[MyDomoAtHome] Support thread
resentedpoet
Re: [MyDomoAtHome] Support thread
Post by resentedpoet »
I'm having some problems setting up MDAH and Domoticz on the same Raspberry Pi 2.
I have Domoticz installed and working great (v2.2563) and followed the Wiki guide and installed MyDomoAtHome. I copied the default config.yml, development.yml and production.yml files and edited their settings and put in the IP address of my Raspberry pi and port (which I changed from the default 8080 to 8085).
I placed the same settings in all three files and ran the run-once.sh program. After all was completed successfully, I ran the setup instructions. At first, I didn't have access to my list of devices in domoticz, but after opening up the port in my router directly (as well as port 3001 for MDAH, I did not change the default port) I was able to get the list.
As well, I am able to access the main landing page for the MDAH server (http://myservergatewayip:3001) but when I try to access http://myservergatewayip:3001/devices , I receive an error message saying:
An internal error occured
I'm not sure what I have done wrong to get here. At first, I thought it had something to do with the permissions Domoticz has to give to the MDAH api to access it, but i'm not too sure where I would find that to change it.
Any help is appreciated, thanks!
epierre
Post by epierre »
resentedpoet wrote:As well, I am able to access the main landing page for the MDAH server (http://myservergatewayip:3001) but when I try to access http://myservergatewayip:3001/devices , I receive an error message saying:
That is not so frequent...
Can you launch start2.sh that will display output on the command line and request the device list again ? The error messaye should be displayed on the console.
Thanks,
ImperiHome & MyDomoAtHome on top of:
868.42Mhz - Vera Lite - Fibaro SS-101, S-211, K-101, FWP - Fortress SSA2
433Mhz - Cubie Domoticz + RFXtrx + Oregon || Foscam 9821W
2,4Ghz - Cubie MySensors Gateway + COV + TempHumidity + Pressure + WaterMeter
resentedpoet
Thanks,
Hi epierre,
This is the output I get when I launch the start2.sh script:
pi@domoticz ~/domoticz/MyDomoAtHome $ ./start2.sh
2015/10/05-11:24:54 Starman::Server (type Net::Server::PreFork) starting! pid(15771)
Resolved [*]:3001 to [0.0.0.0]:3001, IPv4
Host [*] resolved to IPv6 address [::] but IO::Socket::INET6->new fails: Address family not supported by protocol at /usr/share/perl5/Net/Server/Proto.pm line 133.
Binding to TCP port 3001 on host 0.0.0.0 with IPv4
2015/10/05-11:24:54 Can't connect to TCP port 3001 on 0.0.0.0 [Address already in use]
  at line 67 in file /usr/share/perl5/Net/Server/Proto/TCP.pm
2015/10/05-11:24:54 Received QUIT. Running a graceful shutdown
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 355.
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 385.
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 405.
Use of uninitialized value in subtraction (-) at /usr/share/perl5/Net/Server/PreFork.pm line 413.
2015/10/05-11:24:54 Worker processes cleaned up
2015/10/05-11:24:54 Server closing!
shutdown() on closed socket GEN1 at /usr/lib/perl/5.14/IO/Socket.pm line 294.
epierre
Post by epierre »
@resentpoet ok a process is still running on 3001 port
, please do:
lsof -i tcp:3001
from that kill the listening process (called starman master) and launch start2.sh
resentedpoet
epierre wrote:@resentpoet ok a process is still running on 3001 port
, please do:
lsof -i tcp:3001
Hello again epierre,
Killed all the processes and started start2.sh, this is the output I am receiving now:
2015/10/05-11:36:04 Starman::Server (type Net::Server::PreFork) starting! pid(16046)
Host [*] resolved to IPv6 address [::] but IO::Socket::INET6->new fails: Address family not supported by protocol at are/perl5/Net/Server/Proto.pm line 133.
Setting gid to "33 33 33"
Use of uninitialized value in negation (-) at /usr/lib/perl5/DateTime.pm line 1764.
epierre
Post by epierre »
ok this is fine, now get the /devices
resentedpoet
epierre wrote:ok this is fine, now get the /devices
Still getting the same problem:
"An Internal Error Occurred"
epierre
Post by epierre »
same thing on the console ??
resentedpoet
The error is what I get when I try and access devices from my web browser, this is the response in console when I try and access http://gatewayip:3001/devices
pi@domoticz ~/domoticz/MyDomoAtHome $ sudo lsof -i tcp:3001
COMMAND   PID USER   FD   TYPE DEVICE SIZE/OFF NODE NAME
starman 16626 root    5u  IPv4  31663      0t0  TCP *:3001 (LISTEN)
starman 16652 root    5u  IPv4  31663      0t0  TCP *:3001 (LISTEN)
starman 16653 root    5u  IPv4  31663      0t0  TCP *:3001 (LISTEN)
starman 16913 root    5u  IPv4  31663      0t0  TCP *:3001 (LISTEN)
starman 16916 root    5u  IPv4  31663      0t0  TCP *:3001 (LISTEN)
pi@domoticz ~/domoticz/MyDomoAtHome $ sudo kill 16626
2015/10/05-12:34:41 Starman::Server (type Net::Server::PreFork) starting! pid(16931)
epierre
Post by epierre »
@resentedpoet: hard to tell from that... can you do an ./update-mdah.sh and try again this way ?
try edition start2.sh and change the production string to development
resentedpoet
epierre wrote:@resentedpoet: hard to tell from that... can you do an ./update-mdah.sh and try again this way ?
Here is the output after running update-mdah.sh
pi@domoticz ~/domoticz/MyDomoAtHome $ ./update-mdah.sh
Stoping MyDomoAtHome service...
[ ok ] Stopping plack server: MyDomoAtHome.
Retrieving latest code...
Already up-to-date.
Checking latest libraries dependencies...
Reading package lists... Done
Building dependency tree
Reading state information... Done
cpanminus is already the newest version.
libaudio-mpd-perl is already the newest version.
libnet-upnp-perl is already the newest version.
libpoe-component-client-mpd-perl is already the newest version.
whiptail is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Note, selecting 'perl' instead of 'libtime-piece-perl'
E: Unable to locate package libdancer2-perl
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   314    0   314    0     0    329      0 --:--:-- --:--:-- --:--:--   507
100  296k  100  296k    0     0   104k      0  0:00:02  0:00:02 --:--:--  273k
--> Working on Dancer2
Fetching http://www.cpan.org/authors/id/X/XS/XSAWYERX/Dancer2-0.162000.tar.gz ... OK
Configuring Dancer2-0.162000 ... OK
==> Found dependencies: App::Cmd::Setup
--> Working on App::Cmd::Setup
Fetching http://www.cpan.org/authors/id/R/RJ/RJBS/App-Cmd-0.328.tar.gz ... OK
Configuring App-Cmd-0.328 ... OK
Building and testing App-Cmd-0.328 ... FAIL
! Installing App::Cmd::Setup failed. See /home/pi/.cpanm/work/1444068402.18977/build.log for details. Retry with --force to force install it.
! Installing the dependencies failed: Module 'App::Cmd::Setup' is not installed
! Bailing out the installation for Dancer2-0.162000.
Restarting MyDomoAtHome service...
[ ok ] Starting plack server: MyDomoAtHome.
Update path finished
resentedpoet
I changed production to development in start2.sh and this is what I get now in browser when visiting /devices
exception: "Could not create socket: Invalid argument ",
error: "Could not create socket: Invalid argument "
And this is the responses in console:
[05/Oct/2015:15:12:29 -0300] "GET /css/style.css HTTP/1.1" 200 2850 "http://192.168.86.198:3001/" "Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/45.0.2454.101 Safari/537.36"
[19245]  core @0.000803> request: GET /images/imperihome.png from 192.168.86.162 in /usr/share/perl5/Dancer/Handler.pm l. 56
[19246]  core @0.002658> request: GET /javascripts/jquery.js from 192.168.86.162 in /usr/share/perl5/Dancer/Handler.pm l. 56
[19245]  core @0.005556> [hit #3]response: 200 in /usr/share/perl5/Dancer/Handler.pm l. 179
192.168.86.162 - - [05/Oct/2015:15:12:29 -0300] "GET /images/imperihome.png HTTP/1.1" 200 36659 "http://192.168.86.198:3001/" "Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/45.0.2454.101 Safari/537.36"
[19246]  core @0.039250> [hit #1]response: 200 in /usr/share/perl5/Dancer/Handler.pm l. 179
192.168.86.162 - - [05/Oct/2015:15:12:29 -0300] "GET /javascripts/jquery.js HTTP/1.1" 200 252880 "http://192.168.86.198:3001/" "Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/45.0.2454.101 Safari/537.36"
[19245]  core @0.000785> request: GET /images/perldancer.jpg from 192.168.86.162 in /usr/share/perl5/Dancer/Handler.pm l. 56
[19246]  core @0.000736> request: GET /images/perldancer-bg.jpg from 192.168.86.162 in /usr/share/perl5/Dancer/Handler.pm l. 56
[19245]  core @0.003410> [hit #4]Trying to match 'GET /images/perldancer.jpg' against /^\/$/ (generated from '/') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.003644> [hit #2]Trying to match 'GET /images/perldancer-bg.jpg' against /^\/$/ (generated from '/') in /usr/share/perl5/Dancer/Route.pm l. 84
[19245]  core @0.004834> [hit #4]Trying to match 'GET /images/perldancer.jpg' against /^\/rooms$/ (generated from '/rooms') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.004895> [hit #2]Trying to match 'GET /images/perldancer-bg.jpg' against /^\/rooms$/ (generated from '/rooms') in /usr/share/perl5/Dancer/Route.pm l. 84
[19245]  core @0.006241> [hit #4]Trying to match 'GET /images/perldancer.jpg' against /^\/system$/ (generated from '/system') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.006192> [hit #2]Trying to match 'GET /images/perldancer-bg.jpg' against /^\/system$/ (generated from '/system') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.007517> [hit #2]Trying to match 'GET /images/perldancer-bg.jpg' against /^\/devices\/([^\/]+)\/([^\/]+)\/histo\/([^\/]+)\/([^\/]+)$/ (generated from '/devices/:deviceId/:paramKey/histo/:startdate/:enddate') in /usr/share/perl5/Dancer/Route.pm l. 84
[19245]  core @0.007566> [hit #4]Trying to match 'GET /images/perldancer.jpg' against /^\/devices\/([^\/]+)\/([^\/]+)\/histo\/([^\/]+)\/([^\/]+)$/ (generated from '/devices/:deviceId/:paramKey/histo/:startdate/:enddate') in /usr/share/perl5/Dancer/Route.pm l. 84
[19245]  core @0.008995> [hit #4]Trying to match 'GET /images/perldancer.jpg' against /^\/devices\/([^\/]+)\/action\/([^\/]+)\/?([^\/]+)?$/ (generated from '/devices/:deviceId/action/:actionName/?:actionParam?') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.008946> [hit #2]Trying to match 'GET /images/perldancer-bg.jpg' against /^\/devices\/([^\/]+)\/action\/([^\/]+)\/?([^\/]+)?$/ (generated from '/devices/:deviceId/action/:actionName/?:actionParam?') in /usr/share/perl5/Dancer/Route.pm l. 84
[19245]  core @0.010376> [hit #4]Trying to match 'GET /images/perldancer.jpg' against /^\/devices$/ (generated from '/devices') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.010327> [hit #2]Trying to match 'GET /images/perldancer-bg.jpg' against /^\/devices$/ (generated from '/devices') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.011706> [hit #2]Trying to match 'GET /images/perldancer-bg.jpg' against /^\/$/ (generated from '/') in /usr/share/perl5/Dancer/Route.pm l. 84
[19245]  core @0.011755> [hit #4]Trying to match 'GET /images/perldancer.jpg' against /^\/$/ (generated from '/') in /usr/share/perl5/Dancer/Route.pm l. 84
[19245]  core @0.013028> [hit #4]Trying to match 'GET /images/perldancer.jpg' against /^\/rooms$/ (generated from '/rooms') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.012979> [hit #2]Trying to match 'GET /images/perldancer-bg.jpg' against /^\/rooms$/ (generated from '/rooms') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.014244> [hit #2]Trying to match 'GET /images/perldancer-bg.jpg' against /^\/system$/ (generated from '/system') in /usr/share/perl5/Dancer/Route.pm l. 84
[19245]  core @0.014293> [hit #4]Trying to match 'GET /images/perldancer.jpg' against /^\/system$/ (generated from '/system') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.015498> [hit #2]Trying to match 'GET /images/perldancer-bg.jpg' against /^\/devices\/([^\/]+)\/([^\/]+)\/histo\/([^\/]+)\/([^\/]+)$/ (generated from '/devices/:deviceId/:paramKey/histo/:startdate/:enddate') in /usr/share/perl5/Dancer/Route.pm l. 84
[19245]  core @0.015546> [hit #4]Trying to match 'GET /images/perldancer.jpg' against /^\/devices\/([^\/]+)\/([^\/]+)\/histo\/([^\/]+)\/([^\/]+)$/ (generated from '/devices/:deviceId/:paramKey/histo/:startdate/:enddate') in /usr/share/perl5/Dancer/Route.pm l. 84
[19245]  core @0.016884> [hit #4]Trying to match 'GET /images/perldancer.jpg' against /^\/devices\/([^\/]+)\/action\/([^\/]+)\/?([^\/]+)?$/ (generated from '/devices/:deviceId/action/:actionName/?:actionParam?') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.016835> [hit #2]Trying to match 'GET /images/perldancer-bg.jpg' against /^\/devices\/([^\/]+)\/action\/([^\/]+)\/?([^\/]+)?$/ (generated from '/devices/:deviceId/action/:actionName/?:actionParam?') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.018163> [hit #2]Trying to match 'GET /images/perldancer-bg.jpg' against /^\/devices$/ (generated from '/devices') in /usr/share/perl5/Dancer/Route.pm l. 84
[19245]  core @0.018212> [hit #4]Trying to match 'GET /images/perldancer.jpg' against /^\/devices$/ (generated from '/devices') in /usr/share/perl5/Dancer/Route.pm l. 84
[19245]  core @0.022198> [hit #4]response: 404 in /usr/share/perl5/Dancer/Handler.pm l. 179
[19246]  core @0.022149> [hit #2]response: 404 in /usr/share/perl5/Dancer/Handler.pm l. 179
192.168.86.162 - - [05/Oct/2015:15:12:29 -0300] "GET /images/perldancer.jpg HTTP/1.1" 404 499 "http://192.168.86.198:3001/css/style.css" "Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/45.0.2454.101 Safari/537.36"
192.168.86.162 - - [05/Oct/2015:15:12:29 -0300] "GET /images/perldancer-bg.jpg HTTP/1.1" 404 499 "http://192.168.86.198:3001/css/style.css" "Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/45.0.2454.101 Safari/537.36"
[19245]  core @0.000975> request: GET /images/logo-MyDomoAtHome-w.png from 192.168.86.162 in /usr/share/perl5/Dancer/Handler.pm l. 56
[19245]  core @0.006396> [hit #5]response: 200 in /usr/share/perl5/Dancer/Handler.pm l. 179
192.168.86.162 - - [05/Oct/2015:15:12:30 -0300] "GET /images/logo-MyDomoAtHome-w.png HTTP/1.1" 200 19674 "http://192.168.86.198:3001/" "Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/45.0.2454.101 Safari/537.36"
[19246]  core @0.001129> request: GET /devices from 192.168.86.162 in /usr/share/perl5/Dancer/Handler.pm l. 56
[19246]  core @0.004509> [hit #3]Trying to match 'GET /devices' against /^\/$/ (generated from '/') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.007024> [hit #3]Trying to match 'GET /devices' against /^\/rooms$/ (generated from '/rooms') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.009361> [hit #3]Trying to match 'GET /devices' against /^\/system$/ (generated from '/system') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.011586> [hit #3]Trying to match 'GET /devices' against /^\/devices\/([^\/]+)\/([^\/]+)\/histo\/([^\/]+)\/([^\/]+)$/ (generated from '/devices/:deviceId/:paramKey/histo/:startdate/:enddate') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.013969> [hit #3]Trying to match 'GET /devices' against /^\/devices\/([^\/]+)\/action\/([^\/]+)\/?([^\/]+)?$/ (generated from '/devices/:deviceId/action/:actionName/?:actionParam?') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.016061> [hit #3]Trying to match 'GET /devices' against /^\/devices$/ (generated from '/devices') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.017992> [hit #3]  --> got 1 in /usr/share/perl5/Dancer/Route.pm l. 102
[19246] debug @0.022549> [hit #3]http://192.168.86.198:8085/json.htm?type=devices&filter=all&used=true&order=Name in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 347
[19246] debug @0.425602> [hit #3]https://api.github.com/repos/empierre/MyDomoAtHome/releases/latest in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 954
[19246] error @3.302974> [hit #3]request to GET /devices crashed: Could not create socket: Invalid argument in /usr/share/perl5/Dancer/Handler.pm l. 98
[19246]  core @3.307594> [hit #3]response: 500 in /usr/share/perl5/Dancer/Handler.pm l. 179
192.168.86.162 - - [05/Oct/2015:15:12:38 -0300] "GET /devices HTTP/1.1" 500 127 "-" "Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/45.0.2454.101 Safari/537.36"
[19246]  core @0.001203> request: GET /devices from 192.168.86.162 in /usr/share/perl5/Dancer/Handler.pm l. 56
[19246]  core @0.005866> [hit #4]Trying to match 'GET /devices' against /^\/$/ (generated from '/') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.008284> [hit #4]Trying to match 'GET /devices' against /^\/rooms$/ (generated from '/rooms') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.010624> [hit #4]Trying to match 'GET /devices' against /^\/system$/ (generated from '/system') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.012638> [hit #4]Trying to match 'GET /devices' against /^\/devices\/([^\/]+)\/([^\/]+)\/histo\/([^\/]+)\/([^\/]+)$/ (generated from '/devices/:deviceId/:paramKey/histo/:startdate/:enddate') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.015135> [hit #4]Trying to match 'GET /devices' against /^\/devices\/([^\/]+)\/action\/([^\/]+)\/?([^\/]+)?$/ (generated from '/devices/:deviceId/action/:actionName/?:actionParam?') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.017276> [hit #4]Trying to match 'GET /devices' against /^\/devices$/ (generated from '/devices') in /usr/share/perl5/Dancer/Route.pm l. 84
[19246]  core @0.019427> [hit #4]  --> got 1 in /usr/share/perl5/Dancer/Route.pm l. 102
[19246] debug @0.022927> [hit #4]http://192.168.86.198:8085/json.htm?type=devices&filter=all&used=true&order=Name in /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm l. 347
[19246] error @0.142799> [hit #4]request to GET /devices crashed: Could not create socket: Invalid argument in /usr/share/perl5/Dancer/Handler.pm l. 98
[19246]  core @0.146890> [hit #4]response: 500 in /usr/share/perl5/Dancer/Handler.pm l. 179
192.168.86.162 - - [05/Oct/2015:15:13:21 -0300] "GET /devices HTTP/1.1" 500 127 "-" "Mozilla/5.0 (Windows NT 10.0; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/45.0.2454.101 Safari/537.36"
epierre
Post by epierre »
ok something interresting. Can you send me your database to [email protected] so I can try to reproduce it locally ?
thanks,
resentedpoet
thanks,
Sure can. I am assuming you mean the Domoticz database?
epierre
Post by epierre »
yes the database. the log for app::... interrest me too
resentedpoet
epierre wrote:yes the database. the log for app::... interrest me too
Just sent the files.
There was a third, deployment.log but because it was 0kb, it would not attach/send it.
epierre
Post by epierre »
don't worry there is no link to your error on these logs, another user reported the same issue and I opened a bug to the package maintener.
thebeetleuk
Post by thebeetleuk »
I'm struggling to get this setup. completedthe install as per the wiki and the service crashed just after running.
I ran this to start:
sudo /usr/bin/plackup -E production -s Starman --workers=4 -p 3001 -a /home/pi/domoticz/MyDomoAtHome/bin/app.pl --pid /tmp/mydomoathome.pid
got this:
Error while loading /home/pi/domoticz/MyDomoAtHome/bin/app.pl: Can't locate Crypt/SSLeay.pm in @INC (@INC contains: /home/pi/domoticz/MyDomoAtHome/lib /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm line 11.
BEGIN failed--compilation aborted at /home/pi/domoticz/MyDomoAtHome/lib/Domo.pm line 11.
Compilation failed in require at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 3.
BEGIN failed--compilation aborted at /home/pi/domoticz/MyDomoAtHome/bin/app.pl line 3.
then tried to install
sudo perl -MCPAN -e 'install Crypt::SSLeay'
reboot just in case...
now I get this:
pi@domoticzpi ~ $ sudo /usr/bin/plackup -E production -s Starman --workers=4 -p 3001 -a /home/pi/domoticz/MyDomoAtHome/bin/app.pl --pid /tmp/mydomoathome.pid
Can't locate Plack/Handler/Starman.pm in @INC (@INC contains: /home/pi/domoticz/MyDomoAtHome/lib /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /usr/local/share/perl/5.14.2/Plack/Util.pm line 26.
tried an update as something isnt right!
sh ./update-mdah.sh
then I get this at the end... looks like something has failed:
! Installing App::Cmd::Setup failed. See /home/pi/.cpanm/work/1444215836.7798/build.log for details. Retry with --force to force install it.
now getting this when I start and its just hanging:
2015/10/07-12:10:39 Starman::Server (type Net::Server::PreFork) starting! pid(8406)
Setting gid to "0 0 0 1001"
Edit: hmm, now seems to be working although I cant get the /devices page to show anything yet.
Last edited by thebeetleuk on Wednesday 07 October 2015 14:16, edited 1 time in total.
My Setup: Pi, RFXtrx433, HomeEasy: 13 Dimmers & 4 Sockets, 2 motion-sensors, 3 magnetic switches, 1 OWL Electricity Sensor, 3 Oregon Temp Sensor.
epierre
Post by epierre »
thebeetleuk wrote:Hi,
Have you run the run-once.sh ?
thebeetleuk
Hi epierre, yes ran that and then the update which seems to have resolved some issues.
now mi stuck with the devices page. double checked the production.yml to make sure correct (see below) but it cant seem to communicate with domoticz. :cry:
pi@domoticzpi ~/domoticz/MyDomoAtHome $ more production.yml
log: 'error'
startup_info: 0
show_errors: 0
domo_path: "http://172.0.0.1:8080"
volumio_path: ""
appname: "MyDomoAtHome REST Gateway"
charset: "UTF-8"
