Page 101 of 123
Posted: Thursday 19 October 2017 10:40
by borewicz
When I update Xiaomi Gateway to 1.4.1_150.0143 turning ON/OFF light via Domoticz stop working. How to resolve problem ?
Posted: Thursday 19 October 2017 13:50
by Stanleyk
borewicz wrote: Thursday 19 October 2017 10:40
Try to check xiaomi network password. In my case help me to change it with stop acces (not only change pass):
switch off communication protocol, confirm, switch it on (this change pass), confirm and change pass in domoticz
Posted: Friday 20 October 2017 22:34
by Stanleyk
Sometimes domoticz not log door sensor. in mihome app is log ok , all opens and all closes. have somebody same problem ?
I use door contact also for switch on light, but sometimes not work
Posted: Saturday 21 October 2017 0:25
by corbin
Andree wrote: Wednesday 18 October 2017 12:41
The problem is that: since I added the second smart plugs (connected to the first one) sometimes they do not respond and the lights and sounds of the two Gateway almost never work.
Thx
Try setting up from scratch on a new system? I've just followed the steps in the wiki on Windows and Raspberry Pi, and both gateways responded to commands 100% of the time I tried.
Posted: Saturday 21 October 2017 11:00
by borewicz
Stanleyk wrote: Thursday 19 October 2017 13:50
It works, thx.
Posted: Saturday 21 October 2017 18:47
by mvveelen
Luigi87 wrote: Wednesday 11 October 2017 11:38
Are there here more with problems in the voltage feedback from the Xiaomi devices?
From 9-10-2017 in am not getting updates on the voltage sensors. ( I have done an update to the latest beta that evening)
(an soft reset of the Gateway has not fixed it).
I am running the beta: 3.8563
and firmware on the gateway:
Version code: 149
Zigbee: 20
Fw_ver: 1.4.1_150
Maybe they are some ideas here to fix this.
Running Beta 3.8590 at the moment and my Xiaomi LUX sensor (gateway) and also all voltage sensors aren't updated anymore. Is there a fix for this? I already read that removing and adding the Xiaomi gateway doesn't resolve the issue.
Anyone ?
Posted: Sunday 22 October 2017 20:24
by robertje221
I am running domoticz and the aqara/xiaomi gateway was running ok untill today.
I tried to add the xiaomi gateway but i think there is a problem i cant explain
when i add the gateway i fill in Remote Address: 192.168.2.3
but when i see the log, it says
2017-10-22 20:11:42.392 XiaomiGateway: will listen on 9898 for hardware id 3
2017-10-22 20:11:42.392 XiaomiGateway: Delaying worker startup...
2017-10-22 20:11:47.393 XiaomiGateway: Worker started...
2017-10-22 20:11:47.393 XiaomiGateway: Using 192.168.2.1 for local IP address.
no sensors are visible after adding.
192.168.2.1 is the ip addrss of domoticz
is it correct the log says XiaomiGateway: Using 192.168.2.1 for local IP address.
shouldnt it be 192.168.2.3????
Posted: Sunday 22 October 2017 20:49
by Derik
Set your ip for the gateway static in your modem/router...
And add that ip in domoticz xiaomi hardware
Posted: Sunday 22 October 2017 21:01
by robertje221
i already set the 192.168.2.3 / xiaomi gateway IP as static
But no matter which IP i fill in in domoticz, it always says XiaomiGateway: Using 192.168.2.1 for local IP address.
Posted: Sunday 22 October 2017 22:59
by terrorsource
I've bought a few Aqara Human Body Sensors v2(with the stand and lux-meter). Added them to the Xiaomi Home Gateway but they won't show up in Domoticz.
Looks like Domoticz doesn't suppor this version yet. this is what i see in the logs:
2017-10-22 22:53:54.849 XiaomiGateway: unhandled model: sensor_motion.aq2
2017-10-22 22:53:54.856 XiaomiGateway: unhandled model: sensor_motion.aq2
Anything i can do to get these things working? file a bug-report on github or what?
Posted: Monday 23 October 2017 0:17
by mayyam
Get the newer beta for pir to work.
Posted: Monday 23 October 2017 0:47
by Shred
Does anyone else have issues with contact bounce on the Aqara door/window sensor?
I have a few of the door/window sensors. When a door - particularly a sliding door like a garage door opens or closes slowly, the device sends Domoticz a number of off/on/off events within a second or so. In a perfect world, this would be filtered out in the Xiaomi hardware - but that's not happening. What is the best way to "debounce" the switch in software, so I don't get bombarded with multiple notifications for a single event?
I've tried setting "on delay" and "off delay", but these just hold up the series of messages - there's no sanity checking. I guess I could write a LUA script, but it seems like a lot of messing around to implement switch debouncing.
[EDIT] here's a copy/paste of the log from a door opening, then closing this morning:
2017-10-23 07:32:49 On
2017-10-23 07:32:49 Off
2017-10-23 07:34:45 Off
2017-10-23 07:34:46 On
2017-10-23 07:34:46 Off
Posted: Monday 23 October 2017 8:29
by terrorsource
Omg, it's was too late on the evening when i posted the above. I've now updated Domoticz as mentioned a few posts before and the Aqara Human Body Sensors are now seen by Domoticz.
PIR is, Lux/Voltage isnt yet but maybe i need to press the side-button a few times to get those working too.
Posted: Monday 23 October 2017 10:14
by corbin
robertje221 wrote: Sunday 22 October 2017 20:24
Local IP should be the IP that Domoticz is running on, so that is OK. Was it working previously and then stopped? Did you change something on your network configuraiton?
Posted: Monday 23 October 2017 10:15
by corbin
Shred wrote: Monday 23 October 2017 0:47
Are you using the newer square Aqara sensors? I have the original sensors on sliding doors and haven't noticed this problem.
Posted: Monday 23 October 2017 11:11
by Shred
Yes. I have the newer squared off door switches. I bought three and all behave in the same manner.
Posted: Tuesday 24 October 2017 11:58
by phoxy84
deennoo wrote: Tuesday 05 September 2017 18:07
Have a look to
https://github.com/rytilahti/python-mirobo
That tje n'est python lib to drive Xiaomi wifi device, dev are working hard and add new device/function every day. I manage to drive my Xiaomi Philips ball led with this.
Python plugin for robot vaccum use the same lib (an older version) his way to run looks the best one, just need to be adapted for other device.
I can't find to control my Xiaomi Philips lights with Domoticz, I have the IP and the token, what is the next step? I allready have the python mirobo installed and can fire up the vacuum with domoticz. Next step are my lights
, any help?
Posted: Tuesday 24 October 2017 21:15
by robertje221
corbin wrote: Monday 23 October 2017 10:14
yes the router was reset by the ISP. after that, the gateway was working normally and just after a firmware upgrade of the gateway it suddenly stopped.
Maybe it is the best to reset the gateway?
Posted: Wednesday 25 October 2017 13:59
by kmccor
Hi, I get a battery low warning from one of my Xiaomi temp sensors, even though it's not that old and the temp/humidy battery level on the same device is showing 80%.
Is anyone else experiencing this and if so is there a fix? It changes state as well, the temp/hum is currently not showing any battery level and temp is showing 100%?? I have tried removing and re-adding the device from Domoticz and the Xiaomi gateway a few times to no avail.
Cheers
Karl
Posted: Thursday 26 October 2017 11:19
by mvveelen
No fix yet for the battery status in the Beta version of Domoticz? Anyone?
