Page 13 of 15
Re: Domoticz to Google Assistant integration
Posted: Sunday 23 February 2020 10:34
by Justintime
I can't get the service to run. Also i dont see config.yaml in the Domoticz-Google-Assistant folder. There is a file in the config folder. Do i need to rename and replace??
This is the error message. I saw another member had the same problem he had to remove the folder. Tried that but didnt work. I am a new user so didnt set it up.
As far as i understand i can acces the
http://localhost:3030/settings without setting up the rest first??
My device runs Buster.
● dzga.service - Domoticz-Google-Assistant Service
Loaded: loaded (/etc/systemd/system/dzga.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Sun 2020-02-23 10:22:50 CET; 6min ago
Process: 16981 ExecStart=/home/pi/Domoticz-Google-Assistant/env/bin/python3 /home/pi/Domoticz-Google-Assistant/ (code=exited, status=203/EXEC)
Main PID: 16981 (code=exited, status=203/EXEC)
Feb 23 10:22:50 raspberrypi systemd[1]: dzga.service: Service RestartSec=100ms expired, scheduling restart.
Feb 23 10:22:50 raspberrypi systemd[1]: dzga.service: Scheduled restart job, restart counter is at 5.
Feb 23 10:22:50 raspberrypi systemd[1]: Stopped Domoticz-Google-Assistant Service.
Feb 23 10:22:50 raspberrypi systemd[1]: dzga.service: Start request repeated too quickly.
Feb 23 10:22:50 raspberrypi systemd[1]: dzga.service: Failed with result 'exit-code'.
Feb 23 10:22:50 raspberrypi systemd[1]: Failed to start Domoticz-Google-Assistant Service.
Posted: Sunday 23 February 2020 12:24
by DewGew
Try start manually the you can see in terminal if there is any errors. If it works maby something is wrong in services.
cd /home/${USER}/
sudo systemctl stop dzga #If service is running
source Domoticz-Google-Assistant/env/bin/activate
python3 Domoticz-Google-Assistant
Posted: Sunday 23 February 2020 16:06
by Justintime
DewGew wrote: Sunday 23 February 2020 12:24
cd /home/${USER}/
There is no file or directory. I have checked with winscp. And indeed there is none.
pi@raspberrypi:~ $ cd /home/${USER}/
pi@raspberrypi:~ $ sudo systemctl stop dzga
pi@raspberrypi:~ $ source Domoticz-Google-Assistant/env/bin/activate
-bash: Domoticz-Google-Assistant/env/bin/activate: No such file or directory
pi@raspberrypi:~ $
- Naamloos.jpg (130.54 KiB) Viewed 4196 times
Posted: Monday 24 February 2020 7:20
by DewGew
Justintime wrote: Sunday 23 February 2020 16:06
simpliest is to remove Domoticz-Google-assistant:
cd /home/${USER/
sudo systemctl disable dzga
sudo rm /etc/systemd/system/dzga.service
sudo rm -r Domoticz-Google-Assistant
then run the installer:
bash <(curl -s https://raw.githubusercontent.com/DewGew/dzga-installer/master/install.sh)
Posted: Monday 24 February 2020 20:11
by Justintime
DewGew wrote:Justintime wrote: Sunday 23 February 2020 16:06
cd /home/${USER/
Thanks... Turneded out there was a checksum error on a Debian package from another source. So it only installed a part of your application.
On to the next challenges to get it to work.
Posted: Sunday 01 March 2020 22:04
by Justintime
Great everything is working fine now.
Got a problem with APi HomoGraph but I have set report state to False. As far as i have read it's a language issue? My language is Dutch.
Now i am trying to get the webcams to work on my Nest hub.
FFmpeg decoder is working i see a file being created in var/html/cam
But how do i get the stream created to the Hub?
I have tried http://domoticz_ip:port/cam/voordeur.m3u8
Do I oversee something??
Posted: Wednesday 04 March 2020 8:20
by DewGew
Justintime wrote: Sunday 01 March 2020 22:04
I have problem also with hls files.
But it works with this url
https://content.jwplatform.com/manifests/yp34SRmf.m3u8 ??
Somthing with decoding or headers or similar. I have no clue.
I manage to get it to work with mp4 file thou
Posted: Wednesday 04 March 2020 15:25
by DewGew
Dzga Beta(V.1.6.2) now supports
Thermostat modes
Merge selector device retaining the modes for thermostats, supports following levels:
Off - Heat - Cool - Auto - Eco
Add modes to thermostat:
- Create selector device with levels above
In thermostat description add:
<voicecontrol>
selector_modes_idx = 123
</voicecontrol>
or in config.yaml:
Device_Config:
234:
There is a small Bug! Selector device idx must to be lower than thermostat idx
Posted: Wednesday 04 March 2020 17:09
by EddyG
After this last update to 1.6.2 1 (or more) of my devices got type "Hidden" and is not visible anymore on my phone.
And Google home does not know this device anymore. Got a message that the device got disconnected.
How can I add this device again?
Posted: Thursday 05 March 2020 7:25
by DewGew
EddyG wrote: Wednesday 04 March 2020 17:09
What kind of device? light, temp, etc.
Do you have any settings for this device in description or in config.yaml?
Posted: Thursday 05 March 2020 9:47
by EddyG
Found it. accidentally mistyped an idx in the config.yaml.
Tnx.
Posted: Thursday 05 March 2020 11:18
by EddyG
Other question.
I have my cams running in Domoticz and connected to a switch. My cams do not support rtsp anymore (Foscam FI9803p latest firmware).
The url I use is not a stream but a snapshot and that works perfect every 1-2 seconds.
The url I use is:
http://192.168.x.x/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=#USERNAME&pwd=#PASSWORD
Is it possible to get those pictures in the rate of 1-2 seconds to my Chromecast?
Posted: Friday 06 March 2020 8:15
by DewGew
EddyG wrote: Thursday 05 March 2020 11:18
Other question.
The url I use is:
I cant help you with that. I know that Google Assistant (smart home) support streaming with:
- HLS (HTTP Live Streaming)
- DASH (Dynamic Adaptive Streaming over HTTP)
- Smooth Streaming
- Progressive MP4
You can get a separate solution like zonminder,
shinobi cctv or similar to get a streamurl from.
or Maybe this can help you
https://www.domoticz.com/forum/viewtopi ... 38&t=30644
Posted: Friday 06 March 2020 10:59
by EddyG
Tnx for the answers. I will look into those.
Posted: Sunday 08 March 2020 9:40
by Justintime
You also can make a switch which starts a script. And let VLC stream it to Chromecast.
Home assistant way... U can't make it to work
Install VLC
And this bash script works in ssh command.
#!/bin/bash
cvlc --sout="#chromecast{ip=192.168.1.XXX}" --demux-filter=demux_chromecast rtsp://admin:
[email protected]:xx0/Streaming/Channels/1/picture sleep 30 ; kill $!
Rtsp stream which suits your cam.
Unfortunately the bash script don't respond in Domoticz. Saw some other post with same complaint.
Edit:
It now works.
Type this in terminal. VLC become root.
sed -i 's/geteuid/getppid/' /usr/bin/vlc
Posted: Tuesday 10 March 2020 19:19
by ressof
I wonder if I can use Google to change a selector switch?
If it is possible can I have any text on the selector or must it be predefined?
Posted: Tuesday 10 March 2020 19:39
by DewGew
ressof wrote: Tuesday 10 March 2020 19:19
User: Turn on [Level Name] on living room light.
Google Assistant: Turning on [Level Name] on living room light?
Posted: Tuesday 10 March 2020 22:45
by Justintime
ressof wrote:Hi
You can fill in any name in the Domoticz description box. Something like this.
<voicecontrol>
nicknames = Eettafellamp
</voicecontrol>
Works great! Very happy with this integration.
Posted: Thursday 12 March 2020 11:12
by Ierlandfan
Can we ask Home for the status? Something like: what's the status of Diningroomlight?
Posted: Thursday 12 March 2020 11:15
by DewGew
Ierlandfan wrote: Thursday 12 March 2020 11:12
Not "status" but you can ask:
"Is Diningroom light is on?"
