Page 13 of 24
Re: Aurora theme
Posted: Monday 05 February 2018 10:34
by blauwebuis
When you change these privacy settings this is actually noted in the log (to leave a trail when someone 'tampers' with the privacy settings).
And you can change these settings under the theme settings.
I could make it so that it is no longer a default, in order to limit confusion.
Re: Aurora theme
Posted: Monday 05 February 2018 20:05
by bdormael
Small issue, I’ve combined several battery sensors together, but somewhere in the middle the layout is not correct, see screenshot,
Verzonden vanaf mijn iPad met Tapatalk
Re: Aurora theme
Posted: Tuesday 06 February 2018 0:52
by blauwebuis
@bdormael: that's not a bug. You can merge at most 6 items. This is precisely because more won't fit in a highlighted item. In this case you could disable highlighted items.
A NEW VERSION HAS BEEN UPLOADED
FIXES
- Fixed bug with fluid display on pages other than the front page.
- Tried to put back a more optimal alignment of fluid items. Hopefully it won't break anything.
NEW FEATURES
- Change the value of text items on the utilities page simply by clicking on the text value.
Re: Aurora theme
Posted: Tuesday 06 February 2018 6:37
by jeanclic
Thanks for the new version ! I will test it asap
Send via Tapatalk
Re: Aurora theme
Posted: Tuesday 06 February 2018 7:18
by jeanclic
just tried it now !
looks better for empty room.
New feature doesn't seem to work... did I missed something or do I just have to click on a text item to change its text ?
Re: Aurora theme
Posted: Tuesday 06 February 2018 8:36
by bdormael
Thx, didn't think about that, I've added 3 highlighted items, then the battery sensors, all is fine now, thx again for the kind support, I love this theme
Re: Aurora theme
Posted: Tuesday 06 February 2018 23:39
by blauwebuis
@bdormael: glad to hear it!
@jeanclic: yes, just click on the text, and it will transform into an input field. Click outside it when you are done changing it, and the new value will be stored. This makes it a lot easier to, for example, set the text of a LED display via MySensors.
Re: Aurora theme
Posted: Wednesday 07 February 2018 8:19
by jeanclic
Yes it works ! Thanks for having explain it again !
Send via Tapatalk
Re: Aurora theme
Posted: Sunday 11 February 2018 10:53
by Kivi
for some strange reason I cant see any history in switch page, history is empty
Re: Aurora theme
Posted: Monday 12 February 2018 9:46
by jeanclic
please read the first post regarding privacy...
Re: Aurora theme
Posted: Monday 12 February 2018 11:29
by emme
uhm... it might be possible to replace the grouping character from "-" to "_" ?
(or at least have it selectable?)
I have a lot of devices with the same prefix and _ separated... and a lot of scripts using such syntax... and I was wondering if there would be a way to avoid changing all scripts
thanks
ciao
M
Re: Aurora theme
Posted: Wednesday 14 February 2018 19:09
by Phantom
Great theme,
i have 1 issue with it, i am using the :
https://www.domoticz.com/wiki/Plugins/BatteryLevel.html plugin to monitor the battery level of my pir.
But when i combine those it looks really weird:
My other question is, there is an option "Show three highlighted items" is it possible to make this adjustable with a slider or number because i would like to have more then 3.
Re: Aurora theme
Posted: Wednesday 14 February 2018 20:05
by devros
jeanclic wrote: Tuesday 06 February 2018 7:18
just tried it now !
Really great feature... this way could be posiblle to hack domoticz and make switch with input text field ? With little modified selector switch and editable text? (I have selector switch connected to python script that play custom song (i have to edit selector switch python command) ....
Re: Aurora theme
Posted: Thursday 15 February 2018 0:10
by dagger38
BIGGG problems...
After installing the new design it was all white , so after reading , i cleared the app data cache in chrome.
Now i can bearly reatch the pi , sometimes , after a hard reset (unplug power
( ) the dashticz works , but the browser domoticz version gets :'browser cache refresh failed'...after that not even dashticz can reatch the pi?? 'deze site is niet bereikbaar' message...
After the hard reset i can also make contact whith the pi with my MOBAXTERM programm via ssl
What have i done wrong , and HOW TO FIX this...
HEELP
Re: Aurora theme
Posted: Thursday 15 February 2018 9:44
by kevinbiri
bonjour je viens d'installer le théme aurora aujourdhui mais j'ai un graphique qui ne va pas du tout j'ai éffacé le cache isntaller en ftp et en direct sur la raspberry mais rien n'y fair help me please
Re: Aurora theme
Posted: Thursday 15 February 2018 10:08
by CLEMENT99
kevinbiri wrote: Thursday 15 February 2018 9:44
Tu utilises quel navigateur ?
Re: Aurora theme
by Cletus
@kevinbiri Please note that this is an english speaking forum.
I have the same thing though, all white
Re: Aurora theme
Posted: Thursday 15 February 2018 10:15
by EdwinK
Looks like the css isn't working properly. Maybe if you try installing the theme again
Re: Aurora theme
Posted: Thursday 15 February 2018 10:37
by Cletus
Already tried that several times. No luck
Re: Aurora theme
Posted: Thursday 15 February 2018 11:19
by olinek2
It seems to work properly only on beta release.
