sincze
Domoticz version: 2024.4
Post by sincze »
joebar wrote:
sincze wrote:Very nice. Maybe with these items I can use the Xiaomi Smartplug as well without it being sticking out of the wall ;-) :D .
However with tha adapter price tag of around 10 euro's .... the Neo Cool Smartplug Can compete with it as well priced at € 16- €20 euro's
At least it will plug the Gateway much nicer against the wall I think.
Last year found these, ive installed 6 of them and working since Jan. Very flat and way cheaper (with shipping around $2 a piece)
https://www.ebay.com/itm/EU-3-Round-Pin ... 1737610742
Excellent. Never seen the shipping price higher than the goods itself. :)
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
krizzz
Post by krizzz »
Thanks!! Ordered them myself.
iganin
Post by iganin »
Hi, Having issue with integration of human body sensor into Blocky.
A simple script : If(motion sensor name) = "on" set "light" = "on"
doesn't work.
Screen Shot 2017-11-15 at 09.51.55.png (22.18 KiB) Viewed 3341 times
Does some on know how to solve it?
panajaquel
Domoticz version: 3.8739
Post by panajaquel »
Hi, I configured the xiaomi gateway as wiki, everything works except the brightness sensor that updates only if I turn the internal LEDs, I tried both with the stable version or with the latest beta of domoticz but it gives the same problem to someone does it same? you know the solutions.
Thank you
resolved, removed from domoticz xiaomi gateway restarted domoticz, reset xiaomi gateway and reconfigured now works regularly
Last edited by panajaquel on Monday 20 November 2017 21:24, edited 1 time in total.
drmabuse71
Post by drmabuse71 »
does someone get the additional features of the gateway working ?
Sound and the illumination ?
The gateway itself works perfect, but the light and sound of the gateway can´t be reached by domoticz,
works perfect with the Xiaomi app !
Kind regards
CaesarPL
Post by CaesarPL »
drmabuse71 wrote: Wednesday 15 November 2017 12:16 does someone get the additional features of the gateway working ?
Sure, works great 'out of the box' in Domoticz. What are your issues?
https://imgur.com/a/vM4AA
kluczus
Post by kluczus »
iganin wrote: Wednesday 15 November 2017 9:59 Hi, Having issue with integration of human body sensor into Blocky.
doesn't work.
Change "if" to Image
RPi2 + sonoff + 433MHz + Xiaomi Gateway + EQ-3 MAX!
salvacalatayud
Post by salvacalatayud »
mayyam wrote: Thursday 09 November 2017 15:51 Hi, there a
is promo code for Original Xiaomi Aqara Air Conditioning Companion
I'm reading the thread now, but the promo can end quickly.
So my question is - will this gateway work as the second one with Domoticz, or not?
Not working. I've got one and can only be operated by mi home app
DAVIZINHO
Post by DAVIZINHO »
hello I have two questions:
1.- Someone have 2 gateways working???
2.- someone have the last beta version and no problems with yeelight or with vacuum?
yesterday I upgrade to the last beta and have a lot of problems with yeelight rgb and vacuum :-(
and its imposible to me make work two gateways.
all problems!!! jejejeje
bing69
Post by bing69 »
krizzz wrote: Saturday 11 November 2017 13:43 Anyone here who can recommend a realtime flat adapter for a Chinese to EU powerplug?
http://www.ebay.nl/itm/EU-3-Round-Pin-T ... 2749.l2649
elgiampo
Post by elgiampo »
Is it possible through homekit-domoticz to activate the alarm on the gateway? and if so, how can it be done?
thank you!
mvveelen
Post by mvveelen »
mvveelen wrote: Thursday 26 October 2017 11:19 No fix yet for the battery status in the Beta version of Domoticz? Anyone?
Can anyone let me know if the battery statuses stopped working everywhere, or just with me in my (Beta) Domoticz set-up?
If this isn't supported anymore, please let me know. It's just the third time I ask the same question in this topic and so far I haven't heard anything about it.
robertje221
Post by robertje221 »
robertje221 wrote: Sunday 22 October 2017 20:24 I am running domoticz and the aqara/xiaomi gateway was running ok untill today.
I tried to add the xiaomi gateway but i think there is a problem i cant explain
when i add the gateway i fill in Remote Address: 192.168.2.3
but when i see the log, it says
2017-10-22 20:11:42.392 XiaomiGateway: will listen on 9898 for hardware id 3
2017-10-22 20:11:42.392 XiaomiGateway: Delaying worker startup...
2017-10-22 20:11:47.393 XiaomiGateway: Worker started...
2017-10-22 20:11:47.393 XiaomiGateway: Using 192.168.2.1 for local IP address.
no sensors are visible after adding.
192.168.2.1 is the ip addrss of domoticz
is it correct the log says XiaomiGateway: Using 192.168.2.1 for local IP address.
shouldnt it be 192.168.2.3????
Found the problem
The raspberry shouldnt be conected by LAN cable
When the raspberry was connected on the same wifi as the xiaomi gateway, it was working again!!
matteos1
Post by matteos1 »
Egregius wrote: Wednesday 08 November 2017 19:49 Anyone has a link where to buy Xiaomi stuff?
I ordered some items on Aliexpress but none of them got delivered...
gearbest
Egregius
Domoticz version: v2024.7
Post by Egregius »
matteos1 wrote: Monday 20 November 2017 13:43
gearbest
Do you have a link?
Because http://www.gearbest.com/ only gives me a 1px image and https://www.gearbest.com/ gives me a SSL error.
jannl
Domoticz version: 2025.5.x
Post by jannl »
Found the problem
That sounds very strange, I have my pi connected vua cable and do not have any issues with the Xiaomi. Did you have both wifi and cable active? That may give very unpredictable results.
sincze
Post by sincze »
panajaquel wrote: Wednesday 15 November 2017 10:38 Hi, I configured the xiaomi gateway as wiki, everything works except the brightness sensor that updates only if I turn the internal LEDs, I tried both with the stable version or with the latest beta of domoticz but it gives the same problem to someone does it same? you know the solutions.
Thank you
Mmm while browsing the internet I see a lot of problems with resetting the xiaomi gateway.
I had to reset it as it was connecting to an old SSID.
- Pressed the reset button -> Chinese blabla
- Started the APP
- Started scanning
- Found the Gateway
- Connected to the new SSID + Password.
- Updating Connection status at around 45%....
- Chinese blabla...
- Progress bar 0-100% connection succesful.. but no blue light comes back on.
Did the reset several times.
Sometimes it says connection time-out.. retry.
I can see the device it is connected to the wifi (responds to ping), however the key changed so domoticz is unable to connect to it. If I unplug and replug the device I see a blue ring flashing and that switches off. It starts responding to pings.
What am I missing here?
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
mvveelen
Post by mvveelen »
Did you generate a new key and did you put that new key in Domoticz? Not sure if you followed that step......
remb0
Post by remb0 »
great stuff.
when I start the hardware i see in my logs:
2017-11-23 21:37:03.300 XiaomiGateway: New Xiaomi Gateway Alarm Ringtone Found (34ce008c100f)
2017-11-23 21:37:03.302 XiaomiGateway: New Xiaomi Gateway Alarm Clock Found (34ce008c100f)
2017-11-23 21:37:03.304 XiaomiGateway: New Xiaomi Gateway Doorbell Found (34ce008c100f)
2017-11-23 21:37:03.305 XiaomiGateway: New Xiaomi Gateway MP3 Found (34ce008c100f)
2017-11-23 21:37:03.307 XiaomiGateway: New Xiaomi Gateway Volume Found (34ce008c100f)
2017-11-23 21:37:03.322 XiaomiGateway: New Xiaomi Wireless Switch Found (158d00016d7c01)
but when I check in devices I don't see this soundoptions selectors. It was the accept new hardware settings. ;)
sincze
Post by sincze »
mvveelen wrote: Thursday 23 November 2017 18:15 Did you generate a new key and did you put that new key in Domoticz? Not sure if you followed that step......
A yes I had the new key but it just did not work as when I pressed 'confirm' in the app .. it said time-out.
Well read all kinds of disturbing messages on a different portal and tried them all.
- Hotspot a different phone with same SSID
- Redirect default DNS to 8.8.8.8 and 8.8.4.4
- Reset & Configure with old app (apkmirror).
That kind of stuff. But the strange part is .. it did respond to pings but the APP said.. no-connection, so I left it overnight in the power socket...
And noticed in the APP it did see the motion of my motion sensors but it was just offline..
At around 08:30 I started the app.. Pressed the off-line gateway button.. And the thing came back to life.
Generated a new key. Pressed Confirm... (no error)
Put the key in domoticz.
Back up and running. :D
Pass2php
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
