Page 13 of 123
Posted: Thursday 05 January 2017 16:34
by deennoo
corbin wrote:
{"cmd":"read_ack","model":"","sid":"158d00010eebac","short_id":31286,"data":"{}"}
Is the Cube
sending :
return :
{"cmd":"get_id_list_ack","sid":"f0b429cc2781","token":"u3Oh9zL1FMPAe8DH",
"data":"
[\\"158d00010abb62\\", = temp/hum id from domoticz
\\"158d0001186b5e\\", = magnet id from domoticz
\\"158d000125664f\\", = switch id from domoticz
\\"158d00010eebac\\", = the only who left is my cube
\\"158d00010fe2de\\"]"} = pir id from domotticz
Will try to continu investigation
Posted: Thursday 05 January 2017 16:52
by deennoo
{"cmd":"write","model":"gateway","sid":"f0b429cc2781","short_id":0,"key":"8","data":"{\"rgb\":4278255360}" }
from API have to change gateway color but still the same message :
{"cmd":"write_ack","sid":"f0b429cc2781","data":"{\\"error\\":\\"No device\\"}"}
This can confirme a futur FW update
Posted: Thursday 05 January 2017 17:15
by WrathfulFab
Hi, and thank you for all the job done with th Xiaomi Gateway.
I am totally new to Domoticz. I understand every part of the procedure to add the gateway to Domotcz, but i don't see any devices...
I reset the gateway to be sure, the problem do not come from it.
I am tottally in the dark... I need some help.
Thank you for your time.
Posted: Thursday 05 January 2017 17:23
by deennoo
WrathfulFab wrote:Hi, and thank you for all the job done with th Xiaomi Gateway.
You need to update to a beta version
by oleg77rus
Limitation is 10
Sensors only without zigbee plugs?
Posted: Thursday 05 January 2017 18:03
by WrathfulFab
Update to a beta version? Domoticz or my Gateway?
My domoticz version is 3.6288
My gateway version is 1.4.1_142.0141
Posted: Thursday 05 January 2017 18:52
by Derik
Do have the MI Square Smart IP Camera @ home.
Nice camera very nice picture's.. smal only perfect quality [ can talk and listen to the camera with the app.. ]
Do not have the gateway yet...
Only is there a option to use the ipcam without a bridge?
Or the gateway?
Connect the cam with my wifi.
Can see the pictures/movie only with the android app.
Is there no other option to use the camera as stand alone IP camera or something?[ is there a open port? ]
Or is the cam with the bridge to use in Domoticz?
Cannot wait for the bridge ..
Found a Boa webgui??
- ScreenShot189.jpg (22.86 KiB) Viewed 2764 times
Posted: Thursday 05 January 2017 19:08
by deennoo
WrathfulFab wrote:Update to a beta version? Domoticz or my Gateway?
Xiaomi gateway have to Be présent on hardware page.
Posted: Thursday 05 January 2017 19:12
by deennoo
Derik wrote:Do have the MI Square Smart IP Camera @ home.
Or the gateway?
Your caméra is a wifi product.
Xiaomi gateway only drive zigbee devices.
Xiaomi Mi Home app is a master app with differents plugin.
Gateway will never provid caméra vidéo.
You have to find a hack
Posted: Thursday 05 January 2017 19:14
by WrathfulFab
The thing is i have the gateway in the hardware page, all the parameters seems good, but i do not have any devices...
Posted: Thursday 05 January 2017 19:25
by Derik
Did install ispy..
Only when i search all ports with the build in scanner...
Ispy crash...
Posted: Thursday 05 January 2017 19:31
by levynger
Corbin, The default value for the door sensor is "Open"?
i have restart the domoticz server now, and eventhough the state seems to be open.. at least till i open and close the door..
i think the default value for door and motion should be Closed/Off be default.
Posted: Thursday 05 January 2017 19:38
by pavelbor
I have connected 4 motion sensors, 5 temperature sensors, 4 zigbee power sockets and 5 switches. It's more than 10
I seen number 30 somewhere.
Отправлено с моего SGP521 через Tapatalk
Posted: Thursday 05 January 2017 19:40
by pavelbor
And forgot 3 door sensors. That's 21 devices total.
Posted: Thursday 05 January 2017 20:09
by deennoo
pavelbor wrote:And forgot 3 door sensors. That's 21 devices total.
Great news !
Posted: Thursday 05 January 2017 20:11
by corbin
deennoo wrote:pavelbor wrote:And forgot 3 door sensors. That's 21 devices total.
Great news !
yeah, more than 10 here too, don't believe the support line!
Posted: Thursday 05 January 2017 20:14
by corbin
http://www.domoticz.com/forum/viewtopic ... 80#p111930
Posted: Thursday 05 January 2017 20:20
by corbin
deennoo wrote:
@Corbin did you allow to have multiple gateway ? on the same domoticz ?
not yet, when are you getting a 2nd one to test?
Posted: Thursday 05 January 2017 20:23
by deennoo
Maybe never if we can add more than 10 devices and the wall plug+230v wall switch act as a real zigbee device and create a mesh network
Posted: Thursday 05 January 2017 23:09
by PABben
So the xiaomi is using wifi to communicate. I assume it is using an existing wan so it can be connected to the lan where the domoticz server is for easy connection to the gateway?
Is this device what i need as a gateway? (URL in spoiler)
- Spoiler: show
- http://www.ebay.com/itm/Original-Xiaomi ... SwmLlX9ggm
