TOON died within Domoticz
MatthijsD
Re: TOON died within Domoticz
Post by MatthijsD »
domonator wrote: Saturday 30 September 2017 23:03 Did anyone find out what this error is about that Dressie, tlpeter and Martijn85 reported back in August?
Error: ToonThermostat: retrieveToonState request not successful, restarting..!
I also get this error logged every ~7 minutes even though everything seems to be working. Why would it need restarting? I'm experimenting with Blockly scripts and it looks like my Fibaro smart plugs connected to Toon only report their status at the same interval.
I have the same problem, but I'm not getting the data. It says "Last seen" but the data doesn't change.
More about my issue here: viewtopic.php?f=6&t=19880
EdwinK
Post by EdwinK »
That error has been there ever since the Toonopafstand website has been taken down. As long as you can still access your Toon from domoticz I wouldn't worry about it.
DennisD
Post by DennisD »
Root it and be done with it ;) I have done it and love it, also the extra plugins it has now (afvalkalender, etc) is a nice plus
MatthijsD
Post by MatthijsD »
EdwinK wrote: Monday 16 October 2017 15:50 That error has been there ever since the Toonopafstand website has been taken down. As long as you can still access your Toon from domoticz I wouldn't worry about it.
Ok, ignoring error then ;)
But still don't get good data from the Toon. Room temp, energy usage etc. Any idea's on that?
EdwinK
Post by EdwinK »
Nope same problem over here.
MatthijsD
Post by MatthijsD »
EdwinK wrote: Monday 16 October 2017 20:01 Nope same problem over here.
Wow, I thought I was alone with this ;)
I did do a firmware update on the Toon last week, but that was a few days before the problems started.
tlpeter
Post by tlpeter »
I had the same and i have rebooted the Toon and stopped and started the Toon plugin. I have now new data again.
fkok
Post by fkok »
Same here. For the last 4 days no data..... :roll:
*Edit: Just restarted the PI. Disabled the Toon and Dummy plugin. Enabled them again, and it's collectie data again.... :shock:
tlpeter
Post by tlpeter »
It stopped again. There is a problem for sure.
djshorteez
Domoticz version: 3.8158
Post by djshorteez »
I had the same thing, but. I just logged into my Eneco account page, it asked me if they could read my data and provide it to me. I agreed and magically Domoticz started to process my data again.
It seems that Eneco has updated their Terms and you have to explicitly approved them to collect and process you data.
Hope this helps...
_______________
Regards,
Stefan
fkok
Post by fkok »
fkok wrote: Tuesday 17 October 2017 7:49 Same here. For the last 4 days no data..... :roll:
It stopped collecting data again. Only when i disable Toon in domoticz en enable is again, it collects some data. But then it stops again.
EdwinK
Post by EdwinK »
djshorteez wrote: Tuesday 17 October 2017 22:04 I had the same thing, but. I just logged into my Eneco account page, it asked me if they could read my data and provide it to me. I agreed and magically Domoticz started to process my data again.
I really doubt that. The only thing Eneco ever had asked permission for was to read your smartmeters. I havent seen anything about an updated terms.
djshorteez
EdwinK wrote: Wednesday 18 October 2017 9:38
Why should they suddenly ask you for permission to read out your smartmeter after years of doing it, without changing their something to their terms? Well it doesnt really matter if they updated their terms or not. I just wanted to let you guys know that after giving permission Domoticz started to process data again.
tlpeter
Post by tlpeter »
I noticed that the Eneco dient have the correct reading also. The app works for changing home or sleep but if i do it from the Toon itself it isn't updated in the app. Gas and energy usage in the graph seems for work but kwh usage on the main screen is from the day before.
MatthijsD
Post by MatthijsD »
tlpeter wrote: Wednesday 18 October 2017 11:04 I noticed that the Eneco dient have the correct reading also. The app works for changing home or sleep but if i do it from the Toon itself it isn't updated in the app. Gas and energy usage in the graph seems for work but kwh usage on the main screen is from the day before.
Now you've mentioned this, I checked the app and I'm getting weird things in there too.
Power Today is 1,84 kWh. But when I check the graph it says we've used 6 kWh today. That's even above our average usage of 4 kWh...
So chances are all the mentioned problems are Eneco related and not Domoticz?
tlpeter
Post by tlpeter »
It looks like that indeed. Very strange behavior.
MatthijsD
Post by MatthijsD »
I think something has been fixed!
Since 07:20 this morning I have been getting data again from Toon: room temp and energy usage.
Great!
Plantje
Post by Plantje »
Yes, I have this issue too. Not really a problem as I am using a P1 cable as well. But interesting.
astrapowerrr
Post by astrapowerrr »
Does anyone here has the issue that in the log the toon is set to 6 degrees. At every Sunday morning about 00:02...
I see this constantly coming back only at that moment.
Also here a lot of proxy errors.
But I don’t think this has to do with the weekly error.
Any thoughts? Something maybe is reset weekly in the script?
Plantje
Post by Plantje »
No, I don't have that issue.
In general, when it comes to Toon and Domoticz I saw the following a while ago: https://androidworld.nl/apps/drebbl-the ... loot-toon/
With the API available the way is paved for Domoticz connecting to Toon, right?
