Page 11 of 12
Re: Mi-Light / LimitlessLED / Applamp
Posted: Sunday 25 November 2018 14:30
by galinette
I have the same issue, a 8 channel FUT089 and the newest Milight bulbs and controllers.
All these device communicate with a newer v7 protocol, which is AFAIK not implemented yet in Domoticz. So no luck, currently.
Posted: Thursday 29 November 2018 19:35
by lukbe
Hello, is possible use this milight bridge with domoticz without problems? Thank you
Odesláno z mého MIX 2S pomocí Tapatalk
Posted: Thursday 29 November 2018 19:50
by poudenes
lukbe wrote:Hello, is possible use this milight bridge with domoticz without problems? Thank you
I'm using it for weeks now without any problem. More then 30 bulbs now in 8 virtual remotes each 4 groups ( first 4 groups you can use other 4 you can't)
Verzonden vanaf mijn iPhone met Tapatalk Pro
Posted: Thursday 29 November 2018 20:16
by lukbe
And in domoticz is possible use same settings like for ibox2 - new hardware, milight ? Or is necessary control esp8266 via Lua scripts?
Posted: Tuesday 11 December 2018 21:14
by ledfreak3d
nope just setup the same as ibox
Posted: Saturday 15 December 2018 17:39
by j0eyv
stewdyne wrote: Friday 20 July 2018 8:01
Okay I've been busy for 3 hours but I can not get the lights to talk with Domoticz. I can control the lights via the app (milight 3.0). Hopefully someone has a clue.
I have no experience with Domoticz at all. The spent 3 hours are the first 3 hours that I spent on Domoticz. So I might overlook a basic option? ...
Hardware setup:
- 5W GUI10 RGBWW lamps
- Wifi iBox2
Domoticz
- Domoticz on Windows 10 notebook
- V4.9700
Domoticz hardware
- Accept new hardware devices = on
- Bridge type: v6 (v4/v5 tried too)
- Poort: 8899 & 5987 tried
- IPadress same as I use to configure the bridge
Domoticz devices:
- RGB & RGBWW tried
- Type: color switch
Domoticz switches
- Color switch, dimmer
Bridge setup
- Port: 8899 & 5987 tried
- Mode: STA
- Protocol: TCP-server
- Obtain an IP adress automatically: disabled
- Bridge connected with Smartlink.
LOG (part of)
2018-07-19 20:28:39.041 Status: EventSystem: reset all device statuses...
2018-07-19 20:28:41.489 Status: User: Admin initiated a switch command (1/AppLamp All/Set Level)
2018-07-19 20:28:47.749 (Milight) Color Switch (AppLamp All)
2018-07-19 20:28:50.141 Status: User: Admin initiated a switch command (1/AppLamp All/Set Level)
2018-07-19 20:28:56.379 (Milight) Color Switch (AppLamp All)
2018-07-19 20:29:08.728 Status: User: Admin initiated a switch command (7/AppLamp Group1/Set Level)
2018-07-19 20:29:11.868 (Milight) Color Switch (AppLamp Group1)
2018-07-19 20:29:12.407 Status: User: Admin initiated a switch command (1/AppLamp All/Set Level)
2018-07-19 20:29:15.539 (Milight) Color Switch (AppLamp All)
2018-07-19 20:29:17.442 Status: User: Admin initiated a switch command (7/AppLamp Group1/Set Level)
2018-07-19 20:29:20.578 (Milight) Color Switch (AppLamp Group1)
2018-07-19 20:29:21.114 Status: User: Admin initiated a switch command (2/AppLamp Group1/Set Level)
2018-07-19 20:29:24.244 (Milight) Color Switch (AppLamp Group1)
2018-07-19 20:29:30.983 Status: User: Admin initiated a switch command (11/AppLamp Bridge/Off)
2018-07-19 20:29:34.117 (Milight) Color Switch (AppLamp Bridge)
2018-07-19 20:29:36.693 Status: User: Admin initiated a switch command (6/AppLamp All/Off)
2018-07-19 20:29:39.820 (Milight) Color Switch (AppLamp All)
Same problem here! Bridge is found bt i'm unable to control the GU10 lights. The Milight app works.. How did u fix this?
Posted: Sunday 16 December 2018 0:22
by poudenes
j0eyv wrote:stewdyne wrote: Friday 20 July 2018 8:01
Hardware setup:
- Wifi iBox2
Domoticz
- V4.9700
Domoticz hardware
Domoticz devices:
- RGB & RGBWW tried
Domoticz switches
Bridge setup
- Mode: STA
LOG (part of)
Do you gave right version of protocol and bulb type in hardware?
Posted: Monday 17 December 2018 9:10
by j0eyv
V6. Tried all options RGB, RGBWW, Etc.. I only have GU10 spots, no bulbs.
Posted: Monday 17 December 2018 11:45
by poudenes
When goto hardware then Set Mode. I have this and everything is working correct here.
First allow for 5 minutes for accept new hardware
Posted: Friday 21 December 2018 22:49
by MpanosX
According to the following link
https://github.com/sidoh/esp8266_milight_hub
I believe that domoticz not support the ...
FUT089 8-zone RGB/CCT Most newer rgb + dual white bulbs and controllers
Posted: Saturday 22 December 2018 11:28
by ledfreak3d
dual white works fine for me
Posted: Saturday 22 December 2018 12:31
by poudenes
But you can pair the bulbs with the "esp8266_milight_hub" ?
My remote type is RGB-CCT in webgui. Did you have same, if so can you control the bulbs using the webgui?
If you have different remote type maybe delete everything and create a RGB-CCT remote pair bulbs.
Maybe then you can use them in Domoticz as well.. Here everything is working perfect, but i don't have the latest version of the bulbs.
Otherwise we need to ask the developer of the "Limitless/AppLamp/Mi Light with LAN/WiFi interface" if he can implement the latest bulbs support as well
Posted: Saturday 22 December 2018 12:41
by ledfreak3d
Yep sure can
But domoticz could use a upgrade for all the milight bulbs
Posted: Saturday 22 December 2018 12:53
by jvdz
All Domoticz doesn't support yet is the 8 groups type remote, but it work for all bulbs that are supported by the ESP8266 bridge or MiLight Wifi gateway as far as I know.
Jos
Posted: Sunday 23 December 2018 17:45
by janvangent2
Melotron wrote: Saturday 11 August 2018 21:37
Its partly solved.
I need to pair the led with the first RGBWW controller in the box.
Then set it as RGBWW and then I can control it from Domoticz.
The big problem are that its a single color led stripe ww FUT036.
It will be really annoying to control it manually.
I don't want to make 3 scenes for it.
Anyway to get it t work as Type: White in the mode set?
What remote should I pair it with? I've tested all the white remotes in the app.
Hi, I have the single color warm white with FUT036 controller.
But I cannot seem to control it in Domoticz.
To which controller do you link in the app? I don't know which one is the "first RGBWW".
Posted: Monday 24 December 2018 15:21
by MpanosX
Remote control Fut089 / B8 use a newer protocol.
Some new bulps and led controllers can pair only with these remotes.
Maybe the following links can help someone to understand the differences to the code...
https://github.com/sidoh/esp8266_miligh ... ormatter.h
https://github.com/sidoh/esp8266_miligh ... matter.cpp
Posted: Monday 24 December 2018 19:00
by j0eyv
Today i got my milight gu10 spots responding to on/off/dim comments from Domoticz and HA-Bridge. Since that does work i’m figuring out how i can control them with Amazon Echo Plus (Alexa). My devices are configured as Domoticz devices in HA-Bridge.
How can i send voice controlled commands via alexa to domoticz? Do i have to configure the lights as other types? Or which options do i have between Amazon Echo and Domoticz? When i change it to HUE they arent responding anymore. I guess wrong comments then..?
Posted: Wednesday 09 January 2019 18:34
by wuffer
I got the iBox2 and FUT036. I can get it installed in domoticz and turn on and off but i cant change brightness. Any suggestions on whats wrong?
Posted: Thursday 10 January 2019 10:50
by janvangent2
wuffer wrote: Wednesday 09 January 2019 18:34
That is already more than I managed to get working with the FUT036
Could you describe your steps on how to get this working?
Posted: Friday 11 January 2019 17:00
by wuffer
janvangent2 wrote: Thursday 10 January 2019 10:50
I just followed the domoticz wiki page
