FlatZ Frontpage
mvveelen
Re: FlatZ Frontpage
Post by mvveelen »
I'm having some troubles with the home page. I only get 1 donut chart which displays the temperature. When I hover over this donut chart, the text that shows up is text from another temperature donut chart that won't show up.
I checked everything and even started with a new settings file: no result.
I'm using 3 temperature/humidity sensors which are the same.
This is what I get:
When I hover over "TEMPERATUUR SLAAPKAMER", I get: "VOCHT WOONKAMER: 51%".
This is what the settings.js has:
    //other devices
    ['8', 'Humidity', 'cell7', 'Vocht woonkamer', 'woonkamer', '#b2c831'],
    ['8', 'LastUpdate', 'cell70', 'Vocht woonkamer'],
    ['650', 'Temp', 'cell8', 'Temperatuur slaapkamer', 'slaapkamer', '#2980B9'],
    ['650', 'LastUpdate', 'cell80', 'Temperatuur slaapkamer'],
    ['92', 'Usage', 'cell9', 'Elektra (Watt)'],
    ['92', 'Data', 'cell29', 'Elektra'],
    ['92', 'CounterToday', 'cell39', 'Elektra'],
    ['92', 'LastUpdate', 'cell19', 'Elektra'],
    ['667', 'Temp', 'cell10', 'Temperatuur werkkamer', 'werkkamer', '#C0382B'],
    ['667', 'LastUpdate', 'cell100', 'Temperatuur werkkamer'],
    ['630', 'Data', 'cell11', 'Kodi Status'],
    ['597', 'Status', 'cell12', 'Toiletverlichting Status'],
    ['509', 'Status', 'cell13', 'Ventilatie', 'arrow'],
Edit:
I've found it. The 'divs' are hardcoded in frontpage.html and must not be changed:
            <!-- DONUT CHART -->
-knip-
                    <div id="badkamer" style="height: 11.313em;width: 11.313em;margin: auto;"></div>
-knip-
-knip-
                    <div id="woonkamer" style="height: 11.313em;width: 11.313em;margin: auto;"></div>
-knip-
-knip-
                    <div id="buiten" style="height: 11.313em;width: 11.313em;margin: auto;"></div>
-knip-
Btje
Redraw
Post by Btje »
What I see is that pies redraw al the time. Is this configurable?
Btje
Re: FlatZ Frontpage
Post by Btje »
Pitty that the pie's use java that wont run on a tablet. At least that is what I can find.
johansson
Re: FlatZ Frontpage
Post by johansson »
Anybody? Any pointers would be highly appreciated.
johansson wrote:Great approach, looks great! I've been looking for a solution to gather the all main data into one dashboard, including e.g. switches, temperatures, traffic and train details etc; so far the best alternative I've found.
After several hours of fiddling with the dashboard, most of the external stuff (traffic, cameras and so on) are in place, but no Domoticz switches or temperatures. Cannot figure out what's wrong, maybe you guys could help out. For example, a switch from json:
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 255,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "HardwareName" : "RFXCom",
         "HardwareType" : "RFXCOM - RFXtrx433 USB 433.92MHz Transceiver",
         "HardwareTypeVal" : 1,
         "HaveDimmer" : true,
         "HaveGroupCmd" : true,
         "HaveTimeout" : false,
         "ID" : "0F7E8A2",
         "Image" : "Light",
         "IsSubDevice" : true,
         "LastUpdate" : "2016-10-04 13:08:46",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "Name" : "Block",
         "Notifications" : "false",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Protected" : false,
         "ShowNotifications" : true,
         "SignalLevel" : "-",
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "SwitchType" : "On/Off",
         "SwitchTypeVal" : 0,
         "Timers" : "false",
         "Type" : "Lighting 2",
         "TypeImg" : "lightbulb",
         "Unit" : 1,
         "Used" : 1,
         "UsedByCamera" : false,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "13"
That inserted into the switches section in settings.js should be:
    ['13', 'Data', 'cell1', 'Block', 'onbutton'],//onbutton = only push on
But nothing, I've tried all the options I could figure out with no luck.
Same goes with my thermometers:
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "BatteryLevel" : 100,
         "CustomImage" : 0,
         "Data" : "8.3 C",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "8800",
         "LastUpdate" : "2016-10-04 15:42:02",
         "Name" : "Outer_temp",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SignalLevel" : 7,
         "SubType" : "Viking 02811/02813, Proove TSS330",
         "Temp" : 8.300000000000001,
         "Timers" : "false",
         "Type" : "Temp",
         "TypeImg" : "temperature",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "12"
That in other devices should look something like:
      ['12', 'Temp', 'cell10', 'Ulkolampo', 'Ulko', '#C0382B'],
Again, nothing anywhere but don't know where's the problem.
Even the log page is empty, maybe there's an issue the Domoticz connection. Or something. Any advice would be highly appreciated.
sorampage
Domoticz version: LastStab
Re: FlatZ Frontpage
Post by sorampage »
It's possible to add Blinds ??
I have some switches in my Domoticz for my blinds, I have 1 ID per Blinds, but 3 switches for one blind ... (Open,Stop,Close) PJ
If anyone has an idea .. :)
satanasinc
Domoticz version: 4.9700
Re: FlatZ Frontpage
Post by satanasinc »
Hi!
Great work with FlatZ it is great thanks!
I have been trying to configure a in FlatZ a SetPoint for control my domoticz themostat without luck.
Someone has this function working on Flatz integrated with the domoticz popup?
Please explain the config process.
Greetings from spain!
stavroshamster
Re: FlatZ Frontpage
Post by stavroshamster »
For the switch have you tried replacing 'onbutton' with 'button'?
johansson wrote:Anybody? Any pointers would be highly appreciated.
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "Off",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "0F7E8A2",
         "Image" : "Light",
         "Level" : 0,
         "LevelInt" : 0,
         "MaxDimLevel" : 15,
         "Name" : "Block",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "Status" : "Off",
         "StrParam1" : "",
         "StrParam2" : "",
         "SubType" : "AC",
         "Timers" : "false",
         "Unit" : 1,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "13"
"AddjMulti" : 1.0,
         "AddjMulti2" : 1.0,
         "AddjValue" : 0.0,
         "AddjValue2" : 0.0,
         "CustomImage" : 0,
         "Data" : "8.3 C",
         "Description" : "",
         "Favorite" : 1,
         "HardwareID" : 2,
         "ID" : "8800",
         "PlanID" : "0",
         "PlanIDs" : [ 0 ],
         "SignalLevel" : 7,
         "Timers" : "false",
         "Type" : "Temp",
         "Unit" : 0,
         "Used" : 1,
         "XOffset" : "0",
         "YOffset" : "0",
         "idx" : "12"
stavroshamster
Re: FlatZ Frontpage
I have managed to hack in a thermostat SetPoint adjustment function into the frontpage.html file by modifying a 'dash-unit' div as follows:
<div class="dash-unit">
		    <dtitle id="desc_cell54"></dtitle>
                    <hr>
                    <div class="info-user">
                        <span aria-hidden="true" class="info-user"></span>
                    	</div>
				<br/>
				<div style="text-align:center"><div class="btnnew" style="font-size:20px; margin-right: 5px" id="tempup">UP</div><div class="btnnew" style="font-size:20px" id="tempupone">+1</div></div>
				</br>
                    		<div style="text-align:center;font-size: 60px" id="insert"></div>
				</br>
		    		<div style="text-align:center"><div class="btnnew" style="font-size:20px; margin-right: 5px"  id="tempdown">DOWN</div><div class="btnnew" style="font-size:20px" id="tempdownone">-1</div></div>
                    	</div>
            	</div>
Then there is some JavaScript code to read the SetPoint and pass it to the 'insert' div, noting that the '11' here is the position of the thermostat in the resulting JSON information:
<script>
	$.ajax({
		url: 'http://<DOMOTICZ URL & PORT>/json.htm?type=devices&jsoncallback=?',
		async: false,
		dataType: 'json',
		success: function(data){}
	var myjson = data.result[11];
        var res = myjson.Data;
	var value = parseFloat(res);
	pass = value.toString();
	document.getElementById("insert").innerHTML = pass;
</script>
For each button, I have some further script which modifies the SetPoint value by first reading it using the JSON API, and then sending a new value (noting that the '9' in the URL here is the idx number of my thermostat) e.g.:
<script>
	document.getElementById("tempup").onclick = function() {myFunction1()}
	function myFunction1() {
		$.ajax({
			async: false,
			dataType: 'json',
			var n = noty({
						text: 'Setpoint adjusted - please wait for update',
						type: 'success'
                value = value + 0.5;
		var jurl = 'http://<DOMOTICZ URL & PORT>/json.htm?type=command&param=udevice&idx=9&nvalue=0&svalue=' + pass;
		$.ajax({
			url: jurl,
			async: true,
			dataType: 'json',
			success: function(){
</script>
For other buttons you just modify the function name, the 'id' and the amount you modify the 'value' variable by whatever amount you want to adjust by.
The visual result is:
It's worth stating that I am very inexperienced with both javascript and HTML so there are certainly likely to be many improvements that could be made to make it more efficient! However, I thought I would share anyway!
johansson
Re: FlatZ Frontpage
Post by johansson »
stavroshamster wrote:For the switch have you tried replacing 'onbutton' with 'button'?
Oh my - it worked! Don't know what I dis, but to my surprise the switch along the logs etc appeared. Hallelujah, now I'm not gonna touch it anymore :D Thanks.
Tried that, no luck though.
Could this be authorisation related issue: nothing Domoticz -related is showing (logs, switches, even Raspberry memory usage), but both internal and external webcams are displayed correctly, as well as traffic, news feeds...
Thanks for the tip, anyhow,
satanasinc
Re: FlatZ Frontpage
stavroshamster wrote:I have managed to hack in a thermostat SetPoint adjustment function into the frontpage.html file by modifying a 'dash-unit' div as follows:
                    <hr>
                    	</div>
				<br/>
				</br>
				</br>
                    	</div>
            	</div>
<script>
	$.ajax({
		async: false,
		dataType: 'json',
</script>
<script>
		$.ajax({
			async: false,
			dataType: 'json',
			var n = noty({
						type: 'success'
		$.ajax({
			url: jurl,
			async: true,
			dataType: 'json',
</script>
Hi!
stavroshamster i have been trying your code without luck. I modified de code in frontpage.html only. I this correct?
Can you post your frontpage.html as example.
Thank you in advanced.
sorampage
Re: FlatZ Frontpage
Post by sorampage »
sorampage wrote:Hi all,
Someone can help me ?
DaWauZ
Re: FlatZ Frontpage
Post by DaWauZ »
does it work with mi lights rgb too, instead of hue?
Raspberry Pi 2 model B with domoticz
OMV NAS installed on thin client HP T610
Openelec Kodi Mediaplayer on thin client HP T520 (and with multiboot windows 10)
SwordFish
Domoticz version: V4.11375
Re: FlatZ Frontpage
Post by SwordFish »
I want to put 2 donut charts in one dash-unit for temp and Humidity. I have try several things but i cannot get it done. Is there someone that can help or has this already done?
denisj
Re: FlatZ Frontpage
Post by denisj »
Hi there
this frontpage is wonderfol
So I want to ask... can be this frontpage adapted to a tablet form please ?
Thanks in advance
Denis
seblang
Re: FlatZ Frontpage
Post by seblang »
I am new and i am trying to use this fabulous frontpanel but I nothing appear on it.
I have this kinf of error in Domoticz error log :
Error: Webserver: File '/FlatZ-Frontpage/undefined/json.htm': No such file or directory (2)
can some body help me?
thanks in advance
regards
sebastien
Siewert308SW
Domoticz version: Stable
Re: FlatZ Frontpage
Post by Siewert308SW »
@galadril
Any change the frontpage is updated again?
As someone asked it a couple of months ago.
But the graphs aren't working any more for Youless devices (atleast) since something changed on the Domoticz side months ago.
Setup:
- DS923+ Docker
Domoticz Latest Stable
Mosquitto / ZwaveJSUI @ Aeotec Z-Stick Gen5+ / PiHole Unbound
P1 USB Gas/Power, HW watermeter
- A lot of Zwave switches, contacts, plugs, smoke/Co2 ect
- DiY 7.5kWh Solar Storage @ GitHuB
seblang
Re: FlatZ Frontpage
Post by seblang »
Hi no feedback about this issue?
I have check in Chrome console and have always the same message see enclosed file
please help me
thanks
jhenrikb
Re: FlatZ Frontpage
Post by jhenrikb »
Hello.
Kind of noob question here.
Is there any special way to unzip the files into the WWW folder on the raspberry pi? or does it work on a raspberry pi at all?
I have tried to install this frontpage, Dashticz, and many others without success.
Domoticz only show "domoticz offline" which I guess is the same as a white page people used to get.
I download the package on my comp, unzip it, change whatever Config or setting while I need to according to the guidance.
Add in my local Raspi3 IP and port.
but still I seem to get the offline thing.
Anyone know why?
I edit the files in windows and upload it through filezilla, then "sudo reboot".
sincerely
John
denisj
Re: FlatZ Frontpage
Post by denisj »
If I remember there is a unzip command on raspberry
try
unzip filename.zip
Denis
Zahariac
Re: FlatZ Frontpage
Post by Zahariac »
I am now busy getting everything to work. And I must say it is a great frontpage!
But I still have trouble with 2 things:
The news api doesn't work, tried serveral rss feeds
I do not see how I can setup the camera page to 4 camera's instead of 6. If I delete some of the div's it deletes the squares but still remains the same size. (hope that I made myself clear).
