Page 12 of 16
Re: Python Plugin: Broadlink RM2 V3
Posted: Thursday 07 December 2017 17:14
by zak45
@hrushchov
may reason should be wrong IP address or not reachable.
@vchecco
I actually decided to use this one :
http://jarvishome.fr/index.html
Can ask for question like Room Temp / outside temp / Should it rain in next hour etc ...
Able to manage in the way I want and all stay local.
Posted: Saturday 09 December 2017 19:36
by MikeNg
TigroEHOT wrote: Monday 14 August 2017 6:00
If i delete the hardware and create new with 127.0.0.1 I get the discover device. If i turn it on i get this in the log:
2017-08-14 13:56:05.018 User: Admin initiated a switch command (228/Broadlink RM2 - Discover/On)
2017-08-14 13:56:05.051 (Broadlink RM2) Calling message handler 'onCommand'.
2017-08-14 13:56:05.051 (Broadlink RM2) onCommand called for Unit 1: Parameter 'On', Level: 0 , Connected : False
2017-08-14 13:56:05.051 (Broadlink RM2) All plugin system is on pause for 5s...
2017-08-14 13:56:10.058 (Broadlink RM2) Found 1 broadlink devices
2017-08-14 13:56:10.071 Error: (Broadlink RM2) 'onCommand' failed 'TypeError':'sequence item 0: expected str instance, bytes found'.
2017-08-14 13:56:10.071 Error: (Broadlink RM2) ----> Line 210 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function onCommand
2017-08-14 13:56:10.071 Error: (Broadlink RM2) ----> Line 397 in /home/pi/domoticz/plugins/BroadlinkRM2/plugin.py, function Discover
2017-08-14 13:56:10.072 Error: (Broadlink RM2) ----> Line 203 in /usr/lib/python3.5/broadlink/__init__.py, function auth
2017-08-14 13:56:10.072 Error: (Broadlink RM2) ----> Line 258 in /usr/lib/python3.5/broadlink/__init__.py, function send_packet
2017-08-14 13:56:10.072 Error: (Broadlink RM2) ----> Line 162 in /usr/lib/python3.5/broadlink/__init__.py, function encrypt_pyaes
2017-08-14 13:56:29.005 (Broadlink RM2) Calling message handler 'onHeartbeat'.
2017-08-14 13:56:29.019 Error: (Broadlink RM2) Error Connecting to Broadlink device....
I'm running domoticz 3.8288 on raspberri pi 3, python 3.5.2, broadlink 0.5
P.S. On the latest stable i get the same error.
I got the same issue and successfully fixed it. So this is what i did.
when i installed broadlink again and also crypo and copied both to the /usr/lib/python3.5 i noticed that the one in the 3.5 has no capitol C for Crypto
i tried to rename it but that did not work.
Then i looked in the folder /usr/lib/python3/dist-packages/ and there is saw Crypto with a lot more files then in the 3.5 one.
So i copied that one "sudo cp -r /usr/lib/python3/dist-packages/Crypto/ /usr/lib/python3.5/" restarted Domoticz and everything works.
Posted: Sunday 17 December 2017 12:35
by SzymonZy
Can we use Broadlink SP1 with this plugin already? I found protocol hack on net (
https://blog.ipsumdomus.com/broadlink-s ... 0b4b397af1) but will it be implemented into Domoticz?
Posted: Sunday 17 December 2017 12:40
by zak45
yes, the V4 is finished : could use Sp1 , sp2/sp3/sp3s, mp1, a1
publish soon.
Posted: Sunday 17 December 2017 12:56
by SzymonZy
Does git repository at this moment include support for this sockets?
Posted: Tuesday 19 December 2017 16:02
by omnisxin
hi ,zark45:
I use domoticz 3.8791, python 3.4 in raspberry pi, for attached json files ,jsonSubIr.rar is backup seven months ago,jsonSubIr.zip is backup today,all from same phone e-control app,
jsonSubIr.rar can be generated correctly, but jsonSubIr.zip informs error "Error with json files to import "
trace the error ,maybe caused by these lines in plugin.py:
try:
with open(path+"jsonIrCode") as code_name:
data_code = json.load(code_name)
except ValueError: # includes simplejson.decoder.JSONDecodeError
return False
Posted: Tuesday 19 December 2017 19:21
by zak45
hi omnisxin
to be able to test, I need all ini files.
Posted: Wednesday 20 December 2017 2:01
by omnisxin
As described ,jsonSubIr.rar can generate ini files, I'll upload later,but jsonSubIr.zip inform error, didn't generate any files.
Posted: Thursday 28 December 2017 12:25
by SzymonZy
@zak45 do you plan to support SC1 in V4 release?
Posted: Tuesday 02 January 2018 0:21
by zak45
SzymonZy wrote: Thursday 28 December 2017 12:25
Not yet part of the broadlink module.
Posted: Tuesday 02 January 2018 11:16
by SzymonZy
Are there any special circumstances that prevent adding this device in future?
Posted: Tuesday 02 January 2018 13:52
by zak45
SzymonZy wrote: Tuesday 02 January 2018 11:16
don't think so... maybe you can made a request to broadlink module devloper:
https://github.com/mjg59/python-broadlink
if this become be part of it, I can try to include into the plugin.
Posted: Tuesday 16 January 2018 21:54
by domoticzag
Hi All,
Quick question.
I have the Broadlink RM2 plugin working for the mini RM 3.
Works fine!
One thing I wanted to do, was use my TV remote controller to set devices in domoticz, so i could use the colors on the remote to set all the lights in the house to the same color
But the device doesnt update if I press the teached button on the remote controller. The RM does imitate the teached code, but not update the device in domoticz.
Is this currently possible with this plugin?
Posted: Tuesday 16 January 2018 23:00
by zak45
domoticzag wrote: Tuesday 16 January 2018 21:54
Hi All,
Quick question.
Works fine!
What I had understood, you need some IR receiver connected to Domoticz ( made one myself using ESP8266 + IR receiver ). The RM2 device is just like your TV remote controller, only able to send some IR codes.
Posted: Wednesday 17 January 2018 11:44
by domoticzag
Hmm oke thanks, already thought so
Did you use your own code for the ESP8266 if so could you share the code?
Or did you use the Easy ESP Firmware?
I have an ESP and IR receiver lying around somewhere
Posted: Wednesday 17 January 2018 13:03
by zak45
domoticzag wrote: Wednesday 17 January 2018 11:44
Yep, ESPEasy is the way to go
I created a dummy switch and a LUA script :
if devicechanged['IR'] == '16595143' then
commandArray['433-VoletCuisine'] = 'On REPEAT 2'
commandArray['433-VoletSAM'] = 'On REPEAT 2'
elseif devicechanged['IR'] == '16586983' then
commandArray['433-VoletCuisine'] = 'Off REPEAT 2'
commandArray['433-VoletSAM'] = 'Off REPEAT 2'
elseif devicechanged['IR'] == '16631863' then
elseif devicechanged['IR'] == '16642063' then
elseif devicechanged['IR'] == '16582903' then
elseif devicechanged['IR'] == '16593103' then
elseif devicechanged['IR'] == '16589023' then
commandArray['Portail'] = 'On'
elseif devicechanged['IR'] == '16635943' then
if otherdevices['Garage - Porte'] == 'Closed' then
commandArray['Garage - open'] = 'On'
commandArray['Garage - close'] = 'Off'
So, in this way I can use my Logitech Harmony as Domoticz remote control
Posted: Friday 19 January 2018 10:52
by domoticzag
@Zak45 Thanks!
Posted: Monday 22 January 2018 22:41
by SzymonZy
zak45 wrote: Sunday 17 December 2017 12:40
publish soon.
Any release date scheduled?
Posted: Wednesday 24 January 2018 20:44
by ChopCZ
I am having a strange issue.
It took me long time to locate the problem but I have found that when I comment out the line
in the plugin.py file
then plugin starts and creates two new devices for discover and remote.
Of course in the log there is an error
2018-01-24 20:30:41.931 (Xiaomi Gateway) Temp (Xiaomi Temperature)
2018-01-24 20:30:42.000 Python EventSystem: Initalizing event module.
2018-01-24 20:30:42.000 EventSystem: Started
2018-01-24 20:30:42.000 EventSystem: Queue thread started...
2018-01-24 20:30:42.094 PluginSystem: Entering work loop.
2018-01-24 20:30:42.370 (Broadlink) Entering work loop.
2018-01-24 20:30:42.370 (Broadlink) Initialized version 3.0.0, author 'zak45'
2018-01-24 20:30:42.373 (Broadlink) Debug log level set to: 'true'.
2018-01-24 20:30:42.373 (Broadlink) 'Version':'3.0.0'
2018-01-24 20:30:42.373 (Broadlink) 'Author':'zak45'
2018-01-24 20:30:42.373 (Broadlink) 'DomoticzVersion':'3.8841'
2018-01-24 20:30:42.373 (Broadlink) 'DomoticzHash':'b86cc8ab'
2018-01-24 20:30:42.373 (Broadlink) 'Address':'127.0.0.1'
2018-01-24 20:30:42.373 (Broadlink) 'Key':'BroadlinkRM2'
2018-01-24 20:30:42.373 (Broadlink) 'Mode3':'no'
2018-01-24 20:30:42.373 (Broadlink) 'Mode5':'9000'
2018-01-24 20:30:42.373 (Broadlink) 'Mode6':'Debug'
2018-01-24 20:30:42.373 (Broadlink) 'Port':'0'
2018-01-24 20:30:42.373 (Broadlink) 'Mode1':'000000000000'
2018-01-24 20:30:42.373 (Broadlink) 'HardwareID':'6'
2018-01-24 20:30:42.373 (Broadlink) 'HomeFolder':'/home/pi/domoticz/plugins/Broadlink/'
2018-01-24 20:30:42.373 (Broadlink) 'Name':'Broadlink'
2018-01-24 20:30:42.373 (Broadlink) 'Mode4':'no'
2018-01-24 20:30:42.373 (Broadlink) 'DomoticzBuildTime':'2018-01-24 15:06:19'
2018-01-24 20:30:42.373 (Broadlink) 'Mode2':'/home/pi/domoticz/broadlink_ini'
2018-01-24 20:30:42.373 (Broadlink) Device count: 2
2018-01-24 20:30:42.373 (Broadlink) Device: 1 - ID: 52, Name: 'Broadlink - Discover', nValue: 0, sValue: 'Off'
2018-01-24 20:30:42.373 (Broadlink) Device ID: '52'
2018-01-24 20:30:42.373 (Broadlink) Device Name: 'Broadlink - Discover'
2018-01-24 20:30:42.373 (Broadlink) Device nValue: 0
2018-01-24 20:30:42.373 (Broadlink) Device sValue: 'Off'
2018-01-24 20:30:42.373 (Broadlink) Device LastLevel: 0
2018-01-24 20:30:42.373 (Broadlink) Device: 254 - ID: 53, Name: 'Broadlink - Remote', nValue: 0, sValue: ''
2018-01-24 20:30:42.373 (Broadlink) Device ID: '53'
2018-01-24 20:30:42.373 (Broadlink) Device Name: 'Broadlink - Remote'
2018-01-24 20:30:42.373 (Broadlink) Device sValue: ''
2018-01-24 20:30:42.374 (Broadlink) Device LastLevel: 0
2018-01-24 20:30:42.374 (Broadlink) Connecting to: 127.0.0.1:000000000000
2018-01-24 20:30:42.374 Error: (Broadlink) Error Connecting to Broadlink device....
But when I uncomment the import line and restart my Domoticz then it freezes everytime and it is not responding.
I have tried to use broadlink module directly and my test script
import broadlink
devices = broadlink.discover(timeout=5)
print(devices)
is working fine when I run it from the console.
Any advices?
Posted: Wednesday 24 January 2018 22:49
by zak45
ChopCZ wrote: Wednesday 24 January 2018 20:44
import broadlink
print(devices)
Any advices?
can you do in console :
pip show broadlink
pip3 show broadlink
