Page 11 of 19
Re: Satel Integra (Security System) with ethernet module
Posted: Sunday 20 August 2017 12:07
by borewicz
Yes it is.
Configuration with dloadx is possible via ethernet (LAN), USB or Satel server.
There's also dedicated app:
VERSA CONTROL autorstwa Satel sp. z o.o.
https://itunes.apple.com/pl/app/versa-c ... ?l=pl&mt=8
Posted: Sunday 20 August 2017 17:21
by fantom
But how do connect versa to Ethernet ? Does it have rj45 or use ethm1 ?
Posted: Sunday 20 August 2017 17:27
by borewicz
fantom wrote: Sunday 20 August 2017 17:21
RJ45
Posted: Saturday 26 August 2017 22:16
by sapa
Welcome everybody, I'm a newbie so sorry if my question will be a bit silly and sorry for my english
I've integrated Integra with Domoticz but there is a few problems/questions that I can't find answer in this thread:
1. Is there a posibility to encrypt integration (an option in Dloadx )?
2. I've been looking for posibility to block arm/disarm function in Domoticz - I won't use it so it is unnesessery security risk for me.
3. Which baudrate is correct?
now problems:/
1. I've a lot errors in log:
017-08-26 21:40:23.911 Error: Satel Integra: receive error: other error
2017-08-26 21:40:23.911 Error: Satel Integra: Receive info about zone 121 failed
2017-08-26 21:40:24.212 Error: Satel Integra: receive error: other error
2017-08-26 21:40:24.212 Error: Satel Integra: Receive info about zone 122 failed
2017-08-26 21:40:24.513 Error: Satel Integra: receive error: other error
2017-08-26 21:40:24.513 Error: Satel Integra: Receive info about zone 123 failed
2017-08-26 21:40:24.814 Error: Satel Integra: receive error: other error
2017-08-26 21:40:24.814 Error: Satel Integra: Receive info about zone 124 failed
2017-08-26 21:40:25.055 Error: Satel Integra: receive error: other error
2017-08-26 21:40:25.055 Error: Satel Integra: Receive info about zone 125 failed
2017-08-26 21:40:25.376 Error: Satel Integra: receive error: other error
2017-08-26 21:40:25.376 Error: Satel Integra: Receive info about zone 126 failed
2017-08-26 21:40:25.597 Error: Satel Integra: receive error: other error
2017-08-26 21:40:25.597 Error: Satel Integra: Receive info about zone 127 failed
2017-08-26 21:40:25.858 Error: Satel Integra: receive error: other error
2017-08-26 21:40:25.858 Error: Satel Integra: Receive info about zone 128 failed
and all the time the same from 1 to 128 zone
What could make this errors?
2. After connection with Integra my Domoticz get stuck often - it looks like problem with database connection (everything is empty) or "domoticz offline" - after manualy service restart it is OK for a while (it is so often that i've to stop integration)
My system:
Domoticz 3.8153 @Raspberry Pi 2B
Integra 128WRL v. 1.16 with 4xINT-IORS Extension +INT-E
ETHM 1Plus V. 2.03
Could that problems originate from size of Integra system and Rpi performance?
Posted: Sunday 27 August 2017 13:21
by fantom
I am on holiday. I will reply after return.
Fantom
Posted: Sunday 03 September 2017 14:18
by fantom
I can't find protocol for Versa Plus.
But i finded, that ETHM1 may be connected to Versa Plus.
Fantom
Posted: Sunday 03 September 2017 14:26
by fantom
sapa wrote: Saturday 26 August 2017 22:16
4. I've a lot errors in log:
5. After connection with Integra my Domoticz get stuck often - it looks like problem with database connection (everything is empty) or "domoticz offline" - after manualy service restart it is OK for a while (it is so often that i've to stop integration)
Ad 1. I have a plan but I don't know when I will do it.
Ad 2. Maybe use Security Panel in Domoticz ? Or set rights for user in Domoticz ? OR check "protected" on device ?
Ad 3. Baudarate ?? Where is this setting ?
Ad 4. All unused output, send error on start. This is normal and i didn't find solution for this problem (not exists in ethm1 protocol). Used outputs - don't log errors.
Ad. 5 I don't understand
Fantom
Posted: Tuesday 05 September 2017 21:12
by sapa
fantom wrote: Sunday 03 September 2017 14:26
Fantom
Thanks for your answer,]
Ad 2 - I've thought about permanent disable of this function
Ad 3 - In hardware preferences - maybe you can give us a clear quide how to set all preferences as rate time refresh rate etc
ad 4 - OK
Ad 5 - for me it looks like to much data and system is crashing it is all the time when i've connected integra to domoticz. it works properly for few minutes then crash. Mayby I've some bad setting in hardware preferences ? (screenshot in attachment)
Posted: Tuesday 05 September 2017 21:37
by fantom
Ad 2. For me the best methos is set "protected" and set password in settings.
Ad 3. Lol. You have problem with cache or .. I don't know. This page is broken. Pls wiil try refresh www cache etc. Youu see to many fields on this page.
Ad 5. Pls check log after crash.
Fantom
Posted: Tuesday 05 September 2017 23:41
by sapa
Ad 3 - you've right cache problem;) but still i can't change refresh rate it always back to 1000ms
Ad 5 few lines before crash and the fatal errors (the last line - manual service restart via ssh)
2017-09-05 23:26:37.795 (Integra) General/Alert (Zone:Salon)
2017-09-05 23:26:40.039 (1-wire) Temp (Temp Sypialnia)
2017-09-05 23:26:44.040 (1-wire) Temp (Temp zewnetrzna zachod)
2017-09-05 23:26:44.241 Kodi: Restarting I/O service thread.
2017-09-05 23:26:45.799 (Integra) General/Alert (Zone:Salon)
2017-09-05 23:26:47.040 (1-wire) Temp (Temp Salon)
2017-09-05 23:26:49.801 (Integra) General/Alert (Zone:Salon)
2017-09-05 23:26:50.041 (1-wire) Temp (Temp Sypialnia)
2017-09-05 23:26:54.040 (1-wire) Temp (Temp zewnetrzna zachod)
2017-09-05 23:26:57.797 Satel Integra: Destroy instance
2017-09-05 23:26:57.798 Error: Domoticz received fatal signal 11 !...
2017-09-05 23:26:57.839 Error: /home/pawel/domoticz/domoticz() [0x1cdc48]
2017-09-05 23:26:57.839 Error: /home/pawel/domoticz/domoticz(_Z14signal_handleri+0x58) [0x1cdd00]
2017-09-05 23:26:57.840 Error: /lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer_v2+0) [0x76ac2180]
2017-09-05 23:26:57.840 Error: /home/pawel/domoticz/domoticz(_ZN5boost6detail17sp_counted_impl_pINS_8signals26detail12signal4_implIvP21CDomoticzHardwareBasePKhPKciN$
2017-09-05 23:26:57.840 Error: /home/pawel/domoticz/domoticz(_ZN5boost6detail15sp_counted_base7releaseEv+0x44) [0x1c4088]
2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN5boost6detail15sp_counted_base7releaseEv+0x44) [0x1c4088]
2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN21CDomoticzHardwareBaseD1Ev+0x68) [0x34d600]
2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN12SatelIntegraD1Ev+0x74) [0x448dd0]
2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN12SatelIntegraD0Ev+0xc) [0x448e64]
2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN10MainWorker22RemoveDomoticzHardwareEP21CDomoticzHardwareBase+0x90) [0x20ce7c]
2017-09-05 23:26:57.841 Error: /home/pawel/domoticz/domoticz(_ZN10MainWorker21AddHardwareFromParamsEiRKSsb15_eHardwareTypesS1_tS1_S1_S1_S1_iiiiiiib+0x44) [0x222004]
2017-09-05 23:26:57.842 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10CWebServer18Cmd_UpdateHardwareERNS0_14_tWebEmSessionERKNS0_7requestERN4Json5ValueE+0x5$
2017-09-05 23:26:57.845 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10CWebServer13HandleCommandERKSsRNS0_14_tWebEmSessionERKNS0_7requestERN4Json5ValueE+0x68$
2017-09-05 23:26:57.847 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10CWebServer11GetJSonPageERNS0_14_tWebEmSessionERKNS0_7requestERNS0_5replyE+0x390) [0x2c$
2017-09-05 23:26:57.850 Error: /home/pawel/domoticz/domoticz(_ZNK5boost9function3IvRN4http6server14_tWebEmSessionERKNS2_7requestERNS2_5replyEEclES4_S7_S9_+0x2c) [0x$
2017-09-05 23:26:57.852 Error: /home/pawel/domoticz/domoticz(_ZN4http6server6cWebem20CheckForPageOverrideERNS0_14_tWebEmSessionERNS0_7requestERNS0_5replyE+0x388) [0$
2017-09-05 23:26:57.854 Error: /home/pawel/domoticz/domoticz(_ZN4http6server20cWebemRequestHandler14handle_requestERKNS0_7requestERNS0_5replyE+0x3b0) [0x4dcd1c]
2017-09-05 23:26:57.857 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10connection11handle_readERKN5boost6system10error_codeEj+0x3b0) [0x4cd5b4]
2017-09-05 23:26:57.859 Error: /home/pawel/domoticz/domoticz(_ZN5boost4asio6detail23reactive_socket_recv_opINS0_17mutable_buffers_1ENS_3_bi6bind_tIvNS_4_mfi3mf2IvN4$
2017-09-05 23:26:57.861 Error: /home/pawel/domoticz/domoticz(_ZN5boost4asio6detail15task_io_service3runERNS_6system10error_codeE+0x248) [0x328454]
2017-09-05 23:26:57.863 Error: /home/pawel/domoticz/domoticz(_ZN4http6server11server_base3runEv+0x30) [0x4e7254]
2017-09-05 23:26:57.866 Error: /home/pawel/domoticz/domoticz(_ZN4http6server10CWebServer7Do_WorkEv+0x28) [0x27ff58]
2017-09-05 23:26:57.868 Error: /home/pawel/domoticz/domoticz() [0x5b6730]
2017-09-05 23:28:08.667 RxQueue: queue worker started...
Posted: Friday 08 September 2017 10:06
by borewicz
fantom wrote: Sunday 03 September 2017 14:18
Fantom
Unfortunately there's no open protocol in Versa Plus.
Additional ETHM1 will not change anything because it depends on centrala main board.
Posted: Friday 08 September 2017 10:21
by fantom
borewicz wrote: Friday 08 September 2017 10:06
Why is it not works ?
Fantom
Posted: Friday 08 September 2017 11:05
by borewicz
fantom wrote: Friday 08 September 2017 10:21
Fantom
Satel support told me that INTEGRA main board have got open protocol and VERSA doesn't (ETHM1 module got nothing to do with it)
Posted: Sunday 17 September 2017 23:04
by sapa
Fantom do you have any sugestion what can make that problems?
sapa wrote: Tuesday 05 September 2017 23:41
Posted: Monday 16 October 2017 19:52
by fantom
sapa wrote: Sunday 17 September 2017 23:04
I'm not Front-end developer. Maybe is bug inf front, but i can't find it
I'm wrote this code but .... i don't know html/js
Fantom
Posted: Friday 20 October 2017 23:37
by sapa
Thanks Fantom:)
Solution for me was... new instalation of Rasbian and Domoticz. I hadto do this because of other problems but after installing Stretch problem has gone. Now everything seems to be working ok.
Posted: Saturday 21 October 2017 10:48
by fantom
Super
Fantom
Posted: Wednesday 25 October 2017 9:52
by florekk
Hello
I have a problem with integra 128 WRL integration with domoticz.
Integra Outputs (but only 105,106, 24,25) hasn't names. Just first two switch outputs from satel has name and corect type (blinds for 105,106 - switch for 24,25).
Outputs type 41,47,14,85,86,99,101 has names and type text.
Whole inputs hasn't names.
My conf:
domoticz 3.8153
Raspi 3B
Integra 128 WRL v. 1.16
ETHM-1 v.2.03
florekk
Posted: Wednesday 25 October 2017 11:19
by fantom
florekk wrote: Wednesday 25 October 2017 9:52
Hello
florekk
viewtopic.php?f=17&t=4260&start=80#p61894
Fantom
Posted: Wednesday 25 October 2017 12:22
by florekk
It isn't my case, I mean.
I wrote about names and types, not state.
I have a problem during device instalation process. Domoticz can't read names and types.
Logs contains line like:
2017-10-25 12:15:19.464 (Satel Integra 128) General/Alert (Unknown)
2017-10-25 12:15:54.112 (Satel Integra 128) Light/Switch (Unknown)
florekk
