Page 11 of 12
Re: FlatZ Frontpage
Posted: Saturday 08 October 2016 19:53
by mvveelen
I'm having some troubles with the home page. I only get 1 donut chart which displays the temperature. When I hover over this donut chart, the text that shows up is text from another temperature donut chart that won't show up.
I checked everything and even started with a new settings file: no result.
I'm using 3 temperature/humidity sensors which are the same.
This is what I get:
When I hover over "TEMPERATUUR SLAAPKAMER", I get: "VOCHT WOONKAMER: 51%".
This is what the settings.js has:
    //other devices
    ['8', 'Humidity', 'cell7', 'Vocht woonkamer', 'woonkamer', '#b2c831'],
    ['8', 'LastUpdate', 'cell70', 'Vocht woonkamer'],
    ['650', 'Temp', 'cell8', 'Temperatuur slaapkamer', 'slaapkamer', '#2980B9'],
    ['650', 'LastUpdate', 'cell80', 'Temperatuur slaapkamer'],
    ['92', 'Usage', 'cell9', 'Elektra (Watt)'],
    ['92', 'Data', 'cell29', 'Elektra'],
    ['92', 'CounterToday', 'cell39', 'Elektra'],
    ['92', 'LastUpdate', 'cell19', 'Elektra'],
    ['667', 'Temp', 'cell10', 'Temperatuur werkkamer', 'werkkamer', '#C0382B'],
    ['667', 'LastUpdate', 'cell100', 'Temperatuur werkkamer'],
    ['630', 'Data', 'cell11', 'Kodi Status'],
    ['597', 'Status', 'cell12', 'Toiletverlichting Status'],
    ['509', 'Status', 'cell13', 'Ventilatie', 'arrow'],
Edit:
I've found it. The 'divs' are hardcoded in frontpage.html and must not be changed:
            <!-- DONUT CHART -->
-knip-
                    <div id="badkamer" style="height: 11.313em;width: 11.313em;margin: auto;"></div>
-knip-
-knip-
                    <div id="woonkamer" style="height: 11.313em;width: 11.313em;margin: auto;"></div>
-knip-
-knip-
                    <div id="buiten" style="height: 11.313em;width: 11.313em;margin: auto;"></div>
-knip-
Redraw
Posted: Saturday 08 October 2016 21:08
by Btje
What I see is that pies redraw al the time. Is this configurable?
Re: FlatZ Frontpage
Posted: Sunday 23 October 2016 20:33
by Btje
Pitty that the pie's use java that wont run on a tablet. At least that is what I can find.
Re: FlatZ Frontpage
Posted: Sunday 23 October 2016 20:43
by johansson
Anybody? Any pointers would be highly appreciated.
johansson wrote:Great approach, looks great! I've been looking for a solution to gather the all main data into one dashboard, including e.g. switches, temperatures, traffic and train details etc; so far the best alternative I've found.
After several hours of fiddling with the dashboard, most of the external stuff (traffic, cameras and so on) are in place, but no Domoticz switches or temperatures. Cannot figure out what's wrong, maybe you guys could help out. For example, a switch from json:
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HardwareName" : "RFXCom",
         "HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
         "HardwareTypeVal" : 1,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "0F7E8A2",
         "Image" : "Light",
         "IsSubDevice" : true,
         "LastUpdate" : "2016-10-04 13:08:46",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "Name" : "Block",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "SwitchType" : "On/Off",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "Lighting 2",
         "TypeImg" : "lightbulb",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "13"
That inserted into the switches section in settings.js should be:
    ['13', 'Data', 'cell1', 'Block', 'onbutton'],//onbutton = only push on
But nothing, I've tried all the options I could figure out with no luck.
Same goes with my thermometers:
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 100,
         "CustomImage" : 0,
         "Data" : "8.3 C",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "8800",
         "LastUpdate" : "2016-10-04 15:42:02",
         "Name" : "Outer_temp",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SignalLevel" : 7,
         "SubType" : "Viking 02811/02813, Proove TSS330",
         "Temp" : 8.300000000000001,
         "Timers" : "false",
         "Type" : "Temp",
         "TypeImg" : "temperature",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "12"
That in other devices should look something like:
      ['12', 'Temp', 'cell10', 'Ulkolampo', 'Ulko', '#C0382B'],
Again, nothing anywhere but don't know where's the problem.
Even the log page is empty, maybe there's an issue the Domoticz connection. Or something. Any advice would be highly appreciated.
Re: FlatZ Frontpage
Posted: Tuesday 25 October 2016 14:27
by sorampage
It's possible to add Blinds ??
I have some switches in my Domoticz for my blinds, I have 1 ID per Blinds, but 3 switches for one blind ... (Open,Stop,Close) PJ
If anyone has an idea .. :)
Re: FlatZ Frontpage
Posted: Sunday 30 October 2016 7:51
by satanasinc
Hi!
Great work with FlatZ it is great thanks!
I have been trying to configure a in FlatZ a SetPoint for control my domoticz themostat without luck.
Someone has this function working on Flatz integrated with the domoticz popup?
Please explain the config process.
Greetings from spain!
Re: FlatZ Frontpage
Posted: Sunday 30 October 2016 16:41
by stavroshamster
For the switch have you tried replacing 'onbutton' with 'button'?
johansson wrote:Anybody? Any pointers would be highly appreciated.
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "0F7E8A2",
         "Image" : "Light",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "Name" : "Block",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "13"
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "8.3 C",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "8800",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SignalLevel" : 7,
         "Timers" : "false",
         "Type" : "Temp",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "12"
Re: FlatZ Frontpage
Posted: Tuesday 01 November 2016 15:46
by stavroshamster
I have managed to hack in a thermostat SetPoint adjustment function into the frontpage.html file by modifying a 'dash-unit' div as follows:
<div class="dash-unit">
		    <dtitle id="desc_cell54"></dtitle>
                    <hr>
                    <div class="info-user">
                        <span aria-hidden="true" class="info-user"></span>
                    	</div>
				<br/>
				<div style="text-align:center"><div class="btnnew" style="font-size:20px; margin-right: 5px" id="tempup">UP</div><div class="btnnew" style="font-size:20px" id="tempupone">+1</div></div>
				</br>
                    		<div style="text-align:center;font-size: 60px" id="insert"></div>
				</br>
		    		<div style="text-align:center"><div class="btnnew" style="font-size:20px; margin-right: 5px"  id="tempdown">DOWN</div><div class="btnnew" style="font-size:20px" id="tempdownone">-1</div></div>
                    	</div>
            	</div>
Then there is some JavaScript code to read the SetPoint and pass it to the 'insert' div, noting that the '11' here is the position of the thermostat in the resulting JSON information:
<script>
	$.ajax({
		url: 'http://<DOMOTICZ URL & PORT>/json.htm?type=devices&jsoncallback=?',
		async: false,
		dataType: 'json',
		success: function(data){}
	var myjson = data.result[11];
        var res = myjson.Data;
	var value = parseFloat(res);
	pass = value.toString();
	document.getElementById("insert").innerHTML = pass;
</script>
For each button, I have some further script which modifies the SetPoint value by first reading it using the JSON API, and then sending a new value (noting that the '9' in the URL here is the idx number of my thermostat) e.g.:
<script>
	document.getElementById("tempup").onclick = function() {myFunction1()}
	function myFunction1() {
		$.ajax({
			async: false,
			dataType: 'json',
			var n = noty({
						text: 'Setpoint adjusted - please wait for update',
						type: 'success'
                value = value + 0.5;
		var jurl = 'http://<DOMOTICZ URL & PORT>/json.htm?type=command&param=udevice&idx=9&nvalue=0&svalue=' + pass;
		$.ajax({
			url: jurl,
			async: true,
			dataType: 'json',
			success: function(){
</script>
For other buttons you just modify the function name, the 'id' and the amount you modify the 'value' variable by whatever amount you want to adjust by.
The visual result is:
It's worth stating that I am very inexperienced with both javascript and HTML so there are certainly likely to be many improvements that could be made to make it more efficient! However, I thought I would share anyway!
Re: FlatZ Frontpage
Posted: Friday 04 November 2016 13:51
by johansson
stavroshamster wrote:For the switch have you tried replacing 'onbutton' with 'button'?
Oh my - it worked! Don't know what I dis, but to my surprise the switch along the logs etc appeared. Hallelujah, now I'm not gonna touch it anymore :D Thanks.
Tried that, no luck though.
Could this be authorisation related issue: nothing Domoticz -related is showing (logs, switches, even Raspberry memory usage), but both internal and external webcams are displayed correctly, as well as traffic, news feeds...
Thanks for the tip, anyhow,
Re: FlatZ Frontpage
Posted: Saturday 05 November 2016 8:18
by satanasinc
stavroshamster wrote:I have managed to hack in a thermostat SetPoint adjustment function into the frontpage.html file by modifying a 'dash-unit' div as follows:
                    <hr>
                    	</div>
				<br/>
				</br>
				</br>
                    	</div>
            	</div>
<script>
	$.ajax({
		async: false,
		dataType: 'json',
</script>
<script>
		$.ajax({
			async: false,
			dataType: 'json',
			var n = noty({
						type: 'success'
		$.ajax({
			url: jurl,
			async: true,
			dataType: 'json',
</script>
Hi!
stavroshamster i have been trying your code without luck. I modified de code in frontpage.html only. I this correct?
Can you post your frontpage.html as example.
Thank you in advanced.
Re: FlatZ Frontpage
Posted: Monday 07 November 2016 15:17
by sorampage
sorampage wrote:Hi all,
Someone can help me ?
Re: FlatZ Frontpage
Posted: Monday 14 November 2016 20:58
by DaWauZ
does it work with mi lights rgb too, instead of hue?
Re: FlatZ Frontpage
Posted: Friday 18 November 2016 16:44
by SwordFish
I want to put 2 donut charts in one dash-unit for temp and Humidity. I have try several things but i cannot get it done. Is there someone that can help or has this already done?
Re: FlatZ Frontpage
Posted: Sunday 25 December 2016 9:25
by denisj
Hi there
this frontpage is wonderfol
So I want to ask... can be this frontpage adapted to a tablet form please ?
Thanks in advance
Denis
Re: FlatZ Frontpage
Posted: Sunday 01 January 2017 22:33
by seblang
I am new and i am trying to use this fabulous frontpanel but I nothing appear on it.
I have this kinf of error in Domoticz error log :
Error: Webserver: File '/FlatZ-Frontpage/undefined/json.htm': No such file or directory (2)
can some body help me?
thanks in advance
regards
sebastien
Re: FlatZ Frontpage
Posted: Tuesday 03 January 2017 17:03
by Siewert308SW
@galadril
Any change the frontpage is updated again?
As someone asked it a couple of months ago.
But the graphs aren't working any more for Youless devices (atleast) since something changed on the Domoticz side months ago.
Re: FlatZ Frontpage
Posted: Tuesday 03 January 2017 21:08
by seblang
Hi no feedback about this issue?
I have check in Chrome console and have always the same message see enclosed file
please help me
thanks
Re: FlatZ Frontpage
Posted: Sunday 08 January 2017 20:09
by jhenrikb
Hello.
Kind of noob question here.
Is there any special way to unzip the files into the WWW folder on the raspberry pi? or does it work on a raspberry pi at all?
I have tried to install this frontpage, Dashticz, and many others without success.
Domoticz only show "domoticz offline" which I guess is the same as a white page people used to get.
I download the package on my comp, unzip it, change whatever Config or setting while I need to according to the guidance.
Add in my local Raspi3 IP and port.
but still I seem to get the offline thing.
Anyone know why?
I edit the files in windows and upload it through filezilla, then "sudo reboot".
sincerely
John
Re: FlatZ Frontpage
Posted: Sunday 08 January 2017 20:28
by denisj
If I remember there is a unzip command on raspberry
try
unzip filename.zip
Denis
Re: FlatZ Frontpage
Posted: Wednesday 25 January 2017 16:29
by Zahariac
I am now busy getting everything to work. And I must say it is a great frontpage!
But I still have trouble with 2 things:
The news api doesn't work, tried serveral rss feeds
I do not see how I can setup the camera page to 4 camera's instead of 6. If I delete some of the div's it deletes the squares but still remains the same size. (hope that I made myself clear).
