Page 13 of 16
Re: Python Plugin: Broadlink RM2 V3
Posted: Thursday 25 January 2018 15:38
by ChopCZ
Yes I can, here is the output :)
pi@raspberrypi:~ $ pip show broadlink
-bash: pip: command not found
pi@raspberrypi:~ $ pip3 show broadlink
Version: 0.6
Summary: Python API for controlling Broadlink IR controllers
Home-page: http://github.com/mjg59/python-broadlink
Author: Matthew Garrett
Author-email: [email protected]
License: UNKNOWN
Requires: pycrypto
pi@raspberrypi:~ $
Posted: Thursday 25 January 2018 17:11
by zak45
ChopCZ wrote: Thursday 25 January 2018 15:38 Yes I can, here is the output :)
Version: 0.6
License: UNKNOWN
Requires: pycrypto
pi@raspberrypi:~ $
this line Location: /home/pi/.local/lib/python3.5/site-packages
show us that you have installed broadlink under your user context. (you do not have used sudo)
you need now to copy the broadlink module located under this directory into the one search by your python framework installation.
Posted: Thursday 25 January 2018 20:50
by ChopCZ
I have tried what You suggested but the result was the same.
Domoticz is freezing as soon as it starts importing the broadlink module.
Sorry but I am not python programmer and by importing I mean when I do not comment the
import broadlink
line in the plygin.py file.
I have completlly uninstalled the broadlink module and reinstalled it by using
sudo pip3 install broadlink
And when I do pip3 show broadlink it outputs the following
Version: 0.6
License: UNKNOWN
Requires: pycrypto
Then I have copied the broadlink files with
pi@raspberrypi:~ $ sudo cp -r  /usr/local/lib/python3.5/dist-packages/broadlink /usr/lib/python3.5
But if I uncomment the import line in the plugin.py and restart the Domoticz, its freezing again.
I don't understand why importing the module is not working in the domoticz but it is working in my test script that I run in the console...
I don't know, what I am doing wrong.
Thank You for your help and sorry for my english... :oops:
Posted: Friday 26 January 2018 13:00
by zak45
ChopCZ wrote: Thursday 25 January 2018 20:50
domoticz python framework do not provide full/all feature as your python installation and had some limitations.
can you post your domoticz log just after you restart it ?
Posted: Friday 26 January 2018 19:51
by ChopCZ
Here is the Log, with import broadlink line commented in the plugin.py file
2018-01-26 19:48:47.748 Domoticz V3.8841 (c)2012-2018 GizMoCuz
2018-01-26 19:48:47.749 Build Hash: b86cc8ab, Date: 2018-01-24 15:06:19
2018-01-26 19:48:47.749 Startup Path: /home/pi/domoticz/
2018-01-26 19:48:47.789 Sunrise: 07:27:00 SunSet: 16:30:00
2018-01-26 19:48:47.789 Day length: 09:03:00 Sun at south: 11:05:00
2018-01-26 19:48:47.789 Civil twilight start: 06:51:00 Civil twilight end: 17:05:00
2018-01-26 19:48:47.789 Nautical twilight start: 06:12:00 Nautical twilight end: 17:45:00
2018-01-26 19:48:47.789 Astronomical twilight start: 05:34:00 Astronomical twilight end: 18:23:00
2018-01-26 19:48:47.789 EventSystem: reset all events...
2018-01-26 19:48:47.789 dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Kostka.lua
2018-01-26 19:48:47.910 PluginSystem: Started, Python version '3.5.3'.
2018-01-26 19:48:47.919 Active notification Subsystems: (0/14)
2018-01-26 19:48:47.920 WebServer(HTTP) started on address: :: with port 8080
2018-01-26 19:48:47.924 WebServer(SSL) started on address: :: with port 443
2018-01-26 19:48:47.926 Proxymanager started.
2018-01-26 19:48:47.927 Starting shared server on: :::6144
2018-01-26 19:48:47.927 TCPServer: shared server started...
2018-01-26 19:48:47.927 RxQueue: queue worker started...
2018-01-26 19:48:48.001 Incoming connection from: 192.168.1.3
2018-01-26 19:48:49.928 XiaomiGateway: will listen on 9898 for hardware id 2
2018-01-26 19:48:49.928 XiaomiGateway: Delaying worker startup...
2018-01-26 19:48:54.929 XiaomiGateway: Worker started...
2018-01-26 19:48:54.929 (Broadlink) Started.
2018-01-26 19:48:54.929 YeeLight Worker started...
2018-01-26 19:48:54.929 EventSystem: reset all events...
2018-01-26 19:48:54.968 XiaomiGateway: Using 192.168.1.228 for local IP address.
2018-01-26 19:48:54.968 dzVents: Write file: /home/pi/domoticz/scripts/dzVents/generated_scripts/Kostka.lua
2018-01-26 19:48:54.969 EventSystem: reset all device statuses...
2018-01-26 19:48:54.981 XiaomiGateway: RGB Gateway Detected
2018-01-26 19:48:55.059 (Xiaomi Gateway) Lighting Limitless/Applamp (Gateway Light)
2018-01-26 19:48:55.156 Python EventSystem: Initalizing event module.
2018-01-26 19:48:55.157 EventSystem: Started
2018-01-26 19:48:55.157 EventSystem: Queue thread started...
2018-01-26 19:48:55.292 PluginSystem: Entering work loop.
2018-01-26 19:48:55.467 {"cmd":"read_ack","model":"sensor_ht","sid":"158d0001df5c42","short_id":25545,"data":"{\"voltage\":2965,\"temperature\":\"2061\",\"humidity\":\"6673\"}"}
2018-01-26 19:48:55.468 {"cmd":"read_ack","model":"sensor_ht","sid":"158d0001b90443","short_id":4702,"data":"{\"voltage\":2995,\"temperature\":\"2126\",\"humidity\":\"6344\"}"}
2018-01-26 19:48:55.468 {"cmd":"read_ack","model":"cube","sid":"158d0001051622","short_id":1583,"data":"{\"voltage\":3015}"}
2018-01-26 19:48:55.468 {"cmd":"read_ack","model":"magnet","sid":"158d0001ad7157","short_id":32912,"data":"{\"voltage\":2975,\"status\":\"close\"}"}
2018-01-26 19:48:55.468 {"cmd":"read_ack","model":"motion","sid":"158d0001d54199","short_id":28091,"data":"{\"voltage\":3005}"}
2018-01-26 19:48:55.468 {"cmd":"read_ack","model":"motion","sid":"158d0001d524fd","short_id":31782,"data":"{\"voltage\":3045}"}
2018-01-26 19:48:55.469 {"cmd":"read_ack","model":"switch","sid":"158d00016bf52d","short_id":5394,"data":"{\"voltage\":3052}"}
2018-01-26 19:48:55.469 {"cmd":"read_ack","model":"sensor_magnet.aq2","sid":"158d0001ab3aea","short_id":3703,"data":"{\"voltage\":3025,\"status\":\"close\"}"}
2018-01-26 19:48:55.476 (Xiaomi Gateway) Temp (Xiaomi Temperature)
2018-01-26 19:48:55.481 (Xiaomi Gateway) Humidity (Vlhkost Pracovna)
2018-01-26 19:48:55.485 (Xiaomi Gateway) Temp (Xiaomi Temperature)
2018-01-26 19:48:55.488 (Xiaomi Gateway) Humidity (Vlhkost Ložnice)
2018-01-26 19:48:55.492 (Xiaomi Gateway) Temp (Xiaomi Temperature)
2018-01-26 19:48:55.495 (Xiaomi Gateway) Humidity (Vlhkost Obývák)
2018-01-26 19:48:55.499 (Xiaomi Gateway) Temp (Xiaomi Temperature)
2018-01-26 19:48:55.502 (Xiaomi Gateway) Humidity (Vlhkost Dětský)
2018-01-26 19:48:55.523 (Broadlink) Entering work loop.
2018-01-26 19:48:55.523 (Broadlink) Initialized version 3.0.0, author 'zak45'
2018-01-26 19:48:55.528 (Broadlink) Debug log level set to: 'true'.
2018-01-26 19:48:55.528 (Broadlink) 'Mode6':'Debug'
2018-01-26 19:48:55.529 (Broadlink) 'Port':'0'
2018-01-26 19:48:55.529 (Broadlink) 'HardwareID':'6'
2018-01-26 19:48:55.529 (Broadlink) 'Name':'Broadlink'
2018-01-26 19:48:55.529 (Broadlink) 'DomoticzVersion':'3.8841'
2018-01-26 19:48:55.529 (Broadlink) 'Mode2':'/home/pi/domoticz/broadlink_ini'
2018-01-26 19:48:55.529 (Broadlink) 'HomeFolder':'/home/pi/domoticz/plugins/Broadlink/'
2018-01-26 19:48:55.529 (Broadlink) 'DomoticzHash':'b86cc8ab'
2018-01-26 19:48:55.529 (Broadlink) 'Mode3':'no'
2018-01-26 19:48:55.529 (Broadlink) 'Version':'3.0.0'
2018-01-26 19:48:55.529 (Broadlink) 'DomoticzBuildTime':'2018-01-24 15:06:19'
2018-01-26 19:48:55.529 (Broadlink) 'Key':'BroadlinkRM2'
2018-01-26 19:48:55.529 (Broadlink) 'Address':'127.0.0.1'
2018-01-26 19:48:55.529 (Broadlink) 'Mode4':'no'
2018-01-26 19:48:55.529 (Broadlink) 'Mode5':'9000'
2018-01-26 19:48:55.529 (Broadlink) 'Mode1':'000000000000'
2018-01-26 19:48:55.529 (Broadlink) 'Author':'zak45'
2018-01-26 19:48:55.529 (Broadlink) Device count: 2
2018-01-26 19:48:55.529 (Broadlink) Device: 1 - ID: 52, Name: 'Broadlink - Discover', nValue: 0, sValue: 'Off'
2018-01-26 19:48:55.529 (Broadlink) Device ID: '52'
2018-01-26 19:48:55.529 (Broadlink) Device Name: 'Broadlink - Discover'
2018-01-26 19:48:55.529 (Broadlink) Device nValue: 0
2018-01-26 19:48:55.529 (Broadlink) Device sValue: 'Off'
2018-01-26 19:48:55.529 (Broadlink) Device LastLevel: 0
2018-01-26 19:48:55.529 (Broadlink) Device: 254 - ID: 53, Name: 'Broadlink - Remote', nValue: 0, sValue: ''
2018-01-26 19:48:55.529 (Broadlink) Device ID: '53'
2018-01-26 19:48:55.530 (Broadlink) Device Name: 'Broadlink - Remote'
2018-01-26 19:48:55.530 (Broadlink) Device nValue: 0
2018-01-26 19:48:55.530 (Broadlink) Device sValue: ''
2018-01-26 19:48:55.530 (Broadlink) Device LastLevel: 0
2018-01-26 19:48:55.530 (Broadlink) Connecting to: 127.0.0.1:000000000000
2018-01-26 19:48:55.530 Error: (Broadlink) Error Connecting to Broadlink device....
2018-01-26 19:48:55.530 (Broadlink) Device Number begin to : 1
2018-01-26 19:48:55.545 (Broadlink) No ini file :/home/pi/domoticz/broadlink_ini/remote/plugin_remote_6.ini
2018-01-26 19:48:55.545 (Broadlink) Custom Commands for Remote not managed
2018-01-26 19:48:55.545 (Broadlink) Heartbeat interval set to: 30.
Posted: Saturday 27 January 2018 12:30
by zak45
@ChopCZ
that looks ok from a plugin point of view... now maybe some conflict with your OS version etc...
Posted: Sunday 28 January 2018 9:19
by ChopCZ
I am running Domoticz on my raspberrypi v. 3
Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l
Do you have any idea where should I look for the solution?
Some kind of logging etc.
I would love to use my Broadlink with domoticz. :)
Posted: Sunday 28 January 2018 11:24
by zak45
give it a try with the v4 version, just released... who know ?.. but not so optimistic!!
Posted: Thursday 08 February 2018 16:42
by leandrosaltori
Estou tentando instalar o domoticz com broadlink em um PC Windows.
Após inslar o Phyton, tento executar o "SETUP.exe" disponibilizado no link- https://www.dropbox.com/sh/htyghey9e402 ... 3H36a?dl=0
Mas apresenta o seguinte erro na Instalação:
Alguem pode me ajudar:
ERRO:
"Broadlink RM2 python plugin install for Win"
" this need to be run with admin right "
"Search python version"
Python 3.6.4
" main module used by the plugin"
"Python version : " 36
Collecting broadlink
Using cached broadlink-0.6.tar.gz
Collecting pycrypto==2.6.1 (from broadlink)
Using cached pycrypto-2.6.1.tar.gz
Installing collected packages: pycrypto, broadlink
Running setup.py install for pycrypto ... error
Complete output from command "c:\program files (x86)\python36-32\python.exe" -u -c "import setuptools, tokenize;__file__='C:\\Users\\leand\\AppData\\Local\\Temp\\pip-build-vdyydfhi\\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\leand\AppData\Local\Temp\pip-gmir_fki-record\install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
creating build\lib.win32-3.6
creating build\lib.win32-3.6\Crypto
copying lib\Crypto\pct_warnings.py -> build\lib.win32-3.6\Crypto
copying lib\Crypto\__init__.py -> build\lib.win32-3.6\Crypto
creating build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\hashalgo.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\HMAC.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\MD2.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\MD4.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\MD5.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\RIPEMD.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA224.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA256.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA384.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\SHA512.py -> build\lib.win32-3.6\Crypto\Hash
copying lib\Crypto\Hash\__init__.py -> build\lib.win32-3.6\Crypto\Hash
creating build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\AES.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\ARC2.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\ARC4.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\blockalgo.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\Blowfish.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\CAST.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\DES.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\DES3.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_OAEP.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_v1_5.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\XOR.py -> build\lib.win32-3.6\Crypto\Cipher
copying lib\Crypto\Cipher\__init__.py -> build\lib.win32-3.6\Crypto\Cipher
creating build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\asn1.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\Counter.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\number.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\py3compat.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\randpool.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\RFC1751.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\winrandom.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\_number_new.py -> build\lib.win32-3.6\Crypto\Util
copying lib\Crypto\Util\__init__.py -> build\lib.win32-3.6\Crypto\Util
creating build\lib.win32-3.6\Crypto\Random
copying lib\Crypto\Random\random.py -> build\lib.win32-3.6\Crypto\Random
copying lib\Crypto\Random\_UserFriendlyRNG.py -> build\lib.win32-3.6\Crypto\Random
copying lib\Crypto\Random\__init__.py -> build\lib.win32-3.6\Crypto\Random
creating build\lib.win32-3.6\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\FortunaAccumulator.py -> build\lib.win32-3.6\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\FortunaGenerator.py -> build\lib.win32-3.6\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\SHAd256.py -> build\lib.win32-3.6\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\__init__.py -> build\lib.win32-3.6\Crypto\Random\Fortuna
creating build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\fallback.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\nt.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\posix.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\rng_base.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\__init__.py -> build\lib.win32-3.6\Crypto\Random\OSRNG
creating build\lib.win32-3.6\Crypto\SelfTest
copying lib\Crypto\SelfTest\st_common.py -> build\lib.win32-3.6\Crypto\SelfTest
copying lib\Crypto\SelfTest\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest
creating build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\common.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_AES.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC2.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC4.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_Blowfish.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_CAST.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES3.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_15.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_oaep.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_XOR.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Cipher
creating build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\common.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_HMAC.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD2.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD4.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD5.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_RIPEMD.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA224.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA256.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA384.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA512.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Hash
creating build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_AllOrNothing.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_chaffing.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_KDF.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_rfc1751.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Protocol
creating build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_DSA.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_ElGamal.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_importKey.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_RSA.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\PublicKey
creating build\lib.win32-3.6\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_random.py -> build\lib.win32-3.6\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_rpoolcompat.py -> build\lib.win32-3.6\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test__UserFriendlyRNG.py -> build\lib.win32-3.6\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Random
creating build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaAccumulator.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaGenerator.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_SHAd256.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\Fortuna
creating build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_fallback.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_generic.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_nt.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_posix.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_winrandom.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Random\OSRNG
creating build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_asn1.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_Counter.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_number.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_winrandom.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Util
creating build\lib.win32-3.6\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\test_pkcs1_15.py -> build\lib.win32-3.6\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\test_pkcs1_pss.py -> build\lib.win32-3.6\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\__init__.py -> build\lib.win32-3.6\Crypto\SelfTest\Signature
creating build\lib.win32-3.6\Crypto\Protocol
copying lib\Crypto\Protocol\AllOrNothing.py -> build\lib.win32-3.6\Crypto\Protocol
copying lib\Crypto\Protocol\Chaffing.py -> build\lib.win32-3.6\Crypto\Protocol
copying lib\Crypto\Protocol\KDF.py -> build\lib.win32-3.6\Crypto\Protocol
copying lib\Crypto\Protocol\__init__.py -> build\lib.win32-3.6\Crypto\Protocol
creating build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\DSA.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\ElGamal.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\pubkey.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\RSA.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\_DSA.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\_RSA.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\_slowmath.py -> build\lib.win32-3.6\Crypto\PublicKey
copying lib\Crypto\PublicKey\__init__.py -> build\lib.win32-3.6\Crypto\PublicKey
creating build\lib.win32-3.6\Crypto\Signature
copying lib\Crypto\Signature\PKCS1_PSS.py -> build\lib.win32-3.6\Crypto\Signature
copying lib\Crypto\Signature\PKCS1_v1_5.py -> build\lib.win32-3.6\Crypto\Signature
copying lib\Crypto\Signature\__init__.py -> build\lib.win32-3.6\Crypto\Signature
Skipping optional fixer: buffer
Skipping optional fixer: idioms
Skipping optional fixer: set_literal
Skipping optional fixer: ws_comma
running build_ext
warning: GMP or MPIR library not found; Not building Crypto.PublicKey._fastmath.
building 'Crypto.Random.OSRNG.winrandom' extension
creating build\temp.win32-3.6
creating build\temp.win32-3.6\Release
creating build\temp.win32-3.6\Release\src
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\BIN\cl.exe /c /nologo /Ox /W3 /GL /DNDEBUG /MD -Isrc/ -Isrc/inc-msvc/ "-Ic:\program files (x86)\python36-32\include" "-Ic:\program files (x86)\python36-32\include" "-IC:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\INCLUDE" "-IC:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt" "-IC:\Program Files (x86)\Windows Kits\8.1\include\shared" "-IC:\Program Files (x86)\Windows Kits\8.1\include\um" "-IC:\Program Files (x86)\Windows Kits\8.1\include\winrt" /Tcsrc/winrand.c /Fobuild\temp.win32-3.6\Release\src/winrand.obj
winrand.c
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(26): error C2061: syntax error: identifier 'intmax_t'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(27): error C2061: syntax error: identifier 'rem'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(27): error C2059: syntax error: ';'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(28): error C2059: syntax error: '}'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(30): error C2061: syntax error: identifier 'imaxdiv_t'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(30): error C2059: syntax error: ';'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(40): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(41): error C2146: syntax error: missing ')' before identifier '_Number'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(41): error C2061: syntax error: identifier '_Number'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(41): error C2059: syntax error: ';'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(42): error C2059: syntax error: ')'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(45): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(46): error C2146: syntax error: missing ')' before identifier '_Numerator'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(46): error C2061: syntax error: identifier '_Numerator'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(46): error C2059: syntax error: ';'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(46): error C2059: syntax error: ','
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(48): error C2059: syntax error: ')'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(50): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(56): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(63): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(69): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(76): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(82): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(89): error C2143: syntax error: missing '{' before '__cdecl'
C:\Program Files (x86)\Windows Kits\10\include\10.0.10240.0\ucrt\inttypes.h(95): error C2143: syntax error: missing '{' before '__cdecl'
error: command 'C:\\Program Files (x86)\\Microsoft Visual Studio 14.0\\VC\\BIN\\cl.exe' failed with exit status 2
Command ""c:\program files (x86)\python36-32\python.exe" -u -c "import setuptools, tokenize;__file__='C:\\Users\\leand\\AppData\\Local\\Temp\\pip-build-vdyydfhi\\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\leand\AppData\Local\Temp\pip-gmir_fki-record\install-record.txt --single-version-externally-managed --compile" failed with error code 1 in C:\Users\leand\AppData\Local\Temp\pip-build-vdyydfhi\pycrypto\
"ERROR: broadlink installation error"
Pressione qualquer tecla para continuar. . .
Deseja finalizar o arquivo em lotes (S/N)?
Posted: Thursday 08 February 2018 17:03
by leandrosaltori
Tentei novamente, agora instalando o "pycrypto-2.6.1.win32-py3.4.exe" . Instalei também o python 3.4.0.
As instalações deste foram normais.
Porém hora que tento executar o "setup.exe" para instalar o broadlink ele abre e fecha rapidamente.
Posted: Thursday 08 February 2018 18:54
by zak45
leandrosaltori wrote: Thursday 08 February 2018 17:03 Tentei novamente, agora instalando o "pycrypto-2.6.1.win32-py3.4.exe" . Instalei também o python 3.4.0.
In english please ...
Posted: Thursday 08 February 2018 19:30
by leandrosaltori
zak45 wrote: Thursday 08 February 2018 18:54
Excuse me,
I tried again, now installing "pycrypto-2.6.1.win32-py3.4.exe". I also installed python 3.4.0.
The facilities of this were normal.
But time I try to run "setup.exe" to install broadlink it opens and closes quickly.
Posted: Thursday 08 February 2018 19:33
by leandrosaltori
I'm trying to install domoticz with broadlink on a Windows PC.
After inserting Phyton, I try to run the "SETUP.exe" available on the link- https://www.dropbox.com/sh/htyghey9e402 ... 3H36a? Dl = 0
But it has the following error in Setup:
Can someone help me:
ERRO:
Python 3.6.4
running install
running build
running build_py
creating build
running build_ext
winrand.c
Posted: Thursday 08 February 2018 21:00
by leandrosaltori
rafal wrote: Tuesday 27 June 2017 9:38 Hello,
instalation error on windows 7 platform, domoticz V 3.8007, setup run with admin right
any idea?
Python 3.5.2
"Python version : " 35
Using cached broadlink-0.5.tar.gz
Complete output from command "c:\program files (x86)\python35-32\python.exe" -u -c "import setuptools, tokenize;__file__='C:\\Users\\bed
narzr\\AppData\\Local\\Temp\\pip-build-f6avdhng\\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n
', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record C:\Users\bednarzr\AppData\Local\Temp\pip-rx0m4lk3-record\install-
running install
running build
running build_py
creating build
creating build\lib.win32-3.5
creating build\lib.win32-3.5\Crypto
copying lib\Crypto\pct_warnings.py -> build\lib.win32-3.5\Crypto
copying lib\Crypto\__init__.py -> build\lib.win32-3.5\Crypto
creating build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\hashalgo.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\HMAC.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\MD2.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\MD4.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\MD5.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\RIPEMD.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA224.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA256.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA384.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\SHA512.py -> build\lib.win32-3.5\Crypto\Hash
copying lib\Crypto\Hash\__init__.py -> build\lib.win32-3.5\Crypto\Hash
creating build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\AES.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\ARC2.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\ARC4.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\blockalgo.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\Blowfish.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\CAST.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\DES.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\DES3.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_OAEP.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\PKCS1_v1_5.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\XOR.py -> build\lib.win32-3.5\Crypto\Cipher
copying lib\Crypto\Cipher\__init__.py -> build\lib.win32-3.5\Crypto\Cipher
creating build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\asn1.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\Counter.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\number.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\py3compat.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\randpool.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\RFC1751.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\winrandom.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\_number_new.py -> build\lib.win32-3.5\Crypto\Util
copying lib\Crypto\Util\__init__.py -> build\lib.win32-3.5\Crypto\Util
creating build\lib.win32-3.5\Crypto\Random
copying lib\Crypto\Random\random.py -> build\lib.win32-3.5\Crypto\Random
copying lib\Crypto\Random\_UserFriendlyRNG.py -> build\lib.win32-3.5\Crypto\Random
copying lib\Crypto\Random\__init__.py -> build\lib.win32-3.5\Crypto\Random
creating build\lib.win32-3.5\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\FortunaAccumulator.py -> build\lib.win32-3.5\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\FortunaGenerator.py -> build\lib.win32-3.5\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\SHAd256.py -> build\lib.win32-3.5\Crypto\Random\Fortuna
copying lib\Crypto\Random\Fortuna\__init__.py -> build\lib.win32-3.5\Crypto\Random\Fortuna
creating build\lib.win32-3.5\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\fallback.py -> build\lib.win32-3.5\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\nt.py -> build\lib.win32-3.5\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\posix.py -> build\lib.win32-3.5\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\rng_base.py -> build\lib.win32-3.5\Crypto\Random\OSRNG
copying lib\Crypto\Random\OSRNG\__init__.py -> build\lib.win32-3.5\Crypto\Random\OSRNG
creating build\lib.win32-3.5\Crypto\SelfTest
copying lib\Crypto\SelfTest\st_common.py -> build\lib.win32-3.5\Crypto\SelfTest
copying lib\Crypto\SelfTest\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest
creating build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\common.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_AES.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC2.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_ARC4.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_Blowfish.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_CAST.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_DES3.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_15.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_pkcs1_oaep.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\test_XOR.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
copying lib\Crypto\SelfTest\Cipher\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Cipher
creating build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\common.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_HMAC.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD2.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD4.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_MD5.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_RIPEMD.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA224.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA256.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA384.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\test_SHA512.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
copying lib\Crypto\SelfTest\Hash\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Hash
creating build\lib.win32-3.5\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_AllOrNothing.py -> build\lib.win32-3.5\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_chaffing.py -> build\lib.win32-3.5\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_KDF.py -> build\lib.win32-3.5\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\test_rfc1751.py -> build\lib.win32-3.5\Crypto\SelfTest\Protocol
copying lib\Crypto\SelfTest\Protocol\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Protocol
creating build\lib.win32-3.5\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_DSA.py -> build\lib.win32-3.5\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_ElGamal.py -> build\lib.win32-3.5\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_importKey.py -> build\lib.win32-3.5\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\test_RSA.py -> build\lib.win32-3.5\Crypto\SelfTest\PublicKey
copying lib\Crypto\SelfTest\PublicKey\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\PublicKey
creating build\lib.win32-3.5\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_random.py -> build\lib.win32-3.5\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test_rpoolcompat.py -> build\lib.win32-3.5\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\test__UserFriendlyRNG.py -> build\lib.win32-3.5\Crypto\SelfTest\Random
copying lib\Crypto\SelfTest\Random\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Random
creating build\lib.win32-3.5\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaAccumulator.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_FortunaGenerator.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\test_SHAd256.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\Fortuna
copying lib\Crypto\SelfTest\Random\Fortuna\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\Fortuna
creating build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_fallback.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_generic.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_nt.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_posix.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\test_winrandom.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
copying lib\Crypto\SelfTest\Random\OSRNG\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Random\OSRNG
creating build\lib.win32-3.5\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_asn1.py -> build\lib.win32-3.5\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_Counter.py -> build\lib.win32-3.5\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_number.py -> build\lib.win32-3.5\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\test_winrandom.py -> build\lib.win32-3.5\Crypto\SelfTest\Util
copying lib\Crypto\SelfTest\Util\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Util
creating build\lib.win32-3.5\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\test_pkcs1_15.py -> build\lib.win32-3.5\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\test_pkcs1_pss.py -> build\lib.win32-3.5\Crypto\SelfTest\Signature
copying lib\Crypto\SelfTest\Signature\__init__.py -> build\lib.win32-3.5\Crypto\SelfTest\Signature
creating build\lib.win32-3.5\Crypto\Protocol
copying lib\Crypto\Protocol\AllOrNothing.py -> build\lib.win32-3.5\Crypto\Protocol
copying lib\Crypto\Protocol\Chaffing.py -> build\lib.win32-3.5\Crypto\Protocol
copying lib\Crypto\Protocol\KDF.py -> build\lib.win32-3.5\Crypto\Protocol
copying lib\Crypto\Protocol\__init__.py -> build\lib.win32-3.5\Crypto\Protocol
creating build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\DSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\ElGamal.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\pubkey.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\RSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\_DSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\_RSA.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\_slowmath.py -> build\lib.win32-3.5\Crypto\PublicKey
copying lib\Crypto\PublicKey\__init__.py -> build\lib.win32-3.5\Crypto\PublicKey
creating build\lib.win32-3.5\Crypto\Signature
copying lib\Crypto\Signature\PKCS1_PSS.py -> build\lib.win32-3.5\Crypto\Signature
copying lib\Crypto\Signature\PKCS1_v1_5.py -> build\lib.win32-3.5\Crypto\Signature
copying lib\Crypto\Signature\__init__.py -> build\lib.win32-3.5\Crypto\Signature
running build_ext
error: Unable to find vcvarsall.bat
Command ""c:\program files (x86)\python35-32\python.exe" -u -c "import setuptools, tokenize;__file__='C:\\Users\\rafal\\AppData\\Local\\T
emp\\pip-build-f6avdhng\\pycrypto\\setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(
compile(code, __file__, 'exec'))" install --record C:\Users\rafal\AppData\Local\Temp\pip-rx0m4lk3-record\install-record.txt --single-vers
ion-externally-managed --compile" failed with error code 1 in C:\Users\rafal\AppData\Local\Temp\pip-build-f6avdhng\pycrypto\
Please press any key to continue...
Did you solve your problem? I had the same problem as you. Can you help me?
Posted: Thursday 08 February 2018 21:02
by leandrosaltori
any idea?
Python 3.5.2
running install
running build
running build_py
creating build
running build_ext
Posted: Thursday 08 February 2018 21:22
by leandrosaltori
I did as described, and still have a problem
Now the "setup.exe" opens and closes, and the screen with CMD information does not appear.
rafal wrote: Thursday 29 June 2017 11:39 Hi
i did some test on virtual machine and...
under Windows10 64bit the best way to get BroadlinkRM2 with kodi is:
1) Domoticz V3.8xxxx
2) Install python 3.4.0 (3.5, 3.6.1. doesnt't work) https://www.python.org/downloads/release/python-340/ check "add python.exe.to path"
3) Install pyscrypto-2.6.1.win32-py3.4 with admin right https://www.dropbox.com/sh/htyghey9e402 ... 3H36a?dl=0
4)Install setup.exe. https://www.dropbox.com/sh/htyghey9e402 ... 3H36a?dl=0 with admin right
DONE!
Posted: Thursday 08 February 2018 23:06
by zak45
leandrosaltori wrote: Thursday 08 February 2018 21:22 I did as described, and still have a problem
if this open and close quickly, maybe all is done.
do you have checked in Domoticz hardware if you can see Broadlink ?
Posted: Thursday 08 February 2018 23:23
by leandrosaltori
So, when I go into the hardware, the broadlink does not appear. It looks the same as the image I posted above.
zak45 wrote: Thursday 08 February 2018 23:06
Posted: Thursday 08 February 2018 23:30
by leandrosaltori
I closed the application, opened it again, rebooted the machine, hung up, and nothing
leandrosaltori wrote: Thursday 08 February 2018 23:23 So, when I go into the hardware, the broadlink does not appear. It looks the same as the image I posted above.
Posted: Friday 09 February 2018 12:35
by leandrosaltori
Guys, I do not know what else to do. I was thrilled with the idea of controlling the broadlink and syncing with Xiaomi cameras and gateways, but exhausted all my test possibilities.
I have already tried to install on 2 computers (Notebook / Desktop), with Windows 10 Pro, both to no avail.
The entire installation was in administrator mode.
After all installation, the HARDWARE / BROADLINK option does not appear.
Installed Items:
- Domoticz 3.8892
- Python-3.4.0
- pycrypto-2.6.1.win32-py3.4
- setup ( broadlink )
Note: in Windows 10 several versions of Python have been tested.
Windows 10:
Picture 1
I also created a virtual machine and tried with Windows 8.1 and Windows 7: Note: in Windows 10 several versions of Python were tested.
Picture 2
In Windows 8.1 when I went to install "setup.exe" it presents an error:
"This application can not be run on your PC
To locate a version for your PC, consult your software vendor.
Even with the error, I opened Domoticz, and of course, I do not find the broadlink hardware.
Picture 3
In Windows 7, every installation seems to go well.
The "setup.exe" only opens and closes quickly, it does not display any error screen as in Windows 10:
Picture 4
Picture 5
But when I open Domoticz, the broadlink hardware does not appear either ...
Should I give up, I know the forum discussion is already old. Does anyone still use this Domoticz with broadlink?
