Yes. Didn't even notice that I thought it was on by default.
Buienradar Weather Lookup Plugin
- EdwinK
- Domoticz version: BETA
Re: Buienradar Weather Lookup Plugin
- G3rard
- Target OS: -
- Domoticz version: No
Can you share a screen print of the log screen including the above message?Mace wrote:Set it both to True and Logging. All I get is:
2017-10-18 14:42:03.412 (Buienradar) Stop directive received.
2017-10-18 14:42:03.612 (Buienradar) Stopping threads.
2017-10-18 14:42:03.631 (Buienradar) Exiting work loop.
2017-10-18 14:42:03.631 (Buienradar) Stopped.
2017-10-18 14:42:03.632 (Buienradar) Started.
2017-10-18 14:42:04.039 (Buienradar) Entering work loop.
2017-10-18 14:42:04.039 (Buienradar) Initialized version 2.0, author 'ffes'
I'm on the latest Beta.
Not using Domoticz anymore
My Buienradar keeps crashing since the latest update of the plugin:
In order to get buienradar working I need to reboot the domoticz server (UDOO QUAD) and it will work for 1 or 2 days...
I am on Domoticz version 3.83422017-10-19 11:01:37.641 RFLink: 20;56;PONG;
2017-10-19 11:01:38.675 (Buienradar) Stop directive received.
2017-10-19 11:01:39.108 (Buienradar) Exiting work loop.
2017-10-19 11:01:43.680 (Buienradar) Stopping threads.
2017-10-19 11:01:43.680 (Buienradar) Stopped.
2017-10-19 11:01:43.680 (Buienradar) Started.
2017-10-19 11:01:57.644 RFLink: 20;57;PONG;
2017-10-19 11:02:17.646 RFLink: 20;58;PONG;
2017-10-19 11:02:37.648 RFLink: 20;59;PONG;
2017-10-19 11:02:57.650 RFLink: 20;5A;PONG;
2017-10-19 11:03:00.771 Error: Buienradar hardware (15) thread seems to have ended unexpectedly
- Domoticz version: 3.8153
This is actually all the data that is in the log. The rest is from LUA and dzVents scripts....G3rard wrote: ↑Wednesday 18 October 2017 19:17Can you share a screen print of the log screen including the above message?Mace wrote:Set it both to True and Logging. All I get is:
I fixed it in a ugly way by just rebooting my server every 24 hours
- Domoticz version: V4.10232
I suddenly have the same problem on the latest stable v3.8153
I tracked the error in the log file
Not sure if this it but I have disabled the plugin for now to see if Domoticz doesn't crash anymore.
2017-11-08 09:23:37.624 (Buienradar) Initialized version 2.0, author 'ffes'
2017-11-08 09:23:37.677 Error: Domoticz received fatal signal 11 !...
2017-11-08 09:23:37.679 Error: /home/pi/domoticz/domoticz() [0x1cdc48]
2017-11-08 09:23:37.679 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cdd00]
2017-11-08 09:23:37.679 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76aec180]
- Domoticz version: Stable
Latest stable and Buienradar stopped working.
“Error: Buienradar hardware (19) thread seems to have ended unexpectedly”
I’ve set the log to True, but nothing in the log except the “Error: Buienradar hardware (19) thread seems to have ended unexpectedly”
Over 50 Z-Wave Devices (Fibaro and Neo), 4xLogitech Hub, 2xPhilips Hue Bridge+55 Lights, 1x Nest Thermostat, 2xNetatmo Weather Station, 1xSkybell v1 Doorbell, 3 Kwikset KEVO Doorlocks and Domoticz running on a Intel NUC
- EdwinK
Not sure why that is even possible, but after reinstalling Ger3rard's script domoticz is not working anymore. ;(
is there someone who can fix this?
I'm experiencing the same problems as mentioned above; once the plugin is installed, Domoticz stopped working. Simple removal of the plugin and Domoticz is running again. I understand this is all voluntary work (keep up the great work!), but maybe G3rard can post an update about this problem?!
- EdwinK
I think there is something else wrong, I found the same behaviour with other python-based plugins.
- G3rard
- Target OS: -
Hi all, I am running the buienradar script on Domoticz v3.8153 without any problems.
I have an uptime now of 16 days and not any error messages for all of thePython scripts running. In the past I saw some errors on Pi's with the Python script, but as I am running on Ubuntu server I can't simulate the errors.
But I don't think the issues have to do with this script.
I saw some changes on the Python framework in the beta versions, so maybe who currently has errors can upgrade and see if it works.
- EdwinK
Running the latest beta on Pi now. Latest beta since yesterday, that is. Since switching to Pi I get this problem.
- waaren
Still the same problem with version Domoticz V3.8771 and one or more active plugins.
I use buienradar, homewizard, NUT_UPS and Sonos. If I make any or all of these plugins active, domoticz crashes with:
2017-12-06 08:38:18.481 PluginSystem: Entering work loop.
2017-12-06 08:38:18.650 Error: Domoticz received fatal signal 11 !...
2017-12-06 08:38:18.651 Error: /opt/domoticz/domoticz() [0x236254]
2017-12-06 08:38:18.652 Error: /opt/domoticz/domoticz(_Z14signal_handleri+0x4c) [0x23630c]
2017-12-06 08:38:18.652 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x76c7e6b0]
on my RPI3 latest working Beta is domoticz.v3.8627
- EdwinK
No logs available
Running v3.8153 on Synology and RPI.
I see NO problems
I see NO problems
I've got a 'problem' with the location of the 'Buienradar'. I've put the location in Domoticz setup (it's correctly used by the openweathermap), however if I run python3 locatest.py it's pointing to meetstation Lauwersoog (instead of Rotterdam):
pi@raspberrypi:~/domoticz/plugins/domoticz-buienradar $ python3 localtest.py
Retrieve weather data from http://xml.buienradar.nl/
XML file contains weather station information
Found Meetstation Lauwersoog (ID: 6277) at 7.7 km from your home location
No Barometer and Visibility info found in your weather station, getting info from weather station De Bilt
Temperature: 1.6
Wind Speed: 5.65 | Wind Bearing: 97.0 | Wind Direction: E | Wind Speed Gusts: 8.9 | Wind Chill: -3.3
Barometer: None | Barometer Forecast: 5
Humidity: 81 | Humidity status: 3
Visibility: None
Solar Irradiance: 1.0
Rain rate: None
Weather prediction today: Opnieuw flinke sneeuwval (Opgesteld op maandag 11 dec 2017 om 06:30)
Any idea how to change the meetstation into Rotterdam??
Temperature: 1.6
Visibility: None
Rain rate: None
- EdwinK
In localtest.py it uses this location only to test if things work. You need to use the other file. buienradar.py I think.
let's rephrase my question then: how do I check if the correct meetstation location is used?
I found the solution: restart Domoticz and watch the logs
Btw its now pointing to the correct ‘meetstation’
Users browsing this forum: FireWizard and 1 guest
