Page 107 of 120
Re: Domoticz app 2.0
Posted: Saturday 03 October 2020 10:30
by kazze
To anyone who might still have this problem (the sudden crash, not the slider affecting other dimmers!): the workaround is to lookup the switch that has a level higher than 100 (oh yes, you will find it) and lower it in the
web UI - then restart the app. Magic !
More info:
https://github.com/domoticz/domoticz-android/issues/603
Posted: Friday 09 October 2020 10:08
by Johndomo
galadril wrote: Wednesday 30 September 2020 13:57
Sorry guys, im fixing the dimmers as we speak!
Many thanks for your efforts! However I still experience the same problem? The app was updated via "auto-update".
Should I do more to force that changes take effort?
Thx
John
Posted: Friday 09 October 2020 11:09
by Johndomo
I did some more testing. I can see that the working has changed.
Before the update, when I changed the level of dimmer 1, dimmer 2, 3 and 4 reacted. After the update only dimmer 3 reacts.
So things have been improved, but it is not perfect yet...
Posted: Thursday 15 October 2020 19:26
by Luigi87
galadril wrote: Thursday 01 October 2020 8:57
Zoonie81 wrote: Sunday 13 September 2020 20:42
I've had the app for a year or two. The latest updates seem to have caused a bug where the slider for a particular z-wave dimmer activates other devices randomly. It can turn on/off other devices or adjust dimming on other devices - randomly every time.
Have you checked the latest update, that should fix the dimmers/sliders
@galadril
Have you also checked the room plans bug?
Everytime i use the app, i need to go the settings first to use the room plans.
Luigi87 wrote: Sunday 23 August 2020 14:07
There seems to be somthing wrong in the app. The switches in the room plans are most of the time not working. I have to switch the switch from slider or buttons in the settings to get the app working again.
There are more people with this:
viewtopic.php?f=37&t=33696
Its in the payed app and in the lite version also!
Posted: Friday 16 October 2020 14:49
by galadril
Luigi87 wrote: Thursday 15 October 2020 19:26
@galadril
I have no issues with my test setup.
If you like, i can debug against your system if you send me the connection+credential details (viewer account)?
[email protected]
Posted: Tuesday 20 October 2020 20:27
by Luigi87
galadril wrote: Friday 16 October 2020 14:49
@galadril
[email protected]
Sorry for my late response.
I would love to give you a possibility to debug against my system, but this is nearly impossible due to security measures in my system.
I there a way i can create a debug log?
the bug is there since the last update from I think 5 aug?
"Android app 0.2.232 (7878)"
also described by an other user here:
"Switches not working in "Plans" after force close"
Hope this helps a bit.
Posted: Saturday 31 October 2020 9:41
by sammyke007
Any idea why the sorting doesn't work?
I use the dashboard as the default screen in the app and every time when I sort my devices, they get reset after opening the app 30 minutes or so later?
I already tried messing with the 2 sorting settings, but none of them help.
Posted: Monday 02 November 2020 11:27
by galadril
I;ve updated the app multiple times this weekend, with a lot of crash report fixes..
So i hope that some of your crashes are fixed now (should be)
Posted: Tuesday 03 November 2020 14:25
by kniazio
After the last update, the Domoticz application does not work on Android11. Finds server and devices but after approval everything disappears.
I get a message: Incorect setting detected. Please reconfigure app
I am asking for a link to the penultimate version that worked properly for me.
I will also add that I have a paid application
Posted: Tuesday 03 November 2020 15:59
by woppybob
For me the same problem??
Posted: Tuesday 03 November 2020 17:03
by samourai47
Same problem for me on my mi mix2s with android 10
woppybob wrote: Tuesday 03 November 2020 15:59
Posted: Tuesday 03 November 2020 17:47
by CarstenK
Same Problem wird Android 10 on Samsung S10
Posted: Tuesday 03 November 2020 17:55
by gennapium
Same here on Samsung S20 Android 10
Posted: Tuesday 03 November 2020 18:09
by sdmg
Same Problem with Android 10 on Samsung S9
Posted: Tuesday 03 November 2020 20:37
by sammyke007
Same here since latest update today. Incorrect settings detected, please reconfigure. Clean reconfigure detects DZ version and devices, but crashes...
Android 11
Verstuurd vanaf mijn IN2013 met Tapatalk
Posted: Tuesday 03 November 2020 20:43
by f12004
Same error, here crash on startup with remote, in local it works.
Huawei P20 Android 11
Posted: Tuesday 03 November 2020 23:41
by gdmr
Same problem
Posted: Wednesday 04 November 2020 7:00
by rtfmjoey
Same issue here; I was greeted with the notification wizard after the update and needed to fill in my server details again. After filling them in, discovery found all devices etc but wheb saving I get an message 'incorrect settings detected' and the wizard starts over.
I've uninstalled the app/removed all cached data and reinstalled but the issue persists.
Posted: Wednesday 04 November 2020 7:30
by martk
Same here...
Posted: Wednesday 04 November 2020 7:44
by rira2005
Same here on Samsung S20+ Android 10
