lapoor
Re: Domoticz app 2.0
Post by lapoor »
great app, bought the premium version.
Problems that I found:
Switches tab is not working I get a message Oops No data on Domoticz server, however when I switch on debugging I see all my switches present in the SwitchInfo blocks.
Improvements:
A setting to set the refresh rate of the widgets I guess the default time of 30 mins is now used
RoadXY
Domoticz version: 2.2331
Post by RoadXY »
lapoor wrote:great app, bought the premium version.
Should be fixed in next version
lapoor wrote:Improvements:
That would be against recommendation of Google which we are not going to do for now.
RoadXY
Post by RoadXY »
pepeEL wrote:When you release new beta or stable version please add in change log google play what is new or change or fix to we know whatvwe can test :-)
Wysłane z mojego SM-G920F przy użyciu Tapatalka
We will.
pepeEL
Post by pepeEL »
Good job :-) i am waiting for implement multilanguage and multiuser...
lapoor
Post by lapoor »
Great, thanks for the fast replay.
Is it also possible to get 1 tile widgets for switches? maybe change the font size to small and put the name above the switch?
galadril
Domoticz version: latest
Post by galadril »
New version coming today:
- Fix for not finding any switches
- Hide exit confirmation
- Wear devices alpha sorting
- Rewoked the json calls for getting switches
- Dimmer not working correctly
- Refresh in onResume
- Cleanup imports
- Change log/graph button color (grey)
Jango
Post by Jango »
Wow, you are fast! ;)
Verstuurd vanaf mijn E6853 met Tapatalk
pepeEL
Post by pepeEL »
Is super next good very fast job :-)
Jango
Post by Jango »
Found another problem. When i want to see the log off wattage usage from my christmas light i get the error message:
could not get Log for: Lichtstreng Electric.
It's a zwave switch, greenwave powernode 1
RoadXY
Post by RoadXY »
Jango wrote:Found another problem. When i want to see the log off wattage usage from my christmas light i get the error message:
Does it work on the Domoticz website?
Jango
Post by Jango »
Jango wrote:Hello developers,
Is it possible to generate separate graphs for temperature, humidity and barometer?
The ranges off the graphs are also very wide. If they are smaller you can see the fluctuations better.
Here is the graph with the temperature and barometer as you can see, you can not see the fluctuations very well.
Jango
Post by Jango »
Yes, it is ok on the website.
The Kwh usage is also not registered.
asjmcguire
Domoticz version: 3.5877
Post by asjmcguire »
galadril wrote:New version coming today:
- Cleanup imports
I meant to tell you by the way when we were conversing - In the premium app "export settings" fails - but the version you sent me to test (Lite) does export settings. I haven't tested whether the Lite version on the Play Store exports settings - but I know the premium version in the Play Store definitely does not.
EDIT: Nevermind - just installed the update from the Play Store and it exports and imports successfully. And I see that it supports Android Marshmallow autobackup - which will make switching to a new phone tomorrow so much easier. Loving the app - thanks guys.
AEOTEC ZStick, 11 ZWave Nodes, RFXCOMM, 50ish Byron Sockets.. HE851 (PIR), 2x HE852 (DoorContact)
WS2300, CM180, CC128, 2xTHGR122NX, 2xPiZeroW w/DS18B20, 8Ch 1W Relay Board.
8 Panasonic IP Cams, 1 16ch CCTV DVR + 15 CCTV Cams
Jango
Post by Jango »
I have installed the update, thanks!
The dimmer function is working ok now in tab switches.
In dashboard it keeps crashing.
pepeEL
Post by pepeEL »
Hello
I today update app. I use Fibaro RGBW - Zwave. And from app i can not dimm led RGBW and i can not set colors. Only can on/off and when i have ON i only can dimm. But when i dimm LED app was stoped. And i must restart app. I send you debug with my opinion and debug file. Please add features to set also color for LED by using RGBW Fibaro Zwave FGRGBWM-441
From web all works ok.
Session
Post by Session »
Hi. The app is great.
I have a suggestion though:
If a switch is dimmable the slider is so small it is nearly impossible to adjust it correct. Maybe make the slider full width so my fat fingers can adjust the light properly :D
pepeEL
Post by pepeEL »
Yes slider is too small but now not working correct.
jvdz
Domoticz version: 4.107
Post by jvdz »
A part of the reason for the small slider is that when the status is "Set Level" it shows the percentage twice:
data: Set Level: 50%, Level 50%
Maybe this can be made like is shown in the Dashboard Device bar showing On/Off/xx % in stead of showing the full content of data?
For me the Dimmer sliders causes also mostly a crash of the app.
Really nice app by the way! :)
Jos
Jango
Post by Jango »
Updated again, dimmer is working in dashboard now, no crash here!
pepeEL
Post by pepeEL »
Good job. Dimmer now works ok. Update fix it.
But still i can not set up color led on dimmer switch fibaro rgbw. Only can eneable switch and set dimm.
