Page 12 of 16
Re: Energy Dashboard (Build in)
Posted: Monday 18 November 2024 12:29
by Ctenberge
Thank you, it works fine.
The watermeter is another issue , and yes I have a watermeter in Domoticz for more then a year.
It is present in the energy dashboard, so why it's not to be handled here?
It is not that important to me, it's just a nice picture.
Posted: Monday 18 November 2024 16:57
You have to set it as one of the custom widgets, see the screenshot in https://wiki.domoticz.com/Energy_dashboard for a reference.
Else post a screenshot of the Watermeter device widget and your the energy dashboard configuration settings.
Posted: Tuesday 19 November 2024 16:08
by Ctenberge
Ah, I see. Forgot to tell that I have it in use, but the icon is not that of drop of water but just 4 squares.
Wat I ment was that choosing the item "water" (the third option), shows only disabled. And choosing waterflow as a dummy does not appear eather, what seams to be logic.
Please let me know when the "water" option will be in use.
It would be nice that I, for now, could choose de waterdrop as the proper icon
Posted: Tuesday 19 November 2024 16:59
Ah, you need to have a proper Domoticz water counter device and then it works.
Edit: as shown here https://wiki.domoticz.com/Dummy_for_vir ... es#Counter
Posted: Wednesday 20 November 2024 10:42
by Ctenberge
My watermeter does not combine 2 values, and therefore my device has only 1. The dashboard does not see's such a device and hence the disable.
How can I create that device, given the presence of more then one counter the actual watermeter send it to Domoticz?
Posted: Wednesday 20 November 2024 10:47
Ctenberge wrote: Wednesday 20 November 2024 10:42 My watermeter does not combine 2 values, and therefore my device has only 1. The dashboard does not see's such a device and hence the disable.
The Domoticz counter does not combine 2 values, it calculates values from the total or incremental counter value it receives from your hardware.
What kind of Domoticz watermeter device do you have now? Can you post a screenshot of the device widget?
Posted: Wednesday 20 November 2024 10:48
by Ctenberge
Now I was to quick to answer. The watermeter device in Domoticz has 2 values:
So, why not showing.
Posted: Wednesday 20 November 2024 10:51
by Ctenberge
And here the widget
Posted: Wednesday 20 November 2024 10:54
You have to manually select it in the Setup - settings menu, tab energy dashboard. By default it is disabled. If you click on the pull down menu for water you should see the Watermeter Value device to select. Then click on Apply Settings and then it should be visible in the energy dashboard.
Posted: Wednesday 20 November 2024 11:00
by Ctenberge
And now i saw what was wrong, the device type "custom"I changed it in watermeter and it shows:
Thank you for showing me the way.
Posted: Thursday 12 December 2024 16:54
by Zuikkis
Are the dynamic energy prices working? I'm having incredibly weird results.
Now, my energy price custom sensor is using c/kWh units which I know are probably wrong, it should be €/kWh? Or perhaps €/Wh? Documentation doesn't mention anything about this.
The price for today has varied between 0.04€ - 0.10€ per kWh.
152/116 = 1.31€ /kWh which is nowhere near the real value even if you divide it by 100..
Edit: I just configured this yesterday, maybe I need to wait a bit longer?
Posted: Thursday 12 December 2024 17:41
You have to use €/kWh as a tariff, it off course also depends on the currency you use $, £,¥ etc
Posted: Thursday 12 December 2024 17:51
by Zuikkis
waltervl wrote: Thursday 12 December 2024 17:41 You have to use €/kWh as a tariff, it off course also depends on the currency you use $, £,¥ etc
Yes. But shouldn't it be 100* times off with c/kWh? It's not.
Posted: Thursday 12 December 2024 19:48
Check the report page of that device. It give perhaps more insight.
And also wait at least 2 full days to understand the values.
Posted: Saturday 14 December 2024 8:11
by gizmocuz
Did you use 116687 kWh for that day? Is this correct? or should it have been 116.xx kWh ? If that is the case, your kWh value is not correct.
Posted: Saturday 14 December 2024 18:27
by Zuikkis
gizmocuz wrote: Saturday 14 December 2024 8:11 Did you use 116687 kWh for that day? Is this correct? or should it have been 116.xx kWh ? If that is the case, your kWh value is not correct.
"," is the decimal point in Finnish locale. Domoticz seems to use "," and "." randomly depending on the page. kWh value is correct.
On the dashboard it shows like this:
And the report page:
Here's the screenshot of the energy page for today:
Electricity price has been quite rock solid 7-8 c/kWh for the entire day. As you can quickly see, the math for each device seems to be different but none are correct.
Upper electric car: 128.14c / 31.368 kWh = 4.08 c/kWh
Lower electric car: 30.37c / 10.691 kWh = 2.84 c/kWh
Solar: 0.42c / 0.072kWh = 5.83 c/kWh (ok quite small numbers :) )
Grid: 696.97c / 153.810 kWh = 4.53 c/ kWh
Here's the daily values of my price custom sensor:
DateTime	Custom Sensor
2024-12-14 00:05:00	7,62
2024-12-14 01:00:00	9,07
2024-12-14 02:05:00	7,96
2024-12-14 03:00:00	7,35
2024-12-14 04:00:00	6,96
2024-12-14 05:05:00	6,52
2024-12-14 06:00:00	6,43
2024-12-14 07:05:00	8,31
2024-12-14 08:05:00	8,77
2024-12-14 09:00:00	8,01
2024-12-14 10:00:00	7,83
2024-12-14 11:00:00	7,33
2024-12-14 12:00:00	7,18
2024-12-14 13:00:00	7,02
2024-12-14 14:00:00	7,02
2024-12-14 15:00:00	6,99
2024-12-14 16:00:00	7,00
2024-12-14 17:00:00	8,64
2024-12-14 18:05:00	7,89
2024-12-14 19:00:00	6,90
Again don't worry about the commas, the values show with dot in Domoticz. Edit: I exported CSV from the report page and deleted lines so I have only one value per hour. Interestingly some hours didn't have the :00:00 time in the log so I used :05:00 for those instead. Why is 00:00 time missing from the report?
As you can see there is no way to get 4.xx c/kWh prices at any hour. And my battery and cars are scheduled so that they charge at the same time so battery power has no effect on car charging price.
I am using the latest stable domoticz. Perhaps it would work better in a later beta version?
Edit: Also where is the electric price unit configured? It just guesses € because of my location? I would prefer c/kWh if possible. But if I get this working better I can change to € if needed, it's just that my own scripting uses c/kWh in many places.
Posted: Saturday 14 December 2024 19:05
by Zuikkis
Hey, I might be hitting some upper limit on the prices in some mysterious way. An hour has passed, last screenshot was from 18:55 and this is from 20:01:
As you can see the prices have not incremented at all, even thought kwh is incremented. But weird if there is some overflow or upper limit, why is the limit different for each counter? The devices might have different update intervals, but can't think of any other difference..
I will try switching to €/kWh in my custom counter, or just create another one with /100 values so I don't have to mess with my scripts that depend on c/kWh. In theory that should move the overflow limit 100 times higher?
Edit: Bah, grid € counter just updated to 708.23€.. so it was not limited after all.
Posted: Sunday 26 January 2025 15:25
by rron
I have a small problem:
A S0 device is not available as Solar device in Energy Dashboard Setup. The type is general and Counter incremental. I have searched this topic but I couldn´t find it. The result is that thereś no value for the solar. How can I solve this?
Posted: Sunday 26 January 2025 16:21
by rron
Got it wrong device. Still the same problem, I cann´t select my S0 general counter in my Solar setting because it does not appear in the selection.
Posted: Sunday 02 February 2025 15:15
by rron
In the other free fields there you can choose general counters but not in solar
