Pass2PHP
Egregius
Domoticz version: v2024.7
Re: LUA Pass2php
Post by Egregius »
I don't understand it's even working if everything in the files is inside a function(){...}
Have a look at my examples at https://github.com/Egregius/LUA-Pass2PH ... e/pass2php
sincze
Domoticz version: 2024.4
Re: LUA Pass2php
Post by sincze »
Egregius wrote:I don't understand it's even working if everything in the files is inside a function(){...}
Aha that is our difference now in configuration. I see it
I stayed with "function" based devices (hence need global variables) and cjson where you moved to different method. :D
All my devices are also stored in subdirectory /pass2php need to be removed of the function() at the beginning of the file.
Let me see if we can make it work on my setup, Still needs some redecoration I think.
$c=ex($_REQUEST['c']);$s=ex($_REQUEST['s']);
foreach($c as $device=>$status)
    if(@include '/volume1/web/secure/pass2php/'.$device.'.php'){apcu_store('t'.$device,time);$dev=$device;}
$split=microtime(true);
if(!isset($dev))die();
include '/volume1/web/secure/pass2php/__CRON.php';
I don't have ACPU so I would still need $t=ex($_REQUEST['t'])
You are using __CRON.php instead of Zon with values 1 and 0 now??
Suggestions?
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Egregius
Re: LUA Pass2php
Post by Egregius »
You can still use memcached if you keep the cset and cget functions.
Or you keep the $t and $i array, it's only couple of milliseconds difference.
Yes, before all my logic was in 'zon'. As I don't store the solar energy in domoticz anymore I renamed the file to __CRON so it'll be always on top of the dir instead of the bottom.
You don't need to follow each brain twitch I have, you can use the basics and work from there in your mindset.
sincze
Re: LUA Pass2php
Post by sincze »
Egregius wrote:You can still use memcached if you keep the cset and cget functions.
Hi i changed my pass2php to the following with your general script_device_lua calling it. That goes okay
<?php
$start=microtime(true);error_reporting(E_ALL);
ini_set("display_errors","on");date_default_timezone_set('Europe/Brussels');
define('time',$_SERVER['REQUEST_TIME']);$actions=0;
define('domoticz','http://192.168.2.10:8080/');
define('webserver','http://127.0.0.1/');
{//lg('For each loop starting: '.$device);
    $devicer=str_replace(" ","_",$device);
    if(@include '/var/www/php/pass3php/'.$device.'.php')
        lg('Hi, I did find: '.$device);
        cset('t'.$device,time);
        $dev=$device;
    elseif(@include '/var/www/php/pass3php/'.$devicer.'.php')
        lg('Hi, I did find: '.$devicer);
        cset('t'.$devicer,time);
        $dev=$device;
//lg('Hi, passed for each statement with: '.$device.'and'.$c);
This will call the appropriate device.php in the subdirectory.
2016-12-29 00:05:32.430 User: Admin initiated a switch command (621/ZonweringAuto/On)
2016-12-29 00:05:32.659 --->> Yes I found you: what a result
2016-12-29 00:05:32.662 --->> ZonweringAuto ON
2016-12-29 00:05:32.665 --->> Hi, I did find: ZonweringAuto
mm had to do a little modification to have it work, Added $i otherwise no light would switch,,,
$i=ex($_REQUEST['i']);
Also the following is not working anymore...
The php is called from within the main script.
Could it be that function donker() that is defined in the main pass2php is not accessible from here for some reason ??? ah it is late...
<?php
    if (($s['Motion Detector Trap']=="On")&&donker()&&($s['Lamp LED Trap']!="On"))
        sw($i['Lamp LED Trap'],'On');
           if($debug=="true")
              lg('Motion Detector Trap and it is dark so swith the light to on');
    elseif (($s['Motion Detector Trap']=="Off")&&($s['Lamp LED Trap']!="Off"))
         sw($i['Lamp LED Trap'],'Off');
        if($debug=="true")
              lg('Motion Detector Trap OFF');
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: LUA Pass2php
Post by Egregius »
You still have other scripts or blocklies active?
sincze wrote: mm had to do a little modification to have it work, Added $i otherwise no light would switch,,,
I store all IDX's in cache. Someone here or at tweakers give me that idea. Idea behind it was that there's to much data sent upon each device changed. The lesser data nescessary the faster it'll go as you need to concatenate, sent and split less stuff. He even stores the otherdevices table in cache so he only needs to send the devicechanged table. I tried several times to do the same but every time ran into issues. As leaving out the otherdevices table only gived me about 3 msec speed difference I don't bother anymore to search for it.
sincze wrote: Also the following is not working anymore...
If donker is a function in pass2php.php it should be available.
Another nice thing about the new @include for your case: you don't need the underscores anymore, you can have spaces in the filenames, just tested with a device "test scha ke laar" and a "pass2php/test scha ke laar.php" file and worked :)
sincze
Re: LUA Pass2php
Post by sincze »
A yes some unconverted blocky and lua scripts are still stored and running. The converted lua -> pass2php ones have been disabled.
Yes and that part i totally missed. I think this is done in __CRON.php
if(apcu_fetch('cron604800')<time-604799){
    apcu_store('cron604800',time);
    $cron.=' + 604800';
    $domoticz=json_decode(file_get_contents(domoticz.'json.htm?type=devices&used=true'),true);
    if($domoticz){
        foreach($domoticz['result'] as $dom){
            $name=$dom['Name'];
            if(strtotime($dom['LastUpdate'])!=apcu_fetch('t'.$name))apcu_store('t'.$name,strtotime($dom['LastUpdate']));
            if($dom['idx']!=apcu_fetch('i'.$name))apcu_store('i'.$name,$dom['idx']);
So I need to rewrite that to memcached. I already did see you would store the time in a similar way in the for each loop.
And then i do not need the $i=ex($_REQUEST['i']); anymore? Correct? and do something like
{sw(cget('islapen'),'Off')
Ok need to figure out what is missing by adding debug lines.
Egregius wrote: Another nice thing about the new @include for your case: you don't need the underscores anymore, you can have spaces in the filenames, just tested with a device "test scha ke laar" and a "pass2php/test scha ke laar.php" file and worked :)
Aha nice. make the code a little bit less complicated. I will start with that later today.
        $dev=$device;
btw what happens after a reboot and acpu is empty? Will it retrieve all the idx values of the active devices only after cron time has been reached? Sorry for all the questions but I try to understand what is going on :P Sometimes I see in your code $i then sw(cget('islapen').. ;) just figuring things out here.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: LUA Pass2php
Post by Egregius »
Look at my __CRON.php ;)
If the cache cron864000 is older than 864000 seconds it grabs all statusses, idxs and timestamps to pre-fill the cache.
Since this morning I only use the $c array :)
Responsetime now 19 msec.
As I'm not a developer I sometimes need to revert changes and try again later. Spend at least 16 hours on it last week without success. This morning in less than 2 hours converted everything so I could avoid the $s array.
Greatest benefit of storing everything in cache goes to my floorplan. Creating the page takes now 0,7 milliseconds against 29 msecs before!
Regarding pass2php the benefit is smaller: 19 msec against 23 msec before.
Will let it run for several days before posting it to Github, need to be sure it's reliable.
Egregius
Re: LUA Pass2php
Post by Egregius »
I wanted to test again the real speed difference between this and the usual blockly and lua scripts.
On my system Blockly seems to be the fastest with 12 msec response time and lua gives me 14 msec.
But, that's when there's only one single script active. As soon as there are some more the time rises to resp. 20 and 37 msec for 5 active scripts. In the past I already tested that even empty script_device files create some kind of bottleneck in the event system. Not so difficult to understand as each script needs to be opened and evaluated.
With pass2php I now have a consistant 19 msec response time, no mather what scripts are behind it. Below test is done with a fully filled php scripting behind it.
So I think I can conclude I reached the maximum speed for my system and for my script :)
Blockly 12 msec (1 blockly)
If pir = on do set wasbak = on
2016-12-29 23:55:03.451  EventSystem: Event triggered: pirkeuken_1
2016-12-29 23:55:03.446  (ZWAVE) Light/Switch (pirkeuken)
2016-12-29 23:55:03.463  OpenZWave: Domoticz has send a Switch command! NodeID: 6 (0x06)
lua 14 msec (1 lua device script)
commandArray={}
if devicechanged['pirkeuken'] == 'On' then
	commandArray['wasbak']='On'
2016-12-30 00:01:59.428  EventSystem: Script event triggered: /usr/local/domoticz/var/scripts/lua/script_device_pirkeuken.lua
2016-12-30 00:01:59.424  (ZWAVE) Light/Switch (pirkeuken)
2016-12-30 00:01:59.438  OpenZWave: Domoticz has send a Switch command! NodeID: 6 (0x06)
Blockly 20 msec (5 blocklies)
2016-12-30 00:10:40.973  EventSystem: Event triggered: pirkeuken_1
2016-12-30 00:10:40.970  (ZWAVE) Light/Switch (pirkeuken)
2016-12-30 00:10:40.990  OpenZWave: Domoticz has send a Switch command! NodeID: 6 (0x06)
lua 37 msec (5 lua device scripts)
2016-12-30 00:05:21.635  EventSystem: Script event triggered: /usr/local/domoticz/var/scripts/lua/script_device_pirkeuken.lua
2016-12-30 00:05:21.628  (ZWAVE) Light/Switch (pirkeuken)
2016-12-30 00:05:21.665  OpenZWave: Domoticz has send a Switch command! NodeID: 6 (0x06)
pass2php (hundreds of scripts)
if($status=="On"){
	if(apcu_fetch('skeuken')=='Off'&&apcu_fetch('swasbak')=='Off'&&apcu_fetch('swerkblad')=='Off'&&apcu_fetch('skookplaat')=='Off'&&apcu_fetch('zon')<500){
		sw(apcu_fetch('iwasbak'),'On','wasbak');
		apcu_store('twasbak',time);
	if((apcu_fetch('sweg')=='On'||apcu_fetch('sslapen')=='On')&&apcu_fetch('smeldingen')=='On'&&apcu_fetch('tweg')<time-178&&apcu_fetch('tslapen')<time-178){
		sw(apcu_fetch('isirene'),'On');
		telegram('Beweging keuken om '.strftime("%k:%M:%S",time),false,3);
2016-12-30 00:16:20.361  (ZWAVE) Light/Switch (pirkeuken)
2016-12-30 00:16:20.380  User: Admin initiated a switch command (61/wasbak/On)
2016-12-30 00:16:20.380  OpenZWave: Domoticz has send a Switch command! NodeID: 6 (0x06)
sincze
Re: LUA Pass2php
Post by sincze »
Whoehoe that is a great performance. My numbers are Not nearly that close with a half converted system (rain and weather, my thermostat still in lua.) the rest already disabled. Will you wiki it a bit as well? :) the relationship between files. It will definitely help starters figuring out what goes where and why :). Again excellent work and I will try to match the numbers using cget and cset.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Toulon7559
Domoticz version: mixed
Re: LUA Pass2php
Post by Toulon7559 »
@Egregius
;-) Have done some digging related to the PHP-capabilities for my local and remote webservers.
The remote webserver allows at choice PHP versions 5.6 till 7.
For local experiments at a PC the version PHP version 5.6 seems easiest (and free) available.
Which version is most compatible with your script Pass2PHP?
Any differences in operation to be expected?
sincze
Re: RE: Re: LUA Pass2php
Post by sincze »
Toulon7559 wrote:@Egregius
5.6 is okay for speed 7
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: LUA Pass2php
Post by sincze »
A yes spaces or nospaces it now indeed works excellent, modified all the php files in the pass2php subdirectory so it is now one happy .php family. Next step is store the $s and $i in memcache right :D so speed things up so we only need $c.
    if(@include '/var/www/php/pass2php/'.$device.'.php')
        $dev=$device;
        if($debug=="true") lg('Hi, I did find: '.$device);
//include '/var/www/php/pass3php/__CRON.php';
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: LUA Pass2php
Post by Egregius »
@Toulon7559:
I don't think there are functions used that are only available in PHP7, so 5.6 should do just fine. There is a performance benefit in PHP7 tough.
@Sincze:
Storing the $i array isn't very difficult. See the cron604800 part of https://github.com/Egregius/LUA-Pass2PH ... __CRON.php (at the moment lines 180-199).
Anyway, updated Github with my latest version, in use for 24 hours without issues now.
sincze
Re: LUA Pass2php
Post by sincze »
Egregius wrote: @Sincze:
Currently working on it,
So script is called.
if(cget('cron604800')<time-604799){
    if($debug=="true") lg('Hi, I am updating the cache now');
    cset('cron604800',time);
    $cron.=' + 604800';
    if($domoticz){
            $name=$dom['Name'];
            if(strtotime($dom['LastUpdate'])!=cget('t'.$name))
                cset('t'.$name,strtotime($dom['LastUpdate']));
                if($debug=="true") lg('Hi, I am updating the cache time value now for: '.'t'.$name.' with value '.$dom['LastUpdate']);
            if($dom['idx']!=cget('i'.$name))
                cset('i'.$name,$dom['idx']);
                if($debug=="true") lg('Hi, I am updating the cache idx value now for: '.'i'.$name.' with value '.$dom['idx']);
I cheated a bit by temporarily commenting out the if(cget(çron604800)
As a result a whole list of these appeared.
2016-12-30 13:37:38.504 --->> Hi, I am updating the cache time value now for: tIPCAM (RF) with value 2016-11-12 12:54:58
2016-12-30 13:37:38.511 --->> Hi, I am updating the cache idx value now for: iIPCAM (RF) with value 556
However:
if($debug=="true") lg('Hi, the idx for IPCAM is: '.cget('iIPCAM (RF)'));
Results in..
2016-12-30 13:39:40.695 --->> Hi, the idx for IPCAM is: 0
Same goes for a non spaced device:
if($debug=="true") lg('Hi, the idx for ZonWeringAuto is: '.cget('iZonweringAuto'));
2016-12-30 13:42:47.151 --->> Hi, the idx for ZonWeringAuto is: 0
Memcache is running as this works:
if($debug=="true") lg('Give me the answer to the light condition: '.cget('var_dark'));
 --->> Give me the answer to the light condition: False
So I guess it has to do something with:
It does not seem to actually 'set' the variables.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: LUA Pass2php
Post by Egregius »
Don't know if spaces and brackets are allowed, shall test that tommorow.
Don't forget the i or t in front of the name...
sincze
Re: LUA Pass2php
Post by sincze »
Egregius wrote:Don't know if spaces and brackets are allowed, shall test that tommorow.
Hehe well here is the answer to the space issue :D
http://stackoverflow.com/questions/5826 ... ain-spaces
https://github.com/memcached/memcached/ ... otocol.txt[/url]
No. Memcached keys cannot contain spaces.
Keys
Data stored by memcached is identified with the help of a key. A key is a text string which should uniquely identify the data for clients that are interested in storing and retrieving it. Currently the length limit of a key is set at 250 characters (of course, normally clients wouldn't need to use such long keys); the key must not include control characters or whitespace.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: LUA Pass2php
Post by sincze »
Keys
Modified the code bit so cset and cget will work again without having to modify all the device names.(strpos($name, " ") !== false)
    $cron.=' + 604800';
    if($debug=="true") lg('Hi, I rertieved values from domoticz now');
    if($domoticz){
            $name=$dom['Name'];
            if (strpos($name, " ") !== false) $name=str_replace(" ","_",$name);
            if(strtotime($dom['LastUpdate'])!=cget('t'.$name)) cset('t'.$name,strtotime($dom['LastUpdate']));
            if($dom['idx']!=cget('i'.$name)) cset('i'.$name,$dom['idx']);
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
sincze
Re: LUA Pass2php
Post by sincze »
Well I managed to get it working all via memcached, however my test switch is now inverted.... :o :shock:
Switch ON result Light OFF (expected light ON):
2016-12-30 18:44:15.195 User: Admin initiated a switch command (621/ZonweringAuto/On)
2016-12-30 18:44:15.197 (Virtual Device) Light/Switch (ZonweringAuto)
2016-12-30 18:44:15.334 --->> 1. In ZonweringAuto.php Finding Status of ZonWeringAuto the status is: Off
2016-12-30 18:44:15.340 --->> SWITCH Off CV Ruimte
2016-12-30 18:44:15.343 User: Admin initiated a switch command (531/Lamp (CV Ruimte) (RF)/Off)
2016-12-30 18:44:15.345 RFLink Sending: 10;NewKaku;ba1e09;a;OFF
2016-12-30 18:44:15.512 (RFXCom) Lighting 2 (Lamp (CV Ruimte))
2016-12-30 18:44:17.180 (RFLink Gateway) Light/Switch (Lamp (CV Ruimte) (RF))
2016-12-30 18:44:17.364 --->> 2. In ZonweringAuto.php Finding Status of ZonWeringAuto the status is: Off
2016-12-30 18:44:17.367 --->> In pass2php we see a status switch: ZonweringAuto status: On
So the status change ZonweringAuto to 'On' is shown later in the Domoticz log after the action has been executed. It is exactly as what happens. next time I switch ZonweringAuto to 'Off'...
Switch OFF result Light ON (expected light OFF)
2016-12-30 18:48:03.204 --->> 1. In ZonweringAuto.php Finding Status of ZonWeringAuto the status is: On
2016-12-30 18:48:03.209 --->> SETLEVEL 100 CV Ruimte
2016-12-30 18:48:03.212 User: Admin initiated a switch command (531/Lamp (CV Ruimte) (RF)/Set Level)
2016-12-30 18:48:03.214 RFLink Sending: 10;NewKaku;ba1e09;a;15
2016-12-30 18:48:03.425 (RFXCom) Lighting 2 (Lamp (CV Ruimte))
2016-12-30 18:48:04.247 (RFLink Gateway) Light/Switch (Lamp (CV Ruimte) (RF))
2016-12-30 18:48:04.434 --->> 2. In ZonweringAuto.php Finding Status of ZonWeringAuto the status is: On
2016-12-30 18:48:04.437 --->> In pass2php we see a status switch: ZonweringAuto status: Off
And just for the check my ZonweringAuto,php
<?php
    lg('1. In ZonweringAuto.php Finding Status of ZonWeringAuto the status is: '.(cget('sZonweringAuto')));
    if(cget('sZonweringAuto')=="On") sl((cget('iLamp_(CV_Ruimte)_(RF)')), 100,'CV Ruimte');
    elseif(cget('sZonweringAuto')=="Off") sw((cget('iLamp_(CV_Ruimte)_(RF)')), 'Off' ,'CV Ruimte');
    lg('2. In ZonweringAuto.php Finding Status of ZonWeringAuto the status is: '.(cget('sZonweringAuto')));
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Egregius
Re: LUA Pass2php
Post by Egregius »
Lg 1 and 2 will always print the same status as lg2 will be executed well before a new cset happens.
sincze
Post by sincze »
Egregius wrote:Lg 1 and 2 will always print the same status as lg2 will be executed well before a new cset happens.
A yes. That was just an extra debug line :) main question remains. Why is it inversed. No more hairs on my head.. I've been pulling them Image
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
