corbin
Post by corbin »
PABben wrote:So the xiaomi is using wifi to communicate. I assume it is using an existing wan so it can be connected to the lan where the domoticz server is for easy connection to the gateway?
Is this device what i need as a gateway? (URL in spoiler)
http://www.ebay.com/itm/Original-Xiaomi ... SwmLlX9ggm
The gateway connects to your WiFi network, and communicates with devices via Zigbee wireless. It is very simple to setup.
That ebay gateway looks fine, but cheaper from http://www.gearbest.com/living-applianc ... tml?wid=21
corbin
Post by corbin »
deennoo wrote:Maybe never if we can add more than 10 devices and the wall plug+230v wall switch act as a real zigbee device and create a mesh network
We know it supports at least 21 devices, see if you can break the limit! Multiple gateways may work already in Domoticz just waiting for someone to test it.
corbin
Post by corbin »
levynger wrote:Corbin, The default value for the door sensor is "Open"?
i have restart the domoticz server now, and eventhough the state seems to be open.. at least till i open and close the door..
i think the default value for door and motion should be Closed/Off be default.
Can you check this again please? When adding new door sensors on my network, they detect in whatever state they are currently in, which is closed.
If it still detects as open when it is in fact closed, detail your setup and I'll look into it.
Coldman
Post by Coldman »
Home sales February 28, price ~$15USD
Отправлено с моего MI PAD 2 через Tapatalk
jelvs
Post by jelvs »
Hi, i’m thinking about buying a xiaomi universal ir remote controller, to use with domoticz, and later on to interact with alexa using the echo dot, do you know if it's possible? Thanks
deennoo
Post by deennoo »
jelvs wrote:Hi, i’m thinking about buying a xiaomi universal ir remote controller, to use with domoticz, and later on to interact with alexa using the echo dot, do you know if it's possible? Thanks Image
If this an ir remote : you need an ir reciever and a soft/app who send http request.
Actually ir solutikn from xiaomi isn't gateway compatible and no api for this.
Got this solution using an logitech harmony and lirc on a Pi running openelec, i drive light and tv corner with this.
Aqara gateway isn't IR.
Have a look to sevenhugs smart remote
https://remote.sevenhugs.com
THIS will be the master remote for home automation.
Will get mine on July.
http://domo-attitude.fr
jelvs
Post by jelvs »
Oh thks, but I'm still checking for the most practical way to use it with my phone. I read that the broadlink rm2 pro can do it and it is quite cheap as well
dcliff1
Post by dcliff1 »
I have 24 devices, soon to be 26 :)
Works well!
corbin
Post by corbin »
dcliff1 wrote: I have 24 devices, soon to be 26 :)
Works well!
Who is going to be the first to find the limit? I've got a few more sensors to deploy here but will only bring me up to 20.
corbin
Post by corbin »
corbin wrote: We know it supports at least 21 devices, see if you can break the limit! Multiple gateways may work already in Domoticz just waiting for someone to test it.
I just realised multiple gateways won't work with the way I have coded it. Hope it won't be needed but can update later if it is.
Coldman
Post by Coldman »
Hi, I'm trying to use Events and can't to get Humidity sValues of sensor, there is showing abnormal values "1" or "2", a value of Temperature is ok.
jjnj
Post by jjnj »
Does anybody know if the motion sensor can be used outside? Would be nice to let the lights react to motion outdoors.
Mooseknuckle
Post by Mooseknuckle »
Hi guys,
Just got my gateway and some sensors and they work great. Thanks for implementing this in Domoticz. Going to buy some more sensors now.
RPI 3, Philips Hue,Toon Thermostat, Harmony Smart Control, Yeelights
Mysensors wifi gateway + sensors, RFXtrx433E, Kaku stuff, Xiaomi gateway + sensors
Domoticz controlled DIY ambilight, Selectplus chime, Mi-light led controller
deennoo
Post by deennoo »
jjnj wrote:Does anybody know if the motion sensor can be used outside? Would be nice to let the lights react to motion outdoors.
For 8€ you can give a try, not fully outside but with a protection it can do the job.
Be carefull of cat walking.
jjnj
Re: RE: Re: RE: Re: Xiaomi Smart Home Suite (very cheap) compatibilty?
Post by jjnj »
Thats true, but i would order extra in case of or being waterproof. I will try one first
Mooseknuckle
At the moment I have 1 motion sensor. When I check the Domoticz log after the sensor has detected motion I see a no_motion event 1 minute after the first no_motion and again a no_motion event after 2, 5 and 10 minutes. Is that normal behaviour?
17:09:17.225 {"cmd":"report","model":"motion","sid":"158d0000fd3203","short_id":7232,"data":"{\"status\":\"no_motion\"}"}
17:10:17.129 {"cmd":"report","model":"motion","sid":"158d0000fd3203","short_id":7232,"data":"{\"status\":\"no_motion\"}"}
17:12:16.945 {"cmd":"report","model":"motion","sid":"158d0000fd3203","short_id":7232,"data":"{\"status\":\"no_motion\"}"}
17:17:16.516 {"cmd":"report","model":"motion","sid":"158d0000fd3203","short_id":7232,"data":"{\"status\":\"no_motion\"}"}
17:27:15.645 {"cmd":"report","model":"motion","sid":"158d0000fd3203","short_id":7232,"data":"{\"status\":\"no_motion\"}"}
icibt
Post by icibt »
WrathfulFab wrote:Update to a beta version? Domoticz or my Gateway?
My domoticz version is 3.6288
My gateway version is 1.4.1_142.0141
Are you installing Domoticz on Windows 10 64bit? If that is the case, you won't see any devices... don't know why. Others have the same problem.
deennoo
Post by deennoo »
Maybe open udp port who is use for gateway spoking on your windows firewall
WrathfulFab
Post by WrathfulFab »
I didn't install it on Win10, i use the Docker container with XPenology.
I tested my Gateway with Packetsender and all the parameters seems good.
And i still don't see my devices (actually i just left one devices)
And i have some doubt about my Domoticz version 3.6288. I couldn't find any information about this one. Maybe it's a docker specific version
Sevift
Domoticz version: Latest
Post by Sevift »
Sevift wrote:Xiaomi Mi Robot Vacuum - Is that possible? )
it's possible!
Снимок экрана 2017-01-08 в 21.06.53.png (36.59 KiB) Viewed 6638 times
