Domoticz to Google Assistant integration
Alexa, Google Home and Siri
Justintime
Re: Domoticz to Google Assistant integration
Post by Justintime »
I can't get the service to run. Also i dont see config.yaml in the Domoticz-Google-Assistant folder. There is a file in the config folder. Do i need to rename and replace??
This is the error message. I saw another member had the same problem he had to remove the folder. Tried that but didnt work. I am a new user so didnt set it up.
As far as i understand i can acces the http://localhost:3030/settings without setting up the rest first??
My device runs Buster.
● dzga.service - Domoticz-Google-Assistant Service
   Loaded: loaded (/etc/systemd/system/dzga.service; enabled; vendor preset: enabled)
   Active: failed (Result: exit-code) since Sun 2020-02-23 10:22:50 CET; 6min ago
  Process: 16981 ExecStart=/home/pi/Domoticz-Google-Assistant/env/bin/python3 /home/pi/Domoticz-Google-Assistant/ (code=exited, status=203/EXEC)
 Main PID: 16981 (code=exited, status=203/EXEC)
Feb 23 10:22:50 raspberrypi systemd[1]: dzga.service: Service RestartSec=100ms expired, scheduling restart.
Feb 23 10:22:50 raspberrypi systemd[1]: dzga.service: Scheduled restart job, restart counter is at 5.
Feb 23 10:22:50 raspberrypi systemd[1]: Stopped Domoticz-Google-Assistant Service.
Feb 23 10:22:50 raspberrypi systemd[1]: dzga.service: Start request repeated too quickly.
Feb 23 10:22:50 raspberrypi systemd[1]: dzga.service: Failed with result 'exit-code'.
Feb 23 10:22:50 raspberrypi systemd[1]: Failed to start Domoticz-Google-Assistant Service.
DewGew
Domoticz version: V4.10618
Post by DewGew »
Try start manually the you can see in terminal if there is any errors. If it works maby something is wrong in services.
cd /home/${USER}/
sudo systemctl stop dzga #If service is running
source Domoticz-Google-Assistant/env/bin/activate
python3 Domoticz-Google-Assistant
Justintime
DewGew wrote: Sunday 23 February 2020 12:24 Try start manually the you can see in terminal if there is any errors. If it works maby something is wrong in services.
cd /home/${USER}/
There is no file or directory. I have checked with winscp. And indeed there is none.
pi@raspberrypi:~ $ cd /home/${USER}/
pi@raspberrypi:~ $ sudo systemctl stop dzga
pi@raspberrypi:~ $ source Domoticz-Google-Assistant/env/bin/activate
-bash: Domoticz-Google-Assistant/env/bin/activate: No such file or directory
pi@raspberrypi:~ $
DewGew
Post by DewGew »
Justintime wrote: Sunday 23 February 2020 16:06 Naamloos.jpg
simpliest is to remove Domoticz-Google-assistant:
cd /home/${USER/
sudo systemctl disable dzga
sudo rm /etc/systemd/system/dzga.service
sudo rm -r Domoticz-Google-Assistant
then run the installer:
bash <(curl -s https://raw.githubusercontent.com/DewGew/dzga-installer/master/install.sh)
Justintime
cd /home/${USER/
Thanks... Turneded out there was a checksum error on a Debian package from another source. So it only installed a part of your application.
On to the next challenges to get it to work.
Justintime
Great everything is working fine now.
Got a problem with APi HomoGraph but I have set report state to False. As far as i have read it's a language issue? My language is Dutch.
Now i am trying to get the webcams to work on my Nest hub.
FFmpeg decoder is working i see a file being created in var/html/cam
But how do i get the stream created to the Hub?
I have tried http://domoticz_ip:port/cam/voordeur.m3u8
Do I oversee something??
DewGew
Post by DewGew »
Justintime wrote: Sunday 01 March 2020 22:04 Great everything is working fine now.
I have problem also with hls files.
But it works with this url https://content.jwplatform.com/manifests/yp34SRmf.m3u8 ??
Somthing with decoding or headers or similar. I have no clue.
I manage to get it to work with mp4 file thou
DewGew
Post by DewGew »
Dzga Beta(V.1.6.2) now supports Thermostat modes
Merge selector device retaining the modes for thermostats, supports following levels: Off - Heat - Cool - Auto - Eco
Add modes to thermostat:
  • Create selector device with levels above
  • Create thermostat device
In thermostat description add:
<voicecontrol>
selector_modes_idx = 123
</voicecontrol>
or in config.yaml:
Device_Config:
  234:
There is a small Bug! Selector device idx must to be lower than thermostat idx
EddyG
Post by EddyG »
After this last update to 1.6.2 1 (or more) of my devices got type "Hidden" and is not visible anymore on my phone.
And Google home does not know this device anymore. Got a message that the device got disconnected.
How can I add this device again?
DewGew
Post by DewGew »
EddyG wrote: Wednesday 04 March 2020 17:09 After this last update to 1.6.2 1 (or more) of my devices got type "Hidden" and is not visible anymore on my phone.
What kind of device? light, temp, etc.
Do you have any settings for this device in description or in config.yaml?
EddyG
Post by EddyG »
Found it. accidentally mistyped an idx in the config.yaml. :oops: Tnx.
EddyG
Post by EddyG »
Other question.
I have my cams running in Domoticz and connected to a switch. My cams do not support rtsp anymore (Foscam FI9803p latest firmware).
The url I use is not a stream but a snapshot and that works perfect every 1-2 seconds.
The url I use is:
http://192.168.x.x/cgi-bin/CGIProxy.fcgi?cmd=snapPicture2&usr=#USERNAME&pwd=#PASSWORD
Is it possible to get those pictures in the rate of 1-2 seconds to my Chromecast?
DewGew
Post by DewGew »
EddyG wrote: Thursday 05 March 2020 11:18 Other question.
The url I use is:
I cant help you with that. I know that Google Assistant (smart home) support streaming with:
- HLS (HTTP Live Streaming)
- DASH (Dynamic Adaptive Streaming over HTTP)
- Smooth Streaming
- Progressive MP4
You can get a separate solution like zonminder, shinobi cctv or similar to get a streamurl from.
or Maybe this can help you https://www.domoticz.com/forum/viewtopi ... 38&t=30644
EddyG
Post by EddyG »
Tnx for the answers. I will look into those. :D
Justintime
You also can make a switch which starts a script. And let VLC stream it to Chromecast.
Home assistant way... U can't make it to work
Install VLC
And this bash script works in ssh command.
#!/bin/bash
cvlc --sout="#chromecast{ip=192.168.1.XXX}" --demux-filter=demux_chromecast rtsp://admin:[email protected]:xx0/Streaming/Channels/1/picture sleep 30 ; kill $!
Rtsp stream which suits your cam.
Unfortunately the bash script don't respond in Domoticz. Saw some other post with same complaint.
Edit:
It now works.
Type this in terminal. VLC become root.
sed -i 's/geteuid/getppid/' /usr/bin/vlc
ressof
Domoticz version: Latest
Post by ressof »
I wonder if I can use Google to change a selector switch?
If it is possible can I have any text on the selector or must it be predefined?
DewGew
Post by DewGew »
ressof wrote: Tuesday 10 March 2020 19:19 Hi
User: Turn on [Level Name] on living room light.
Google Assistant: Turning on [Level Name] on living room light?
Justintime
ressof wrote:Hi
You can fill in any name in the Domoticz description box. Something like this.
<voicecontrol>
nicknames = Eettafellamp
</voicecontrol>
Works great! Very happy with this integration.
Ierlandfan
Post by Ierlandfan »
Can we ask Home for the status? Something like: what's the status of Diningroomlight?
DewGew
Post by DewGew »
Ierlandfan wrote: Thursday 12 March 2020 11:12 Can we ask Home for the status? Something like: what's the status of Diningroomlight?
Not "status" but you can ask:
"Is Diningroom light is on?"
