Page 14 of 123
Posted: Friday 06 January 2017 7:34
by corbin
PABben wrote:So the xiaomi is using wifi to communicate. I assume it is using an existing wan so it can be connected to the lan where the domoticz server is for easy connection to the gateway?
Is this device what i need as a gateway? (URL in spoiler)
http://www.ebay.com/itm/Original-Xiaomi ... SwmLlX9ggm
The gateway connects to your WiFi network, and communicates with devices via Zigbee wireless. It is very simple to setup.
That ebay gateway looks fine, but cheaper from http://www.gearbest.com/living-applianc ... tml?wid=21
Posted: Friday 06 January 2017 7:37
by corbin
deennoo wrote:Maybe never if we can add more than 10 devices and the wall plug+230v wall switch act as a real zigbee device and create a mesh network
We know it supports at least 21 devices, see if you can break the limit! Multiple gateways may work already in Domoticz just waiting for someone to test it.
Posted: Friday 06 January 2017 7:45
by corbin
levynger wrote:Corbin, The default value for the door sensor is "Open"?
i have restart the domoticz server now, and eventhough the state seems to be open.. at least till i open and close the door..
i think the default value for door and motion should be Closed/Off be default.
Can you check this again please? When adding new door sensors on my network, they detect in whatever state they are currently in, which is closed.
If it still detects as open when it is in fact closed, detail your setup and I'll look into it.
Posted: Friday 06 January 2017 12:36
by Coldman
Home sales February 28, price ~$15USD
Отправлено с моего MI PAD 2 через Tapatalk
Posted: Friday 06 January 2017 17:08
by jelvs
Hi, i’m thinking about buying a xiaomi universal ir remote controller, to use with domoticz, and later on to interact with alexa using the echo dot, do you know if it's possible? Thanks
Posted: Friday 06 January 2017 17:41
by deennoo
jelvs wrote:Hi, i’m thinking about buying a xiaomi universal ir remote controller, to use with domoticz, and later on to interact with alexa using the echo dot, do you know if it's possible? Thanks Image
If this an ir remote : you need an ir reciever and a soft/app who send http request.
Actually ir solutikn from xiaomi isn't gateway compatible and no api for this.
Got this solution using an logitech harmony and lirc on a Pi running openelec, i drive light and tv corner with this.
Aqara gateway isn't IR.
Have a look to sevenhugs smart remote
https://remote.sevenhugs.com
THIS will be the master remote for home automation.
Will get mine on July.
Posted: Friday 06 January 2017 17:51
by jelvs
Oh thks, but I'm still checking for the most practical way to use it with my phone. I read that the broadlink rm2 pro can do it and it is quite cheap as well
Posted: Saturday 07 January 2017 5:25
by dcliff1
I have 24 devices, soon to be 26 :)
Works well!
Posted: Saturday 07 January 2017 8:28
by corbin
dcliff1 wrote: I have 24 devices, soon to be 26 :)
Works well!
Who is going to be the first to find the limit? I've got a few more sensors to deploy here but will only bring me up to 20.
Posted: Saturday 07 January 2017 8:33
by corbin
corbin wrote: We know it supports at least 21 devices, see if you can break the limit! Multiple gateways may work already in Domoticz just waiting for someone to test it.
I just realised multiple gateways won't work with the way I have coded it. Hope it won't be needed but can update later if it is.
Posted: Saturday 07 January 2017 13:55
by Coldman
Hi, I'm trying to use Events and can't to get Humidity sValues of sensor, there is showing abnormal values "1" or "2", a value of Temperature is ok.
Posted: Sunday 08 January 2017 15:05
by jjnj
Does anybody know if the motion sensor can be used outside? Would be nice to let the lights react to motion outdoors.
Posted: Sunday 08 January 2017 15:27
by Mooseknuckle
Hi guys,
Just got my gateway and some sensors and they work great. Thanks for implementing this in Domoticz. Going to buy some more sensors now.
Posted: Sunday 08 January 2017 15:50
by deennoo
jjnj wrote:Does anybody know if the motion sensor can be used outside? Would be nice to let the lights react to motion outdoors.
For 8€ you can give a try, not fully outside but with a protection it can do the job.
Be carefull of cat walking.
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Posted: Sunday 08 January 2017 15:57
by jjnj
Thats true, but i would order extra in case of or being waterproof. I will try one first
Posted: Sunday 08 January 2017 16:37
by Mooseknuckle
At the moment I have 1 motion sensor. When I check the Domoticz log after the sensor has detected motion I see a no_motion event 1 minute after the first no_motion and again a no_motion event after 2, 5 and 10 minutes. Is that normal behaviour?
17:09:17.225 {"cmd":"report","model":"motion","sid":"158d0000fd3203","short_id":7232,"data":"{\"status\":\"no_motion\"}"}
17:10:17.129 {"cmd":"report","model":"motion","sid":"158d0000fd3203","short_id":7232,"data":"{\"status\":\"no_motion\"}"}
17:12:16.945 {"cmd":"report","model":"motion","sid":"158d0000fd3203","short_id":7232,"data":"{\"status\":\"no_motion\"}"}
17:17:16.516 {"cmd":"report","model":"motion","sid":"158d0000fd3203","short_id":7232,"data":"{\"status\":\"no_motion\"}"}
17:27:15.645 {"cmd":"report","model":"motion","sid":"158d0000fd3203","short_id":7232,"data":"{\"status\":\"no_motion\"}"}
Posted: Sunday 08 January 2017 18:44
by icibt
WrathfulFab wrote:Update to a beta version? Domoticz or my Gateway?
My domoticz version is 3.6288
My gateway version is 1.4.1_142.0141
Are you installing Domoticz on Windows 10 64bit? If that is the case, you won't see any devices... don't know why. Others have the same problem.
Posted: Sunday 08 January 2017 18:52
by deennoo
Maybe open udp port who is use for gateway spoking on your windows firewall
Posted: Sunday 08 January 2017 19:16
by WrathfulFab
I didn't install it on Win10, i use the Docker container with XPenology.
I tested my Gateway with Packetsender and all the parameters seems good.
And i still don't see my devices (actually i just left one devices)
And i have some doubt about my Domoticz version 3.6288. I couldn't find any information about this one. Maybe it's a docker specific version
Posted: Sunday 08 January 2017 21:08
by Sevift
Sevift wrote:Xiaomi Mi Robot Vacuum - Is that possible? )
it's possible!
Снимок экрана 2017-01-08 в 21.06.53.png (36.59 KiB) Viewed 6641 times
