Pass2PHP
- Egregius
- Domoticz version: v2024.7
Re: LUA Pass2php
I don't understand it's even working if everything in the files is inside a function(){...}
Have a look at my examples at https://github.com/Egregius/LUA-Pass2PH ... e/pass2php
- sincze
- Domoticz version: 2024.4
Re: LUA Pass2php
Aha that is our difference now in configuration. I see itEgregius wrote:I don't understand it's even working if everything in the files is inside a function(){...}
I stayed with "function" based devices (hence need global variables) and cjson where you moved to different method.
All my devices are also stored in subdirectory /pass2php need to be removed of the function() at the beginning of the file.
Let me see if we can make it work on my setup, Still needs some redecoration I think.
$c=ex($_REQUEST['c']);$s=ex($_REQUEST['s']);
foreach($c as $device=>$status)
if(@include '/volume1/web/secure/pass2php/'.$device.'.php'){apcu_store('t'.$device,time);$dev=$device;}
$split=microtime(true);
if(!isset($dev))die();
include '/volume1/web/secure/pass2php/__CRON.php'; You are using __CRON.php instead of Zon with values 1 and 0 now??
Suggestions?
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Egregius
Re: LUA Pass2php
You can still use memcached if you keep the cset and cget functions.
Or you keep the $t and $i array, it's only couple of milliseconds difference.
Yes, before all my logic was in 'zon'. As I don't store the solar energy in domoticz anymore I renamed the file to __CRON so it'll be always on top of the dir instead of the bottom.
You don't need to follow each brain twitch I have, you can use the basics and work from there in your mindset.
- sincze
Re: LUA Pass2php
Hi i changed my pass2php to the following with your general script_device_lua calling it. That goes okayEgregius wrote:You can still use memcached if you keep the cset and cget functions.
<?php
$start=microtime(true);error_reporting(E_ALL);
ini_set("display_errors","on");date_default_timezone_set('Europe/Brussels');
define('time',$_SERVER['REQUEST_TIME']);$actions=0;
define('domoticz','http://192.168.2.10:8080/');
define('webserver','http://127.0.0.1/');
{//lg('For each loop starting: '.$device);
$devicer=str_replace(" ","_",$device);
if(@include '/var/www/php/pass3php/'.$device.'.php')
lg('Hi, I did find: '.$device);
cset('t'.$device,time);
$dev=$device;
elseif(@include '/var/www/php/pass3php/'.$devicer.'.php')
lg('Hi, I did find: '.$devicer);
cset('t'.$devicer,time);
$dev=$device;
//lg('Hi, passed for each statement with: '.$device.'and'.$c);
2016-12-29 00:05:32.430 User: Admin initiated a switch command (621/ZonweringAuto/On)
2016-12-29 00:05:32.659 --->> Yes I found you: what a result
2016-12-29 00:05:32.662 --->> ZonweringAuto ON
2016-12-29 00:05:32.665 --->> Hi, I did find: ZonweringAuto
$i=ex($_REQUEST['i']);
The php is called from within the main script.
Could it be that function donker() that is defined in the main pass2php is not accessible from here for some reason ??? ah it is late...
<?php
if (($s['Motion Detector Trap']=="On")&&donker()&&($s['Lamp LED Trap']!="On"))
sw($i['Lamp LED Trap'],'On');
if($debug=="true")
lg('Motion Detector Trap and it is dark so swith the light to on');
elseif (($s['Motion Detector Trap']=="Off")&&($s['Lamp LED Trap']!="Off"))
sw($i['Lamp LED Trap'],'Off');
if($debug=="true")
lg('Motion Detector Trap OFF');
} Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Egregius
Re: LUA Pass2php
You still have other scripts or blocklies active?sincze wrote:Code: Select all
2016-12-29 00:05:32.430 User: Admin initiated a switch command (621/ZonweringAuto/On) 2016-12-29 00:05:32.659 --->> Yes I found you: what a result 2016-12-29 00:05:32.662 --->> ZonweringAuto ON 2016-12-29 00:05:32.665 --->> Hi, I did find: ZonweringAuto
I store all IDX's in cache. Someone here or at tweakers give me that idea. Idea behind it was that there's to much data sent upon each device changed. The lesser data nescessary the faster it'll go as you need to concatenate, sent and split less stuff. He even stores the otherdevices table in cache so he only needs to send the devicechanged table. I tried several times to do the same but every time ran into issues. As leaving out the otherdevices table only gived me about 3 msec speed difference I don't bother anymore to search for it.sincze wrote: mm had to do a little modification to have it work, Added $i otherwise no light would switch,,,Code: Select all
$c=ex($_REQUEST['c']); $s=ex($_REQUEST['s']); $i=ex($_REQUEST['i']);
If donker is a function in pass2php.php it should be available.sincze wrote: Also the following is not working anymore...
Another nice thing about the new @include for your case: you don't need the underscores anymore, you can have spaces in the filenames, just tested with a device "test scha ke laar" and a "pass2php/test scha ke laar.php" file and worked
- sincze
Re: LUA Pass2php
A yes some unconverted blocky and lua scripts are still stored and running. The converted lua -> pass2php ones have been disabled.Egregius wrote:You still have other scripts or blocklies active?sincze wrote:Code: Select all
Yes and that part i totally missed. I think this is done in __CRON.phpEgregius wrote:I store all IDX's in cache. Someone here or at tweakers give me that idea. Idea behind it was that there's to much data sent upon each device changed. The lesser data nescessary the faster it'll go as you need to concatenate, sent and split less stuff. He even stores the otherdevices table in cache so he only needs to send the devicechanged table. I tried several times to do the same but every time ran into issues. As leaving out the otherdevices table only gived me about 3 msec speed difference I don't bother anymore to search for it.sincze wrote: mm had to do a little modification to have it work, Added $i otherwise no light would switch,,,Code: Select all
if(apcu_fetch('cron604800')<time-604799){
apcu_store('cron604800',time);
$cron.=' + 604800';
$domoticz=json_decode(file_get_contents(domoticz.'json.htm?type=devices&used=true'),true);
if($domoticz){
foreach($domoticz['result'] as $dom){
$name=$dom['Name'];
if(strtotime($dom['LastUpdate'])!=apcu_fetch('t'.$name))apcu_store('t'.$name,strtotime($dom['LastUpdate']));
if($dom['idx']!=apcu_fetch('i'.$name))apcu_store('i'.$name,$dom['idx']);
And then i do not need the $i=ex($_REQUEST['i']); anymore? Correct? and do something like
{sw(cget('islapen'),'Off') Ok need to figure out what is missing by adding debug lines.Egregius wrote:If donker is a function in pass2php.php it should be available.sincze wrote: Also the following is not working anymore...
Egregius wrote: Another nice thing about the new @include for your case: you don't need the underscores anymore, you can have spaces in the filenames, just tested with a device "test scha ke laar" and a "pass2php/test scha ke laar.php" file and worked
Aha nice. make the code a little bit less complicated. I will start with that later today.
$dev=$device;
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Egregius
Re: LUA Pass2php
Look at my __CRON.php
If the cache cron864000 is older than 864000 seconds it grabs all statusses, idxs and timestamps to pre-fill the cache.
Since this morning I only use the $c array
Responsetime now 19 msec.
As I'm not a developer I sometimes need to revert changes and try again later. Spend at least 16 hours on it last week without success. This morning in less than 2 hours converted everything so I could avoid the $s array.
Greatest benefit of storing everything in cache goes to my floorplan. Creating the page takes now 0,7 milliseconds against 29 msecs before!
Regarding pass2php the benefit is smaller: 19 msec against 23 msec before.
Will let it run for several days before posting it to Github, need to be sure it's reliable.
- Egregius
Re: LUA Pass2php
I wanted to test again the real speed difference between this and the usual blockly and lua scripts.
On my system Blockly seems to be the fastest with 12 msec response time and lua gives me 14 msec.
But, that's when there's only one single script active. As soon as there are some more the time rises to resp. 20 and 37 msec for 5 active scripts. In the past I already tested that even empty script_device files create some kind of bottleneck in the event system. Not so difficult to understand as each script needs to be opened and evaluated.
With pass2php I now have a consistant 19 msec response time, no mather what scripts are behind it. Below test is done with a fully filled php scripting behind it.
So I think I can conclude I reached the maximum speed for my system and for my script
Blockly 12 msec (1 blockly)
If pir = on do set wasbak = on
2016-12-29 23:55:03.451 EventSystem: Event triggered: pirkeuken_1
2016-12-29 23:55:03.446 (ZWAVE) Light/Switch (pirkeuken)
2016-12-29 23:55:03.463 OpenZWave: Domoticz has send a Switch command! NodeID: 6 (0x06)
lua 14 msec (1 lua device script)
commandArray={}
if devicechanged['pirkeuken'] == 'On' then
commandArray['wasbak']='On'
2016-12-30 00:01:59.428 EventSystem: Script event triggered: /usr/local/domoticz/var/scripts/lua/script_device_pirkeuken.lua
2016-12-30 00:01:59.424 (ZWAVE) Light/Switch (pirkeuken)
2016-12-30 00:01:59.438 OpenZWave: Domoticz has send a Switch command! NodeID: 6 (0x06)
Blockly 20 msec (5 blocklies)
2016-12-30 00:10:40.973 EventSystem: Event triggered: pirkeuken_1
2016-12-30 00:10:40.970 (ZWAVE) Light/Switch (pirkeuken)
2016-12-30 00:10:40.990 OpenZWave: Domoticz has send a Switch command! NodeID: 6 (0x06)
lua 37 msec (5 lua device scripts)
2016-12-30 00:05:21.635 EventSystem: Script event triggered: /usr/local/domoticz/var/scripts/lua/script_device_pirkeuken.lua
2016-12-30 00:05:21.628 (ZWAVE) Light/Switch (pirkeuken)
2016-12-30 00:05:21.665 OpenZWave: Domoticz has send a Switch command! NodeID: 6 (0x06)
pass2php (hundreds of scripts)
if($status=="On"){
if(apcu_fetch('skeuken')=='Off'&&apcu_fetch('swasbak')=='Off'&&apcu_fetch('swerkblad')=='Off'&&apcu_fetch('skookplaat')=='Off'&&apcu_fetch('zon')<500){
sw(apcu_fetch('iwasbak'),'On','wasbak');
apcu_store('twasbak',time);
if((apcu_fetch('sweg')=='On'||apcu_fetch('sslapen')=='On')&&apcu_fetch('smeldingen')=='On'&&apcu_fetch('tweg')<time-178&&apcu_fetch('tslapen')<time-178){
sw(apcu_fetch('isirene'),'On');
telegram('Beweging keuken om '.strftime("%k:%M:%S",time),false,3);
2016-12-30 00:16:20.361 (ZWAVE) Light/Switch (pirkeuken)
2016-12-30 00:16:20.380 User: Admin initiated a switch command (61/wasbak/On)
2016-12-30 00:16:20.380 OpenZWave: Domoticz has send a Switch command! NodeID: 6 (0x06)
- sincze
Re: LUA Pass2php
Whoehoe that is a great performance. My numbers are Not nearly that close with a half converted system (rain and weather, my thermostat still in lua.) the rest already disabled. Will you wiki it a bit as well?
the relationship between files. It will definitely help starters figuring out what goes where and why
. Again excellent work and I will try to match the numbers using cget and cset.
Sent from my SM-G925F using Tapatalk
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Toulon7559
- Domoticz version: <2025
Re: LUA Pass2php
@Egregius
Have done some digging related to the PHP-capabilities for my local and remote webservers.
The remote webserver allows at choice PHP versions 5.6 till 7.
For local experiments at a PC the version PHP version 5.6 seems easiest (and free) available.
Which version is most compatible with your script Pass2PHP?
Any differences in operation to be expected?
- sincze
Re: RE: Re: LUA Pass2php
5.6 is okay for speed 7Toulon7559 wrote:@Egregius
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- sincze
Re: LUA Pass2php
A yes spaces or nospaces it now indeed works excellent, modified all the php files in the pass2php subdirectory so it is now one happy .php family. Next step is store the $s and $i in memcache rightEgregius wrote: Another nice thing about the new @include for your case: you don't need the underscores anymore, you can have spaces in the filenames, just tested with a device "test scha ke laar" and a "pass2php/test scha ke laar.php" file and worked
if(@include '/var/www/php/pass2php/'.$device.'.php')
$dev=$device;
if($debug=="true") lg('Hi, I did find: '.$device);
//include '/var/www/php/pass3php/__CRON.php'; Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Egregius
Re: LUA Pass2php
@Toulon7559:
I don't think there are functions used that are only available in PHP7, so 5.6 should do just fine. There is a performance benefit in PHP7 tough.
@Sincze:
Storing the $i array isn't very difficult. See the cron604800 part of https://github.com/Egregius/LUA-Pass2PH ... __CRON.php (at the moment lines 180-199).
Anyway, updated Github with my latest version, in use for 24 hours without issues now.
@Sincze:
- sincze
Re: LUA Pass2php
Currently working on it,Egregius wrote: @Sincze:
So script is called.
if(cget('cron604800')<time-604799){
if($debug=="true") lg('Hi, I am updating the cache now');
cset('cron604800',time);
$cron.=' + 604800';
if($domoticz){
$name=$dom['Name'];
if(strtotime($dom['LastUpdate'])!=cget('t'.$name))
cset('t'.$name,strtotime($dom['LastUpdate']));
if($debug=="true") lg('Hi, I am updating the cache time value now for: '.'t'.$name.' with value '.$dom['LastUpdate']);
if($dom['idx']!=cget('i'.$name))
cset('i'.$name,$dom['idx']);
if($debug=="true") lg('Hi, I am updating the cache idx value now for: '.'i'.$name.' with value '.$dom['idx']);
}As a result a whole list of these appeared.
2016-12-30 13:37:38.504 --->> Hi, I am updating the cache time value now for: tIPCAM (RF) with value 2016-11-12 12:54:58
2016-12-30 13:37:38.511 --->> Hi, I am updating the cache idx value now for: iIPCAM (RF) with value 556
if($debug=="true") lg('Hi, the idx for IPCAM is: '.cget('iIPCAM (RF)'));Code: Select all
2016-12-30 13:39:40.695 --->> Hi, the idx for IPCAM is: 0Code: Select all
if($debug=="true") lg('Hi, the idx for ZonWeringAuto is: '.cget('iZonweringAuto'));Code: Select all
2016-12-30 13:42:47.151 --->> Hi, the idx for ZonWeringAuto is: 0Code: Select all
if($debug=="true") lg('Give me the answer to the light condition: '.cget('var_dark'));Code: Select all
--->> Give me the answer to the light condition: Falsecset('t'.$name,strtotime($dom['LastUpdate']));
It does not seem to actually 'set' the variables.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Egregius
Re: LUA Pass2php
Don't know if spaces and brackets are allowed, shall test that tommorow.
Don't forget the i or t in front of the name...
- sincze
Re: LUA Pass2php
Hehe well here is the answer to the space issueEgregius wrote:Don't know if spaces and brackets are allowed, shall test that tommorow.
http://stackoverflow.com/questions/5826 ... ain-spaces
https://github.com/memcached/memcached/ ... otocol.txt[/url]
No. Memcached keys cannot contain spaces.
Keys
Data stored by memcached is identified with the help of a key. A key is a text string which should uniquely identify the data for clients that are interested in storing and retrieving it. Currently the length limit of a key is set at 250 characters (of course, normally clients wouldn't need to use such long keys); the key must not include control characters or whitespace.Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- sincze
Re: LUA Pass2php
sincze wrote:Hehe well here is the answer to the space issueEgregius wrote:Don't know if spaces and brackets are allowed, shall test that tommorow.
Don't forget the i or t in front of the name...![]()
Keys Data stored by memcached is identified with the help of a key. A key is a text string which should uniquely identify the data for clients that are interested in storing and retrieving it. Currently the length limit of a key is set at 250 characters (of course, normally clients wouldn't need to use such long keys); the key must not include control characters or whitespace.
Modified the code bit so cset and cget will work again without having to modify all the device names.(strpos($name, " ") !== false)
$cron.=' + 604800';
if($debug=="true") lg('Hi, I rertieved values from domoticz now');
if($domoticz){
$name=$dom['Name'];
if (strpos($name, " ") !== false) $name=str_replace(" ","_",$name);
if(strtotime($dom['LastUpdate'])!=cget('t'.$name)) cset('t'.$name,strtotime($dom['LastUpdate']));
if($dom['idx']!=cget('i'.$name)) cset('i'.$name,$dom['idx']);
}Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- sincze
Re: LUA Pass2php
Well I managed to get it working all via memcached, however my test switch is now inverted....
Switch ON result Light OFF (expected light ON):
So the status change ZonweringAuto to 'On' is shown later in the Domoticz log after the action has been executed. It is exactly as what happens. next time I switch ZonweringAuto to 'Off'...
Switch OFF result Light ON (expected light OFF)
And just for the check my ZonweringAuto,php
2016-12-30 18:44:15.195 User: Admin initiated a switch command (621/ZonweringAuto/On)
2016-12-30 18:44:15.197 (Virtual Device) Light/Switch (ZonweringAuto)
2016-12-30 18:44:15.334 --->> 1. In ZonweringAuto.php Finding Status of ZonWeringAuto the status is: Off
2016-12-30 18:44:15.340 --->> SWITCH Off CV Ruimte
2016-12-30 18:44:15.343 User: Admin initiated a switch command (531/Lamp (CV Ruimte) (RF)/Off)
2016-12-30 18:44:15.345 RFLink Sending: 10;NewKaku;ba1e09;a;OFF
2016-12-30 18:44:15.512 (RFXCom) Lighting 2 (Lamp (CV Ruimte))
2016-12-30 18:44:17.180 (RFLink Gateway) Light/Switch (Lamp (CV Ruimte) (RF))
2016-12-30 18:44:17.364 --->> 2. In ZonweringAuto.php Finding Status of ZonWeringAuto the status is: Off
2016-12-30 18:44:17.367 --->> In pass2php we see a status switch: ZonweringAuto status: On
2016-12-30 18:48:03.204 --->> 1. In ZonweringAuto.php Finding Status of ZonWeringAuto the status is: On
2016-12-30 18:48:03.209 --->> SETLEVEL 100 CV Ruimte
2016-12-30 18:48:03.212 User: Admin initiated a switch command (531/Lamp (CV Ruimte) (RF)/Set Level)
2016-12-30 18:48:03.214 RFLink Sending: 10;NewKaku;ba1e09;a;15
2016-12-30 18:48:03.425 (RFXCom) Lighting 2 (Lamp (CV Ruimte))
2016-12-30 18:48:04.247 (RFLink Gateway) Light/Switch (Lamp (CV Ruimte) (RF))
2016-12-30 18:48:04.434 --->> 2. In ZonweringAuto.php Finding Status of ZonWeringAuto the status is: On
2016-12-30 18:48:04.437 --->> In pass2php we see a status switch: ZonweringAuto status: OffCode: Select all
<?php
lg('1. In ZonweringAuto.php Finding Status of ZonWeringAuto the status is: '.(cget('sZonweringAuto')));
if(cget('sZonweringAuto')=="On") sl((cget('iLamp_(CV_Ruimte)_(RF)')), 100,'CV Ruimte');
elseif(cget('sZonweringAuto')=="Off") sw((cget('iLamp_(CV_Ruimte)_(RF)')), 'Off' ,'CV Ruimte');
lg('2. In ZonweringAuto.php Finding Status of ZonWeringAuto the status is: '.(cget('sZonweringAuto')));
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
- Egregius
Re: LUA Pass2php
Lg 1 and 2 will always print the same status as lg2 will be executed well before a new cset happens.
- sincze
A yes. That was just an extra debug lineEgregius wrote:Lg 1 and 2 will always print the same status as lg2 will be executed well before a new cset happens.
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
