Snowtiger wrote: Wednesday 18 October 2017 14:22i assume you have debug set to true in the Hardware setup of Buienradar plugin?EdwinK wrote:This is from the log-tab in Domoticz.
Yes. Didn't even notice that
Can you share a screen print of the log screen including the above message?Mace wrote:Set it both to True and Logging. All I get is:
2017-10-18 14:42:03.412 (Buienradar) Stop directive received.
2017-10-18 14:42:03.612 (Buienradar) Stopping threads.
2017-10-18 14:42:03.631 (Buienradar) Exiting work loop.
2017-10-18 14:42:03.631 (Buienradar) Stopped.
2017-10-18 14:42:03.632 (Buienradar) Started.
2017-10-18 14:42:04.039 (Buienradar) Entering work loop.
2017-10-18 14:42:04.039 (Buienradar) Initialized version 2.0, author 'ffes'
I'm on the latest Beta.
I am on Domoticz version 3.83422017-10-19 11:01:37.641 RFLink: 20;56;PONG;
2017-10-19 11:01:38.675 (Buienradar) Stop directive received.
2017-10-19 11:01:39.108 (Buienradar) Exiting work loop.
2017-10-19 11:01:43.680 (Buienradar) Stopping threads.
2017-10-19 11:01:43.680 (Buienradar) Stopped.
2017-10-19 11:01:43.680 (Buienradar) Started.
2017-10-19 11:01:57.644 RFLink: 20;57;PONG;
2017-10-19 11:02:17.646 RFLink: 20;58;PONG;
2017-10-19 11:02:37.648 RFLink: 20;59;PONG;
2017-10-19 11:02:57.650 RFLink: 20;5A;PONG;
2017-10-19 11:03:00.771 Error: Buienradar hardware (15) thread seems to have ended unexpectedly
This is actually all the data that is in the log. The rest is from LUA and dzVents scripts....G3rard wrote: Wednesday 18 October 2017 19:17Can you share a screen print of the log screen including the above message?Mace wrote:Set it both to True and Logging. All I get is:
2017-11-08 09:23:37.624 (Buienradar) Initialized version 2.0, author 'ffes'
2017-11-08 09:23:37.677 Error: Domoticz received fatal signal 11 !...
2017-11-08 09:23:37.679 Error: /home/pi/domoticz/domoticz() [0x1cdc48]
2017-11-08 09:23:37.679 Error: /home/pi/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cdd00]
2017-11-08 09:23:37.679 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76aec180]Users browsing this forum: Google [Bot] and 1 guest
