Page 13 of 20
Re: Watermeter lezen met raspberry en Inductieve NPN sensor
Posted: Wednesday 04 April 2018 21:25
by jnmulder
Thanx for youre repsponse.
instead I changed my script
Every 0.5 sec, I read out the level of the GPIO in an infinit loop.
When it has changed to on I add the counter with 1 and set a variable to on
next reading gpio = on and variable = on nothing happenes
next readin gpio = off variable = changed to off
so far (over 1 week now) not 1 liter deviation :-)
philchillbill wrote: Wednesday 21 March 2018 8:23
jnmulder wrote:Thanx for youre response.
The cable is about 1, m long and not shielded.
There are some electrical devices nearby so youre suggestion could be right. What is the best way to shield the cable? Shield the complete kabel from sensor until Rpi?
Yep, and make sure the shield is grounded. You basically want something like a coax cable where an earthed shield surrounds the core. For a 1m length, just wrapping some tin foil like used for baking might do the trick and be quick to try.
Posted: Tuesday 24 April 2018 8:01
by philchillbill
jnmulder wrote:Thanx for youre repsponse.
Maybe you should post a code-snippet here to help others who have problems with signal bounce.
Posted: Sunday 06 May 2018 11:35
by Joep123
Hobbybob wrote: Friday 25 August 2017 18:55 Today my sensor came in (the one with the yellow cap on the end), and it worked really well when I held a screwdriver next to it, but it looks like the plastic cap on top of the half-moon disc is too thick. It doesn't respond to that in any way... I've tried it with 5V and GND from the Pi (signal-cable not attached of course), and also with a 12V-adapter connected to it.
Any ideas if I can do something about this, or do I have to find a completely other way to register the water-usage? I'd rather not start damaging the water-meter since that belongs to the water-company.
I have the same situation. Did you find a solution for the plastic cap?
I used some sand paper and now the led is only on at a small piece of the water meter. If the metal part turns the led goes off.
Posted: Sunday 06 May 2018 12:19
by Hobbybob
Joep123 wrote: Sunday 06 May 2018 11:35 I have the same situation. Did you find a solution for the plastic cap?
No, I did not. I switched to another system that uses light (IR) to check when the haf-moon disc is rotating. It is a tcrt5000 I am using now.
Posted: Tuesday 08 May 2018 21:24
by Joep123
@pvangorp
Time by time I get this error:
2018-05-08 21:13:26.537 Error: EventSystem: in Watermeter: [string "commandArray = {}
..."]:18: attempt to perform arithmetic on global 'sWaterUsage' (a nil value)
2018-05-08 21:13:33.693 Error: EventSystem: in Watermeter: [string "commandArray = {}
2018-05-08 21:13:33.890 Error: EventSystem: in Watermeter: [string "commandArray = {}
2018-05-08 21:13:33.909 Error: EventSystem: in Watermeter: [string "commandArray = {}
As soon as I put a number > 0 into the user variable everything is fine for some time.
Do you have a solution for this issue?
Posted: Sunday 20 May 2018 8:55
by SorzZy
Same problem here!
2018-05-20 08:47:02.910 Error: EventSystem: in lua-water: [string "commandArray = {}
Posted: Sunday 20 May 2018 10:27
by u01pei
Hobbybob wrote: Sunday 06 May 2018 12:19
I have the same sensor and had the same issue. The plastic cap is just a little to thick, so I used a sharp knife to cut it of. I wrecked one switch first, as I removed the entire orange cap, but that made the resin 9holding the sensor element) come loose, making it very fragile and causing a wire to break.
So on the second switch I only removed the lower side of the cap (so a only a cilinder remains around the sensor). The orange material is about 0,5 mm thick, so if you cut about 0,5 from the bottom edge you will remove only a disk of orange material and the cilinder remains attached.
Posted: Sunday 20 May 2018 11:09
by Hobbybob
u01pei wrote: Sunday 20 May 2018 10:27 I have the same sensor and had the same issue. The plastic cap is just a little to thick, so I used a sharp knife to cut it of. I wrecked one switch first, as I removed the entire orange cap, but that made the resin 9holding the sensor element) come loose, making it very fragile and causing a wire to break.
After I had the IR-sensor in place I read about this. I belief that was someone who used sanding-paper to make it thinner. Perhaps I'll switch to this method sometime. My current setup does count water sometimes when nothing is being used. The half-moon disc is then exactly on the edge of where it is measured... Then again: this problem also occurs with the induction-sensors.
Posted: Tuesday 12 June 2018 12:33
by sincze
After several years of having a TCRT-5000 as a watermeter I decided to check out the NPN as well.
NPN Meter.jpeg (109.91 KiB) Viewed 3464 times
TCRT is connected to the Raspberry pi. The NPN is attached to a WEMOS to create a wireless solution.
In the image you can see the test setup.
Not a lot of room over the watermeter wheel, but just sufficient to have both meters up and running.
Posted: Tuesday 19 June 2018 17:36
by jagroeneveld
In order to see if the results are successfully logged to Domoticz, I added the following lines
#err1 = response1.read()
#print "response = " + str(err1)
just after
#Voor debug => print voorbeeld van de JSON aanroep en/of de counter
#print "JSON call = "+ str(url1)
#print "Watermeter Counter = " + str(Counter)
I needed to do so because I use authorization in Domoticz
Posted: Sunday 22 July 2018 19:14
by jonathan12
pvangorp wrote: Wednesday 06 September 2017 20:45 I've upgraded my script by adding a "uservariable" this makes it possible to set the initial value and to make a correction when your PI is off for a while. Create a user variable called "WaterMeter" and enter the meter value eg "999999" (Where "999999" = 999.999m3). When the value is "0" it ignores the user variable.
I also added a variable for IDX, to make it easier to change the script.
So you don't need the line
To set the initial meter values http://<<YOUR DOMOTICZ IP>>/json.htm?type=command&param=udevice&idx=34&svalue=999999
any more
My updated script
-- Set IDX of Watermeter
iIDX = 34
-- Set Watermeter based on user variable "WaterMeter"
if ( uservariables["WaterMeter"] > 0 ) then
    print("Water usage is set to " .. uservariables["WaterMeter"] / 1000 .. "m3 by user")
    commandArray['UpdateDevice'] = ''..iIDX..'|0|'..uservariables["WaterMeter"]..''
    commandArray['Variable:WaterMeter'] = tostring(0)
-- Water usage
-- Retrieve value from water meter device:
sWaterUsage = otherdevices_svalues['Waterverbruik']
-- To have a better readable format, divide number by 1000:
sWaterUsagePrint = tonumber(sWaterUsage / 1000);
-- calculation is done with the unmodified water value
sWaterUsage = tonumber(sWaterUsage);
-- For Debuging
-- print("Water usage until now is " .. sWaterUsagePrint .. "m3 ")
-- print('GPIO Watermeter = '..otherdevices['GPIO Watermeter'])
function timedifference(s)
   year = string.sub(s, 1, 4)
   month = string.sub(s, 6, 7)
   day = string.sub(s, 9, 10)
   hour = string.sub(s, 12, 13)
   t1 = os.time()
   return difference
if (devicechanged['GPIO Watermeter'] == 'Off')
then
	sWaterUsageTot = (sWaterUsage + 1)
	print("Water usage is set to " .. sWaterUsageTot / 1000 .. "m3 ")
	commandArray['UpdateDevice'] = ''..iIDX..'|0|'..sWaterUsageTot..''
    -- Keep a live device
    if (timedifference(otherdevices_lastupdate["Waterverbruik"]) > 300)
    then
        print("Water usage is still " .. sWaterUsage / 1000 .. "m3 ")
        commandArray['UpdateDevice'] = ''..iIDX..'|0|'..sWaterUsage..''
I question from a Noob:
When I enter the url in my browser http://<<YOUR DOMOTICZ IP>>/json.htm?type=command&param=udevice&idx=34&svalue=999999 I get this output:
"status" : "ERR"
When i try to read the version of domoticz http://<<YOUR DOMOTICZ IP>>/json.htm?type=command&param=getversion it works.
What am I doing wrong?
And maybe someone can edit the first post with the latest script, and the info about using a zener diode. Now al people do have to read all the postings.
Posted: Sunday 22 July 2018 19:33
by pvangorp
Start your url with ?param=......... &param is reserved. When you change the order of the url string it will work. json.htm?param=udevice&type=command&idx=34&svalue=999999
Posted: Monday 23 July 2018 21:08
by jonathan12
http://xxx.xxx.xxx.xxx:8080/json.htm?pa ... lue=999999 is also giving me:
"status" : "ERR"
Without the port 8080 i get a pihole page. (Pihole is also running on my Pi)
Posted: Monday 23 July 2018 21:24
by pvangorp
Looks like your watermeter is not on idx34? 34 is the idx of my watermeter. Is your watermeter (RFXMeter) on the same idx??? Please double check the number in your device list.
Posted: Friday 27 July 2018 9:35
by DutchSolar
Thanks to everyone in this forum for making all this possible.
I have now also successfully added my watermeter to Domoticz.
1 bug that keeps popping up and is really annoying is that whenever you change a device or lua script, the log will show :
2018-07-27 09:19:58.007 Status: EventSystem: reset all device statuses...
And then the LUA script starts throwing errors.
2018-07-27 09:20:02.164 Error: EventSystem: in WaterMeterLuav2: [string "commandArray = {}
The only way to get it working again (to my knowledge) is to fill the uservariable with the total water usage.
This is of course quite annoying because if any water is used during this error period, its usage is not recorded. That means you have to check on the actual meter. Sadly, in my case, the meter is quite inaccessible.
The error is thrown on line 18, Line 18 is :
Anyone have any idea how I (and the others facing the same problem) can fix this?
My lua script in full :
iIDX = 256
-- Water usage
-- For Debuging
--print("Water usage until now is " .. sWaterUsagePrint .. "m3 ")
--print('GPIO Watermeter = '..otherdevices['GPIO Watermeter'])
   t1 = os.time()
   return difference
then
    then
Thanks for taking the time to read this!
Posted: Friday 10 August 2018 21:28
by arnaudarduino
Great tutorial, now my watermeter is in domoticz.
This puls counter works great for 1 puls is 1 liter ,kwh, m3 what ever.
Is it possible to change a little for puls S0 kwh , that means my kwh meter has 2000 imp for 1 kwh, 1pulse is 0.5 ... or 2pulse is 1....
When i change
      Counter = int(c)
  Counter = Counter + 1
  f.close()
1 into 0.5 this script stops working.
What do i have to do txs
Posted: Wednesday 15 August 2018 21:27
by jonathan12
How big does the voltage drop has to be of the NPN sensor?
Mine is 2.8V with metal detecting and 3.5V without metal.
Input is 5V and i use a zener diode 3.3V
When i test the sensor it is always level=1
The led is on when metal is detected
pi@raspberrypi:~ $ sudo raspi-gpio get 21
GPIO 21: level=1 fsel=0 func=INPUT
Posted: Wednesday 15 August 2018 23:17
by freijn
Jhon
I have put my sensor on 12 volts, but indeed.. limit the max voltage with an LED as the output will also become
12 volt when high. Your raspberry or arduino would not like that!
Cheers,
Frank
Posted: Friday 24 August 2018 23:21
by Melissen
Thx to PvanGorp, who started in this threat the LUA script.
Python didn't work for me, so the LUA script was my solution.
I only changed/added something in this script.
In the device/meter you can simply add the start-value. So the start-value is not counted in the usage. So you only see the usage in the logs, but the total-counter gives the good readings.
Instead of PvanGorp's startvalue in uservariables (watermeter) this value is used for correcting the total-counter. For example: if the counter is off by 15 litres after a while, you put 15 in the uservariable and a few seconds later the totalcounter is back on track.
You can enter a positive or negative value in this uservariable.
my counter in Utility is: WaterTester (because I used this one for editing this script) instead of WaterMeter (PvanGorp)
on/off gpio (switch) is: same as PvanGorp
uservariables: WaterMeter
LUA; device
iIDX = 403
SWaterUsage2 = otherdevices_svalues['WaterTester']
SWaterUsage2 = tonumber(SWaterUsage2);
SWaterUsage3 = uservariables["WaterMeter"]
SWaterUsage3 = tonumber(SWaterUsage3);
SWaterUsage4 = (SWaterUsage2 + SWaterUsage3)
if (uservariables["WaterMeter"] == 0 )
then
    sWaterUsage = SWaterUsage4
    print("Water usage is set to " .. SWaterUsage4 / 1000 .. "m3 by user")
    commandArray['UpdateDevice'] = ''..iIDX..'|0|'..SWaterUsage4..''
-- Water usage
-- sWaterUsage = otherdevices_svalues['WaterTester']
-- For Debuging
   t1 = os.time()
   return difference
then
    if (timedifference(otherdevices_lastupdate["WaterTester"]) > 300)
    then
Posted: Saturday 25 August 2018 0:16
by Melissen
The only problem I'm facing right now is the totalcounter in my device.
Instead of 3 digits behind the , I've got 2 digits.
When I make a new device I've got 3 digits, but when I change the 'startvalue' it goes to 2 digits.
Instead of 1184.881m3 it shows 1184.88m3. When the counter reaches 1184.885 it shows 1184.89 (till 1185.894)
How can I get 3 digits back?
Think it's a problem in Domoticz itself. But I hope someone can help me
