domonator wrote: ↑Saturday 30 September 2017 23:03
Did anyone find out what this error is about that Dressie, tlpeter and Martijn85 reported back in August?
Error: ToonThermostat: retrieveToonState request not successful, restarting..!
I also get this error logged every ~7 minutes even though everything seems to be working. Why would it need restarting? I'm experimenting with Blockly scripts and it looks like my Fibaro smart plugs connected to Toon only report their status at the same interval.
I have the same problem, but I'm not getting the data. It says "Last seen" but the data doesn't change.
More about my issue here: viewtopic.php?f=6&t=19880
That error has been there ever since the Toonopafstand website has been taken down. As long as you can still access your Toon from domoticz I wouldn't worry about it.
EdwinK wrote: ↑Monday 16 October 2017 15:50
Ok, ignoring error then
But still don't get good data from the Toon. Room temp, energy usage etc. Any idea's on that?
I had the same thing, but. I just logged into my Eneco account page, it asked me if they could read my data and provide it to me. I agreed and magically Domoticz started to process my data again.
It seems that Eneco has updated their Terms and you have to explicitly approved them to collect and process you data.
djshorteez wrote: ↑Tuesday 17 October 2017 22:04
I really doubt that. The only thing Eneco ever had asked permission for was to read your smartmeters. I havent seen anything about an updated terms.
Why should they suddenly ask you for permission to read out your smartmeter after years of doing it, without changing their something to their terms? Well it doesnt really matter if they updated their terms or not. I just wanted to let you guys know that after giving permission Domoticz started to process data again.
I noticed that the Eneco dient have the correct reading also. The app works for changing home or sleep but if i do it from the Toon itself it isn't updated in the app. Gas and energy usage in the graph seems for work but kwh usage on the main screen is from the day before.
tlpeter wrote: ↑Wednesday 18 October 2017 11:04
Now you've mentioned this, I checked the app and I'm getting weird things in there too.
Power Today is 1,84 kWh. But when I check the graph it says we've used 6 kWh today. That's even above our average usage of 4 kWh...
So chances are all the mentioned problems are Eneco related and not Domoticz?
Yes, I have this issue too. Not really a problem as I am using a P1 cable as well. But interesting.
Does anyone here has the issue that in the log the toon is set to 6 degrees. At every Sunday morning about 00:02...
I see this constantly coming back only at that moment.
Also here a lot of proxy errors.
But I don’t think this has to do with the weekly error.
Any thoughts? Something maybe is reset weekly in the script?
