Page 106 of 120
Re: Domoticz app 2.0
Posted: Friday 19 June 2020 11:31
by galadril
I've uploaded a new beta with changes to the way i build api calls.
It should improve the speed throughout the application.. Please test beta (as i dont want the shit we had last release)
Posted: Sunday 05 July 2020 12:55
by niki_lauda
galadril wrote: Wednesday 05 February 2020 17:08
New update is coming for the Android app with quite some big rework.
I've released it to the beta channel of Android at the moment!
Changelog version 0.2.192 (6889)
- New themes (including day/night themes)
- New notification inbox
- Rebuild all preferences screens from scratch
- Added the option to trigger/send notifications
- Updated the look on Wear OS
- Added action button on notifications to inbox
- Improved error state handling
- Fixed some other various layout/device issues
Theme picker (with day/night options)
Complete new rebuild of preferences with category icons:
New notification inbox to check your notification history AND send notifications:
Where can I find the Inbox?
I'm on 0.2.226(7631). I would like to clean it.
Posted: Monday 27 July 2020 4:46
by joyride1176
galadril wrote: Friday 19 June 2020 11:31
I had same permissions issue "you don't have the rights to..." on paid and lite version
I confirm you beta release 3rd July has fixed the issue
After one hour of testing issue disappeared and before was persistent without workaround possible
Tested on multiple servers
New date 32/7 :-)
Posted: Tuesday 04 August 2020 7:51
by niki_lauda
The app displays a date that to my knowledge doesn't exist.
Posted: Tuesday 04 August 2020 10:19
by galadril
niki_lauda wrote: Sunday 05 July 2020 12:55
Its in you settings/notifications/history or Inbox
Or you click on the Inbox button when you've received a new notification
Re: New date 32/7 :-)
by galadril
niki_lauda wrote: Tuesday 04 August 2020 7:51
Oef thats weird.. ok ill put it on my list to check, thanks
Posted: Tuesday 04 August 2020 10:21
by galadril
New beta is uploaded to the play store (0.2.230 (7815))
Posted: Wednesday 05 August 2020 9:03
by galadril
Posted: Thursday 06 August 2020 11:18
by galadril
New beta is coming with a new feature (multi graph for temp devices):
Full changelog for this beta (0.2.232 (7878))
- Implemented camera background for connected switches
- Improved camera detail page
- Added new multi graph option for temperature devices
- Reworked slider component
- Added new Dark Blue theme
- Use Tasker for Automation
- Updated translations
- Improved import/export settings with file picker implementation
- Removed unsecure LoginCheck calls
- Fix for filtering Logs
Posted: Sunday 23 August 2020 14:07
by Luigi87
There seems to be somthing wrong in the app. The switches in the room plans are most of the time not working. I have to switch the switch from slider or buttons in the settings to get the app working again.
There are more people with this:
https://www.domoticz.com/forum/viewtopi ... 37&t=33696
Its in the payed app and in the lite version also!
Posted: Thursday 27 August 2020 16:13
by paolone919191
Luigi87 wrote: Sunday 23 August 2020 14:07
I can confirm the same problem, on my android 9 and 10 devices.
To make the switch working, i don't need to change the "kind" of switch, but simply open and close the settings menu of the app.
Thanks for your support
Paolo
Posted: Friday 28 August 2020 15:09
by Michalux
I've been testing domoticz widgets lately and it seems there is something wrong with push on/off button.
It generates three actions instead of one. When I use a switch type push on/off button in domoticz, than it generates one action (on or off).
But android widget generates on+off+on or off+on+off.
So it looks like something is wrong here
Posted: Sunday 13 September 2020 20:42
by Zoonie81
Hello, paid user here. Not sure this is the right place to report bugs and erratic behavior but here goes.
I've had the app for a year or two. The latest updates seem to have caused a bug where the slider for a particular z-wave dimmer activates other devices randomly. It can turn on/off other devices or adjust dimming on other devices - randomly every time.
- This only happens in the app and only in the Dashboard-view.
- Same slider in Switches-view acts normally in the app.
- Same slider in the domoticz web gui acts normally - independent of dash/switch view.
- All other devices/sliders/switches act normally when interacted with through Dashboard.
- Domoticz server is up-to-date, running on a rpi3.
- Android app is up-to-date. Have tried clearing cache, removing app, reinstalling app etc.
- The z-wave device with the affected slider has been part of the network for couple of years and worked flawlessly earlier.
- I noticed the problems about a couple of weeks ago. Could be longer and I just missed noticing it.
If problem is on my end I welcome suggestions.
Thx, Z
Posted: Thursday 17 September 2020 12:07
by juankar
Hi, I¡m using Domitcz Lite and it's updated.
Some times when I try to send a command (switch on or off) I receive an error message telling that I have no rights for this action!(well I receive it in spanish, usted no tiee derechos para esta acción)
When I switch off several times or change any settings, then I can do the action, but after some time I receive the error message again.
Where is the mistake?
Posted: Thursday 17 September 2020 21:58
by Johndomo
I also experience some bugs with the latest app. Paid verion, everything up-to-date, Android 9
Problems occur with Zwave (Fibaro) dimmers.
When I switch on / off devices, everything goes ok. But when I change the level of one of the dimmers, other devices are switched on too and set to the same level.
When I change the level of dimmer 1, dimmer 2...5 are switched on and set to the same level.
When I change the level of dimmer 2, dimmer 3...5 are switched on and set to the same level. Dimmer 1 is not changed.
When I chnage the level of dimmer 3, dimmer 4...5 are switched on and set to the same level. Dimmer 1..2 are not changed.
etc.
This only happens in the app, not in the web based application on the laptop.
Hope this can be solved in a future version.
John
Posted: Saturday 26 September 2020 18:52
by Zoonie81
Johndomo wrote: Thursday 17 September 2020 21:58
etc.
John
So this must indeed be a bug introduced in one of the app updates, as it resembles my own experience. Let's hope it gets fixed by next update.
Regards, Z
Posted: Sunday 27 September 2020 1:13
by Pancak1998
Hi! I am a happy user of the paid app.
But as of this weekend I am trying to move to a new phone without Google Play Services.
Any way to activate the 'premium' function on a phone without the Google Play Services / Framework?
Posted: Wednesday 30 September 2020 13:57
by galadril
etc.
John
Sorry guys, im fixing the dimmers as we speak!
Posted: Thursday 01 October 2020 8:57
by galadril
Zoonie81 wrote: Sunday 13 September 2020 20:42
Have you checked the latest update, that should fix the dimmers/sliders
Posted: Saturday 03 October 2020 0:26
by Zoonie81
galadril wrote: Thursday 01 October 2020 8:57
Thanks for replying. I've updated, unfortunately to no avail. Also, last week the paid version suddenly started crashing at startup and auto-closing. I tested everything, force close, clear cache, remove data, uninstall, reinstall. Nothing worked, so I was forced to use the Lite version, until now. The update fixed the crashing and I'm back on the paid version, but the bug is still alive.
