Controlling Toon [HACKED] from Domoticz
madpatrick
Domoticz version: 2026.1
Re: Controlling Toon [HACKED] from Domoticz
Post by madpatrick »
For who is interested, i've updated the current scripts since they where not working for me.
Also i've added the Boilermodulationlevel
Now it is a complete package with all the possible Toon sensors available.
1e:
- Toon_Getinfo_lua
- Lua
- Device
-- Version 1:
-- Time script runs every minute, intended to sync Domoticz with Toon in case the value is changed on the physical device.
-- Updates Toon Thermostat Sensor to value set on Toon
-- Updates Toon Temperature Sensor to value set on Toon
-- Updates Toon Scenes switch based on program set on Toon
-- Updates Toon Auto Program switch to value set on Toon
-- Updates Toon program information text to value set on Toon
-- Version 2
-- Improvements:
-- - Check each value for a nil value (in case of a failed request)
-- - Changed all global allocations to local. This is to prevent a memory leak. (This is how LUA works)
-- - Added a timeout to curl (--max-time) which will prevent the script from running for more than 10 seconds and thus decreasing the warnings, in case Toon can't be reached.
--   Please take note that this will also ignore the values for that particular request.
-- Source: https://www.domoticz.com/forum/viewtopic.php?f=34&t=11421&start=20#p125837
-- Extra improvement:
-- Updates Toon Burner status in order to see in domoticz if your boiler is on for the hotwater or heating or off
-- Updates Toon Boiler temp
-- Updates Toon ToonboilerOutTempName Sensor to value set on Toon
-- Updates Toon ToonboilerInTempName Sensor to value set on Toon
-- Updates Toon ToonboilerPressure sensor to value set on Toon
-- Updates Toon boilerModulationLevel sensor to value set on Toon
-- uservariables
    ToonIP = uservariables['UV_ToonIP']
    DomoticzIP = uservariables['UV_DomoticzIP']
    ToonThermostatSensorName = uservariables['UV_ToonThermostatSensorName'] -- Sensor showing current setpoint
    ToonTemperatureSensorName = uservariables['UV_ToonTemperatureSensorName'] -- Sensor showing current room temperature
    ToonScenesSensorName  = uservariables['UV_ToonScenesSensorName'] -- Sensor showing current program
    ToonAutoProgramSensorName = uservariables['UV_ToonAutoProgramSensorName'] -- Sensor showing current auto program status
	ToonBurnerName = uservariables['UV_ToonBurnerName']
	ToonProgramInformationSensorName = uservariables['UV_ToonProgramInformationSensorName'] -- Sensor showing displaying program information status
	ToonBoilerTempSetpoint = uservariables['UV_ToonBoilerTempSetpointSensorName'] -- Sensor showing current internal boiler temp
	ToonboilerInTempName = uservariables['UV_ToonboilerInTempName'] -- Sensor inlet temperature
    ToonboilerOutTempName = uservariables['UV_ToonboilerOutTempName'] -- Sensor outlet temperature
    ToonboilerPressure  =   uservariables['UV_ToonboilerPressure'] -- ToonboilerPressure
    ToonboilerModulationLevel = uservariables['UV_ToonboilerModulationLevel'] -- Sensor showing current Boiler Modulation Level
-- Choose the correct platform which Domoticz runs on
-- Remove -- before the line which applies for your situation, set -- for all other platforms
    json = assert(loadfile "/var/domoticz/scripts/lua/JSON.lua")()  -- For Linux (ClearOS)
--  json = assert(loadfile "/home/pi/domoticz/scripts/lua/JSON.lua")()  -- For Raspberry
--  json = assert(loadfile "/opt/domoticz/scripts/lua/JSON.lua")()  -- For Linux (LEDE)
--  json = assert(loadfile "C:\\Program Files (x86)\\Domoticz\\scripts\\lua\\json.lua")() -- For Windows
--  json = assert(loadfile "/volume1/@appstore/domoticz/var/scripts/lua/JSON.lua")() -- For Synology
    local handle = assert(io.popen(string.format('curl -m 5 http://%s/happ_thermstat?action=getThermostatInfo', ToonIP)))
        local ThermostatInfo = handle:read('*all')
    handle:close()
        local handle = assert(io.popen(string.format('curl http://%s/boilerstatus/boilervalues.txt', ToonIP)))
        local BoilerInfo = handle:read('*all')
    handle:close()
-- JSON data from Toon contains a extra "," which should not be there.
    BoilerInfo = string.gsub(BoilerInfo, ",}", "}")
    jsonBoilerInfo = json:decode(BoilerInfo)
    ThermostatInfo = string.gsub(ThermostatInfo, ",}", "}")
    jsonThermostatInfo = json:decode(ThermostatInfo)
    currentSetpoint = tonumber(jsonThermostatInfo.currentSetpoint) / 100
    currentTemperature = tonumber(jsonThermostatInfo.currentTemp) / 100
    currentTemperature = tonumber(string.format("%.1f", currentTemperature))  -- 1 decimaal is voldoende
    currentProgramState = tonumber(jsonThermostatInfo.programState)
    currentActiveState = tonumber(jsonThermostatInfo.activeState)
    currentNextTime = jsonThermostatInfo.nextTime
    currentBurnerInfo = tonumber(jsonThermostatInfo.burnerInfo)
    currentNextSetPoint = tonumber(jsonThermostatInfo.nextSetpoint) / 100
    currentBoilerSetPoint = tonumber(jsonThermostatInfo.currentInternalBoilerSetpoint)
    currentboilerInTemp = tonumber(jsonBoilerInfo.boilerInTemp)
    currentboilerInTemp = tonumber(string.format("%.0f", currentboilerInTemp))  -- afgeronde getallen is voldoende
    currentboilerOutTemp = tonumber(jsonBoilerInfo.boilerOutTemp)
    currentboilerOutTemp = tonumber(string.format("%.0f", currentboilerOutTemp))  -- afgeronde getallen is voldoende
    currentboilerPressure = tonumber(jsonBoilerInfo.boilerPressure)
    currentboilerModulationLevel = tonumber(jsonBoilerInfo.boilerModulationLevel) --Toon Modulation Level
-- Update the thermostat sensor to current setpoint
    if otherdevices_svalues[ToonThermostatSensorName]*100 ~= currentSetpoint*100 then
       print('Updating thermostat sensor to new set point: ' ..currentSetpoint)
        commandArray[1] = {['Variable:UV_ToonChangedByDomoticz'] = '1'} -- Set variable changed to 1 to prevent script ToonSetPoint from shooting an event at Toon
        commandArray[2] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonThermostatSensorName], currentSetpoint)}
-- Update the temperature sensor to current room temperature
    if otherdevices_svalues[ToonTemperatureSensorName]*100 ~= currentTemperature*100 then
        print('Updating the temperature sensor to new value: ' ..currentTemperature)
        commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonTemperatureSensorName], currentTemperature)}
-- Update the toon scene selector sensor to current program state
    CurrentToonScenesSensorValue = otherdevices_svalues[ToonScenesSensorName]
        if currentActiveState == -1 then currentActiveState = '50' -- Manual
            elseif currentActiveState == 0 then currentActiveState = '40' -- Comfort
            elseif currentActiveState == 1 then currentActiveState = '30' -- Home
            elseif currentActiveState == 2 then currentActiveState = '20' -- Sleep
            elseif currentActiveState == 3 then currentActiveState = '10' -- Away
        if CurrentToonScenesSensorValue ~= currentActiveState then  -- Update toon selector if it has changed
            print ('Updating Toon Scenes selector')
            commandArray[4] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonScenesSensorName], currentActiveState)}
-- Updates the toon auto program switch
    CurrentToonAutoProgramSensorValue = otherdevices_svalues[ToonAutoProgramSensorName]
        if currentProgramState == 0 then currentProgramState = '10' -- No
            elseif currentProgramState == 1 then currentProgramState = '20' -- Yes
            elseif currentProgramState == 2 then currentProgramState = '30' -- Temporary
        if CurrentToonAutoProgramSensorValue ~= currentProgramState then -- Update toon auto program selector if it has changed
            print ('Updating Toon Auto Program selector')
            commandArray[5] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonAutoProgramSensorName], currentProgramState)}
-- Updates the toon program information text box
    CurrentToomProgramInformationSensorValue = otherdevices_svalues[ToonProgramInformationSensorName]
        if currentNextTime == 0 or currentNextSetPoint == 0 then
            ToonProgramInformationSensorValue = 'Temp : ' ..currentSetpoint.. '° / ' ..currentTemperature.. '°'
            ToonProgramInformationSensorValue = 'Om ' ..os.date('%H:%M', currentNextTime).. ' op ' ..currentNextSetPoint.. '°'
        if CurrentToomProgramInformationSensorValue ~= ToonProgramInformationSensorValue then
            commandArray[6] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonProgramInformationSensorName], ToonProgramInformationSensorValue)}
-- Update the toon burner selector to current program state
	CurrentToonBurnerValue = otherdevices_svalues[ToonBurnerName]
		if currentBurnerInfo == 0 then currentBurnerInfo = '0' -- uit
		    elseif currentBurnerInfo == 1 then currentBurnerInfo = '10' -- cv aan
		    elseif currentBurnerInfo == 2 then currentBurnerInfo = '20' -- warmwater aan
		if CurrentToonBurnerValue ~= currentBurnerInfo then  -- Update toon burner selector if it has changed
			print ('Updating Toon burner info')
			commandArray[7] = {['UpdateDevice'] = string.format('%s|1|%s', otherdevices_idx[ToonBurnerName], currentBurnerInfo)}
-- Update the boilerInTemp
        if otherdevices_svalues[ToonboilerInTempName]*100 ~= currentboilerInTemp*100 then
            print('Updating boiler inlet temp to new value: ' ..currentboilerInTemp)
            commandArray[1] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonboilerInTempName], currentboilerInTemp)}
            -- update the boilerModulationLevel
            print('Updating boiler Modulation Level to value: ' ..currentboilerModulationLevel)
            commandArray[11] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonboilerModulationLevel], currentboilerModulationLevel)}
-- Update the boilerOutTemp
        if otherdevices_svalues[ToonboilerOutTempName]*100 ~= currentboilerOutTemp*100 then
            print('Updating boiler outlet temp to new value: ' ..currentboilerOutTemp)
            commandArray[2] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonboilerOutTempName], currentboilerOutTemp)}
-- Update the boilerPressure
        if otherdevices_svalues[ToonboilerPressure]*100 ~= currentboilerPressure*100 then
            print('Updating boiler pressure to new value: ' ..currentboilerPressure)
            commandArray[3] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonboilerPressure], currentboilerPressure)}
        --if otherdevices_svalues[ToonboilerModulationLevel]*100 ~= currentboilerModulationLevel*100 then
        --    print('Updating boiler Modulation Level to value: ' ..currentboilerModulationLevel)
        --    commandArray[11] = {['UpdateDevice'] = string.format('%s|0|%s', otherdevices_idx[ToonboilerModulationLevel], currentboilerModulationLevel)}
        --end
2e:
- Toon_Thermostat
- Lua
- Device
-- Script used for Toon Thermostaat utility device, upon changing temp in Domoticz, temperature is sent to Toon.
    for deviceName,deviceValue in pairs(devicechanged) do
        if (deviceName == ToonThermostatSensorName) then
            if uservariables['UV_ToonChangedByDomoticz'] == 1 then
                commandArray['Variable:UV_ToonChangedByDomoticz'] = '0'
                SetPoint = otherdevices_svalues[ToonThermostatSensorName]
                ToonCommand = string.format('http://%s/happ_thermstat?action=setSetpoint&Setpoint=%s', ToonIP, SetPoint*100)
                print('Setting Toon setpoint to '.. SetPoint)
                commandArray['OpenURL'] = ToonCommand
User variables
Switches
francisb
Post by francisb »
Hi madpatrick,
I tried your script, but when i run the toon_getinfo_lua script i get the following in the log:
Error: EventSystem: in Toon_Getinfo_lua: /home/pi/domoticz/scripts/lua/JSON.lua:660: html passed to JSON:decode(): <?xml version="1.0" encoding="iso-8859-1"?>
2018-10-21 19:31:40.343 <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
2018-10-21 19:31:40.343 "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
2018-10-21 19:31:40.343 <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
2018-10-21 19:31:40.343 <head>
2018-10-21 19:31:40.343 <title>404 - Not Found</title>
2018-10-21 19:31:40.343 </head>
2018-10-21 19:31:40.343 <body>
2018-10-21 19:31:40.343 <h1>404 - Not Found</h1>
2018-10-21 19:31:40.343 </body>
2018-10-21 19:31:40.343 </html>
Can you help me?
Regards,
Francis
Raspberry Pi 2B, rfxcom rfxtrx433e, COCO switches, oregon scientific temp/hum sensors, Foscam 8904W, Foscam 9821W v2,
madpatrick
francisb wrote: Sunday 21 October 2018 19:33 Hi madpatrick,
Can you help me?
Regards,
Francis
Hi Francis,
This is harmless. I've also something this in my log file.
It will dissapear after a few minutes.
I think it has to do will the data Toon is sending.
EdwinK
Post by EdwinK »
O. Right. Need to re-add this again, since Domoticz died on me earlier.
francisb
Post by francisb »
well, i have run this for two hours now but still the error.....
madpatrick
francisb wrote: Sunday 21 October 2018 22:12 well, i have run this for two hours now but still the error.....
Check out this comment
Maybe you can rwmove the extra “,”
francisb
Post by francisb »
nope,
now i get this:
2018-10-22 19:13:51.924 Error: EventSystem: in Toon_Getinfo_lua: [string "-- Version 1:..."]:57: ')' expected near '"}"'
Regards,
Francis
tc1dft
Domoticz version: V4.9796
Post by tc1dft »
Hoi ..my too ..
Does anyone have an idea what is?
2018-11-02 11:28:06.247 Error: EventSystem: in BoilerTemp: [string "-- Time script runs every minute, intended to..."]:43: attempt to perform arithmetic on field '?' (a nil value)
2018-11-02 11:28:06.616 Error: EventSystem: in ToonBeta: [string "-- Version 1:..."]:80: attempt to perform arithmetic on field '?' (a nil value)
Regards, Tinus
I think look over it.
http://10.2.2.90:8080/#UserVariables
EdwinK
Post by EdwinK »
Check if your user-variables are EXACTLY written as instructed. I made a typo in one of them, and it gave me the same error.
madpatrick
Check out this post. https://www.domoticaforum.eu/viewtopic. ... =15#p87836
This script is in DZvent and is running smoother.
If you do not use all the functions you just need to disable them.
I've disable these functions (complete block):
-- domoticz.log(jsonGasPower)
-- Update the temperature Boiler setpoint to current boiler set point
Last edited by madpatrick on Saturday 03 November 2018 9:29, edited 1 time in total.
EdwinK
Post by EdwinK »
Seems to be using other user-variables.
madpatrick
EdwinK wrote: Saturday 03 November 2018 9:22 Seems to be using other user-variables.
Corrrect. but you can adjust these easily
The only thing i'm not getting to work in the P1 powerconsumption and P1 Powerdelivery (solarpanels)
EdwinK
Post by EdwinK »
Changed them all (Almost I think). Just need to find out about those P1 variables.
madpatrick
EdwinK wrote: Saturday 03 November 2018 10:19 Changed them all (Almost I think). Just need to find out about those P1 variables.
My Toon2 has different dev_ numbers.
Instead of dev_4 it is dev_2
So dev_44 = dev_24
EdwinK
Post by EdwinK »
Ah.. I have a Toon1.
thought i had it working..
 There is no device with that name or id: ToonBoilerTempIn
There is..
 	UV_ToonBoilerTempIn	String	ToonBoilerTempIn	2018-11-03 11:22:08
*sighs*
MatthijsD
Post by MatthijsD »
I hope someone can help me out here :)
Toon suddenly stopped working on Domoticz; Room Setpoint, HeatingOn, Stroom and Temperature are all last sen on 2018-10-10 02:07:38.
I have no idea where to look how to get this working again.
Anyone had this happen to?
Smiggel
Domoticz version: 4.9700
Post by Smiggel »
Did Toon perhaps get a new IP address?
MatthijsD
Post by MatthijsD »
Smiggel wrote: Monday 05 November 2018 11:07 Did Toon perhaps get a new IP address?
Could be. But I can't remember ever filling in an IP adress anywhere.
MatthijsD
Post by MatthijsD »
MatthijsD wrote: Monday 05 November 2018 11:02 I hope someone can help me out here :)
I've read the tutorial about Toon and Domoticz again, couldn't find anything out of the ordinary.
Then, I went to the Toon Hardware in Domoticz and turned it off and on again. Then suddenly it started working again!
Was lucky that this did the trick :')
ronalddehaan
Domoticz version: 2021.1
Post by ronalddehaan »
madpatrick wrote: Sunday 23 September 2018 14:11 snip
So this is the most recent (in a nutshell) instruction to get Toon talking to Domoticz?
In that case I will offer up a spare saturday evening to give it a new try :D
