Page 12 of 94
Posted: Tuesday 21 July 2015 14:50
by Hartenj
I have a DS213+ running DSM 5.2-5592 Update 1 with Domotics V2.2621 set up as master
The slave is A Exchange 2008 server running Domoticsz V2.2657 and Open Hardware monitor to monitor it's motherboard sensors
The connectivity between Master and slave is OK, remote sensors from the Exchange server show up but the info is completely meaningless.
Is there an issue on the Synology, if not which versions work together or...... even better.... can we expect build V2.2657 for the Synology and does this solve the issue?
Many thanks!
Posted: Tuesday 21 July 2015 23:05
by kraades
Does anyone have the S0 Pulse Counter Module working connected to the Synology?
https://sites.google.com/site/nta8130p1 ... er/webshop
Any change of having the drivers included in the package?
I think it is Arduino Leonardo based.
Posted: Friday 14 August 2015 12:59
by DinkyToys
I have troubles to get the event working with a timestamp.
Is there some bug arround with Synology and Domoticz?
Posted: Saturday 15 August 2015 10:09
by mvveelen
Hi Jumbotroll, I've been running the V2.2621 for a while now and also installed it on the DS414 my father-in-law just bought: works great. But, will there be an update in the near future for the armadaxp (DSM5.2, latest) to keep up with the latest developments
? Thanks for your great work, much appreciated !
Posted: Monday 17 August 2015 23:35
by jumbotroll
mvveelen wrote:Hi Jumbotroll, I've been running the V2.2621 for a while now and also installed it on the DS414 my father-in-law just bought: works great. But, will there be an update in the near future for the armadaxp (DSM5.2, latest) to keep up with the latest developments
There is so much changes in the domoticz source and Openzwave source , so there is a lot of work and many changes to cross- compile for synology at the moment that I await further updates. I do not have time to change the code. Time will tell if I sit down and work on it.
Jumbotroll
Posted: Tuesday 18 August 2015 9:14
by tehnoinstyle
jumbotroll
I've been using your package USBserialDriver
http://www.domoticz.com/forum/viewtopic ... 120#p35984
on my DS3615 (bromolow) DSM5.1-5022 for other applications that use AeonLab Stick S2 (not Domoticz).
On my second DS3615 (bromolow) DSM5.2-5592.
You have a package USBserialDriver for DSM5.2-5592?
Posted: Tuesday 18 August 2015 12:54
by jumbotroll
tehnoinstyle wrote:Hi,
jumbotroll
USBSerialDrivers_5.2_5592_Test.spk
Deleted
Jumbotroll
Posted: Tuesday 18 August 2015 16:20
by LouiS22
jumbotroll wrote:tehnoinstyle wrote:Hi,
jumbotroll
THIS IS ONLY A TEST!
I have tested on arch-x86 DS-712+ and it worked here.
Modified some foldername.
You can download from my server and test USBSerialDrivers_5.2_5592_Test.spk :
http://jadahl.dscloud.me/sspks/packages ... 2_Test.spk
REMEMBER THIS IS ONLY A TEST!!!
Jumbotroll
Hey, I also did the above modification, it seems working on my config, at least RFXCOM is happy
Jumbotroll, may I request you to upload your modified spksrc files somewhere? I'm interested in 88f6281, I have successfully build my own versions up to 2730, but without OZW, since I couldn't figure out one thing with that (I think it's just a symlink, or something trivial). If so, then probably I could provide updates (though I have to find a solution to grab the latest beta from github
Posted: Tuesday 18 August 2015 19:42
by dpons039
Hey there,
I have been using the package successfully for the last weeks and it works great!
But I'm having issues with the USB coz randomly the port changes from ttyACM0 to ttyACM1, i read there's an option for persistence but no clue on how to perform that on the NAS.
Any clues?
Thank you
PS: The Lua Scripts folder has changed the location and it's not updated within the package
Posted: Tuesday 18 August 2015 22:19
by jumbotroll
I do not have the spksrc files, USBSerialDrivers, source is made by Noam Lebovitz.
Jumbotroll
Posted: Tuesday 18 August 2015 22:41
by LouiS22
Jumbotroll
Forgive me, I should have request more clearly
I'm interested in the spksrc files for compiling domoticz.spk, not he USB drivers!
Posted: Tuesday 18 August 2015 22:52
by jumbotroll
Jumbotroll
I Use Gkroone spksrc files and have change the OpenZwave and domoticz version.
You can downlod it here :
https://github.com/gkroone/spksrc/tree/Domoticz2563
Posted: Tuesday 18 August 2015 23:13
by LouiS22
No additional changes at all? I use gkroone's repo too, but have problems compiling OZW. Thought you might have changed there something.
Posted: Tuesday 18 August 2015 23:21
by jumbotroll
Same problem here
Cross Compiling fails after OpenZwave 1.3.328 Thats the reason I don't have updated.
I don't have time to look at it right now.
If you find a solution, let me know.
Jumbotroll
Posted: Wednesday 19 August 2015 10:17
by tehnoinstyle
Many thanks. I downloaded, I will try.
Will the release, not a test version?
Posted: Wednesday 19 August 2015 11:36
by jumbotroll
I do not have the spksrc files, USBSerialDrivers Source code is made by Noam Lebovitz.
Noam Lebovitz is the man that can make releases, not me
I only make some modifications from USBSerialDrivers_3.0.2.
But it seems that he have left the project, he haven't made new releases for a long time.
Jumbotroll
Posted: Wednesday 19 August 2015 11:37
by LouiS22
Same problem here
Jumbotroll
Hehe. And now, after moving domoticz to github, there'll be another issue: to fix the source code download and correcting the version numbers.
Posted: Friday 21 August 2015 16:08
by amz4u2nv
Hi, I've just installed the domoticz package, and im new to domoticz.
I am trying to get a script to run -
The script is place in /volume1/@appstore/domoticz/samplescripts/lua
However looking at the logs in never runs, do I need to do anything else to get the script to run -
permissions on the script is -rwxrwxrwx 1 root root 1842 Aug 21 14:36 script_device_sensorWU.lua
Any help is much appreciated.
Posted: Friday 21 August 2015 20:54
by G3rard
The lua scripts that you want to use must be in domoticz/var/scripts/lua (or something like that, I am not in front of my PC right now so can not check).
I think my scripts have domoticz as user instead of root (again can't check that right now). So maybe change that as well.
Posted: Friday 21 August 2015 21:11
by jumbotroll
On my Synology it is /volume1/@appstore/domoticz/var/scripts/lua
Jumbotroll
