The answer (for now) is no. This device is not new and doesn't show the same options (i.e. API password) within the Mi app. I think it will require a different approach from the normal gateway. I use it as a security cam at the moment. Just get the supported gateway for now.dmcastillo78 wrote: ↑Tuesday 07 August 2018 13:24 Hi,
Someone knows if the new Xiaomi Aqara IP camera Gateway is compatible with Domoticz as Gateway. This device works as a zigbee gateway and is a good alternative as a hub:
https://www.aliexpress.com/item/Origina ... autifyAB=0
I have seen that you have already asked but it has not been answered.
Thank you
The Aqara Shock/Vibration sensor just showed up in the Mi App.
https://www.aliexpress.com/item/Origina ... 51794.html
Would be cool to get support for it.
This shock devices is amazin but is "aqara", attention with the new aqara devices becasue aqara release a new gateway that only woks with aqara devices.
I dont know if this aqara shock device its compatible with previous mijia gateway :-O
i dont know
i dont know
I use the gateway that works with Domoticz and it popped up as a device I can add.
oleee.tezzlicious wrote: ↑Friday 17 August 2018 12:36I use the gateway that works with Domoticz and it popped up as a device I can add.
Thanks!! i bought one few minutes ago
Can anyone tell me how to upload a custom mp3 to the gateway? I have looked everywhere in the Mi Home app on Android but can't find it. I found some settings like color and volume but no option to upload anything
hi,
you need to enter the gateway, then select auto from top menu bar (Gateway - Auto - Device). The last row, menu 5 is "Doorbell" , select this one and then "Doorbell tone". There you you can add ringtones.
As far as I know you can not upload mp3 files.
ahhh, thank you.
edit: tried an mp3 and it seams to work fine
- gijsje
- Domoticz version: Stable
I have now included a few temp sensors with humidity and pressure and did see something strange.
There where 4 devices added to the device list.
But i do see difference in the humidity with the combined one the the device with only humidity.
If i look in the mi home app i do see that the 56% is correct.
Where is the 61% coming from?
Synology DS218+ - RFXtrx433 - Aeotec Z-Stick Gen5 - Toon Thermostat - Neo CoolCam plug - Neo CoolCam PIR - FIBARO PIR - Heiman Smart Smoke Senso - Neo CoolCam Leakage Detector - BeNext Tag Reader - P1 and S0 USB - many Mi-Light lights - KAKU switches
Did you finaly made it work? I just got mine today and I can't find the way.
No, i buy a Yeelight bulb and that works fine!salvacalatayud wrote: ↑Monday 03 September 2018 16:27
- sincze
- Domoticz version: 2024.4
i tried to retrieve the token for the lamp to have it work. However the token was not stored anymore in my mobile APP. So nu luck.salvacalatayud wrote: ↑Monday 03 September 2018 16:27
i was a bit to late as it seems I needed to retrieve it during registration in the APP... Well nu luck at all.
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Today i have a lot of errors like this:
Error: XiaomiGateway: received data from unregisted gateway!
anyone more?
anyone more?
Yes same for me. I try to delete and create gateway. Now i have no devices...
Envoyé de mon SM-G960F en utilisant Tapatalk
One gateway controlled with domoticz and home assistant.
It work correctly with home assistant
I open a issue in github:
https://github.com/domoticz/domoticz/issues/2711
- Domoticz version: latest
It is not a issue. Just added native support for multiple Xiaomi gateways.
You can simple add, remove and modify settings for Xiaomi gateway hardware without any restrictions.
Devices tied to the gateways will be managed and displayed correctly in the Domoticz.
in Domoticz you need to register all gateways. If the devices were logically connected to only the first gateway, then they need to be re-registered in Domotics correctly. Just like in MiHome. The device connected to the second gateway in MiHome, also must be connected to the second gateway in Domoticz.
- sincze
Hey xiaomi NOOB question, would this mean I can now also monitor devices connected to my second gateway ???ak97 wrote: ↑Monday 10 September 2018 5:57 It is not a issue. Just added native support for multiple Xiaomi gateways.
As the wiki states: 'Multiple gateways are supported but only with limited functionality on the additional gateways. Note that only the master gateway will listen for incoming messages (the master gateway is the hardware device in Domoticz with the lowest hardware Id). This is not a perfect solution, and if you have any questions or problems, post in the forum and I will try to address them.'
So I thought adding a motion sensor / door sensor to the second gateway is not really an option.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
