godinperson
That appears after a couple of seconds on the dashboard (beta)
VM228:1 Uncaught TypeError: Cannot read property 'push' of undefined
at <anonymous>:1:320
at <anonymous>:1:362
at gtm.js?id=GTM-KBQV6R:78
at Object.Xh (gtm.js?id=GTM-KBQV6R:80)
at wf (gtm.js?id=GTM-KBQV6R:32)
at yk.D (gtm.js?id=GTM-KBQV6R:124)
at Ik (gtm.js?id=GTM-KBQV6R:120)
at Vk (gtm.js?id=GTM-KBQV6R:134)
at dg (gtm.js?id=GTM-KBQV6R:135)
at ng (gtm.js?id=GTM-KBQV6R:43)
tontze
- Domoticz version: Beta Ch
Maybe add :godinperson wrote:Pretty much the same background only image.
var _THEME = 'default'; // default = dashticz default theme
to the beginning ?
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
robgeerts
- Domoticz version: 3.7067
Do you have Teamviewer? I can check your dashboard remotely if you want...
godinperson
sent my info in pm
SuperMouse
I have the exact same issue..SwordFish wrote:So i set variable _SHOW_LASTUPDATE = true and it works with the lines lastupdate in custom.js.bsmeding wrote:and the variable _SHOW_LASTUPDATE = true in CONFIG.js?
Now i have to set in all blocks that i dont want lastupdate to false.
I had it set variable _SHOW_LASTUPDATE = false and in some blocks i set show last update = true and that works.
But for some reason that doesn't work when you use custom.js to modify some text for switch.
Thanks for the help
qwerk
but if you use the orginal text is does work. as a work aroundSuperMouse wrote:I have the exact same issue..SwordFish wrote:So i set variable _SHOW_LASTUPDATE = true and it works with the lines lastupdate in custom.js.bsmeding wrote:and the variable _SHOW_LASTUPDATE = true in CONFIG.js?
Thanks for the help
the modified text will/can still be used with the device
brandnl
hello
I only get my favorite thing on it bookmark with a star but no
Groups.
and only one layout no Weather forecast etc
i use the Default installation and only the port number has changed
domoticz/www/
what am I doing wrong
gr jeroen (beginner)
Groups.
domoticz/www/
SuperMouse
Sorry it seens I have a different problem:qwerk wrote:but if you use the orginal text is does work. as a work aroundSuperMouse wrote:I have the exact same issue..SwordFish wrote:
Thanks for the help
I have a waterdetector under the washing machine what give other statuses.
Wasmachine water detector
blocks[164] = {}
blocks[164]['image'] = 'wasmachine.png'
blocks[164]['title'] = 'Wasmachine';
blocks[164]['width'] = 12;
function getBlock_164(device,idx){
$('.block_'+idx).attr('onclick','switchDevice(this)');
var html='';
html+='<div class="col-xs-4 col-icon">';
if(device['Status']=='Off') html+=iconORimage(idx,'fa-toggle-off','','off icon');
else html+=iconORimage(idx,'fa-toggle-on','','on icon');
html+='</div>';
html+='<div class="col-xs-8 col-data">';
html+='<strong class="title">'+device['Name']+'</strong><br />';
if(device['Status']=='Alarm') html+='<span class="state">PANIEK IN DE TENT</span>';
else html+='<span class="state">OK</span>';
html+='</div>';
return html;
- was paniek.png (7.7 KiB) Viewed 2874 times
- was ok.png (4.81 KiB) Viewed 2874 times
- HansieNL
Hello Jeroen,brandnl wrote:hello
Groups.
domoticz/www/
Can you show us your config.js file. You can put it in a post between
blocks. Then we can check if there's something wrong with it.Blah blah blah
SwordFish
- Domoticz version: V4.11375
But it is original a on/off switch and I want that to be aanwezig / afwezig.qwerk wrote:but if you use the orginal text is does work. as a work aroundSuperMouse wrote:I have the exact same issue..SwordFish wrote:
Thanks for the help
brandnl
Hello Jeroen,HansieNL wrote:brandnl wrote:hello
Groups.
domoticz/www/
blocks. Then we can check if there's something wrong with it.[/quote]
[code]var _LANGUAGE = 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ = 'http://192.168.2.2:8080';
var _DOMOTICZ_REFRESH = 5; //in seconds
var _DASHTICZ_REFRESH = 30; //in minutes
var _HOST_ZIGGO_HORIZON = ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND = '';
var _WEATHER_CITY = 'nuth';
var _WEATHER_CITYNAME = ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY = 'NL';
var _USE_AUTO_POSITIONING = false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = true; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = false; //do not show the seconds in the clock
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT = false;
var _USE_BEAUFORT = true; //Bft instead of m/s
var _TRANSLATE_SPEED = false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES = false; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER = 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE = true;
var _LASTUPDATE_FORMAT = 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT = 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
var _APIKEY_MAPS = '';
var _MAPS_LATITUDE = '';
var _MAPS_LONGITUDE = '';
var _AUTO_SWIPEBACK_TO = 1; //when no activity, swipe back to main screen after x seconds
var _AUTO_SWIPEBACK_TIME = 10; //seconds
//predefined colors, when you have RGB-lamps
var _SAVED_COLORS = ['black', 'white', 'blanchedalmond','rgb(255, 128, 0);', 'hsv 100 70 50', 'lightyellow'];
// Online Radio Stream Plugin, Note: you must enable plugin in column section 'streamplayer', see columns[3]['blocks'] example below.
var _STREAMPLAYER_TRACKS = [
{"track":1,"name":"Music FM","file":"http://stream.musicfm.hu:8000/musicfm.mp3"},
{"track":2,"name":"Radio 1","file":"http://213.181.210.106:8000/high.mp3"},
{"track":3,"name":"Test FM","file":"http://213.181.210.106:8000/high.mp3"},
// iCalendar Plugin, supports all .ics calendar types like Google Calendar, Apple Calendar
var _ICALENDAR_URL = 'https://testurl.com/ical.ics'; //supports .ics type calendars (Google Calendar, Apple Calendar etc.)
var _ICALENDAR_DATEFORMAT = 'friendly'; //'friendly', 'MM.DD.YYYY HH:mm', 'DD.MM.YYYY HH:mm', 'YYYY.MM.DD HH:mm'
var _ICALENDAR_LOCALE = 'en'; //en,hu, etc.
//Buttons or images to open webpages in an iframe, like a news website or weather forecast
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weeronline.nl/Europa/Nederland/Son/4058667'}
//CUSTOM POSITIONING:
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
//var blocks = {}
//blocks[1] = {}
//blocks[1]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
//blocks[1]['title'] = 'Living room' //if you want change the name of switch different then domoticz
//blocks[1]['icon'] = 'fa-eye'; //if you want an other icon instead of the default, choose from: http://fontawesome.io/cheatsheet/
//blocks[1]['image'] = 'bulb_off.png'; //if you want to show an image instead if icon, place image in img/ folder
//blocks[204] = {} //dimmer
//blocks[204]['width'] = 12;
//blocks[204]['title'] = 'Living room' //if you want change the name of switch different then domoticz
//blocks['blocktitle_1'] = {}
//blocks['blocktitle_1']['type'] = 'blocktitle';
//blocks['blocktitle_1']['title'] = 'Schakelaars';
//var columns = {}
//columns[1] = {}
//columns[1]['blocks'] = ['blocktitle_1',1,2,62,'144_2',204,248,295] //remark: idx 144 produces 2 blocks, so you can use: '144_1' and '144_2' (or of course, just 144 if you want one)
//columns[1]['width'] = 5;
//columns[2] = {}
//columns[2]['blocks'] = ['currentweather_big','weather',5,'144_1']
//columns[2]['width'] = 5;
//columns[3] = {}
//columns[3]['blocks'] = ['clock','sunrise','horizon','streamplayer',buttons.buienradar,buttons.radio,buttons.calendar,buttons.nunl,buttons.nzbget]
//columns[3]['width'] = 2;
//var columns_standby = {}
//columns_standby[1] = {}
//columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
//columns_standby[1]['width'] = 12;
//if you want to use multiple screens, use the code below:
//var screens = {}
//screens[1] = {}
//screens[1]['background'] = 'bg1.jpg';
//screens[1]['background_morning'] = 'bg_morning.jpg';
//screens[1]['background_noon'] = 'bg_noon.jpg';
//screens[1]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[1]['background_night'] = 'bg_night.jpg';
//screens[1]['columns'] = [1,2,3]
//screens[2] = {}
//screens[2]['background'] = 'bg3.jpg';
//screens[2]['background_morning'] = 'bg_morning.jpg';
//screens[2]['background_noon'] = 'bg_noon.jpg';
//screens[2]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[2]['background_night'] = 'bg_night.jpg';
//screens[2]['columns'] = [4,5,6]
- EdwinK
- Domoticz version: BETA
I think this might be the problem:
If you want to use favorites, you need to set _USE_AUTO_POSTING = true; see the remarks.
var _USE_FAVORITES = true; //only used when using auto positioningRunning latest BETA on a Pi-3 | Toon® Thermostat (rooted) | Hue | Tuya | IKEA tradfri | Dashticz V3 on Lenovo Huawei Tablet | Conbee
- HansieNL
@brand.nl:
You want custom positioning var _USE_AUTO_POSITIONING = false so you have to uncomment (remove the slashes //) everything under following lines and fill in your own blocks/columns/screens.
About the weather forecast, did you fill in var _APIKEY_WUNDERGROUND = ''; ? You can get a free API key at https://www.wunderground.com/weather/api/d/pricing.html
I hope this info will help you.
Blah blah blah
godinperson
We (@robgeerts did) solved my issue. Because it's a brand new installation and project, I don't have any switches so we had to create a dummy switch and do the positioning manual in order to get info on the screen.
It would be nice to have a Kodi widget in the future and I'll try to put an RSS field in the right positioning.
Thanks for your help!
godinperson
Can't place my rss. Would that link work: http://www.rds.ca/cmlink/le-fil-de-pres ... ttes-1.831 (French sports). I would also have another link which is in XML http://www.lapresse.ca/rss/225.xml
For the media player, which one is it? It would be nice to have a widget where it shows currently playing and basic control. I can help gather the information is you want.
tontze
Does faulty custom.css generate "check var _HOST_DOMOTICZ " error that comes up time to time ?
Because im not finding any error in CONFIG.js atm ..
Im not sure is my custom.js faulty, i just copied some corner rounding code to it and it works, but might have errors in it. Can someone check it below ?
Here is my CONFIG.js too :
Thnx !
CUSTOM CSS FILE
/* Background blocks */
.transbg.col-xs-1,
.transbg.col-xs-2,
.transbg.col-xs-3,
.transbg.col-xs-4,
.transbg.col-xs-5,
.transbg.col-xs-6,
.transbg.col-xs-7,
.transbg.col-xs-8,
.transbg.col-xs-9,
.transbg.col-xs-10,
.transbg.col-xs-11,
.transbg.col-xs-12 {
padding-top:15px;
padding-bottom:15px;
border: 7px solid rgba(255,255,255,0);
background: rgba(0,0,0,0.2);
background-clip: padding-box;
border-radius: 25px; /* Round corners */
.fa.fa-lightbulb-o.on {
color:#F1C300;
.fa.fa-lightbulb-o.off {
color:#fff;
var _LANGUAGE = 'en_US'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ = 'http://192.168.xxx.xxx:8080';
var _WEATHER_CITY = '';
var _WEATHER_COUNTRY = 'FI';
var _USE_FAVORITES = false; //only used when using auto positioning
var _HIDE_MEDIAPLAYER_WHEN_OFF = true; //when you have a mediaplayer connected, hide it if nothing is playing
var _NEWS_RSSFEED = 'http://feeds.feedburner.com/ampparit-kaikki-rss';
var _USE_BEAUFORT = false; //Bft instead of m/s
var _STANDBY_AFTER_MINUTES = 5; //enter amount of minutes like: 5 (5 minutes)
{"track":1,"name":"Kiss FM","file":"http://stream2.bauermedia.fi/kiss.mp3"},
{"track":2,"name":"Bassoradio","file":"http://stream.basso.fi:8000/stream"},
{"track":3,"name":"Loop","file":"http://icelive0.80692-icelive0.cdn.qbrick.com/10561/80692_Loop.mp3"},
{"track":4,"name":"Radio SuomiPop","file":"http://icelive0.80692-icelive0.cdn.qbrick.com/10566/80692_RadioSuomipop.mp3"},
{"track":5,"name":"Radio NRJ","file":"http://cdn.nrjaudio.fm/adwz1/fi/35001/mp3_128.mp3"},
{"track":6,"name":"Radio Rock","file":"http://icelive0.80692-icelive0.cdn.qbrick.com/10565/80692_RadioRock.mp3"},
//var _ICALENDAR_URL = 'https://testurl.com/ical.ics'; //supports .ics type calendars (Google Calendar, Apple Calendar etc.)
//var _ICALENDAR_DATEFORMAT = 'friendly'; //'friendly', 'MM.DD.YYYY HH:mm', 'DD.MM.YYYY HH:mm', 'YYYY.MM.DD HH:mm'
//var _ICALENDAR_LOCALE = 'en'; //en,hu, etc.
var calendars = {}
calendars.hobby = { url: 'https://some_url/api/v2/public/calendar-share/fi/userfile/all.ics', icalurl: 'https://some_url/api/v2/public/calendar-share/fi/userfile/all.ics' }
var buttons = {}
buttons.radio = {width:12, image: 'img/radio_on.png', title: 'Radio', url: 'http://livetaajuus.fi'}
buttons.nunl = {width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', url: 'http://feeds.feedburner.com/ampparit-kaikki-rss'}
buttons.moon = {width:12, isimage:true, refreshimage:60000, image: 'moon'}
var blocks = {}
blocks[163] = {}
blocks[163]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[163]['title'] = 'BMW' //if you want change the name of switch different then domoticz
blocks[163]['image'] = 'fa_bmw.png'; //if you want to show an image instead if icon, place image in img/ folder
blocks[184] = {}
blocks[184]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[184]['title'] = 'KiA' //if you want change the name of switch different then domoticz
blocks[184]['image'] = 'kia-128.png'; //if you want to show an image instead if icon, place image in img/ folder
blocks[36] = {}
blocks[36]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
blocks[36]['title'] = 'Ulkopistoke' //if you want change the name of switch different then domoticz
blocks[36]['icon'] = 'fa-pause-circle-o'; //if you want an other icon instead of the default, choose from: http://fontawesome.io/cheatsheet/
//blocks[36]['image'] = 'wall-socket.png'; //if you want to show an image instead if icon, place image in img/ folder
//blocks[28] = {}
//blocks[28]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
//blocks[28]['title'] = 'Patio' //if you want change the name of switch different then domoticz
//blocks[28]['icon'] = 'fa-film'; //if you want an other icon instead of the default, choose from: http://fontawesome.io/cheatsheet/
var columns = {}
// First Column
columns[10] = {}
columns[10]['blocks'] = ['clock',calendars.hobby,119,120,121,122,123,2,144,1]
columns[10]['width'] = 5;
// Second Column
columns[20] = {}
columns[20]['blocks'] = ['currentweather_big','weather',149,163,184,93,99,27,98,33,28,105,36,162]
columns[20]['width'] = 5;
// Third Column
columns[30] = {}
columns[30]['blocks'] = ['sunrise',buttons.moon,'streamplayer',buttons.radio]
columns[30]['width'] = 2;
columns_standby[1]['blocks'] = ['clock','weather']
var screens = {}
screens[1] = {}
screens[1]['background'] = 'bg_1.jpg';
screens[1]['columns'] = [10,20,30]
//screens[2] = {}
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
robgeerts
Well, it looks like a missing } at the end of custom.css..
But i dont know if that causes the problem..
Jonb
- Domoticz version: 3.5877
I see that Repoman asked this question already 2 times. I have the same question too...repoman wrote:Any suggestions?repoman wrote:Hi folks,
I've downloaded the latest beta and i like the moving weather icons. I'm also happy to see that the news items are scrolling again. Thnx!
The problem I have is with the dual output blocks. I'm using a youless device to monitor energy usage.
When I use 'idx_1' I get te total power usage of today and when I use 'idx_2' I get the total power usage.
I would like to see the current power usage. ('ídx_3' gives me an emty block...)
Related to this is are the temperature sensors. I suspect it should be possible to use i.e. 'idx_1'for temperature and 'idx_2' for humidity but it doesn't.
I still get two blocks while I only need the temperature reading..
Probably something stupid but I can't find it in the wiki..
A little help is much appreciated.
Thnx,
Pascal
Anybody that can help maybe?
tontze
Oh, it is there, copy/paste errorrobgeerts wrote:Well, it looks like a missing } at the end of custom.css..
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
qwerk
I have the clock running on 1 screen.
sometimes it stotters a little, or hangs a few seconds and then jumps to the correct time.
Where is the clock time "running" is this my local pc, or on the webserver ?
