vomera on Wednesday 06 September 2017 9:43, edited 1 time in total.
galadril
Re: Domoticz App
Post by galadril »
Vomera wrote: Wednesday 06 September 2017 9:22 Tnx for the app i'm very happy you lauched this.
Vomera wrote: Wednesday 06 September 2017 9:22 I have only a small problem, i think ;)
Anyone other tips?
(i do it via login screen settings)
http://ip:port/#/Setup
galadril
Re: Domoticz App
Post by galadril »
G3rard wrote: Wednesday 06 September 2017 9:00 Okay, but I meant the black border. It seems the logo hasn't the right size and therefore the black border is shown.
should be fixed in the next beta, thanks for pointing ;)
johansson
Re: Domoticz App
Post by johansson »
galadril wrote: Wednesday 06 September 2017 7:49 Thanks also not possible in Domoticz itself right?
Don't think so, user variables have to be set through Setup > More options > User variables. Please keep this in mind as well, a shortcut for these would be great.
Domoticzfun
Domoticz version: 3.8153
Re: Domoticz App
Post by Domoticzfun »
Sorry if part of my remarks are already said in this thread, I haven't red all 278 posts. I installed the latest version from the app store and I wanted to give you a heads up, you did a wonderful job, thanks!
I used it for now only in my local network and with username/password validation. This is what I found out while using the app for an hour or so:
  • App crashes in the setup when setting no or wrong port. After filling with the correct info and using http instead of https with untrusted certificate (uuuh...) it works fine. An helpfull error message is appreciated.
  • Temperature decimals is presented with decimal point and at other places (dauwpunt) with comma seperator. One used format is preferred, in my case a comma seperator would be great.
    One can discuss the chosen number of decimals. Only very expensive and precise calibrated thermometers are worth showing 2 or maybe 1 decimal.
  • Humidity is only shown with a name e.g. "wet" and not the percentage.
  • Last seen times in days and hours, hours and minutes, seconds and milliseconds ago. Can I choose for showing me "Last seen time and date" instead? (wishlist)
  • Gas meter shows only total for today, not grand total on meter (the raw value is recieved from P1 Smart meter USB). Electricity does show actual, today an total use. The Android app doesn't do this too but this is on my wishlist.
  • The Dashboard seems not to be sorted like the webpage, where you can order the icons like you wish. Is this possible?
Best regards,
Domoticzfun
HansieNL
Re: Domoticz App
Post by HansieNL »
Using IOS version 1.01, but can't set the color of my Hue lights?
Blah blah blah
